BRAKING GUARD off??
veedabowlu
C?ID=56963
Trying to fix this car... 2012 Audi A7 stealership is quoting like $7500.00 new camera, new cable, new module... (everything under the hood kind of estimate)
I am getting "Braking guard off" on instrument cluster, and when i scan with my Hex+can I get these fault codes...
I do know of a leaking tire, so that explains the tire pressure fault... but the
"0784 - Function Restriction due to Implausible Message(s)
U1112 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]"
and other un explainable UDS faults cant find anything in my repair information as to how to even attack/diagnose this...
suggestions & help would be greatly appreciated...
VIN: WAU2GAFC3CN064663
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 28 36 3B 3C 42 44 46
          47 52 53 55 56 5F 62 6C 6D 72 85 8B 8E 8F 90
VIN: WAU2GAFC3CN064663   Mileage: 136507km-84821miles
Address 01: Engine (J623-CGXB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551 A    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0010
   Revision: --H07---
   Coding: 1A2A0034056600060000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551A 003011
   ROD: EV_ECM30TFS0214G0907551A_003.rod
   VCID: 2757F4DD5ED2A872B4-8072
9662 - EVAP System
          P0456 00 [096] - Very Small Leak Detected
                    Mileage: 136149 km
                    Date: 2018.10.30
                    Time: 09:05:12
                    Engine speed: 1311.00 /min
                    Normed load value: 13.3 %
                    Coolant temperature: 27 °C
                    Intake air temperature: 28 °C
                    Voltage terminal 30: 13.202 V
                    Unlearning counter according OBD: 26
                    CTR_NR_DIAG_SMALL_LEAK_NVLD: 1
                    CTR_NR_DIAG_TGT_NVLD: 149
                    CTR_NR_RESP_REP_COMC_NVLD_ENVD: 0
                    Ambient temperature: 23.25 °C
                    AMP_ENVD: 1013.5684 hPa
                    FTL_CAN: 64 l
Readiness: 0010 0001
   Part No SW: 4G0 927 158 P    HW: 0BK 927 156 R
   Component: 0BK 30TFSIUSA H08 1006
   Revision: --H08---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: 3B7F38ADB25A1C92C0-806E
   Part No SW: 4G0 907 379 G    HW: 4G0 907 379 G
   Component: ESP PREMIUM   H09 0250
   Coding: 44A70F0322E5F0C05B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004017
   VCID: 356B2E95947ECAE236-8060
0607 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Fault Frequency: 8
                    Reset counter: 50
                    Mileage: 135652 km
                    Date: 2018.10.20
                    Time: 23:14:40
                    VzRef: 5B
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 28
                    Uz: B4
          U1112 00 [009] - -
                    Reset counter: 27
                    Mileage: 136507 km
                    Date: 2018.11.07
                    Time: 11:56:28
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DF
                    Uz: B5
   Part No SW: 4H0 907 064 BR    HW: 4H0 907 064 BR
   Component: BCM2 2.0      H31 0330
   Coding: 0D8A2000000000000000
   VCID: 7AF1FDA9F5E0E59A9B-802E
   Component: J764 ELV MLB  H39 0046
   Serial number: 2311000216700011
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 5
                    Mileage: 136061 km
                    Date: 2018.10.28
                    Time: 09:26:37
   Part No SW: 4G0 820 043 L    HW: 4G0 820 043 L
   Component: KLIMA 4 ZONEN H11 0062
   Serial number: 06101100040297
   Coding: 6603207A4C
   ASAM Dataset: EV_AirCondiComfoUDS 002033
   VCID: 2855F7E153CCA70ABD-807C
0518 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Fault Frequency: 36
                    Reset counter: 67
                    Mileage: 131933 km
                    Date: 2018.08.10
                    Time: 11:51:44
                    Voltage terminal 30: 11.65 V
                    Outside air temperature: 34.0 °C
                    Engine speed: 1321 /min
   Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0100
