Disable headlight washers
gdallas
C?ID=95831
can anyone advise how this is done please? I cannot see whats what in centr elec 09. read somewhere online that Byte 20 may contain the answer, but cant tell whats what in there as VCDS still does not know my ECU (2015 car) that well despite having sent my maps many many months ago to support team.
Wednesday,14,November,2018,20:50:01:12530
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
VIN: WAUZZZ4G8GN095717   License Plate:
Mileage: 40773km-25335mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 3B 42 44 46 52 53 55 5F
          62 72 A9 AC C0
VIN: WAUZZZ4G8GN095717   Mileage: 40773km-25335miles
Address 01: Engine (J623-CVUA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 589 D    HW: 4G0 907 589 B
   Component: 3.0BTD EDC17  H23 0002
   Revision: 54H23---
   Coding: 0A2A4032252603030000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30BTD0114G0907589D 001002
   ROD: EV_ECM30BTD0114G0907589D.rod
   VCID: 3537DC9805C2798F7D3-8060
   Part No SW: 4G0 927 158 AK    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H19 1005
   Revision: --H19---
   VCID: 77AB16905F4E4B9FAFF-8022
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 49A79E4192E579829B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DFB848410AC52FD1B-8014
   Part No SW: 4H0 907 064 GN    HW: 4H0 907 064 GN
   Component: BCM2 2.0      H37 0572
   Coding: 01B8704E000000000000
   VCID: 7BA30AA063E66FFFCB7-802E
   Serial number: 0215000188678006
   Part No SW: 4G0 820 043 CC    HW: 4G0 820 043 CC
   Serial number: 08101500040560
   Coding: 36211178210000
   VCID: 629D57C4E4CCBE37E81-8036
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: 00001182453302
   Coding: 0105801440349FE0410140C0000018000F9DC3082F08020100000894E100150200400024030000
   VCID: 71BF288831AA15AF61B-8024
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 150715  H38 0080
   Serial number:         150819223949
   Coding: 0045F7
   Serial number: 20763505
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 13 10 2015  00000873
   Serial number: ED8880D7000000000001
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1006SWY0
   Coding: 30333130313730323737554A305234473053
   VCID: 3B23CAA023E6AFFF8B7-806E
   Serial number: 3575HRB40633JUD03OCK
   Serial number: 3585HRB40573KGI0APDP
   Serial number: 3515JRB404T3JK6259MM
   Serial number: 3525JRB40633FSTU6HIG
   Serial number: 3554VRB400S553HED8T/
   Serial number: 3564VRB400S553HED90D
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 90862OJC00068
   Coding: 000034
   VCID: 3B23CAA02366AFFF8B7-806E
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 01 09 2015  C0002893
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G8 920 986 M    HW: 4G8 920 986 M
   Component: TDieGb        H11 0106
   Revision: 07001088    Serial number: 658150915596041
   Coding: 23A70A000B412600010000
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K.rod
   VCID: 42DDB744440CDE37C81-8016
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002004092
   Coding: C0CD078118
   ASAM Dataset: EV_GatewPkoUDS 001028
   Serial number: 1931577903
   Voltage stabilizer:
   Serial number: 150725000000000004E9
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04028264747464545425363E00
   VCID: 678B46D00F6EDB1F3FF-8032
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 09101500040125
   Coding: 22
   VCID: 3D27C4B83DF2A1CFB53-8068
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720KW0DP
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3333E2800BB667BF537-8066
   Component: TSG FA        H03 0511
   Coding: 011C16014001620002080002
   VCID: 47CBA6506FAEFB1F1FF-8012
   Component: RCevo         H53 0202
   Revision: 00000002    Serial number: 0000283456
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2DCFA42CDC96F7901-806E
   Revision: 00002001    Serial number: 0382488804
   Coding: 011F062280B90000C320080400010E470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 A
   Component: Sensor, DWA  005 0002
   Component: TSG BF        H03 0511
   VCID: 46D5AB5468A4E217E49-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001619448
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D07F4F8ED92314F053-8078
   Coding: 04FE02102A630200
   VCID: 3431E19C0EB860874AD-8060
   Coding: E01E00
   Coding: E01E00
   Part No SW: 4G1 035 021 E    HW: 4G1 035 021
   Component: MU-H-LND-EU   042 0335
   Serial number: A588J0F7528209
   Coding: 017501010000000013111102000A00132F0006E7F1700100DF
   VCID: 1C61293C8628C8C762D-8048
   Subsystem 1 - Part No SW: V03 959 801 FC    HW: -----------
   Component: ECE 2017  --- 0157
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0006
   Serial number: AUZ8Z9FY802QD8
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349OJ6000EJ
   Compact Disc Database:
   Component: Gracenote  --- 1010
   Component: TSG HL        H03 0511
   Coding: 010814004001620002080002
   VCID: 49CFA06879BA0D6F09B-801C
   Component: TSG HR        H03 0511
   Part No SW: 4G0 907 159 D    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0007
   Serial number: 151002203103
   VCID: 2E05F3F4E0944A573C9-807A
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 152451062
   ROD: EV_RDCMA00100_008.rod
   VCID: 2F3BEEF0E79E435F37F-807A
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4G0 907 160 E    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0011
   Serial number: 151001200324
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
   VCID: 270B06D0CF6E1B1FFFF-8072
End----------(Elapsed Time: 01:48, VBatt start/end: 13.2V/14.1V)-----------
What do you have in Adaption channel 006? I'm thinking something like 600? If so, try 0 there. I believe that's the amount of time the headlight washers are activated for.
siLc
Tallinn, Estonia
C?ID=330192
If the car had xenon headlights, the headlight washers would be a requirement and not having them working would be a MOT fail? Can't imaging it would be different for factory LED headlights, like this car has.
South Molton, UK
Correct, from May 2018 the UK MOT rules require that if headlight washers or auto-levelling are fitted they MUST work; whether the car has halogen, LED or HID headlamps is not relevant.
gdallas
C?ID=95831
I will have a look later when im home and report back. cheers
NZDubNurd
New Zealand
C?ID=230482
You may also be able to set the delay for them coming on to a longer time - so they still function, but only after a very long pull of the screen washers???
South Molton, UK
That's what I've done on my MQB platform Skoda Octavia
[FONT=&quot]Controller 09 – Central Electronics[/FONT]
[FONT=&quot]16 - Security Access - enter 31347[/FONT]
[FONT=&quot]10 - Adaptations[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung - 10[/FONT]
[FONT=&quot]Windshield wiper-SRA Verzoegerungszeit - 0 ms default, change to 2000ms (delay before headlamp washer activates)[/FONT]
[FONT=&quot]Windshield wiper-SRA Waschzeit - 600 ms[/FONT]
[FONT=&quot]Windshield wiper-SRA Einweichpausenzeit - 2000 ms[/FONT]
[FONT=&quot]Windshield wiper-SRA Nachwaschzeit - 1100 ms[/FONT]
[FONT=&quot]Windshield wiper-SRA Pausenzeit - 0 ms[/FONT]
[FONT=&quot]Windshield wiper-SRA bei Waschwassermangel - not active [/FONT]
