Hello there,
I replace Central Electrical module in a Passat CC 2013 ,BCM PQ47 H++ with a new one i put the old coding into it but it seems that the Parking Light Front doesn't work.
I checked all the fuses, wiring and so on and everything it's ok.
The old module has the same coding and also the same part number as this one.
I attached here the coding of the module if anyone could help me.
Wednesday,07,November,2018,19:38:27:32554
VCDS Version: 18.9.0.1 (x64) HEX-NET CB: 0.4436.4
VIN: WVWZZZ3CZCE719988 License Plate:
Mileage: 218570km-135813mi Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 37 42 44 46 4F 52 53 55
56 61 62 72
VIN: WVWZZZ3CZCE719988 Mileage: 218570km-135813miles
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 PR HW: 03L 907 309 AE
Component: R4 2.0l TDI H27 9980
Revision: 41H27--- Serial number: 00000000000000
Coding: 00190012042401080000
Shop #: WSC 80093 222 69422
ASAM Dataset: EV_ECM20TDI01103L906018PR 003008
ROD: EV_ECM20TDI01103L906018PR.rod
VCID: 095A68C2A846680281-805C
5253 - Diesel Particle Filter; Differential Pressure Sensor
P2452 00 [039] - Elect. Malfunction
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:33
Engine speed: 0.00 /min
Coolant temperature: 68 °C
Intake air temperature: 26 °C
Voltage terminal 30: 12.280 V
Sensor for particle filter differential press: raw value: 1057 hPa
Particle filter: difference pressure: 0 hPa
Particle filter: offset for differential press.: 1 hPa
Particle filter: differential pressure: dynamic offset: 0 hPa
Outside air temperature: 12.0 °C
Particle filter: soot mass measured: 13.86 g
Particle filter: soot mass calculated: 13.88 g
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AG HW: 3AA 614 109 AG
Component: J104 C2 450M VDD3 0023
Revision: --H07--- Serial number: 00000005686084
Coding: 0002480
VCID: 72A82F2E6DD00BDAD0-8026
014 - Defective
Fault Status: 01101110
Reset counter: 211
Mileage: 218578 km
Date: 2018.11.07
Time: 04:02:18
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.25 V
Bin. Bits: 00011110
Count: 230
Hex Value: 0x0000
Reset counter: 211
Mileage: 218578 km
Date: 2018.11.07
Time: 04:02:18
Hex Value: 0x0000
Voltage: 12.25 V
Bin. Bits: 00011110
Count: 230
Hex Value: 0x0000
Part No SW: 3AA 907 044 C HW: 3AA 907 044 C
Component: Climatronic H03 0101
Revision: 00001K03
Coding: 0010004809
Shop #: WSC 00015 115 00000
VCID: 302CE5266B5C79CA66-8064
9601321 - Humidity sensor
B1281 29 [009] - Signal Implausible
Reset counter: 211
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:30
9479442 - Control Circuit for Front Right Seat Heater
B10A5 12 [009] - Short to Plus
Reset counter: 211
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:30
9479698 - Control Circuit for Front Left Seat Heater
B10A6 12 [009] - Short to Plus
Reset counter: 211
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:30
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 J HW: 3AA 937 087 J
Component: BCM PQ47 H++ 421 0465
Revision: BD421001
Coding: 0008000000000000008800809400294023570088402205206484C7200040
VCID: 41CAB0E2D8F6E04299-8014
Subsystem 1 - Part No SW: 3C1 955 119 HW: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 12 0503
Coding: 00FFD5
Reset counter: 211
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:33
Voltage: 12.20 V
Fault Status: 01101000
Reset counter: 211
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:33
Voltage: 12.20 V
02092 - Enabling Heated Seat
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 211
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:29
Voltage: 12.20 V
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 211
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:33
Voltage: 12.20 V
Reset counter: 211
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:33
Voltage: 12.20 V
Address 10: Park/Steer Assist (J446) Labels:| 3AE-919-475.clb
Part No SW: 3AE 919 475 B HW: 7N0 919 475
Component: PARKHILFE 8K H06 0016
Revision: -------- Serial number: 28261211400083
Coding: 108004
ASAM Dataset: EV_EPHVA18VW47X0000 001005
ROD: EV_EPHVA18VW47X0000.rod
VCID: 3E30CB1EA1089FBAE4-806A
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0071
Revision: 00000000 Serial number: 03051204170002
Coding: 010180
Shop #: WSC 05311 000 08193
VCID: 271E0E7A56923E72B7-8072
03263 - Functional Restriction
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 211
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:28
Error Code: 7
Bin. Bits: 00000000
01767 - Sensor for Vehicle Leveling; Left; Supply Voltage
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 211
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:28
Fault Status: 00101101
Reset counter: 251
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:28
Bin. Bits: 00000000 00010000
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__70J VW10 HI 2118
Revision: 24017000 Serial number: 003L7P8DHFS8
Coding: 0012362
