Seat Ateca retrofit foot gestic fault
toncsa
Hungary
C?ID=333251
Hi all,
Please help retrofit Sensor for Rear Lid/Hatch Opening (open the luggage compartment with flap)
I can not do the calibration (Missing Calibration / Basic Setting)
Scan:
Friday,02,November,2018,18:37:37:60022
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
VIN: VSSZZZ5FZH6505219   License Plate: NWW992
Mileage: 71779km-44601mi   Repair Order: 20181102total
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 6D A5
          CA
VIN: VSSZZZ5FZH6505219   Mileage: 71779km-44601miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CZEA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 JT    HW: 04E 907 309 BJ
   Component: R4 1.4l TFS   H23 3139
   Revision: R6H23---
   Coding: 0125003223641D083000
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_ECM14TFS01104E906027JT 001004
   ROD: EV_ECM14TFS01104E906027JT_AU37.rod
   VCID: 7F5BFFEA4773DB9FE7F-802A
   CAN Converter 01:
   Part No SW: 0CW 300 049 R    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0903
   Revision: 00005026    Serial number: CU501607146531
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 4CC198264645B00732D-8018
   Part No SW: 5Q0 614 517 BH    HW: 5Q0 614 517 AD
   Component: ESC           H25 0507
   Revision: 00000000    Serial number: 61676000000466
   Coding: 21EE6A92342014718779660141CC2584562C28E16682A4733822F074C62203
   ROD: EV_Brake1UDSContiMK100IPB_035_VW41.rod
   VCID: 78A914F6625DECA7A65-802C
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0412007821
   Coding: 032C0C0F03
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   VCID: 3C21C8E616E5008782D-8068
   Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
   Component: GEB.F.Heckoef  H17 0903
   Serial number: 98328917
221445 - Sensor for Rear Lid/Hatch Opening
          B1303 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 24
                    Mileage: 71657 km
                    Date: 2018.11.02
                    Time: 07:37:34
                    Terminal_15_Kessy_specified_value: On
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_specified_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_Kessy_specified_value: On
                    Terminal_S_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Park selector lever position: Not engaged and not locked
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 13.402 V
                    Vehicle speed: 35.5 km/h
                    Engine speed: 1480.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID sensor 1 authentication: status: No response
                    ID sensor 2 authentication: status: No response
                    ID sensor 3 authentication: status: No response
                    ID sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 5F0 907 044 AE    HW: 5F0 907 044 AE
   Component: Climatronic   H05 1601
   Revision: 00001K09
   Coding: 02000024200110011105004001101020
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   ROD: EV_ACClimaBHBVW37X_006_SE37.rod
   VCID: 698F41B229F7452F29B-803C
   Air quality sensor:
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001619701330
   ROD: EV_BCMBOSCH_017.rod
   Component: RLHS  042 0105
   Serial number: S4Y16M07D27H12M29S06
   Coding: 06996E
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183616202
   Coding: 0271063051
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   VCID: 0D4755227DDFF90FE53-8058
   Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0156
   Coding: 3200474310FF8728749C8065804081
   ASAM Dataset: EV_ACCMRRCONTIVW376 001011
   ROD: EV_ACCMRRCONTIVW376_001.rod
   VCID: 3B23CBFA13EB07BF8B7-806E
   Part No SW: 3Q0 959 655 AK    HW: 3Q0 959 655 AK
   Component: Airbag VW21   004 0305
   Revision: --------    Serial number: 003R6PDW7RP-
   Coding: 98CCC0C0000000005C5400CC000800000065
