Audi A5 2.0 TFSI Fault Help Please
Dadar
C?ID=350099
Hello to all,new member here with an issue on a newly acquired vehicle that has suffered a small front end crash but has been repaired. The problems I have are hopefully listed in the VCDS autoscan that I have attached.Vehicle runs fine and only throws up the MIL after a couple of ignition cycles,but what trouble me is that the 2nd fault does not clear at all and has no date/time stamp.I have flushed complete cooling system through and re-bled as per Audi instructions and would appreciate any further help from you knowledgeable people .
Tuesday,13,November,2018,17:37:02:38628
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
VIN: WAUZZZ8T2EA012133   License Plate:
Mileage: 62830km-39040mi   Repair Order:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 47 52 53 55 56 5F
VIN: WAUZZZ8T2EA012133   Mileage: 62830km-39040miles
55-Headlight Range -- Status: Cannot be reached 1100
Address 01: Engine (J623-CNCD)       Labels:. 06L-907-115-V1.clb
   Part No SW: 8T2 907 115     HW: 8T2 907 115
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 1A1900322327010B2000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM20TFS0218T2907115 001004
   ROD: EV_ECM20TFS0218T2907115.rod
   VCID: 75B7E230154858EFBD3-8020
16464 - Insufficient Engine Cooling / Coolant Flow
          P00B7 00 [047] - -
                    Mileage: 62834 km
                    Date: 2018.11.10
                    Time: 14:12:55
                    Engine speed: 0.00 /min
                    Coolant temperature: 84 °C
                    Intake air temperature: 55 °C
                    Voltage terminal 30: 11.933 V
                    Engine: operating status: ES
                    Engine temp. management actuator: raw value: 1194
                    Engine temperature management actuator: stop open: 1194
                    Engine temperature management actuator: after-run stop: 3948
                    RVC_SP: 8.98 °
                    RVC_AV: 80.05 °
                    RVCPWM: 100.000 %
15470 - Insufficient Engine Cooling / Coolant Flow
          P00B7 00 [101] - -
                    Mileage: 62834 km
                    Coolant temperature: 67 °C
                    Intake air temperature: 58 °C
                    Voltage terminal 30: 12.050 V
                    Engine temp. management actuator: raw value: 1192
                    Engine temperature management actuator: stop open: 145
                    RVC_SP: 78.75 °
                    RVC_AV: 70.20 °
                    RVCPWM: 100.000 %
Readiness: 1010 0001
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CD    HW: 8K0 907 379 CD
   Component: ESP8 quattro  H09 0050
   Coding: 30154401
   Shop #: WSC 06325 000 00000
   VCID: 7DA7FA102DF800AFF53-8028
   Part No SW: 8K0 907 064 GE    HW: 8K0 907 064 FE
   Component: BCM2 2.0      H12 0633
   Coding: 03B04040000000000000
   VCID: 79AFEE0039D03C8FD9B-802C
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0813000089166008
   Serial number: 2313000118606014
   Part No SW: 8K2 820 043 T    HW: 8K2 820 043 T
   Revision: D1000000    Serial number: 01020720130594
   Coding: 642602C000
   VCID: 3A2D310C7C56F797901-806E
03220 - Stop Valve for Coolant for Climatronic (N422)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 187
                    Mileage: 62834 km
                    Date: 2018.11.10
                    Time: 14:12:53
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000639432602
   Coding: 260000108034AFC00081400300001D0D001D038827090201000008004400030100000024000000
   VCID: 78A9EB0402DA2587A65-802C
   Subsystem 1 - Part No SW: 8T2 955 119 D    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 020713  H13 0080
   Serial number: SWF13070025424
   Coding: 00FD11
   Serial number: 21474630
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002206130833
   Serial number: 2B9884B6000000000001
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003KFDB0KHCP
   Coding: 30533933363030303030554A305238543053
   VCID: 48C95BC4323A9507165-801C
   Serial number: 6334MSME7B352464F
   Serial number: 6344MSME7C2631005
   Serial number: 6352QSME72330D70C
   Serial number: 6362QSME584C4C52U
   Serial number: 63732SME7050004CR
   Serial number: 63832SME64505166X
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20130702001425
   Coding: 000016
   VCID: 4FFB70D8D7D4423F57F-801A
   Part No SW: 8T0 920 984 J    HW: 8T0 920 984 J
   Component: KOMBIINSTR.   H35 0563
   Revision: 00300000    Serial number: WVG47HK6E
   Coding: 33AD010002012600010000
   Shop #: WSC 06325 123 12345
   VCID: 46D555FC38AE8377E49-8012
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0056
   Revision: 1Y070028    Serial number: 2841Y13613811A
   Coding: 80CF07FF00
   VCID: 4ACD61CC2CB66717001-801E
   Serial number: 8955830803
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 13176002211011200410
                    Reset counter: 187
                    Mileage: 62834 km
                    Date: 2018.11.10
                    Time: 14:12:54
                    Bin. Bits:    10111
                    Voltage: 11.90 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
   Part No SW: 8T0 959 793 Q    HW: 8T0 959 793 F
   Component: TSG FA        H09 0305
   Coding: 011002224001120102
   VCID: 57EB88B8EF040AFF8FF-8002
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0028625771
   Coding: 100000000001
   Shop #: WSC 06324 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 34311F345EB201E74AD-8060
   Revision: 00002001    Serial number: 0310607949
   Coding: 011B068280B900408030003680000047