   Revision: 11012002    Serial number: 00000001073412
   Coding: 02002091163C9FE0C1008884A0003928CF9CD208A2080125800008402000
   VCID: 6ED9C1F9B9A8B93A37-803A
   Component: WWS57X 110805  H35 0051
   Serial number:         110809225533
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11706940
   Coding: 02562B
   Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
   Component: E1 - LDS  H07 0044
   Serial number: 21 09 2011  00000774
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R0NK402
   Subsystem 5 - Part No SW: 8K0 959 772 C    HW: 8K0 959 772
   Component: SLR-B8  H05 0006
   Serial number:           0014653152
   Coding: 853000
   Subsystem 6 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA102281000000488969
   Coding: 020300
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 1A288DC5000000000001
03188 - Bulb for Side Marker Light; Front Left
                    Fault Status: 00101100
                    Reset counter: 33
                    Mileage: 135273 km
                    Date: 2018.10.14
                    Time: 21:01:00
03608 - Humidity Sensor in Fresh Air Intake Duct
                    Fault Status: 00101110
                    Fault Frequency: 37
                    Reset counter: 67
                    Mileage: 131933 km
                    Date: 2018.08.10
                    Time: 11:51:00
Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
   Part No SW: 8X0 035 110 C    HW: 8X0 035 110
   Component: CDC-MP3-Pana  H41 0490
   Revision: 00000007
   VCID: 2D5B06F5742E82224E-8078
   Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0050
   Revision: 11001001    Serial number: 55901126901706
   Coding: 280904
   ASAM Dataset: EV_EPHVA18AU57X0000 002005
   ROD: EV_EPHVA18AU57X0000_002_AU57.rod
   VCID: 3D7B36B5AC4E12A2FE-8068
   Part No SW: 4G0 907 561     HW: 4G0 907 561
   Component: ACC3          H15 0160
   Coding: 3601010201
   ASAM Dataset: EV_AdaptCruisContrAU57X 001003
   ROD: EV_AdaptCruisContrAU57X_001.rod
   VCID: 67D7B4DD9E52687274-8032
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 27
                    Mileage: 133628 km
                    Date: 2018.09.05
                    Time: 11:46:02
                    Control Module temperature: 31 °C
                    Voltage terminal 15: 13.009 V
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H31 0032
   Revision: --------    Serial number: 003D8001E6MO
   Coding: 303145313131303030324A55304C34473853
   VCID: 336F108D9A0AD4D218-8066
   Serial number: 6940000Y150001FH2C0K
   Serial number: 3575HRB405D0U20SA0PK
   Serial number: 3585HRB405V0Q4PG4GD5
   Serial number: 3515JRB405L0Q8K4K88N
   Serial number: 3525JRB40650OPMMCOVW
   Serial number: 3554VRB405H0P4N0G8P+
   Serial number: 3564VRB405H0P4N02P1L
   Revision: --------    Serial number: 90372KIU001E9
   Coding: 00003C
   VCID: 3777249D867238F224-8062
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Component: E221 - MFL  H08 0009
   Serial number: 16 09 2011  B0056880
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G8 920 982 F    HW: 4G8 920 982 F
   Component: TBenUsaAcc    H79 0375
   Revision: 26181120    Serial number: 658240911593040
   Coding: 0BCF01060F03D705020100
   ASAM Dataset: EV_RBD4K 004040
   ROD: EV_RBD4K.rod
   VCID: 3777249D8E7238F224-8062
   Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000264156
   Coding: 00C1033000
   ROD: EV_GatewUDS_AU57.rod
   VCID: 326115896510DDDA13-8066
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650617360
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0062
   Serial number: 28091100040373
   Coding: 00
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002015
   VCID: 2F671CFD7622F0327C-807A
   Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000014818392
   Coding: C0581B008F002001000001010101102030303232203232
   VCID: 387527A18B6C378A2D-806C
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA42024MTE0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D5B06F57C2E82224E-8078
