Vehicle is a 2012 Audi A8 4.2. The customer recently purchased the vehicle, and a couple small repairs were needed. One thing we noticed: the trunk would not open/close using the motor. It would pop, then you had to manually open/close the lid.
We found fault stored:
Using VCDS/MVB, we determined there was a problem with one of the hall sensors, which are part of the motor assembly. Replaced motor assembly, and this fault does not return. If the old unit is plugged back in, fault returns. This motor assembly fixed the hall sensor.
We expected a basic setting to be necessary, and a fault code is now stored needing a basic setting (see newest autoscan below). We spent hours yesterday trying this basic setting, including using a non-licensed VAS5054.
We start the basic setting and press the trunk release. As per Audi and Ross-tech, the trunk should then open itself to the complete stop, etc. FOR US, WE POP THE TRUNK, AND IT JUST SITS THERE. Every time. No matter which trunk button. We have verified the trunk latch registers closed/open correctly. Vehicle sees every button to release the trunk. Hall effect sensors are reading the position, seemingly correct.
What are we missing and what can we check? Thank you in advance!
0051 - Hall Sensors in Motor 1 for Rear Lid
B1211 12 [008] - Short to Plus
Fault Frequency: 36
Reset counter: 111
Mileage: 147698 km
Date: 2018.07.13
Time: 16:40:47
Voltage terminal 30: 14.20 V
Tuesday,06,November,2018,14:21:54:23112
VCDS Version: 18.9.0.2 HEX-NET CB: 0.4436.4
VIN: WAURVAFD4CN022709 License Plate:
Mileage: 149973km-93188mi Repair Order:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 28 34 36 3B 3C 42
46 47 48 52 53 55 56 5B 5F 62 6C 6D 6F 72 7F 81 84 85 88 8A
8B 8D 8E 8F 90
VIN: WAURVAFD4CN022709 Mileage: 149973km-93188miles
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
7F-Inform. Electr. II -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
Address 01: Engine (------CDRA) Labels:| 079-907-560-CFS.clb
Part No SW: 4H0 907 560 C HW: 4H0 907 560
Component: 4.2l V8/4V H07 0005
Revision: N5H07---
Coding: 0106000A290F0268
Shop #: WSC 49783 000 1048576
ASAM Dataset: EV_ECM42FSI0114H0907560C 001006
ROD: EV_ECM42FSI0114H0907560C.rod
VCID: AA184CCFCDA5E11A2B-80FE
Readiness: 0000 0001
Part No SW: 4H1 927 158 BR HW: 0BK 927 156 AF
Component: 0BK 42 FSIUSA H16 1001
Revision: --H16---
Coding: 000002
ROD: EV_TCMALX51011.rod
VCID: 814ACB631053C2425A-80D4
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 E HW: 4H0 907 379 E
Component: ESP PREMIUM H10 0352
Coding: 44E6F20022674F00E200
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ESPPremi 005013
ROD: EV_ESPPremi_005_AU64.rod
VCID: B42452B71F61A7EA81-80E0
Part No SW: 4H0 907 064 DD HW: 4H0 907 064 BD
Component: BCM2 2.0 H31 0510
Coding: 0D872006000000000000
Shop #: WSC 49782 000 1048576
VCID: EE9080DF39CDCD3AB7-80BA
Component: J764 ELV MLB H39 0046
Serial number: 2311000253123015
Part No SW: 4H0 959 760 H HW: 4H0 959 760 H
Component: MEM-BFS H09 0163
Revision: AA000000 Serial number: 00000034386362
Coding: C018B60084002201040001010101112909313229283232
Shop #: WSC 44670 001 1048576
VCID: B83C66870B09438AAD-80EC
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 H HW: 4H0 820 043 H
Component: Klima 4 Zonen H20 0072
Coding: 480122FECC
Shop #: WSC 02313 785 00200
ROD: EV_AirCondiFront_001_AU64.rod
VCID: A502BFF3A4BBCE6206-80F0
0137 - Motor for Right Side Window Defrost Flap
B10D8 22 [009] - Signal Amplitude Too High
Reset counter: 106
Mileage: 149960 km
Date: 2018.11.05
Time: 12:37:56
0233 - Button or Switch in Operating Unit
B10C7 07 [009] - Mechanical Failure
Fault Frequency: 7
Reset counter: 106
Mileage: 149960 km
Date: 2018.11.05