03177 - Relay for Power Outlets (J807)
                    Reset counter: 187
                    Mileage: 62834 km
                    Date: 2018.11.10
                    Time: 14:12:53
   Revision: 00005001    Serial number: 94813016632703
   VCID: 2D070A50BD18502F053-8078
   Part No SW: 8T0 959 792 Q    HW: 8T0 959 792 H
   Component: TSG BF        H08 0305
   VCID: 56F585BCE80E33F7949-8002
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 10000000235244
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 392F2E0079D0FC8F99B-806C
Address 55: Headlight Range
   Part No SW: 4G0 035 061 L    HW: 4G0 035 061
   Component: Radio U DAB   H60 0133
   Revision: AB001007    Serial number: 109FD0D7688589
   Coding: 010103010000000001
   VCID: 2615F57C98EE6377C49-8072
   Part No SW: 8R2 035 666 F    HW: 8R2 035 666 C
   Component: H-BN-EU       H46 0739
   Revision: --------    Serial number: 206FX0D7531608
   Coding: 13010102000681ED01808B5E00000403E40000020000000000
   VCID: 3C2137147662C9A782D-8068
   Subsystem 1 - Part No: 8R0 060 884 BC
   Component: EUR 2013/2014  1603
   Component: DU7 High  H42 0104
   Serial number: A130FU0D2767162
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000001549349
   Component: CD-Database  5298
End----(Elapsed Time: 01:38, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
Mika_M
Finland
C?ID=183725
My guess is a broken thermostat. They tend to fail in these engines, about a year ago I had similar problems with same CNCD engine.
Larry Manton
C?ID=112505
Not familiar, but noted code in N422 climatronic fault, as stated not familiar with it and don't know if this is on the havac side of things.
Being crashed, did the right radiator get in? Always have
To ask. As stated recharged as per Audi instructions, again, did it get burped, happens plenty. I recommend an uplift tool to make sure system is purged. Good luck.
LARIMORE
Jef
HQ
Thank you for posting a full Auto-Scan! :thumbs:
Vehicle Identification No. WAUZZZ8T2EA012133
Model Audi A5 Coupe
Quattro 2.0
A5CO
Date of production 10.07.2013
Year 2014
Sales type 8T30A9
Engine Code CNCD
Transmission Code PJA
Provided there are no air pockets in the coolant system, I suspect the most likely issue is the thermostat. On most engines, when the thermostat is removed, you can get your fingers onto the impeller of the coolant pump. If this is the case, then with the thermostat off, make sure the impeller of the coolant pump doesn't have any wiggle or free play in it, should feel solid.
But first thing I would sort out is the fault code in the HVAC:
The N422 get power from fuse SB7, but so do several other items, so if the fuse was bad, you'd have a lot more fault codes.
  • Is the wiring from the fuse to the N422 good?
  • Ohm test the N422, what value do you get?
  • HVAC grounds the N422, wiring to the HVAC module good?
  • T17b connector at lower right A pillar (blue), any issues there?
While I have my doubts fixing the N422 electrical issue will sort out your P00B7 code, may as well sort it out first and see if you get lucky.
Gone But Not Forgotten
In addition to Jef's great suggestions............
I'd have my eyes on whether this thing has PSI in order to perform its task too & as a closed cooling system relies on PSI, so before doing anything verify this.......because that could indicate a leak without evidence of a leak, such as for example a twisted o-ring at expansion tank cap!
Dadar
C?ID=350099
Thankyou all for your replies,I will answer all in order.
Mika M your suggestion was my initial assumption based on being informed of the electronic thermostat problems with these engines,so thanks for confirming my suspicions.
Larry Manton thanks for your input as well, I did a coolant flush as a precaution and burped the system correctly,being confident of no air in the system.
Jef your suggestions have had me testing components and wiring this evening and I have come to the conclusion that the N442 coolant valve has indeed gone open circuit so I have ordered a replacement which should be with me soon,and as im sure you are aware the thermostat waterpump on these engines is basically one unit controlled by a rotary valve and according to my TPS man they are a very good seller due to faults,so I have also ordered this part as well.
And finally thanks to Jack for your suggestion and yes plenty of PSI in the system so quite confident of no leaks.
Thankyou all for your input and I will report back with my hopefully good news as soon as I can.
Cheers Paul
Dadar
C?ID=350099
Hello to all again,I thought I would update this thread with some good news.
I have replaced the faulty N442 valve and that is working correctly now and have also had the waterpump/thermostat changed for the uprated part and that has also fixed the P00B7 code.
The only fault I have now is the 01771 - Control Module for Headlight Range (J431).
As I understand this module is incorporated in the power control module in my car so I need to hunt this down and find a fix.
If I were to buy a secondhand power control module would it require coding and or component protection removal or is it plug and play?
Thanks again for your help in these matters
Paul
Jef
HQ
Does this car have a stand alone J431? A quick look at wiring shows that from August 2011, headlight electronics are wired up to the J519. Looking at a similar car... no address 55.
Remove 55-Headlight Range from the Installation List in the CAN Gateway.
Dadar
C?ID=350099
Thanks Jef have done as you suggested
Dadar
C?ID=350099
Done with pleasureJef,hope it helps others.
My car is completely fault free now thanks to this forum,Many many thanks
Paul
