Audi A8 Trunk basic setting issues
Chad@Eurotec
C?ID=100444
Vehicle is a 2012 Audi A8 4.2. The customer recently purchased the vehicle, and a couple small repairs were needed. One thing we noticed: the trunk would not open/close using the motor. It would pop, then you had to manually open/close the lid.
We found fault stored:
0051 - Hall Sensors in Motor 1 for Rear Lid
          B1211 12 [008] - Short to Plus
                    Fault Frequency: 36
                    Reset counter: 111
                    Mileage: 147698 km
                    Date: 2018.07.13
                    Time: 16:40:47
                    Voltage terminal 30: 14.20 V
Using VCDS/MVB, we determined there was a problem with one of the hall sensors, which are part of the motor assembly. Replaced motor assembly, and this fault does not return. If the old unit is plugged back in, fault returns. This motor assembly fixed the hall sensor.
We expected a basic setting to be necessary, and a fault code is now stored needing a basic setting (see newest autoscan below). We spent hours yesterday trying this basic setting, including using a non-licensed VAS5054.
We start the basic setting and press the trunk release. As per Audi and Ross-tech, the trunk should then open itself to the complete stop, etc. FOR US, WE POP THE TRUNK, AND IT JUST SITS THERE. Every time. No matter which trunk button. We have verified the trunk latch registers closed/open correctly. Vehicle sees every button to release the trunk. Hall effect sensors are reading the position, seemingly correct.
What are we missing and what can we check? Thank you in advance!
Tuesday,06,November,2018,14:21:54:23112
VCDS Version: 18.9.0.2  HEX-NET CB: 0.4436.4
VIN: WAURVAFD4CN022709   License Plate:
Mileage: 149973km-93188mi   Repair Order:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 28 34 36 3B 3C 42
          46 47 48 52 53 55 56 5B 5F 62 6C 6D 6F 72 7F 81 84 85 88 8A
          8B 8D 8E 8F 90
VIN: WAURVAFD4CN022709   Mileage: 149973km-93188miles
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
7F-Inform. Electr. II -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
Address 01: Engine (------CDRA)       Labels:| 079-907-560-CFS.clb
   Part No SW: 4H0 907 560 C    HW: 4H0 907 560
   Component: 4.2l V8/4V    H07 0005
   Revision: N5H07---
   Coding: 0106000A290F0268
   Shop #: WSC 49783 000 1048576
   ASAM Dataset: EV_ECM42FSI0114H0907560C 001006
   ROD: EV_ECM42FSI0114H0907560C.rod
   VCID: AA184CCFCDA5E11A2B-80FE
Readiness: 0000 0001
   Part No SW: 4H1 927 158 BR    HW: 0BK 927 156 AF
   Component: 0BK 42 FSIUSA H16 1001
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMALX51011 002018
   ROD: EV_TCMALX51011.rod
   VCID: 814ACB631053C2425A-80D4
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 E    HW: 4H0 907 379 E
   Component: ESP PREMIUM   H10 0352
   Coding: 44E6F20022674F00E200
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ESPPremi 005013
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: B42452B71F61A7EA81-80E0
   Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 BD
   Component: BCM2 2.0      H31 0510
   Coding: 0D872006000000000000
   Shop #: WSC 49782 000 1048576
   VCID: EE9080DF39CDCD3AB7-80BA
   Component: J764 ELV MLB  H39 0046
   Serial number: 2311000253123015
   Part No SW: 4H0 959 760 H    HW: 4H0 959 760 H
   Component: MEM-BFS       H09 0163
   Revision: AA000000    Serial number: 00000034386362
   Coding: C018B60084002201040001010101112909313229283232
   Shop #: WSC 44670 001 1048576
   VCID: B83C66870B09438AAD-80EC
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 H    HW: 4H0 820 043 H
   Component: Klima 4 Zonen H20 0072
   Coding: 480122FECC
   Shop #: WSC 02313 785 00200
   ASAM Dataset: EV_AirCondiFront 001050
   ROD: EV_AirCondiFront_001_AU64.rod
   VCID: A502BFF3A4BBCE6206-80F0
0137 - Motor for  Right Side Window Defrost Flap
          B10D8 22 [009] - Signal Amplitude Too High
                    Reset counter: 106
                    Mileage: 149960 km
                    Date: 2018.11.05
