hi looking for some help next door neighbours car just threw light on for the dynamic steering i can connect to all ecu's. I have logged in and tried a steering angle sensor re-calibration but issue still here any advise
Wednesday,21,November,2018,19:23:35:44553
VCDS Version: 18.9.0.2 (x64)
VIN: WAUZZZ8K68A020599 License Plate: TIM NEW
Mileage: 128720km-79982mi Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 07 08 09 0E 0F 10 14 15 16 17 19 1B 1E 37 42 46 47
52 53 56 62 72 77
VIN: WAUZZZ8K68A020599 Mileage: 128720km-79982miles
1B-Active Steering -- Status: Malfunction 0010
Address 01: Engine (J623-CAPA) Labels:| 059-907-401-V1.clb
Part No SW: 8K0 907 401 F HW: 8K0 907 401
Component: 3.0TDI EDC17 H01 0002
Revision: --H01---
Coding: 0104002C180F0118
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM30LTDIA5 A02002
ROD: EV_ECM30LTDIA5_A02.rod
VCID: 2E53765F71B94C3A77-807A
4984 - Glowplug for Cylinder 1 (Q10)
P161A 00 [039] - Open Circuit
Mileage: 128728 km
Date: 2007.10.26
Time: 00:40:54
Engine speed: 957.00 /min
Normed load value: 36.1 %
Vehicle speed: 3 km/h
Coolant temperature: 5 °C
Intake air temperature: 6 °C
Voltage terminal 30: 13.300 V
Engine speed: 957.0 /min
Vehicle speed: 3.38 km/h
Vehicle voltage terminal 30: 13200 mV
Coolant temperature: 5.5 °C
Preheating system status-Bits 0-7: 00000000
Preheating system status-Bits 0-7: 10110000
Glw Plg r LVS Ps: 23.49 %
Intake air temperature: 6.2 °C
4985 - Glowplug for Cylinder 2 (Q11)
P161B 00 [039] - Open Circuit
Mileage: 128728 km
Date: 2007.10.26
Time: 00:40:54
4986 - Glowplug for Cylinder 3 (Q12)
P161C 00 [039] - Open Circuit
Mileage: 128728 km
Date: 2007.10.26
Time: 00:40:54
5418 - Glowplug for Cylinder 6 (Q15)
P161F 00 [039] - Open Circuit
Mileage: 128728 km
Date: 2007.10.26
Time: 00:40:54
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 S HW: 8K0 907 379 S
Component: ESP8 quattro H04 0210
Coding: 1B2500
VCID: 499925C3E0170B0242-801C
01486 - System Function Test Activated
Reset counter: 172
Mileage: 128728 km
Date: 2007.10.26
Time: 00:41:10
Hex Value: 0x0000
Hex Value: 0x0722
Hex Value: 0x0015
Hex Value: 0x319E
Hex Value: 0x00FF
03110 - Active Steering Control Module (J792)
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 172
Mileage: 128728 km
Date: 2007.10.26
Time: 00:41:10
Hex Value: 0x0000
Hex Value: 0x0722
Hex Value: 0x000D
Hex Value: 0x339E
Hex Value: 0x00FF
Part No SW: 8K0 907 064 C HW: 8K0 907 064 C
Component: BCM2 1.1 H70 0141
Coding: 031100
VCID: 306F6827638D5ACA65-8064
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H35 0052
Serial number: 0107000178132001
Subsystem 2 - Part No SW: 8K0 905 852 C HW: 8K0 905 852 C
Component: ELVAUDIB8 H35 0039
Serial number: 0208000000978012
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 N HW: 4E0 035 729
Component: Interfacebox H43 5170
Revision: 00000000 Serial number: 329A.087539675
Coding: 0000002
VCID: 448734F70735D66AB1-8010
Subsystem 1 - Part No: 8T0 919 609
Component: E0380 BedienteilH08 0100
Subsystem 2 - Serial number: 00000000042025
Subsystem 3 - Serial number: 0123.01.080000000100010266ÿ
Subsystem 4 - Serial number: 010266ÿ
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 N HW: 8T2 820 043 N
Component: KLIMA 3 ZONEN H05 0120
Revision: D1000000 Serial number: 0124.01.080093
Coding: 36040000
VCID: 3D714113A4DFA7A2FE-8068
00457 - Control Module for Network (J519)
Reset counter: 172
Mileage: 128728 km
Date: 2007.10.26
Time: 00:34:18
Fault Status: 01101000
Reset counter: 172
Mileage: 128728 km
Date: 2007.10.26
Time: 00:34:18
Temperature: 5.0°C
Reset counter: 212
Mileage: 128728 km
Date: 2007.10.26
Time: 00:34:18
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H21 0253
Revision: 05021001 Serial number: 00000000089577
Coding: 690040B10014A7311E01000300005F5F0F9D824800000141000000
Subsystem 1 - Part No SW: 8K2 955 119 HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 200108 H05 0060
