- Dec 30, 2015
- 66
- 26
- South Wales, UK
- C?ID=263294
Hi, posting for somebody hoping for help. He's awaiting verification.
Thanks in advance, Paul.
Tuesday,13,November,2018,20:20:21:12450
VCDS Version: 18.9.0.2 (x64)
VIN: SCBCE63W28C059369 License Plate: EUJ469
Mileage: 31840km-19784mi Repair Order: Peter
Chassis Type: 3W (6N0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 19 34 36 37 38 46 47
53 54 57 65 68 6C 71 76 77
VIN: SCBCE63W28C059369 Mileage: 31840km-19784miles
02-Auto Trans -- Status: Malfunction 1010
04-Steering Angle -- Status: Sporadic communication error 1000
11-Engine II -- Status: Malfunction 1010
31-Engine other -- Status: Malfunction 1010
15-Airbags -- Status: Cannot be reached 1100
34-Level Control -- Status: Malfunction 1010
38-Roof Electronics -- Status: Malfunction 0010
47-Sound System -- Status: Sporadic communication error 1000
53-Parking Brake -- Status: Malfunction 1010
54-Rear Spoiler -- Status: OK 0000
57-TV Tuner -- Status: Sporadic communication error 1000
68-Wiper Electr. -- Status: Malfunction 1010
6C-Back-up Cam. -- Status: Malfunction 1010
71-Battery Charger -- Status: Malfunction 1010
Address 01: Engine ( ) Labels: 07C-906-018-BWR1.clb
Part No SW: 07C 906 018 FK HW: 07C 906 018 FK
Component: BY- 6.0L -TT NC G ª1548
Revision: --H03--- Serial number: VWX3Z0H3772154
Coding: 0001175
Shop #: WSC 00083 790 00000
VCID: 73E50CD111858AD2D8-5124
14 Faults Found:
049489 - No Communications with Airbag Control Module
U0151 - 008 -
Fault Status: 01101000
Mileage: 31482 km
Temperature: 94.0°C
Temperature: 66.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.684 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 -
Mileage: 31764 km
RPM: 1904 /min
Load: 14.5 %
Speed: 80.0 km/h
Temperature: 94.0°C
Temperature: 36.0°C
Voltage: 13.589 V
049508 - No Communications with HVAC Control Module (J301)
U0164 - 008 - - Intermittent
Fault Frequency: 39
Mileage: 31764 km
RPM: 1905 /min
Load: 70.6 %
Speed: 54.0 km/h
Temperature: 93.0°C
Temperature: 33.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.462 V
049441 - No Communication with ABS Brake Control Module
U0121 - 008 - - Intermittent
Fault Frequency: 37
Mileage: 31764 km
RPM: 503 /min
Load: 24.3 %
Temperature: 90.0°C
Temperature: 46.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.462 V
049409 - No Communication with Transmission Control Module
U0101 - 008 - - Intermittent - MIL ON
Fault Status: 10101000
Fault Frequency: 32
Mileage: 31764 km
RPM: 1224 /min
Load: 25.1 %
Speed: 53.0 km/h
Temperature: 93.0°C
Temperature: 36.0°C
Voltage: 13.462 V
049412 - No Communication with Cruise Control Module
U0104 - 008 - - Intermittent
Fault Frequency: 37
Mileage: 31764 km
RPM: 1287 /min
Load: 18.0 %
Speed: 54.0 km/h
Temperature: 93.0°C
Temperature: 36.0°C
Voltage: 13.462 V
053258 - No Communications with Control Module for Access/Start Authorization
U100A - 008 - - Intermittent
Fault Frequency: 20
Mileage: 31764 km
RPM: 901 /min
Load: 19.2 %
Speed: 29.0 km/h
Temperature: 90.0°C
Temperature: 43.0°C
Voltage: 13.589 V
U0155 - 008 - - Intermittent
Fault Frequency: 20
Mileage: 31764 km
RPM: 1055 /min
Load: 16.9 %
Speed: 28.0 km/h
Temperature: 93.0°C
Temperature: 38.0°C
Voltage: 13.716 V
049478 - No Communication with Diagnostic Gateway
U0146 - 008 - - Intermittent
Fault Frequency: 14
Mileage: 31765 km
RPM: 989 /min
Load: 18.8 %
Speed: 32.0 km/h