Time: 12:37:56
0386 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
Reset counter: 144
Mileage: 149962 km
Date: 2018.11.06
Time: 10:24:48
Part No SW: 4H0 907 063 BD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0100
Revision: 15012002 Serial number: 00000001153965
Coding: 02002091163C9FE1CB008804A0003908009CD30882000121800008402000
VCID: EB9689CB0ADF381290-80BE
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 111105 H35 0040
Serial number: 111115025354
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10169018
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 E HW: 4H0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 28 11 2011 00001032
Component: USHL4.2 H30 0030
Serial number: 0000002274555R0ZD902
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA102472000000628887
Coding: 020300
Component: AQ_Hum_Sensor H02 0002
Serial number: 9F380CD5000000000001
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 E HW: 4H0 035 108
Component: DVDCAlpine H42 0190
Revision: AA001001
Coding: 020000
VCID: A208A4EFBD95395A63-80F6
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Revision: 11001001 Serial number: 55901133301533
Coding: 280902
ROD: EV_EPHVA18AU57X0000_002_AU64.rod
VCID: BB36798B323F689240-80EE
Part No SW: 4H0 907 561 A HW: 4H0 907 561
Component: ACC3 H17 0160
Coding: 3601020201
ASAM Dataset: EV_AdaptCruisContrAU64X 001012
ROD: EV_AdaptCruisContrAU64X_001.rod
VCID: A91AB3C3C8A3EA0222-80FC
Part No SW: 4H0 959 655 D HW: 4H0 959 655 D
Component: Airbag10.43 H41 0041
Revision: -------- Serial number: 003JS0017WGK
Coding: 303143303230303030354A55304C34483053
VCID: B73E65BB0E174CF2A4-80E2
Subsystem 1 - Part No SW: 4H0 959 339 A HW: 4H0 959 339 A
Component: BF-Gewichtss. H03 0040
Serial number: 5850000R11B1102DHR
Serial number: 3575HRB40650TGJE61MP
Serial number: 3585HRB40690TGJECPKF
Serial number: 3515JRB405D0UFPUEHPY
Serial number: 3525JRB405D0UFPUJPK0
Serial number: 3554VRB404R0Q4PIC988
Serial number: 3564VRB404V0Q4PI4GTX
Revision: -------- Serial number: 90815KKO0001A
Coding: 0000BC
VCID: B73E65BB06174CF2A4-80E2
Subsystem 1 - Part No SW: 4H0 951 528 L HW: 4H0 951 528 L
Component: E221 - MFL H09 0009
Serial number: 03 09 2011 33127093
Part No SW: 4H0 920 880 E HW: 4H0 920 880 E
Component: TBenUSAACCNV- H71 0416
Revision: 32081056 Serial number: 658281111592001
Coding: 0B4608015F00D705020000
ASAM Dataset: EV_RBD4K 004045
ROD: EV_RBD4K.rod
VCID: AC144AD7C751FF2AD9-80F8
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 G HW: 4H0 919 204 G
Component: Analoguhr D4 H05 0224
Serial number: 1111125000435
Part No SW: 4H0 907 468 G HW: 4H0 907 468 C
Component: J533--Gateway H08 0214
Revision: -------- Serial number: 00000000322987
Coding: 00C1034A00
ROD: EV_GatewUDS_AU57.rod
VCID: B5226FB3141BBEE2B6-80E0
Subsystem 1 - Part No SW: 4H0 915 181 HW: 4H0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650991909
U140B 00 [008] - -
[Powermanagement active]
Reset counter: 144
Mileage: 149962 km
Date: 2018.11.06
Time: 10:20:07
Voltage terminal 30: 11.1 V
Voltage terminal 15: 11.2 V
Control Module temperature: 35 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 1
Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb
Part No SW: 4H0 919 158 E HW: 4H0 919 158 E
Component: Klima Fond H16 0071
Coding: 0600000000
ROD: EV_AirCondiHeck.rod
VCID: B22854AFE575A9DA93-80E6
Part No SW: 4H0 907 553 C HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0096
Coding: 008002
Shop #: WSC 12345 057 1234567
ROD: EV_AirSuspe_VW51.rod
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000036113029
Coding: C018BF8085853201070001010101112131313333203333
VCID: B5226FB31C1BBEE2B6-80E0
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 HW: 4H0 907 637