                    Time: 12:37:56
0233 - Button or Switch in Operating Unit
          B10C7 07 [009] - Mechanical Failure
                    Reset counter: 106
                    Mileage: 149960 km
                    Date: 2018.11.05
                    Time: 12:37:56
0386 - Functional Limitation due to Energy Management
          B10CD 00 [008] -  -
                    Reset counter: 144
                    Mileage: 149962 km
                    Date: 2018.11.06
                    Time: 10:24:48
   Part No SW: 4H0 907 063 BD    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0100
   Revision: 15012002    Serial number: 00000001153965
   Coding: 02002091163C9FE1CB008804A0003908009CD30882000121800008402000
   VCID: EB9689CB0ADF381290-80BE
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 111105  H35 0040
   Serial number:         111115025354
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10169018
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531 E    HW: 4H0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 28 11 2011  00001032
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R0ZD902
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA102472000000628887
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 9F380CD5000000000001
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 E    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0190
   Revision: AA001001
   Coding: 020000
   VCID: A208A4EFBD95395A63-80F6
   Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0043
   Revision: 11001001    Serial number: 55901133301533
   Coding: 280902
   ASAM Dataset: EV_EPHVA18AU57X0000 002005
   ROD: EV_EPHVA18AU57X0000_002_AU64.rod
   VCID: BB36798B323F689240-80EE
   Part No SW: 4H0 907 561 A    HW: 4H0 907 561
   Component: ACC3          H17 0160
   Coding: 3601020201
   ASAM Dataset: EV_AdaptCruisContrAU64X 001012
   ROD: EV_AdaptCruisContrAU64X_001.rod
   VCID: A91AB3C3C8A3EA0222-80FC
   Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
   Component: Airbag10.43   H41 0041
   Revision: --------    Serial number: 003JS0017WGK
   Coding: 303143303230303030354A55304C34483053
   VCID: B73E65BB0E174CF2A4-80E2
   Subsystem 1 - Part No SW: 4H0 959 339 A    HW: 4H0 959 339 A
   Component: BF-Gewichtss.  H03 0040
   Serial number: 5850000R11B1102DHR
   Serial number: 3575HRB40650TGJE61MP
   Serial number: 3585HRB40690TGJECPKF
   Serial number: 3515JRB405D0UFPUEHPY
   Serial number: 3525JRB405D0UFPUJPK0
   Serial number: 3554VRB404R0Q4PIC988
   Serial number: 3564VRB404V0Q4PI4GTX
   Revision: --------    Serial number: 90815KKO0001A
   Coding: 0000BC
   VCID: B73E65BB06174CF2A4-80E2
   Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
   Component: E221 - MFL  H09 0009
   Serial number: 03 09 2011  33127093
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4H0 920 880 E    HW: 4H0 920 880 E
   Component: TBenUSAACCNV- H71 0416
   Revision: 32081056    Serial number: 658281111592001
   Coding: 0B4608015F00D705020000
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K.rod
   VCID: AC144AD7C751FF2AD9-80F8
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
   Component: Analoguhr D4  H05 0224
   Serial number: 1111125000435
   Part No SW: 4H0 907 468 G    HW: 4H0 907 468 C
   Component: J533--Gateway H08 0214
   Revision: --------    Serial number: 00000000322987
   Coding: 00C1034A00
   ROD: EV_GatewUDS_AU57.rod
   VCID: B5226FB3141BBEE2B6-80E0
   Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650991909
          U140B 00 [008] - -
          [Powermanagement active]
                    Reset counter: 144
                    Mileage: 149962 km
                    Date: 2018.11.06
                    Time: 10:20:07
                    Voltage terminal 30: 11.1 V
                    Voltage terminal 15: 11.2 V
                    Control Module temperature: 35 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 1
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 E    HW: 4H0 919 158 E
   Component: Klima Fond    H16 0071
   Coding: 0600000000