Temperature: 90.0°C
Temperature: 42.0°C
Voltage: 13.462 V
Fault Frequency: 9
Mileage: 31765 km
RPM: 1386 /min
Load: 11.4 %
Speed: 74.0 km/h
Temperature: 90.0°C
Temperature: 43.0°C
Voltage: 13.589 V
049154 - Powertrain Databus
U0002 - 008 - No Communications - Intermittent
Fault Frequency: 21
Mileage: 31765 km
RPM: 503 /min
Load: 23.9 %
Temperature: 90.0°C
Temperature: 46.0°C
Voltage: 13.462 V
049446 - No Communications with Steering Angle Sender (G85)
U0126 - 008 - - Intermittent
Fault Frequency: 9
Mileage: 31769 km
RPM: 503 /min
Load: 24.3 %
Temperature: 90.0°C
Temperature: 46.0°C
Voltage: 13.462 V
005748 - Powertrain Data Bus
P1674 - 008 - Implausible Message from Instrument Cluster - Intermittent
Mileage: 31769 km
RPM: 1220 /min
Load: 17.2 %
Speed: 43.0 km/h
Temperature: 90.0°C
Temperature: 43.0°C
Voltage: 13.208 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Mileage: 31846 km
Temperature: 48.0°C
Temperature: 51.0°C
Voltage: 11.938 V
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 09E 927 760 P HW: GS1 911 4
Component: ZWDU3404 6L W12TT 3404
Revision: --H04--- Serial number: 0125771
Coding: 0000111
VCID: 3D71EAE967410CA2FE-5124
006246 - Powertrain Data Bus
P1866 - 000 - Missing Messages - Intermittent
Fault Frequency: 18
Mileage: 31764 km
Address 03: ABS Brakes Labels: 3W0-614-511.clb
Part No SW: 3W0 614 511 B HW: 3W0 614 511 B
Component: ESP 8.1 4WD H01 0350
Coding: 0002307
VCID: 2E53DDA5BD27E73A77-807A
8 Faults Found:
Hex Value: 0x4500
Hex Value: 0x4004
Hex Value: 0x001D
Hex Value: 0x43A9
Hex Value: 0x0001
Fault Frequency: 143
Hex Value: 0x0000
Hex Value: 0x4080
Hex Value: 0x0013
Hex Value: 0x158C
Hex Value: 0x0001
01310 - Level Control System Control Module (J197)
Hex Value: 0x39C0
Hex Value: 0x4204
Hex Value: 0x0013
Hex Value: 0x2AA8
Hex Value: 0x0001
Hex Value: 0x37C0
Hex Value: 0x4204
Hex Value: 0x0013
Hex Value: 0x85A9
Hex Value: 0x0001
Hex Value: 0x39C0
Hex Value: 0x4204
Hex Value: 0x0032
Hex Value: 0x05A7
Hex Value: 0x0001
Hex Value: 0x39C0
Hex Value: 0x4204
Hex Value: 0x0013
Hex Value: 0x44A9
Hex Value: 0x0001
Hex Value: 0x4F00
Hex Value: 0x4204
Hex Value: 0x002D
Hex Value: 0x03A9
Hex Value: 0x0001
Hex Value: 0x2CC0
Hex Value: 0x4204
Hex Value: 0x0013
Hex Value: 0x29A7
Hex Value: 0x0001
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 F HW: 3D0 909 137 F
Component: 74 Kessy 6850
Revision: 00H22070 Serial number: VWX3Z0H3772154
Coding: 0422125
VCID: 2A5BD1B581CF8B1AAB-807E
Component: ELV XXXX
7 Faults Found:
Fault Frequency: 14
Reset counter: 221
Date: 2018.05.01
Time: 15:16:44
00955 - Key 1
Reset counter: 0
Date: 2018.10.09
Time: 08:17:38
01312 - Powertrain Data Bus
014 - Defective
Fault Status: 01101110
Fault Frequency: 14
Reset counter: 6
Date: 2018.11.13
Time: 14:44:54
Reset counter: 6
Date: 2018.11.13
Time: 15:04:44
Reset counter: 6
Date: 2018.11.13
Time: 15:04:44
Reset counter: 6
Date: 2018.11.13
Time: 15:04:44
00458 - Control Module for Battery Monitoring (J367)
Reset counter: 6
Date: 2018.11.13
Time: 15:04:44
Address 06: Seat Mem. Pass Labels: None
Part No: 3W0 959 759 C
Component: CM Seat Pass. 0018
Coding: 0000002
Shop #: WSC 52310 000 1048576
VCID: 49998E392489A00242-801C
013 - Check DTC Memory
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3W0 035 007 Q
Component: ZAB COCKPIT 2215
Coding: 0401337
VCID: 3A7BE1F5766F3B9ADB-5124
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