Component: SARA 6D H02 0015
Revision: -------- Serial number: EJ1BPA31015NSC0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: EC948AD707D13F2A99-80B8
Part No SW: 4H0 907 566 A HW: 4G0 907 566
Component: J769 SWA MasterH02 0030
Revision: 00H02000 Serial number: 6PZ 010 287-07
VCID: AE1040DF394D8D3AF7-80FA
Subsystem 1 - Part No: 4H0 907 568 A
Component: J770 SWA Slave H02 0030
Subsystem 2 - Serial number: 6PZ 010 287-27
Subsystem 3 - Serial number: 5F02.12.1100H020003CX20303ÿ
Subsystem 4 - Serial number: X20303ÿ
Part No SW: 4H0 959 793 G HW: 4H0 959 793 G
Component: TSG FA H06 0261
Revision: -------- Serial number: 0000122627607
Coding: 011F1F005E0062C202003017
VCID: BD327793242B66A27E-80E8
Revision: 00002001 Serial number: 0164461617
Coding: 0106023A00FA759FB0B0C780020301000000000000000000000000000000
Subsystem 1 - Part No SW: 4H0 959 719 HW: 4H0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000058843
Subsystem 3 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J245 007C H06 0005
Serial number: 147500016276
Coding: 020200
Subsystem 4 - Part No SW: 4H0 947 135 BR HW: 4H0 947 135 BR
Component: Dachelektroni H11 0080
Serial number: A2011000000000512178
Coding: 070000
Subsystem 5 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J394 0014 H06 0005
Serial number: 147500016663
Coding: 020200
Subsystem 6 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J392 006A H06 0005
Serial number: 147500016279
Coding: 020200
Subsystem 7 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J867 00E0 H06 0005
Serial number: 147500016686
Coding: 020200
Subsystem 8 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0719
Serial number: 84187474
03622 - Control Module 2 for Roof Shade
Fault Status: 01100101
Reset counter: 104
Mileage: 149960 km
Date: 2018.11.05
Time: 12:37:58
Part No SW: 4H0 035 465 A HW: 4H0 035 465 A
Component: BO G3 D4 H07 0150
Revision: 05S00000 Serial number: 0016908
VCID: A404A2F7A781376A11-80F0
Subsystem 1 - Part No SW: 4H0 035 466 HW: 4H0 035 466
Component: BO D4 SLAVE H51 0180
Serial number: 01409110006777
Address 48: Seat, Rear, DS (J876) Labels: None
Part No SW: 4H0 959 860 A HW: 4H0 959 860 A
Component: MEM-FS-Fond H06 0155
Revision: AA000000 Serial number: 00000018793438
Coding: C01892808500300D0B00392038193A2039203B3B202020
VCID: B22854AFED75A9DA93-80E6
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H06 0261
Revision: -------- Serial number: 0000122627251
Coding: 011F1F005E0062C202003007
VCID: BC347A973F316FAA49-80E8
02111 - Motor for Window Regulator
Fault Status: 00100101
Reset counter: 146
Mileage: 149960 km
Date: 2018.11.05
Time: 17:24:53
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000200560
ROD: EV_ParkiBrake_VW51.rod
Address 55: Headlight Range (J431) Labels:| 4H4-907-357-V1.clb
Part No SW: 4H4 907 357 A HW: 4H4 907 357 A
Component: ....AFS13.... H01 0012
Serial number: 111202-0004-062
Coding: 12116F33701AA400
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU21.rod
VCID: B02C5EA7EB799BCAE5-80E4
H02 0008
Coding: 1C0000
H02 0008
Coding: 1C0000
Part No SW: 4H0 035 082 B HW: 4H0 035 082
Component: Radio U SIRIU H53 0076
Revision: AB001007 Serial number: 155K70B7516589
Coding: 020007010003000001
VCID: A00CAEE7B3992B4A75-80F4
Address 5B: Seat,Rear,PS (J877) Labels: None
Component: MEM-BFS-Fond H06 0155
Revision: AA000000 Serial number: 00000018285118
Coding: C01896808500300D0F00392038193A2039203B3B3B2020
Part No SW: 4H0 035 746 D HW: 4H0 035 746
Component: H-BNT-NA H48 0423
Revision: -------- Serial number: 035L%0B7506539
Coding: 020200000001F9EF7D568B1E00000003140001000000000000
Shop #: WSC 22803 444 183826
VCID: A91AB3C3C0A3EA0222-80FC