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
   VCID: 074B670A1FA3935FDFF-8052
   Subsystem 1 - Part No SW: -----------    HW: 454 001 806 16
   Serial number: 35700000000C3439AB1P
   Subsystem 2 - Part No SW: -----------    HW: 454 000 707 16
   Serial number: 358000000009E274DB1Y
   Subsystem 3 - Part No SW: -----------    HW: 454 801 406 16
   Serial number: 351003485C90B000000I
   Subsystem 4 - Part No SW: -----------    HW: 454 801 906 16
   Serial number: 35200DB96C90B000000
   Subsystem 5 - Part No SW: -----------    HW: 454 802 805 16
   Serial number: 355005837470B000000F
   Part No SW: 3Q0 953 521 EE    HW: 5Q0 953 569 A
   Revision: FF036036    Serial number: 20160721400799
   Coding: 6C14
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 77AB17CA6F43E3DFAFF-8022
   Part No SW: 5F0 920 740 D    HW: 5F0 920 740 D
   Component: KOMBI         205 8311
   Coding: 07A5221A6F84000800883A031001000000000000
   VCID: 25170D82856FA14FCD3-8070
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 23071610800742
   Coding: 030100F42F085700EA000250140F00010001050000000000000000000000
   Shop #: WSC 33361 790 00114
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 7CA108E65665C087C2D-8028
   Subsystem 2 - Part No SW: 5F0 959 537 A    HW: 5F0 959 537 A
   Serial number: 000000000B0649050416
   Coding: 012000
   Serial number: 75410803001607270054
   Serial number: 16000154551001
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BF29D20127BDEF61B-8024
   Component: TSG FS        010 0031
   Serial number: 0000211224110
   Coding: 00311320D000040000001000
   VCID: 47CBA70A5F23535F1FF-8012
   Serial number: 00000000000010835108
   Coding: 210000
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000934230
   Coding: 01010011004000
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_008.rod
   VCID: 3D27C5E20DFF098FB53-8068
   Component: TSG BFS       010 0031
   Serial number: 0000211032019
   Coding: 00311320DC00040000001000
   VCID: 46D5AA0E58294A57E49-8012
   Serial number: 00000000000010887931
   Coding: 390000
   Coding: 068A000009000000
   VCID: 75B71DC2754F91CFBD3-8020
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 5QA 035 824 A    HW: 5QA 035 824 A
   Component: MU-S--ER      H30 0351
   Serial number: SEZAZ2S0121586
   Coding: 04230600D70A000011110001000808002F0100C40120010002
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: EV_MUStd6C1TSAT_SK25.rod
   VCID: 3E25C2EE00F91297AC9-806A
   Subsystem 1 - Part No SW: 575 919 606 A    HW: 575 919 606 A
   Component: ABT_High-2_R  H41 1041
   Serial number: SEZ8Z9SCC001A9
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30845819900000
   Coding: 1908
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   ROD: EV_DeckLidCONTIAU736_VW41.rod
   VCID: 3FDBBFEA07F31B9FA7F-806A
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0220
   Serial number: 22071611P21068
   Coding: 030307060000040000220044C040A10094000E200020
   ROD: EV_MFKBoschMQBB_001_SE37.rod
   VCID: 3A2DCEFE1CD13EB7901-806E
   Part No SW: 4M0 907 594 D    HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Coding: 408040532602
   VCID: 372BD7CA2FC323DF6FF-8062
End----------(Elapsed Time: 01:53, VBatt start/end: 12.3V/12.3V)-----------
;SW:3Q0-959-435-E   HW:3Q0-959-435-E ---  Acc/Start Auth. --- SA: 20103
;Component:VWKESSYMQB    036 0811, Coding:032C0C0F03
;EV_KessyHellaMQBAB,004039,EV_KessyHellaMQBAB_004_VW37.rod
;Friday,02,November,2018,18:40:06:60022
;VCDS Version: Release 18.9.0 (x64)  Data version: 20180927 DS296.0
;VCID: 3C21C8E616E5008782D-8068
IDE00001-MAS12708-Production mode-Deactivation of automatic shutdowns of terminal 15,not active ,3
IDE00001-MAS12709-Production mode-Deactivation of automatic rear lid opening,not active ,3
IDE00001-MAS12710-Production mode-Deactivation of terminal 50 request,not active ,3
IDE03251-Stop release for start-stop function,According to function requirements ,1