Address 08: Auto HVAC Labels: None
Part No: 3W0 907 040 F
Component: Climatronic BY614 2014
Coding: 0000111
VCID: 3467CFCD530BCDEA01-8060
Address 09: Cent. Elect. Labels:. 3D0-937-049-V2.clb
Part No SW: 3D0 937 049 M HW: 3D0 937 049 M
Component: J519 6500
Revision: -4004--- Serial number: --------------
Coding: 40020000AB2A11000000000000000000
Address 11: Engine II Labels: 07C-906-018-BWR2.clb
Coding: 0001175
P1624 - 008 -
Mileage: 31764 km
RPM: 1959 /min
Load: 14.9 %
Speed: 83.0 km/h
Temperature: 94.0°C
Temperature: 37.0°C
Voltage: 13.589 V
Fault Frequency: 23
Mileage: 31765 km
RPM: 499 /min
Load: 23.9 %
Temperature: 90.0°C
Temperature: 44.0°C
Voltage: 13.462 V
Mileage: 31769 km
RPM: 1242 /min
Load: 16.5 %
Speed: 52.0 km/h
Temperature: 90.0°C
Temperature: 42.0°C
Voltage: 13.335 V
Address 15: Airbags
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 K
Component: J527 3601
Coding: 0000012
VCID: 479D8801329D567254-8012
Address 17: Instruments Labels: 3Wx-920-xxx-17.lbl
Part No SW: 3W0 920 841 Q HW: 3W0 920 841 Q
Component: J285 KOMBI-INST. 1824
Revision: K0H10V37
Coding: 0007702
Shop #: WSC 04025 002 1048576
VCID: 43859C1102A57A5288-8016
8 Faults Found:
Reset counter: 64
Mileage: 29382 km
Date: 2018.08.13
Time: 15:29:27
Fault Frequency: 37
Reset counter: 104
Mileage: 31764 km
Date: 2018.11.13
Time: 14:44:56
Fault Frequency: 43
Reset counter: 104
Mileage: 31764 km
Date: 2018.11.13
Time: 14:44:56
Fault Frequency: 56
Reset counter: 104
Mileage: 31764 km
Date: 2018.11.13
Time: 14:44:58
Fault Frequency: 32
Reset counter: 104
Mileage: 31764 km
Date: 2018.11.13
Time: 14:44:58
Fault Frequency: 34
Reset counter: 104
Mileage: 31764 km
Date: 2018.11.13
Time: 14:44:59
Fault Frequency: 14
Reset counter: 104
Mileage: 31764 km
Date: 2018.11.13
Time: 14:45:08
Fault Frequency: 26
Reset counter: 104
Mileage: 31765 km
Date: 2018.11.13
Time: 14:45:37
Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 3W0 920 841 Q
Component: J533 GW-K-CAN TP20 1824
Coding: DFF8FF2E9F0E4701
VCID: 70EF03DD6393B1CA25-8024
14 Faults Found:
Reset counter: 64
Mileage: 29382 km
Date: 2018.08.13
Time: 15:29:27
Fault Frequency: 37
Reset counter: 104
Mileage: 31764 km
Date: 2018.11.13
Time: 14:44:56
Fault Frequency: 43
Reset counter: 104
Mileage: 31764 km
Date: 2018.11.13
Time: 14:44:56
Fault Frequency: 56
Reset counter: 104
Mileage: 31764 km
Date: 2018.11.13
Time: 14:44:58
Fault Frequency: 32
Reset counter: 104
Mileage: 31764 km
Date: 2018.11.13
Time: 14:44:58
Fault Frequency: 34
Reset counter: 104
Mileage: 31764 km
Date: 2018.11.13
Time: 14:44:59
Fault Frequency: 14
Reset counter: 104
Mileage: 31764 km
Date: 2018.11.13
Time: 14:45:08
01342 - Engine Control Module 2 (Slave 1)
Reset counter: 104
Mileage: 31765 km
Date: 2018.11.13
Time: 14:45:36
Fault Frequency: 26
Reset counter: 104
Mileage: 31765 km
Date: 2018.11.13
Time: 14:45:37
Reset counter: 104
Mileage: 31769 km
Date: 2018.11.13
Time: 14:58:17
00908 - Control Module for Wiper Motor
Reset counter: 65
Mileage: 28636 km
Date: 2018.04.23
Time: 11:33:36
Reset counter: 65
Mileage: 28854 km
Date: 2006.01.01
Time: 00:00:05
00467 - TV Tuner (R78)
Reset counter: 65
Mileage: 28854 km
Date: 2006.01.01
Time: 00:00:05
Reset counter: 65
Mileage: 28636 km
Date: 2018.04.23
Time: 11:33:39
Address 34: Level Control Labels: None
Part No: 3W0 907 553 B
Component: LUFTFDR.-CDC- 3C3V0 7205
Coding: 0005561
VCID: 3979FEF974693082D2-806C