   ASAM Dataset: EV_AirCondiHeck 001039
   ROD: EV_AirCondiHeck.rod
   VCID: B22854AFE575A9DA93-80E6
   Part No SW: 4H0 907 553 C    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H17 0096
   Coding: 008002
   Shop #: WSC 12345 057 1234567
   ASAM Dataset: EV_AirSuspe 003022
   ROD: EV_AirSuspe_VW51.rod
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000036113029
   Coding: C018BF8085853201070001010101112131313333203333
   VCID: B5226FB31C1BBEE2B6-80E0
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637     HW: 4H0 907 637
   Component: SARA 6D       H02 0015
   Revision: --------    Serial number: EJ1BPA31015NSC0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: EC948AD707D13F2A99-80B8
   Part No SW: 4H0 907 566 A    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0030
   Revision: 00H02000    Serial number: 6PZ 010 287-07
   Coding: 0000002
   VCID: AE1040DF394D8D3AF7-80FA
   Subsystem 1 - Part No: 4H0 907 568 A
   Component: J770  SWA Slave H02 0030
   Subsystem 2 - Serial number: 6PZ 010 287-27
   Subsystem 3 - Serial number: 5F02.12.1100H020003CX20303ÿ
   Subsystem 4 - Serial number: X20303ÿ
   Part No SW: 4H0 959 793 G    HW: 4H0 959 793 G
   Component: TSG FA        H06 0261
   Revision: --------    Serial number: 0000122627607
   Coding: 011F1F005E0062C202003017
   VCID: BD327793242B66A27E-80E8
   Revision: 00002001    Serial number: 0164461617
   Coding: 0106023A00FA759FB0B0C780020301000000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0070
   Serial number: 00000000000000058843
   Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J245  007C  H06 0005
   Serial number: 147500016276
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 BR    HW: 4H0 947 135 BR
   Component: Dachelektroni  H11 0080
   Serial number: A2011000000000512178
   Coding: 070000
   Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J394  0014  H06 0005
   Serial number: 147500016663
   Coding: 020200
   Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J392  006A  H06 0005
   Serial number: 147500016279
   Coding: 020200
   Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J867  00E0  H06 0005
   Serial number: 147500016686
   Coding: 020200
   Subsystem 8 - Part No SW: 3AA 962 243     HW: 3AA 962 243
   Component: GEB.F.Heckoef  H12 0719
   Serial number: 84187474
03622 - Control Module 2 for Roof Shade
                    Fault Status: 01100101
                    Reset counter: 104
                    Mileage: 149960 km
                    Date: 2018.11.05
                    Time: 12:37:58
   Part No SW: 4H0 035 465 A    HW: 4H0 035 465 A
   Component: BO G3 D4      H07 0150
   Revision: 05S00000    Serial number: 0016908
   VCID: A404A2F7A781376A11-80F0
   Subsystem 1 - Part No SW: 4H0 035 466     HW: 4H0 035 466
   Component: BO D4 SLAVE  H51 0180
   Serial number: 01409110006777
Address 48: Seat, Rear, DS (J876)       Labels: None
   Part No SW: 4H0 959 860 A    HW: 4H0 959 860 A
   Component: MEM-FS-Fond   H06 0155
   Revision: AA000000    Serial number: 00000018793438
   Coding: C01892808500300D0B00392038193A2039203B3B202020
   VCID: B22854AFED75A9DA93-80E6
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H06 0261
   Revision: --------    Serial number: 0000122627251
   Coding: 011F1F005E0062C202003007
   VCID: BC347A973F316FAA49-80E8
02111 - Motor for Window Regulator
                    Fault Status: 00100101
                    Reset counter: 146
                    Mileage: 149960 km
                    Date: 2018.11.05
                    Time: 17:24:53
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000200560
   ROD: EV_ParkiBrake_VW51.rod
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0012
   Serial number: 111202-0004-062
   Coding: 12116F33701AA400
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
   VCID: B02C5EA7EB799BCAE5-80E4
H02 0008
   Coding: 1C0000
H02 0008
   Coding: 1C0000
   Part No SW: 4H0 035 082 B    HW: 4H0 035 082
   Component: Radio U SIRIU H53 0076
   Revision: AB001007    Serial number: 155K70B7516589
   Coding: 020007010003000001