   Part No SW: 4G0 907 566 J    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0030
   Revision: 00H02000    Serial number: 6PZ 010 287-08
   Coding: 0000007
   VCID: 366929994178C1FA3F-8062
   Subsystem 1 - Part No: 4G0 907 568 J
   Component: J770  SWA Slave H02 0030
   Subsystem 2 - Serial number: 6PZ 010 287-28
   Subsystem 3 - Serial number: 5F05.10.1100H020003CZ20606ÿ
   Subsystem 4 - Serial number: Z20606ÿ
   Part No SW: 4G8 959 793 D    HW: 4G8 959 793
   Component: TSG FA        H05 0212
   Coding: 011F57225E00628002000413
   Shop #: WSC 02312 785 00200
   VCID: 41834A45D8B676429A-8014
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0015168719
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0160303618
   Coding: 0126063A20FAF48580B00A80020100000000000000000000000000000000
   Component: GTO BF  H01 0070
   Serial number: 00000000000000051168
   Subsystem 3 - Part No SW: 7P5 959 591     HW: 4H0 959 591
   Component: J245 PS40.033  H07 0006
   Serial number:     WOO1361239%
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00000421854
   Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H09 0027
   Serial number: WA102898000000511377
03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
            000 -  -  - Intermittent
                    Fault Frequency: 63
                    Reset counter: 67
                    Mileage: 132028 km
                    Date: 2018.08.13
                    Time: 13:52:03
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 131
                    Mileage: 132450 km
                    Date: 2018.08.17
                    Time: 00:01:12
03128 - Switch 1 for Sunroof
                    Reset counter: 51
                    Mileage: 136153 km
                    Date: 2018.10.30
                    Time: 09:10:40
00204 - Sunroof Button (E325)
                    Reset counter: 51
                    Mileage: 136153 km
                    Date: 2018.10.30
                    Time: 09:10:40
   Revision: CJ007000    Serial number: 00000000028313
   Coding: 030000
   Shop #: WSC 56617 000 1048576
   VCID: 1D3BD635048E72A2DE-8048
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   Coding: 011F57225E00628002000402
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000150701
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A510DE94DC0951AAB-807E
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0012
   Serial number: 110927-0004-124
   Coding: 1223A633701AA400
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
   VCID: 30651F816B1CEFCA65-8064
H01 0031
   Coding: 3A0000
H01 0031
   Coding: 3A0000
572427 - Stationary Cornering Lamp Right
          C1084 13 [008] - Open Circuit
                    Reset counter: 67
                    Mileage: 131933 km
                    Date: 2018.08.09
                    Time: 18:08:12
   Component: Radio U SIRIU H51 0133
   Revision: AB001007    Serial number: 471C 0B7563277
   Coding: 020007010000000001
   VCID: 244DE3D127E4436A91-8070
   Part No SW: 4G0 035 746 E    HW: 4G0 035 746
   Component: H-BNT-NA      H48 0735
   Revision: --------    Serial number: 031J 0B7516198
   Coding: 090200040003E9EF75128B3E00000003100001000000000000
   VCID: 2953F2E540C69E02A2-807C
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB1301NPYE
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 A
   Component: E380 BDT C7  H08 0204
   Serial number: 90349KIT0006E
   Component: CD-Database  3371
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F17224000628002000002
   VCID: 448D4351C7A4636AB1-8010
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H04---    Serial number: 525 PA8J19G11B
   Coding: 1080013
   VCID: 2649F9D991D8B17A8F-8072
   Part No SW: 4G8 959 107 P    HW: 4G8 959 107 G
   Component: HDSG-Modul    H13 0039
   Revision: 12013001    Serial number: 237100211
   Coding: 0A3305C102
   ASAM Dataset: EV_HDSGAu573 001014
   ROD: EV_HDSGAu571.rod
   VCID: 42814549D5B06D5A83-8016
   Component: TSG HR        H04 0212
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H24 0036