Serial number: SWFBIE 0000442
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0002
Serial number: 10050040
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000003001080004
014 - Defective
Fault Status: 01101110
Reset counter: 172
Mileage: 128728 km
Date: 2007.10.26
Time: 00:34:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 8T2 035 110 C HW: 8T2 035 110 C
Component: MP3-Changer H42 0390
Revision: 00042001 Serial number: AUZ5ZBH4573500
VCID: 2B557F4B8AAB391250-807E
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276V7901333
Coding: 0000001
VCID: 24479477E775F66A91-8070
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 C HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0010
Revision: 11001001 Serial number: 75230802416906
Coding: 100003
VCID: 39795503B0F79B82D2-806C
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8K0 907 364 HW: 8K0 907 364
Component: DAEMPFUNGS-SG H08 0044
Revision: 00000000 Serial number: 04010801170001
Coding: 050181
VCID: 70EFA827A30D1ACA25-8024
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD12YMS1
Coding: 30363434363030303030554A3052384B3053
VCID: 3C774C17B7C5AEAAC9-8068
Serial number: 6334MSME38032B1FG
Serial number: 6344MSME3803307CA
Serial number: 6352QSME4C661865P
Serial number: 6362QSME50743B6FT
Serial number: 63732SME516E3111V
Serial number: 63832SME5016222DV
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H10 0012
Revision: -------- Serial number: 90304HAA0006U
Coding: 000016
VCID: 3E73461FA9D9BCBAE7-806A
Component: E221 - MFL H02 0003
Part No SW: 8K0 920 980 B HW: 8K0 920 980 B
Component: KOMBIINSTR. H14 0216
Revision: 00000000 Serial number: 7BY289Y18
Coding: 2F04090032002600010000
VCID: 31696D23688753C26A-8064
Part No SW: 8T0 907 468 F HW: 8T0 907 468 F
Component: GW-BEM 4CAN-M H07 0084
Revision: EB002032 Serial number: 3200E0812081AB
Coding: 000003
Shop #: WSC 00752 210 91076
VCID: 448734F7C735D66AB1-8010
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H03 0150
Serial number: 1800258E090108
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 A HW: 8K0 907 144 A
Component: DYNAMIKLENK. H05 0322
Revision: 50000003 Serial number: --------------
Coding: 0C0000
VCID: 2D51715374BF37224E-8078
000 - - - MIL ON
Fault Status: 11100000
Count: 56
Count: 1
Address 1E: Media Player 2 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 D HW: 4E0 035 785
Component: SG ext.Player H15 0830
Revision: 00000000
VCID: 2959854340572B02A2-807C
Part No SW: 4E0 910 888 E HW: 4E0 919 887 M
Component: MNS ECE H51 1050
Revision: 00000000 Serial number: 333BX087539297
VCID: 306F6827A38D5ACA65-8064
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000006787100
Coding: 011C02205001410001
VCID: 3F8D3B1BAED3B5B2EC-806A
Revision: 00002001 Serial number: 0109278008
Coding: 011B0622003904C0002001
Component: DWA-Sensor H02 0030
Component: LIN BACKUP HO H03 1301
Part No SW: 8T0 035 223 T HW: 8T0 035 223 F
Component: DSP Prem H14 0400
Revision: 00H14003 Serial number: 34871000697603
Coding: 020101
Shop #: WSC 12336 024 394758
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000006784389
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 C HW: 8K0 907 801 C
Component: EPB Audi B8 H03 0040
Revision: 00000003 Serial number: 00000000063280
VCID: 2F6D6B5B7EB345327C-807A
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 336B$087535988
Coding: 0000001
VCID: 2E53765FB9B94C3A77-807A
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000006759477
Coding: 010C02204001210001
VCID: 7F0D7B1BEE5375B2AC-802A
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0170
Revision: Serial number: 0000006789655
VCID: 7EF3861FE9597CBAA7-802A
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 C HW: 4F1 862 335
Component: BTA H10 0960
Revision: 00H10000 Serial number: 00000007558045
Coding: 0010021
End-------------------------(Elapsed Time: 03:33)--------------------------