   VCID: A00CAEE7B3992B4A75-80F4
Address 5B: Seat,Rear,PS (J877)       Labels: None
   Component: MEM-BFS-Fond  H06 0155
   Revision: AA000000    Serial number: 00000018285118
   Coding: C01896808500300D0F00392038193A2039203B3B3B2020
   Part No SW: 4H0 035 746 D    HW: 4H0 035 746
   Component: H-BNT-NA      H48 0423
   Revision: --------    Serial number: 035L%0B7506539
   Coding: 020200000001F9EF7D568B1E00000003140001000000000000
   Shop #: WSC 22803 444 183826
   VCID: A91AB3C3C0A3EA0222-80FC
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 4H0 919 604 F    HW: 4H0 919 604 F
   Component: DU8 D4 SV NB  H47 0021
   Serial number: AUZ8ZDB93000KSU
   Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000061898
   Component: CD-Database  3371
            000 -  -  - Intermittent
                    Reset counter: 144
                    Mileage: 149960 km
                    Date: 2018.11.06
                    Time: 10:35:32
                    Bin. Bits: 00000100 00000000
                    Bin. Bits: 00000000 00000000
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H06 0262
   Revision: --------    Serial number: 0000122673384
   Coding: 010F1F00420062C202003007
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4H0 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H04---    Serial number: 525 PA8J17D0C4
   Coding: 1080003
   Shop #: WSC 02391 785 00200
   VCID: A600B8FF11BDC57A0F-80F2
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 R    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0039
   Revision: 10011001    Serial number: 328100027
   Coding: 0210044100
   ASAM Dataset: EV_DeckLidContrUnit 001025
   ROD: EV_DeckLidContrUnit.rod
   VCID: BD3277932C2B66A27E-80E8
0004 - No Basic Setting
          B2010 00 [137] -  -
          [Steuergerät nicht kalibriert]
                    Reset counter: 104
                    Mileage: 149960 km
                    Date: 2018.11.05
                    Time: 12:39:11
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000054976
   Coding: 400000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: E386E1EBEA0F705228-80B6
   Component: TSG HR        H06 0262
   Revision: --------    Serial number: 0000122673387
Address 7F: Inform. Electr. II (J829)       Labels: None
   Part No SW: 4H0 035 774 E    HW: 4H0 035 774
   Component: H-BN-NA       H48 0424
   Revision: --------    Serial number: 108J-0B7502682
   Coding: 02020000000100400140000400001300E00000000000000000
   VCID: AB1649CBCA5FF812D0-80FE
   Subsystem 1 - Part No SW: 4H0 919 607     HW: 4H0 919 607
   Component: DU10 RSE  H41 0021
   Serial number: AUZ8ZDB1200L5WV
   Subsystem 2 - Part No SW: 4H4 919 607     HW: 4H4 919 607
   Serial number: AUZ8ZDB27004ZY9
   Subsystem 3 - Part No SW: 4H0 919 709 C    HW: 4H0 919 709 C
   Component: E499 BDT 2  H07 0019
   Serial number: 90238KKU0001U
   Subsystem 5 - Part No: 8R0 060 884 AD
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H08 0083
   Revision: 0L0D5013    Serial number: SN111022  0339
   ROD: EV_GSM2x3Mono.rod
   VCID: AB1649CBC25FF812D0-80FE
Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
   Part No SW: 4H0 907 547 E    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H09 0028
   Serial number: 0K84AE40055982
   Coding: 1201
   ASAM Dataset: EV_NightVisioGen1 001002
   ROD: EV_NightVisioGen1.rod
   VCID: B12A5BA3E07392C2EA-80E4
   Night vision system camera:
   Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
   Component: NV-CAM-Gen1  H08 0007
   Serial number: 00000000001131300325
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Coding: E9060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: E582FFF3E43B0E62C6-80B0
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00003854160401
   Coding: 764FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: AF2E5DDBF6478432FC-80FA
Address 8A: Multicont. Seat Rear,DS (J875)       Labels:* None
   Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
   Component: IVB           H08 0042
   Serial number: 00003835181002
   Coding: 304F00