IDE04159-Deactivation of start-stop function,not active ,1
IDE09735-CU tailgate opener: sensor 1: threshold value 1,69 ,1
IDE09736-CU tailgate opener: sensor 1: threshold value 2,16 ,1
IDE09737-CU tailgate opener: sensor 1: threshold value 3,16 ,1
IDE09738-CU tailgate opener: sensor 1: threshold value 4,16 ,1
IDE09739-CU tailgate opener: sensor 1: threshold value 5,16 ,1
IDE09740-CU tailgate opener: sensor 2: threshold value 1,2 ,1
IDE09741-CU tailgate opener: sensor 2: threshold value 2,31 ,1
IDE09742-CU tailgate opener: sensor 2: threshold value 3,2 ,1
IDE09743-CU tailgate opener: sensor 2: threshold value 4,31 ,1
IDE09744-CU tailgate opener: sensor 2: threshold value 5,224 ,1
IDE09745-CU tailgate opener: sensor 1: timer value 1,170 ,1
IDE09746-CU tailgate opener: sensor 1: timer value 2,0 ,1
IDE09747-CU tailgate opener: sensor 1: timer value 3,9 ,1
IDE09748-CU tailgate opener: sensor 1: timer value 4,241 ,1
IDE09749-CU tailgate opener: sensor 1: timer value 5,40 ,1
IDE09750-CU tailgate opener: sensor 2: timer value 1,11 ,1
IDE09751-CU tailgate opener: sensor 2: timer value 2,165 ,1
IDE09752-CU tailgate opener: sensor 2: timer value 3,138 ,1
IDE09753-CU tailgate opener: sensor 2: timer value 4,204 ,1
IDE09754-CU tailgate opener: sensor 2: timer value 5,228 ,1
IDE09755-CU tailgate opener: sensor 1: burst length,16 ,1
IDE09756-CU tailgate opener: sensor 1: active screening,16 ,1
IDE09757-CU tailgate opener: sensor 2: burst length,2 ,1
IDE09758-CU tailgate opener: sensor 2: active screening,31 ,1
IDE09759-CU for tailgate opener: reset all counters,Default ,1
IDE09760-CU for tailgate opener: check sum,170 ,1
IDE09829-CU tailgate opener: foot gestic recognition: timer value 1,2 ,1
IDE09830-CU tailgate opener: foot gestic recognition: timer value 2,31 ,1
IDE09831-CU for tailgate opener: play protection increments,6 ,1
IDE09832-CU for tailgate opener: play protection decrements,25 ,1
IDE09833-CU for tailgate opener: play protection threshold active,255 ,1
IDE09834-CU for tailgate opener: play protection threshold inactive,5 ,1
IDE09835-CU for tailgate opener: play protection decrement interval,60 ,1
IDE09836-CU tailgate opener: sensor 1: control parameter,16 ,1
IDE09837-CU tailgate opener: sensor 2: control parameter,16 ,1
IDE09838-CU tailgate opener: foot gestic recognition: evaluation,0 ,1
IDE09839-CU for tailgate opener: parameter set version,30 ,2
IDE10844-Control module rear lid opening: duration status query,4960 ms,1
IDE10845-Control module rear lid opening: vehicle type,28 ,1
ENG153713-ENG129122-Byte12_diverse-environment_scan_step1,not activated ,1
ENG153713-ENG126978-Byte12_diverse-environment_scan_step2,not activated ,1
ENG153713-ENG154598-Byte12_diverse-exeption_drivers_doors_interior_scan,not activated ,1
ENG153713-ENG154691-Byte12_diverse-interior_scan_clamp_15_new_concept,not activated ,1
ENG153713-ENG154710-Byte12_diverse-open_cabrio_canopy_interior_scan,not activated ,1
ENG153713-ENG154787-Byte12_diverse-suppression_access_detection_for_remotestart,not activated ,1
ENG244871-ENG245027-Byte13_vit_lf-lock_via_toggle_by_closed_vehicle_skin,not activated ,1
ENG244871-ENG245033-Byte13_vit_lf-toggle_active,not activated ,1
ENG244871-ENG245019-Byte13_vit_lf-toggle_at _open_door,not activated ,1
ENG244871-ENG129126-Byte13_vit_lf-vit_evaluate_inversbit,not activated ,1
ENG244871-ENG129125-Byte13_vit_lf-vit_exit,not activated ,1
ENG126956-ENG126976-Byte9_VIP-active_vip,activated ,1
ENG126956-ENG154580-Byte9_VIP-Coding_easyclose_locking,not activated ,1
ENG126956-ENG154581-Byte9_VIP-Coding_kick and_close_function,not activated ,1
ENG126956-ENG248655-Byte9_VIP-ECL_Start_ueber_ViP,not activated ,1
ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation,not activated ,1
ENG126956-ENG142121-Byte9_VIP-vip_activation_on_clamp15,not activated ,1
ENG126956-ENG126977-Byte9_VIP-vip_deactivation_on_running_engine,not activated ,1