Subsystem 1 - Part No: 8R0 060 884 AD
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 4H0 919 604 F HW: 4H0 919 604 F
Component: DU8 D4 SV NB H47 0021
Serial number: AUZ8ZDB93000KSU
Subsystem 3 - Part No SW: 4H1 919 600 H HW: 4H1 919 600
Component: E380 BDT D4 H09 0065
Serial number: 00000000061898
Subsystem 4 - Part No: 8R0 060 961 B
Component: CD-Database 3371
Reset counter: 144
Mileage: 149960 km
Date: 2018.11.06
Time: 10:35:32
Bin. Bits: 00000100 00000000
Bin. Bits: 00000000 00000000
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H06 0262
Revision: -------- Serial number: 0000122673384
Coding: 010F1F00420062C202003007
Part No SW: 4H0 907 441 A HW: 4H0 907 441
Revision: --H04--- Serial number: 525 PA8J17D0C4
Coding: 1080003
Shop #: WSC 02391 785 00200
VCID: A600B8FF11BDC57A0F-80F2
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 R HW: 4H0 959 107 M
Component: HDSG-Modul H11 0039
Revision: 10011001 Serial number: 328100027
Coding: 0210044100
ROD: EV_DeckLidContrUnit.rod
VCID: BD3277932C2B66A27E-80E8
0004 - No Basic Setting
B2010 00 [137] - -
[Steuergerät nicht kalibriert]
Reset counter: 104
Mileage: 149960 km
Date: 2018.11.05
Time: 12:39:11
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000054976
Coding: 400000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: E386E1EBEA0F705228-80B6
Component: TSG HR H06 0262
Revision: -------- Serial number: 0000122673387
Address 7F: Inform. Electr. II (J829) Labels: None
Part No SW: 4H0 035 774 E HW: 4H0 035 774
Component: H-BN-NA H48 0424
Revision: -------- Serial number: 108J-0B7502682
Coding: 02020000000100400140000400001300E00000000000000000
VCID: AB1649CBCA5FF812D0-80FE
Subsystem 1 - Part No SW: 4H0 919 607 HW: 4H0 919 607
Component: DU10 RSE H41 0021
Serial number: AUZ8ZDB1200L5WV
Subsystem 2 - Part No SW: 4H4 919 607 HW: 4H4 919 607
Serial number: AUZ8ZDB27004ZY9
Subsystem 3 - Part No SW: 4H0 919 709 C HW: 4H0 919 709 C
Component: E499 BDT 2 H07 0019
Serial number: 90238KKU0001U
Subsystem 5 - Part No: 8R0 060 884 AD
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H08 0083
Revision: 0L0D5013 Serial number: SN111022 0339
ROD: EV_GSM2x3Mono.rod
VCID: AB1649CBC25FF812D0-80FE
Address 84: Night Vision (J853) Labels:| 4H0-907-547.clb
Part No SW: 4H0 907 547 E HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0028
Serial number: 0K84AE40055982
Coding: 1201
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
VCID: B12A5BA3E07392C2EA-80E4
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H08 0007
Serial number: 00000000001131300325
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Coding: E9060000
ROD: EV_OnBoardCamerDPC.rod
VCID: E582FFF3E43B0E62C6-80B0
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00003854160401
Coding: 764FF2
ROD: EV_IVBDriveSideFrnt.rod
VCID: AF2E5DDBF6478432FC-80FA
Address 8A: Multicont. Seat Rear,DS (J875) Labels:* None
Part No SW: 4H0 907 182 G HW: 4H0 907 182 G
Component: IVB H08 0042
Serial number: 00003835181002
Coding: 304F00
ASAM Dataset: EV_IVBDriveSideRear 001003
VCID: AE1040DFF14D8D3AF7-80FA
Part No SW: 4H0 907 541 A HW: 4H0 907 541
Coding: 3601020201
ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
ROD: EV_AdaptCruisContr2AU64X_001.rod
VCID: A71EB5FBDEB7DC7234-80F2
Address 8D: Multicont. Seat Rear,PS (J874) Labels:* None
Serial number: 00003834031102
Coding: 304F00
ASAM Dataset: EV_IVBPasseSideRear 001003
Part No SW: 4G0 907 107 D HW: 4H0 907 107
Component: BV-SG H30 0038
Serial number: 005000052211117
Coding: 02A19A000111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
Coding: 0066F609031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End----------(Elapsed Time: 04:07, VBatt start/end: 12.4V/12.2V)-----------