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 65CBBED5645E7A6246-8030
   Part No SW: 4G0 907 541     HW: 4G0 907 541
   Coding: 3601010201
   ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
   ROD: EV_AdaptCruisContr2AU57X_001.rod
   Part No SW: 4G0 907 107 C    HW: 4H0 907 107
   Component: BV-SG         H29 0036
   Serial number: 000040222609117
   Coding: 038198180111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 2649F9D959D8B17A8F-8072
0080 - Video Cable for Image Processing
          C1107 02 [024] - Signal Failure
                    Fault Frequency: 145
                    Reset counter: 14
                    Mileage: 134173 km
                    Date: 2018.09.16
                    Time: 12:08:32
                    Outside air temperature: 35.5 °C
                    Voltage terminal 15: 14.0 V
                    Control Module temperature: 38.0 °C
0161 - Video Cable for Image Processing
          C1107 02 [009] - Signal Failure
                    Reset counter: 27
                    Mileage: 133628 km
                    Date: 2018.09.05
                    Time: 11:46:02
                    Outside air temperature: 36.5 °C
                    Voltage terminal 15: 13.1 V
                    Control Module temperature: 31.0 °C
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 0066E608031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 31631A856016E6C26A-8064
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
I believe the 03-ABS is upset about the faults in 55-Headlight Range, while 13-Auto Dist. Reg is upset about the faults in 8E-Image Processing.
If it were me, I'd fix the camera or camera connection first.
veedabowlu
C?ID=56963
Well, for the 55-headlight range, i replaced the cornering light for the passenger side... cleared faults... and these came up...
A little more help with camera OR camera connection... as my VCDS..." [New feature! Extended UDS fault detail is only supported by current gen." DOES NOT HELP!
And I cant find anything in my repair information...
   Revision: --H07---
Readiness: 1110 1101
   Revision: --H08---
   Coding: 000002
          U1112 00 [009] - -
interfaces]
                    Reset counter: 27
                    Mileage: 136507 km
                    Date: 2018.11.08
                    Time: 18:35:01
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DF
                    Uz: 97
00956 - Key 2
                    Reset counter: 27
                    Mileage: 136507 km
                    Date: 2018.11.08
                    Time: 18:35:44
   Coding: 6603207A4C
119.CLB
   Coding: 0045F7
559.CLB
   Coding: 02562B
   Coding: 853000
   Coding: 020300
   Revision: 00000007
   Coding: 280904
   Coding: 3601010201
          U1113 00 [009] - -
interfaces]
                    Reset counter: 27
                    Mileage: 136507 km
                    Date: 2018.11.08
                    Time: 18:35:32
                    Voltage terminal 15: 11.869 V
   Coding: 00003C
   ROD: EV_RBD4K.rod
   Coding: 00C1033000
   Coding: 00
   Coding: 0000007
   Coding: 101F00
            014 - Defective
                    Reset counter: 27
                    Mileage: 136507 km
                    Date: 2018.11.08
                    Time: 18:34:04
   Coding: 030000
H01 0031
   Coding: 3A0000
H01 0031
   Coding: 3A0000
   Coding: 1080013
   Coding: 0A3305C102
   Coding: 6A060000
   Coding: 3601010201
   ROD: EV_BC7.rod
interfaces]
                    Reset counter: 27
                    Mileage: 136507 km
                    Date: 2018.11.08
                    Time: 18:34:28
                    Outside air temperature: 30.0 °C
                    Voltage terminal 15: 11.9 V
                    Control Module temperature: 33.0 °C
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
I believe the 161/C1107 code in 8E: Image Processing would read something to the effect of: "No camera found" if you were using an interface compatible with that feature.
veedabowlu
C?ID=56963
Front bumper camera, windshield camera, or which other camera is this pointing to?