ENG129011-CAN_signal_transmitting_delay_of_car_roll _away_warning,1.00 s,1
ENG126957-CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff,1.00 s,1
ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off,10.00 s,1
ENG105462-CAN-timeout service-key message,260 ms,1
ENG105634-Correction value LED dimming,1.0 ,1
ENG114301-Cycletime for voltage monitoring during sleepmode,100 ms,1
ENG120046-Cyclic interior scan during clamp 15 on,10 s,1
ENG126961-deactivation_time_vip_slidingdoor,15 s,1
ENG126960-Debounce_time_detection,500 ms,2
ENG126959-Debounce_time_driver_presence,200 ms,1
ENG126948-delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle,300 ms,1
ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM,120.00 s,1
ENG105791-Delta value LED dimming curve first point 40 percent dimming,30.0 %,1
ENG105792-Delta value LED dimming curve forth point 100 percent dimming,5.0 %,1
ENG105793-Delta value LED dimming curve second point 60 percent dimming,15.0 %,1
ENG105794-Delta value LED dimming curve third point 80 percent dimming,10.0 %,1
ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open,not activated ,1
ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open,not activated ,1
ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery,not activated ,1
ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go,activated ,1
ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start,activated ,1
ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted,not activated ,1
ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation,activated ,1
ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door,activated ,1
ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive,not activated ,1
ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection,not activated ,1
ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv",not activated ,1
ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT,activated ,1
ENG123036-ENG99363-DeveloperCoding: Search lights-ZAT active during clamp 58t on,activated ,1
ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load,not activated ,1
ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt,not activated ,1
ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt,not activated ,1
ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible,not activated ,1
ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk,activated ,1
ENG123037-ENG129114-DeveloperCoding: vehicle environment-reactivate_all_doorhandles,not activated ,1
ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel,left-hand drive ,1
ENG105825-Diagnostic: wait time after power on,500 ms,1
ENG126943-Display_duration_emergency_off,3000 ms,1
ENG126944-Display_duration_error_mode_2_SPN,10 s,1
ENG126941-Display_duration_please_engage_P,10 s,1
ENG105898-Doorknob contact sensor disconnecting time,5400 min,1
ENG244875-duration_A-CAN_wake_up_for_Engine_ECU_wake_up,1000 ms,1
ENG126955-duration_to_ZAT_continuous_actuation_detection,1000 ms,1
ENG129005-duration_to_ZAT_multi_actuation_detection,3000 ms,1
ENG126950-duration_ZAT_debounce,50 ms,1
ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose,30 %,9
ENG129029-ENG142127-Easy_close_alignment-Max_time_IDGeber_rear,2.00 s,9
ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose,5.00 s,9
ENG129029-ENG142130-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose,150 ,9
ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk,70 %,9
ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate,500 ms,9
ENG129029-ENG129139-Easy_close_alignment-Timeframe_scan_active,20.00 s,9
ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step,01 ,5
ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step,05 ,5
ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4,70 mV/m,5
ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area,65 mV/m,5
ENG126966-environment_scan_cyclic_step1,700 ms,1