   ASAM Dataset: EV_IVBDriveSideRear 001003
   VCID: AE1040DFF14D8D3AF7-80FA
   Part No SW: 4H0 907 541 A    HW: 4H0 907 541
   Coding: 3601020201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
   ROD: EV_AdaptCruisContr2AU64X_001.rod
   VCID: A71EB5FBDEB7DC7234-80F2
Address 8D: Multicont. Seat Rear,PS (J874)       Labels:* None
   Serial number: 00003834031102
   Coding: 304F00
   ASAM Dataset: EV_IVBPasseSideRear 001003
   Part No SW: 4G0 907 107 D    HW: 4H0 907 107
   Component: BV-SG         H30 0038
   Serial number: 005000052211117
   Coding: 02A19A000111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 0066F609031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 04:07, VBatt start/end: 12.4V/12.2V)-----------
Jef
HQ
Thank you for including a full Auto-Scan! :thumbs:
Vehicle Identification No. WAURVAFD4CN022709
Model Audi A8L qu. 4.2
A8Q
Date of production 22.12.2011
Year 2012
Sales type 4H85AA
Engine Code CDRA
Transmission Code NXW
B2010 00 [137] - -
Steuergerät nicht kalibriert = Control unit does not calibrate... I guess we kind of know that already.
If you manually lift the rear lid, does it stay in position? Can you set the open height? Maybe open it 2/3rd the way, then press and hold the button.
There looks to be Output Testing:
  • [*IDE02024-ENG167462*] Open rear lid
  • [*IDE02025-ENG167462*] Close rear lid
  • [*IDE02029-ENG167462*] Open rear lid incrementally
  • [*IDE02030-ENG167462*] Close rear lid incrementally
Have you given those a try to see if there is any operation of the rear lid?
Rear Lid relearn
Prerequisites:
  • Rear Lid closed
  • Transport mode NOT active
  • No rear lid obstructions or damage to the vehicle
  • Park assist functions correctly, no errors (If equipped)
  • DTC B2010 - No Basic Setting stored
  • Battery voltage at least 12.0V
  • Vehicle is on a flat level surface
[Select]
[6D-Trunk Elect.]
[Basic Settings - 04]
Select Adapt flap opening angle from the drop-down menu.
[Go!]
The rear lid Basic Settings will now begin
If the the rear lid begins to open let it continue.
If the read lid does NOT begin to open, operate the switch on the Driver's door -or- the switch on the outside of the lid.
"Unknown" may be shown on-screen during the procedure.
When the rear lid has stopped opening, close the rear lid using Driver's door switch -or- the E406 switch on the inside lid trim.
Finished Correctly should be displayed after the procedure completes.
[Stop]
[Done, Go Back]
Check for fault codes, clear if needed.
Check for proper operation
Re-check for faults
Chad@Eurotec
C?ID=100444
Hey Jeff,
Thank you for the input!
If the rear lid is manually opened, it will stay in position. I tried manually setting the open height, but it has no effect, as pressing the open button will not move the lid at all. It will pop the latch using all 3 options, but never lifts the lid.
None of the output tests have any function. The operation is refused if the trunk is closed. If the trunk is popped, the message says "not running."
I did find that transport mode was active in the coding for 6D. I changed this, but the basic setting still will not run. Still no movement from the lid.
Also, yesterday, we did hook 12V directly to the motor portion itself and were able to move the lid, so the motor is good. Also, checked earlier on, but both related fuses are good as well.
mark07eur
DE, USA
C?ID=420545
Hey Jeff,
Hello, I am having the exact same issue with my D4 A8 as you are describing with the same fault code. I know this thread is a few years old. Am curious if you found a resolution?
Thanks in advance
Chad@Eurotec
C?ID=100444
Unfortunately, no. We were going to try and new trunk lid control module, but the customer never had us proceed. If you try one and it works, please post your results here!
mark07eur
DE, USA
C?ID=420545
Thank you Chad@Eurotec for pointing me in the right direction! Replaced the ECM for the trunk lid and it is opening and closing as it should. And it looks like the Hall sensor fault has cleared. Now just need to put my trunk back together :)
cheers
