Hello to all,new member here with an issue on a newly acquired vehicle that has suffered a small front end crash but has been repaired. The problems I have are hopefully listed in the VCDS autoscan that I have attached.Vehicle runs fine and only throws up the MIL after a couple of ignition cycles,but what trouble me is that the 2nd fault does not clear at all and has no date/time stamp.I have flushed complete cooling system through and re-bled as per Audi instructions and would appreciate any further help from you knowledgeable people .
Tuesday,13,November,2018,17:37:02:38628
VIN: WAUZZZ8T2EA012133 License Plate:
Mileage: 62830km-39040mi Repair Order:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 47 52 53 55 56 5F
VIN: WAUZZZ8T2EA012133 Mileage: 62830km-39040miles
55-Headlight Range -- Status: Cannot be reached 1100
Address 01: Engine (J623-CNCD) Labels:. 06L-907-115-V1.clb
Part No SW: 8T2 907 115 HW: 8T2 907 115
Component: 2.0l R4 TFSI H13 0003
Revision: --H13---
Coding: 1A1900322327010B2000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM20TFS0218T2907115 001004
ROD: EV_ECM20TFS0218T2907115.rod
VCID: 75B7E230154858EFBD3-8020
16464 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [047] - -
Mileage: 62834 km
Date: 2018.11.10
Time: 14:12:55
Coolant temperature: 84 °C
Intake air temperature: 55 °C
Voltage terminal 30: 11.933 V
Engine: operating status: ES
Engine temp. management actuator: raw value: 1194
Engine temperature management actuator: stop open: 1194
Engine temperature management actuator: after-run stop: 3948
RVC_SP: 8.98 °
RVC_AV: 80.05 °
RVCPWM: 100.000 %
15470 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [101] - -
Mileage: 62834 km
Time: 00:00:00
Coolant temperature: 67 °C
Intake air temperature: 58 °C
Voltage terminal 30: 12.050 V
Engine temp. management actuator: raw value: 1192
Engine temperature management actuator: stop open: 145
RVC_SP: 78.75 °
RVC_AV: 70.20 °
RVCPWM: 100.000 %
Readiness: 1010 0001
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CD HW: 8K0 907 379 CD
Component: ESP8 quattro H09 0050
Coding: 30154401
Shop #: WSC 06325 000 00000
VCID: 7DA7FA102DF800AFF53-8028
Part No SW: 8K0 907 064 GE HW: 8K0 907 064 FE
Component: BCM2 2.0 H12 0633
Coding: 03B04040000000000000
VCID: 79AFEE0039D03C8FD9B-802C
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Serial number: 0813000089166008
Serial number: 2313000118606014
Part No SW: 8K2 820 043 T HW: 8K2 820 043 T
Revision: D1000000 Serial number: 01020720130594
Coding: 642602C000
VCID: 3A2D310C7C56F797901-806E
03220 - Stop Valve for Coolant for Climatronic (N422)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 187
Mileage: 62834 km
Date: 2018.11.10
Time: 14:12:53
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000639432602
Coding: 260000108034AFC00081400300001D0D001D038827090201000008004400030100000024000000
VCID: 78A9EB0402DA2587A65-802C
Subsystem 1 - Part No SW: 8T2 955 119 D HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 020713 H13 0080
Serial number: SWF13070025424
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 21474630
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000002206130833
Serial number: 2B9884B6000000000001
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Serial number: 003KFDB0KHCP
Coding: 30533933363030303030554A305238543053
VCID: 48C95BC4323A9507165-801C
Serial number: 6334MSME7B352464F
Serial number: 6344MSME7C2631005
Serial number: 6352QSME72330D70C
Serial number: 6362QSME584C4C52U
Serial number: 63732SME7050004CR
Serial number: 63832SME64505166X
Revision: 00000000 Serial number: 20130702001425
Coding: 000016
VCID: 4FFB70D8D7D4423F57F-801A
Part No SW: 8T0 920 984 J HW: 8T0 920 984 J
Component: KOMBIINSTR. H35 0563
Revision: 00300000 Serial number: WVG47HK6E
Coding: 33AD010002012600010000
Shop #: WSC 06325 123 12345
VCID: 46D555FC38AE8377E49-8012
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0056
Revision: 1Y070028 Serial number: 2841Y13613811A
Coding: 80CF07FF00
VCID: 4ACD61CC2CB66717001-801E
Serial number: 8955830803
Serial number: 13176002211011200410
Reset counter: 187
Mileage: 62834 km
Date: 2018.11.10
Time: 14:12:54
Bin. Bits: 10111
Voltage: 11.90 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Part No SW: 8T0 959 793 Q HW: 8T0 959 793 F
Component: TSG FA H09 0305
Coding: 011002224001120102
VCID: 57EB88B8EF040AFF8FF-8002
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0028625771
Coding: 100000000001
Shop #: WSC 06324 000 00000
ROD: EV_RCEPSAU48X_008.rod
VCID: 34311F345EB201E74AD-8060
Revision: 00002001 Serial number: 0310607949
Coding: 011B068280B900408030003680000047
03177 - Relay for Power Outlets (J807)
Fault Status: 01101011
Reset counter: 187
Mileage: 62834 km
Date: 2018.11.10
Time: 14:12:53
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813016632703
VCID: 2D070A50BD18502F053-8078
Part No SW: 8T0 959 792 Q HW: 8T0 959 792 H
Component: TSG BF H08 0305
VCID: 56F585BCE80E33F7949-8002
Part No SW: 8K0 907 801 M HW: 8K0 907 801 J
Component: EPB-4 H01 0004
Revision: -------- Serial number: 10000000235244
ROD: EV_ParkiBrake_AU48.rod
VCID: 392F2E0079D0FC8F99B-806C
Address 55: Headlight Range
Part No SW: 4G0 035 061 L HW: 4G0 035 061
Component: Radio U DAB H60 0133
Revision: AB001007 Serial number: 109FD0D7688589
Coding: 010103010000000001
VCID: 2615F57C98EE6377C49-8072
Part No SW: 8R2 035 666 F HW: 8R2 035 666 C
Component: H-BN-EU H46 0739
Revision: -------- Serial number: 206FX0D7531608
Coding: 13010102000681ED01808B5E00000403E40000020000000000
VCID: 3C2137147662C9A782D-8068
Subsystem 1 - Part No: 8R0 060 884 BC
Component: EUR 2013/2014 1603
Component: DU7 High H42 0104
Serial number: A130FU0D2767162
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Serial number: 00000001549349
Component: CD-Database 5298
End----(Elapsed Time: 01:38, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