ENG126967-environment_scan_cyclic_step2,2000 ms,1
ENG126965-environment_scan_duration_step1,300 min,1
ENG126971-environment_scan_duration_step2,24 H,1
ENG126969-environment_scan_level_bem,2 ,1
ENG126968-environment_scan_responselevel_reduction,500 ,1
ENG126970-environment_scan_startdelay_time,5 s,1
ENG126958-Ignition_For_Immobilizer,Default ,1
ENG107050-Interior scan: deceleration after comfort closing,3200 ms,1
ENG107051-Interior scan: max. engine speed for standing engine,10 km/h,1
ENG107052-Interior scan: opening threshold sliding roof,1 %,1
ENG107053-Interior scan: opening threshold window lifter,5.0 %,1
ENG107054-Interior scan: Speed - threshold,20 km/h,1
ENG153724-Interior_scans_clamp15_break_at_active_message,5000 ms,1
ENG153725-Interior_scans_clamp15_retry_at_active_message,5 ,1
ENG98656-internal,0 B,1
ENG129022-ENG142120-internal_keyminder_byte1-aktivate_function_trigger_access_leaving_elv,activated ,1
ENG129022-ENG129115-internal_keyminder_byte1-allowa_remotestart_to_disable_keys,not activated ,1
ENG129022-ENG120037-internal_keyminder_byte1-Cyclic interior scan during active warning message "Key not found",not activated ,1
ENG129022-ENG100928-internal_keyminder_byte1-Seat Memory: scan after driver door opening,not activated ,1
ENG129022-ENG99649-internal_keyminder_byte1-Seat Memory: scan after driver door opening no KESSY unlocking,activated ,1
ENG129022-ENG99417-internal_keyminder_byte1-Softtouch mounted,installed ,1
ENG129023-ENG99123-internal_keyminder_byte2-Inhibit ID-transmitter for passive go,activated ,1
ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate,activated ,1
ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior,activated ,1
ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing,activated ,1
ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling,not activated ,1
ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate,activated ,1
ENG129020-ENG121989-internal_passive_entry_exit_byte1-Impairment Entry / Exit key on low battery,not activated ,1
ENG129020-ENG125240-internal_passive_entry_exit_byte1-lf_crc,not activated ,1
ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open,activated ,1
ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open,not activated ,1
ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock,not activated ,1
ENG129021-ENG155267-internal_passive_entry_exit_byte2-lf_shutdown,not activated ,1
ENG129021-ENG155268-internal_passive_entry_exit_byte2-lf_shutdown_gotrigger,not activated ,1
ENG129021-ENG100246-internal_passive_entry_exit_byte2-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed,activated ,1
ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit,activated ,1
ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL,activated ,1
ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1,activated ,1
ENG129021-ENG103529-internal_passive_entry_exit_byte2-Passive Entry: second control concept,not activated ,1
ENG107211-Key Minder: delay reunlocking tailgate,500 ms,1
ENG107212-Key Minder: p_keyless_eventsearch_holding_time,10 s,1
ENG107213-Key Minder: p_keyless_eventsearch_retries,2 ,1
ENG107363-LED dimming curve first point 20 percent dimming,40.0 %,1
ENG107592-MCTX Pause,1 B,1
ENG107593-MCTX pause for Go / Key Minder,20 ms,1
ENG107594-MCTX pause for Go authentification,14 B,1
ENG107595-MCTX settling phase,10 B,1
ENG129013-min_receptiontime_vit,0 ms,1
ENG126945-min_time_for_Terminal_50_request,200 ms,1
ENG129003-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,1
ENG126940-Number_of_ZAT_activations_to_DTC,10 ,1
ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout,2.00 s,1
ENG108166-Passive Entry Exit: entry request e-sliding door active time,500 ms,1
ENG108167-Passive Entry Exit: minimum activity time locking sensor,140 ms,1
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,210 ms,1
ENG108169-Passive Entry Exit: T_ACT_OP_2,5000 ms,1