00456 - Control Module for Access and Start Control (J518)
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
Part No: 3W0 959 760 C
Component: CM Seat Driver 0018
Coding: 0000002
Shop #: WSC 06250 109 60892
VCID: 418996191CB968429A-8014
Address 37: Navigation Labels: None
Part No: 3W0 919 887 J
Component: NAVIGATION 2197
Coding: 0400000
VCID: 4E93BD25DDE7873A17-801A
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 F
Component: Dachmodul 0802
Coding: 0006589
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 H
Component: 0P HSG 0200
Coding: 0000040
VCID: 3561F2C95F71D4E236-4B00
Subsystem 1 - Part No: 3W8 959 701 J
Component: Tuersteuergeraet FS 1106
Subsystem 2 - Part No: 3W8 959 702 J
Component: Tuersteuergeraet BF 1106
Subsystem 3 - Part No: 3W8 959 703 D
Component: Tuersteuergeraet HL 0703
Subsystem 4 - Part No: 3W8 959 704 D
Component: Tuersteuergeraet HR 0703
Subsystem 5 - Part No: 3W0 909 610 F
Component: 14 HDSG 1809
Subsystem 6 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3W8 035 456
Component: 12K-AUDIOVERST 3000
VCID: 79F93EF934E9F08292-802C
Address 53: Parking Brake Labels: 3W0-907-801.clb
Part No SW: 3W0 907 801 E HW: 3W0 907 801 E
Component: EPB BC7H0270 HC7 0270
Coding: 0022413
VCID: 387FFBFD4863298A2D-5140
Address 54: Rear Spoiler Labels: 1C0-959-733.lbl
Part No: 1C0 959 733 H
Component: Heckspoiler 0002
VCID: 306FC3DDF013F1CA65-519A
Address 57: TV Tuner Labels: None
Part No SW: 3D0 919 148 HW: 3D0 919 148
Component: TV-Tuner 0160
Revision: R0H16000 Serial number: 91100500466902
Coding: 0000010
VCID: 67DD6881525D767274-8032
03214 - Video Signal Y+
Fault Status: 00101010
Fault Frequency: 25
03215 - Video Signal C+
Fault Frequency: 24
03228 - Video Signal Y-
Fault Frequency: 25
03229 - Video Signal C-
Fault Frequency: 24
Address 65: Tire Pressure Labels: None
Part No SW: 3W7 907 273 A HW: 3W7 907 273 A
Component: J0502 RDK 0004
Revision: 0004 004 Serial number: 00000700004639
Coding: 3501E052A5F952A5F9A7DA00A7DA00
VCID: 3E73EDE56D4717BAE7-806A
01840 - Antennas for Tire Pressure Monitoring
005 - No or Incorrect Basic Setting / Adaptation - Intermittent - MIL ON
Fault Status: 10100101
Reset counter: 65
(no units): 177.0
02214 - Tire Pressure Warning
Reset counter: 97
Mileage: 31276 km
Date: 2018.10.26
Time: 09:21:01
(no units): 84.0
Address 68: Wiper Electr. Labels: 3Wx-955-023.clb
Part No: 3W2 955 023 G
Component: Wischermodul ª9328
Shop #: WSC 00000 725 65552
VCID: 3B75E4F17E550292C0-806E
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
01308 - Control Module for Roof Electronics (J528)
00459 - Control Module for Display and Input; Front (J523)
00457 - Control Module for Network (J519)
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3W3 907 441 HW: 3W3 907 441
Component: J772__Rearview 0023
Revision: 00H14000 Serial number: PA8 J850167
Coding: 2000002
VCID: 76E335C505F79FFAFF-8022
Reset counter: 66
Mileage: 28636 km
Date: 2018.04.23
Time: 03:25:03
Term 15 Off
Reverse OFF
Count: 3
Fault Status: 01100010
Reset counter: 252
Mileage: 28634 km
Date: 2018.04.22
Time: 20:57:23
Term 15 Off
Reverse OFF
Count: 3
Fault Frequency: 12
Reset counter: 104
Mileage: 31765 km
Date: 2018.11.13
Time: 14:45:37
Reverse OFF
Count: 3
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 D
Component: Batteriemanagement 2800
VCID: 24473F8DE3EB5D6A91-8070
Address 76: Park Assist Labels: Redir Fail!