Shop #: WSC 05311 000 00000
VCID: 7CB401163F944DAA8A-8028
Subsystem 1 - Serial number: 6332MTS653880842
Subsystem 2 - Serial number: 6342MTS682690912
Subsystem 3 - Serial number: 6351HTS6A3S12BKR
Subsystem 4 - Serial number: 6361HTS6MIH22BKR
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C5 953 501 BN HW: 5K0 953 569 AB
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20120424200393
Coding: 0182270000
VCID: 72A82F2EA5D00BDAD0-8026
Component: E221__MFL-TK6 H07 0022
Coding: E20000
1140736 - Steering angle sensor
B1168 07 [009] - Mechanical Failure
Reset counter: 211
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:30
UBat: 12.30 V
MC1 interner Fehlercode: 60
MC2 interner Fehlercode: 188
Part No SW: 3AA 920 870 A HW: 3AA 920 870 A
Component: KOMBI H20 0420
Coding: 160F01
Shop #: WSC 00028 028 00020
Part No SW: 7N0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H41 1623
Revision: H41 Serial number: 140412F2001632
Coding: 469006
Shop #: WSC 05311 123 08193
VCID: 3E30CB1EA9089FBAE4-806A
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 043 0400
Revision: 00043000 Serial number: VWZCZ000000000
VCID: 76A0133E01B817FAFC-8022
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7662446286
Coding: 020000
VCID: 291A084240860802A1-807C
Part No SW: 3C0 035 279 G HW: 3C0 035 279 G
Component: RNS315-EU H36 0263
Serial number: VWZAZ2M4689487
Coding: 0400040104000F0000019002
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_RNS315EUV2UDS A01004
ROD: EV_RNS315EUV2UDS.rod
VCID: 271E0E7A5E923E72B7-8072
Component: EUR_W_0038 0038
1048652 - Telephone Microphone
B1048 13 [009] - Open Circuit
Reset counter: 211
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:30
Part No SW: 1T0 959 701 AG HW: 3C0 959 793 A
Component: TUER-SG FT 002 0307
Revision: 12101005 Serial number: 0001484502
Coding: 0010B7
Shop #: WSC 05311 115 00000
ROD: EV_DCU42BroseDriveSide_VW36.rod
VCID: 7CB40116F7944DAA8A-8028
Slave Driver:
Subsystem 1 - Part No SW: 3C8 959 703 D HW: 3C8 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0501
Serial number: 00000002877655
Coding: 010090
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
Shop #: WSC 00028 028 00001
VCID: 3424E936574445EA02-8060
000 - - - MIL ON
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:28
Battery Volts: 12.2 V
DD
Temperature: 29.0°C
Count: 9
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
008 - Implausible Signal - MIL ON
Fault Status: 11101000
Reset counter: 211
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:28
DD
Temperature: 29.0°C
Count: 9
Count: 1
SteerAng n.Init
Component: KSG PQ47 ELV 043 0634
Coding: 01910A0001860E763604141530085F0F005C01
Shop #: WSC 05311 123 12345
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H41 1623
Coding: 00000008
VCID: 6FAE265ABEE226323F-803A
Subsystem 1 - Part No SW: 3C8 919 204 A HW: 3C8 919 204 A
Component: Analoguhr 005 0003
Part No SW: 1T0 959 702 AC HW: 3C0 959 792 A
Component: TUER-SG BT 002 0307
Revision: 14101005 Serial number: 0000817438
Coding: 0205B6
Shop #: WSC 05311 115 08193
ROD: EV_DCU52BrosePasseSide_VW32.rod
VCID: 79BA1802F8A6788291-802C
Slave Passenger:
Subsystem 1 - Part No SW: 3C8 959 704 D HW: 3C8 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0501
Serial number: 00000002880255
Coding: 010090
66821 - Position Sensor for Mirror Adjustment
B11FA 29 [009] - Signal Implausible
Reset counter: 211
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:30
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000160514
Coding: 0022167
VCID: 3620D33E413857FA3C-8062
03182 - Clutch Position Sensor (G476)
Fault Status: 01111000
Reset counter: 211
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:29
Voltage: 12.20 V
Count: 54
Hex Value: 0x1253
Hex Value: 0x0001
Hex Value: 0x1010
03194 - Incompatible Interface
Fault Status: 01110000
Fault Frequency: 52
Reset counter: 211
Mileage: 218577 km
Date: 2018.11.06
Time: 01:04:24
Voltage: 14.40 V
Count: 95
Hex Value: 0x1253
Hex Value: 0x0001
Hex Value: 0x1010
Fault Status: 01110101
Reset counter: 211
Mileage: 142447 km
Date: 2018.11.26
Time: 00:08:43
Voltage: 11.60 V
Count: 99
Hex Value: 0x1453
Hex Value: 0x0008
Hex Value: 0x1010
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 B HW: 6R0 907 357 A
Component: LWR-ECU 005 0030
Coding: 07A6020001000000
ASAM Dataset: EV_HeadlRegulVWLWRCC 002004
ROD: EV_HeadlRegulVWLWRCC.rod
VCID: 393AD802B826B882D1-806C
13705990 - Databus
[Fehlerwert im Signal NI2_Hoehe_VL_Roh]
Reset counter: 211
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:30
13705991 - Databus
[Fehlerwert im Signal NI2_Hoehe_HL_Roh]
Reset counter: 211
Mileage: 218578 km
Date: 2018.11.07
Time: 04:00:30
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H41 1623
Coding: 030F1859
VCID: 71AA2022A8D630C229-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900185178
End----------(Elapsed Time: 01:32, VBatt start/end: 12.2V/12.2V)-----------