ENG108297-Proximity Sensor: Comfort Exit-Enlargement,200 ms,1
ENG108298-Proximity Sensor: duration of proximity Signal,10 s,1
ENG108299-Proximity Sensor: lower limit Impuls,2000 µs,1
ENG108300-Proximity Sensor: lower limit proximity-Impuls,12200 µs,1
ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle,10.0 km/h,1
ENG108302-Proximity Sensor: max. Impulslength,75 ms,1
ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls,20400 µs,1
ENG108304-Proximity Sensor: max. intermission-length Diagnostic,14 ms,1
ENG108305-Proximity Sensor: max. length of Diagnosticimpuls,71 ms,1
ENG108306-Proximity Sensor: max. length of Entryimpuls,10400 µs,1
ENG108307-Proximity Sensor: max. length of Exitimpuls,40400 µs,1
ENG108308-Proximity sensor: max. length of signal hall sensor,100 s,1
ENG108309-Proximity Sensor: max. signal-length,120 s,1
ENG108310-Proximity sensor: max. tolerance data bit length,200 µs,1
ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle,20.0 km/h,1
ENG108312-Proximity Sensor: min. enginespeed for a running engine,300 /min,1
ENG108313-Proximity Sensor: min. length of Diagnosticimpuls,42 ms,1
ENG108314-Proximity Sensor: min. length of Entryimpuls,6200 µs,1
ENG108315-Proximity Sensor: min. length of Exitimpuls,24200 µs,1
ENG108316-Proximity sensor: min. tolerance data bit length,120 µs,1
ENG108317-Proximity Sensor: SP_X2,10 min,1
ENG108318-Proximity Sensor: SP_X3,1 ,1
ENG108319-Proximity Sensor: SP_X4,80 ,1
ENG108320-Proximity Sensor: SP_X5,1 ,1
ENG108321-Proximity Sensor: SP_X6,30 min,1
ENG108322-Proximity Sensor: SP_X7,1 ,1
ENG108323-Proximity Sensor: Time Power On,1960 ms,1
ENG123035-Proximity Sensor: Timervalue for ExitReverseOption,0 ms,1
ENG108325-Proximity sensor: turn-off limit from battery-manager,2 ,1
ENG108326-Proximity Sensor: upper limit intermission-length,10 ms,1
ENG120045-Reduced current for transponder-ID request,0 Step,1
ENG126939-rpm_threshold_engine_runnning,100 /min,1
ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol,5 Step,1
ENG108576-Scan Procedure: cycle convenience coverage limiting,65 ms,1
ENG108577-Scan Procedure: Number of Repeats,1 ,1
ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause,100 ms,1
ENG108579-Scan Procedure: Timeout Authentification Result,150 ms,1
ENG129017-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go,190 ms,1
ENG129018-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi,700 ms,1
ENG108582-Scan Procedure: Timeout LF Repetition,100 ms,1
ENG108585-ScanProcedure: Timeout Entry Response,260 ms,1
ENG108586-ScanProcedure: Timeout Response,100 ms,1
ENG126963-settime_trigger_entry_vehicle,500 ms,1
ENG126962-settime_trigger_exit_vehicle,500 ms,1
ENG129024-ENG120039-Sonstiges_byte1-Backdoor TSG,not activated ,1
ENG129024-ENG103075-Sonstiges_byte1-Battery manager mounted,activated ,1
ENG129024-ENG102728-Sonstiges_byte1-Diagnostic: service 86 - response on event,not activated ,1
ENG129024-ENG98656-Sonstiges_byte1-internal,not activated ,1
ENG129024-ENG102591-Sonstiges_byte1-Response extension for scan procedure,not activated ,1
ENG129024-ENG99430-Sonstiges_byte1-Scan Procedure: Timeoutcontrol active,activated ,1
ENG129024-ENG104010-Sonstiges_byte1-Use default antenna data,not activated ,1
ENG129025-ENG129137-sonstiges_byte2-interiorscan_clamp15_reach_trashhold,not activated ,1
ENG129025-ENG142122-sonstiges_byte2-sad_existing,not activated ,1
ENG129025-ENG142123-sonstiges_byte2-trunk_ecu_existing,activated ,1
ENG129007-Speed_threshold_for_driving_cycle_detection,3.0 km/h,1
ENG129006-Speed_threshold_for_moving_vehicle_detection,1.0 km/h,1
ENG129008-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,1
ENG109053-Standard dimming value ZAT,80 %,1
ENG126946-Terminal_S_Timeout,30 min,1
ENG102207-Time Sensor Power Off Group 2,3600 min,1
ENG129027-Time_frame_VIP_kick_forecast,5 ,1
ENG126942-time_to_drive_cycle_detection,1.00 s,1
ENG126947-time_to_ignore_ignition_trigger,35 s,1
