Retrofit MFSW to 2010 Mk6 Golf (UK)
lucid
C?ID=39412
I have an early 2010 RHD Mk6 Golf 1.6TDI S (105PS) 5 speed manual UK spec. It already has the Highline Computer operated by the wiper stalk. Presently it does not have a MFSW and has the midline steering control module 1K0-953-549-CQ with a Type 2 Slip ring, SW 0111, no Steering Angle Sensor and no info re LIN according to Ross tech Wiki..
Initially I am trying to determine the most suitable Highline steering control module to get for the vehicle (before getting into the correct coding). The new Steering wheel I have to fit is from a 2012 Mk6 Golf GTD it is the 3 spoke round (not flat bottom). I think the part number is 3C8 419 091 BE E74 or 3C8 959 537D according to the stickers. (see attached pics for these and airbag below).
I have been looking at the 1K0-953-549-CD as this doesn't have a steering angle sensor or the 1K0-953-549-CH which does have the steering angle sensor. Do I need one with or without the sensor?? Both of these are similar part numbers to my midline version. Or would I need a newer one that matches the 2012 new wheel? Is it important what LIN version it supports re the wheel as I presently haven't the specs on the new wheel.
Both of these (1K0-953-549-CD/CH) have support for LIN versions 1.3 & 2.0. Again I am not sure which of these I would need for the new MFSW. I would want the wheel to interface with the MDI media unit (connected to a RCD310 EU Radio and USB SSD for Music). Originally the car was fitted with the VW badged Bury bluetooth hands free tel. unit which was stripped out and replaced with the full Bury equivalent Bury CC9068. This presently interfaces with the MDI. I wonder whether it will work with the wheel buttons?
I have had a full auto scan done here below and any help to begin with here would be greatly appreciated:
 VCDS Version: 18.9.0.2
VIN: WVWZZZ1KZAW2*****
Mileage: 54040km-33578mi
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56
VIN: WVWZZZ1KZAW2*****   Mileage: 54040km-33578miles
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 B    HW: 03L 906 023 A
   Component: 1,6l R4 CR td H23 9971
   Revision: --H23---    Serial number: 00000000000000
   Coding: 00114014030500080000
   ASAM Dataset: EV_ECM16TDI02103L906023B 003011
   ROD: EV_ECM16TDI02103L906023PA.rod
   VCID: 254A63F224ADCF6286-8070
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Revision: 00H30001
   Coding: 133B200D09290003C81104E890210080300000
   VCID: 78F47A86CB9F828AED-802C
   Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000000002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6DDA5BD2BCDD37220E-8038
   Part No SW: 1K0 937 086 D    HW: 1K0 937 086 D
   Component: BCM PQ35  M+  103 0575
   Revision: 00103 AG
   Coding: 48180A3E9025F19044080080100081E443010088524D8160648000200000
   VCID: 316287A2686593C26A-8064
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 09011  21  0512
   Coding: 009795
   Subsystem 2 - Part No: 1K8 951 171
   Subsystem 3 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H10 9003
   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Component: AirbagVW10    037 0606
   Serial number: 003FKRA2JEAY
   Coding: 00003133
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3B7EA58AB2296992C0-806E
   Serial number: 3572MSME7C0A234DZZZ1
   Serial number: 3582MSME3212524EZZZR
   Serial number: 3512QSME10064635ZZZG
   Serial number: 3522QSME0E0A4616ZZZX
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000004
   VCID: 030E1D6A4259D152C8-8056
   Part No SW: 5K0 920 970 N    HW: 5K0 920 970 N
   Component: KOMBI         H03 0305
   Coding: 770B00
   VCID: 3972BF82B8155B82D2-806C
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 120110F1000526
   Coding: E9801F06000212000003
   Shop #: WSC 00246 210 64224
   VCID: 69D22FC240352B0262-803C
   Component: IMMO          H03 0305
   VCID: 6AD050CE8D33201A6B-803E
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667763649
   VCID: 264864FE51ABC47A8F-8072
   Component: Tuer-SG         009 2114
   Coding: 0000564
   VCID: 316287A2A86593C26A-8064
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 69     3001
   Revision: 00H17000
   Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
   Component: Tuer-SG         009 2140
   Coding: 0000564
   VCID: 346C8EB65777A6EA01-8060
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: RCD310 EU     H11 5032
   Revision: -----01S    Serial number: VWZ4Z2K1102548
   Coding: 0500040004
   VCID: 65CA23F26C2D0F6246-8030
End---------------------(Elapsed Time: 02:22, udsna)-----------------------
iichel
Netherlands, eastern part
C?ID=284912
I'd get the 1K0-953-549-CD since it's similar to your current setup, except the LIN functionality.
lucid
C?ID=39412
Thanks for the advice.
Just been reading around most of the day, I came across this post in this thread https://forums.ross-tech.com/showth...2010-gti-to-2007&p=50082&viewfull=1#post50082
Hi Gregg,
..if you were installing a LIN 1.3/Mk5 steering wheel. That would be the easier way to go and MFA/MFSW controls using the DDP protocol would be compatible with the factory protocols in the comfort system, radio and instrument cluster.
Since you want to put a LIN 2.0/Mk6 wheel on the vehicle the direct replacement path won't work. You need a Highline unit that supports a Steering Angle Sensor and the proper LIN Version .. [/B]
I realise it's slightly different as his original midline had a sensor so is replacing with a CH version, but can I thus assume my steering wheel from a 2012 Mk6 is thus a LIN 2.0 version?
Just might make it easier to find a suitable control unit as most of the CD's seem to be Chinese clones.
Thus a 1K0-953-549-CE might work okay? Or perhaps the 1K0-953-549-CF though I am unsure of how this affects it:
#2: Manual Transmission only, does NOT support Ignition Key Lock. Mine is manual but what does the ignition key lock do, that is not supported in the CF version?
m87a
Bosnia and Herzegovina
C?ID=156900
ignition key lock stops you from removing key if dsg handle is not left at P!
lucid
C?ID=39412
Thanks. So makes no difference to mine as manual. So any that are LIN 2.0 without the sensor and slip ring 2 SW 0111 should be okay
lucid
C?ID=39412
I've ordered an 1K0953549CF as I believe that to be compatible as it is a Mk6 MFSW with Lin2.0. Presently as my Golf came with the Highline Computer I have the 1K0953519J RHS wiper stalk with the 2 extra switches, 1 on the end and the button underneath. Would I also need to change this to a 1K0953519H wiper stalk without the 2 switches for the Control module to program correctly with the new wheel. Or do the cars with the MFSW come with both. I would want the buttons on the wheel to work as intended and not conflict with the wiper stalk if possible. I had a read around the forum and read one post saying that if you used the stalk buttons with a new MFSW (on the J variant) then the wheel buttons became inoperative until the engine was turned off then on again. On another thread someone mentioned if the J version was fitted the MFSW buttons operated to mimic the stalk buttons but not as they would without the J version stalk.