Part No: 3W0 919 283 B
Component: 0C Einparkhilfe 0404
VCID: 3C77E7ED7B5B05AAC9-8068
Address 77: Telephone Labels: None
Part No SW: 3W0 035 385 AS HW: 3W0 035 385 AS
Component: rSAP Bentley 0262
Revision: 00008000 Serial number: 30800000074351
Coding: 0031000
VCID: 0603450575178F7AEF-8052
End-------------------------(Elapsed Time: 05:03)--------------------------
Address 17: DTCs cleared
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 05: DTCs cleared
Address 06: DTCs cleared
Address 07: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 11: DTCs cleared
Address 16: DTCs cleared
Address 19: DTCs cleared
Address 34: DTCs cleared
Address 36: DTCs cleared
Address 37: DTCs cleared
Address 38: DTCs cleared
Address 46: DTCs cleared
Address 47: DTCs cleared
Address 53: DTCs cleared
Address 54: DTCs cleared
Address 57: DTCs cleared
Address 65: DTCs cleared
Address 68: DTCs cleared
Address 6C: DTCs cleared
Address 71: DTCs cleared
Address 76: DTCs cleared
Address 77: DTCs cleared
Coding: 0001175
U0151 - 008 -
Mileage: 31846 km
Temperature: 50.0°C
Temperature: 51.0°C
Voltage: 12.065 V
P1923 - 008 -
Mileage: 31846 km
Temperature: 50.0°C
Temperature: 51.0°C
Voltage: 12.065 V
Readiness: 0110 1101
Coding: 0000111
Coding: 0002307
Hex Value: 0x0000
Hex Value: 0x4380
Hex Value: 0x0013
Hex Value: 0x1594
Hex Value: 0x0001
Coding: 0422125
Component: ELV XXXX
Fault Frequency: 0
Reset counter: 222
Date: 2018.11.13
Time: 20:23:08
Coding: 0000002
Coding: 0401337
Coding: 0000111
Coding: 0001175
VCID: 73E50CD111858AD2D8-FFFE
P1624 - 008 -
Mileage: 31764 km
RPM: 1959 /min
Load: 14.9 %
Speed: 83.0 km/h
Temperature: 94.0°C
Temperature: 37.0°C
Voltage: 13.589 V
Fault Frequency: 23
Mileage: 31765 km
RPM: 499 /min
Load: 23.9 %
Temperature: 90.0°C
Temperature: 44.0°C
Voltage: 13.462 V
Mileage: 31769 km
RPM: 1242 /min
Load: 16.5 %
Speed: 52.0 km/h
Temperature: 90.0°C
Temperature: 42.0°C
Voltage: 13.335 V
Address 15: Airbags
Coding: 0000012
Revision: K0H10V37
Coding: 0007702
Reset counter: 64
Mileage: 31846 km
Date: 2018.11.13
Time: 20:22:05
Reset counter: 64
Mileage: 31846 km
Date: 2018.11.13
Time: 20:27:15
Coding: 0005561
Coding: 0000002
Coding: 0400000
No Faults Found
Coding: 0006589
Coding: 0000040
VCID: 3561F2C95F71D4E236-4B1A
Coding: 0022413
VCID: 306FC3DDF013F1CA65-517C
Coding: 0000010
Coding: 2000002
Coding: 0031000
End-------------------------(Elapsed Time: 08:31)--------------------------
OBD DTCs erased
OBD DTCs erased
OBD DTCs erased
OBD DTCs erased
OBD DTCs erased
OBD DTCs erased