ENG126954-time_to_ZAT_Open_circuit_detection,1000 ms,1
ENG126951-time_to_ZAT_Short_circuit_fault_detection,60 s,1
ENG126949-time_ZAT_actuation_detection,3000 ms,1
ENG126952-time_ZAT_lock_after emergency_shutoff,1000 ms,1
ENG126953-time_ZAT_lock_after_normal_shutoff,500 ms,1
ENG129009-Timeframe_request_immobilizer_terminal_approval,10000 ms,1
ENG129019-timeout_convenience_coverage_limiting,75 s,1
ENG129014-Timeout_trigger_terminal_deactivation_central_locking,1.00 s,1
ENG109974-Voltage monitoring: overvoltage Delta,500 mV,1
ENG109975-Voltage monitoring: overvoltage for KESSY ECU,16000 mV,1
ENG109976-Voltage monitoring: overvoltage for Keyless Go,27000 mV,1
ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta,0 mV,1
ENG109978-Voltage monitoring: undervoltage Delta,500 mV,1
ENG109979-Voltage monitoring: undervoltage for KESSY ECU,9000 mV,1
ENG109980-Voltage monitoring: undervoltage for Keyless Go,6000 mV,1
ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta,0 mV,1
ENG120047-ZAT init value,0 %,1
ENG110364-ZAT nominal voltage,13.0 V,1
ENG110365-ZAT post-carridge during clamp 15 off,10 min,1
ENG153750-ZAT_clamp58xt_signal_factor,0.100 ,1
ENG153751-ZAT_clamp58xt_signal_offset,2.0 ,1
ENG153752-ZAT_first_fall_time_high_low_state,500 ms,1
ENG153753-ZAT_first_rise_time_low_high_state,100 ms,1
ENG153754-ZAT_motor_signal_timer_1,2500 ms,1
ENG153755-ZAT_motor_signal_timer_2,2000 ms,1
ENG153756-ZAT_pwm_offset_1_lower_limit,0 %,1
ENG153757-ZAT_pwm_offset_2_lower_limit,0 %,1
ENG153758-ZAT_pwm_peak1_upper_limit,80 %,1
ENG153759-ZAT_pwm_peak2_upper_limit,100 %,1
ENG153760-ZAT_second_fall_time_high_low_state,1600 ms,1
Elapsed Time: 00:55
What is "foot gestic"? Even Google Translate has no idea.
When posting data in this forum, please use the English version of VCDS. You can download it from this page and it will happily coexist with the Magyar translation you are currently using.
toncsa
Hungary
C?ID=333251
I changed the language
downtime
Finland
C?ID=280813
I think OP means trunk foot gesture opening. Means that you swipe your foot under the rear bumper, take a step back and then ”Open Sesame” :)
toncsa
Hungary
C?ID=333251
Hi all.
I found the mistake. In the kessy module.
This line is wrong. :IDE09759-CU for tailgate opener: reset all counters,Default ,1
The good line: IDE09759-CU for tailgate opener: reset all counters;unknow (224);1
This was caused by the basic setting start-stop counter reset command.
adaptation parameter selection: 1 default 2 reset no more options
How can it be repaired?
golfi_vend
Tartu, Estonia
C?ID=195131
Hi all.
This needs custom approach with VCDS. As the "unknown" description is not described in ASAM, it's not selectable with VCDS. - But I think, this means manually feeding the value to controller(which might not be possible). In reality it needs sensor calibration with factory scan tool.
toncsa
Hungary
C?ID=333251
thanks
Test element with the original instrument
hadez16
C?ID=289891
This was done successfully on other boards...you have to search for "VIP" in your units....virtual pedal is the buzz word...
I'm lacking time at the moment for having a deeper look into my stuff...
OEMplusCC
C?ID=160054
Run into very similar issues after easy open retrofit on NAR MQB Tiguan
I successfully changed adaptation channels based on a Tiguan which came with easy open from factory. I still had calibration error but I was able to read all adaptation channels.
But after I cycled the ignition I was not able to read adaptions channels anymore. Luckily, the car operates normally.
Here is the adaptation scan right after changing values.
 ;SW:3Q0-959-435-L   HW:3Q0-959-435-L ---  Acc/Start Auth. --- SA: 20103
;Component:VWKESSYMQB    037 1204	 Coding:132C0C0723
;EV_KessyHellaMQBAB	4046	EV_KessyHellaMQBAB_004_VW37.rod
;Sunday	8	September	2019	10:03:19:18133
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
;VCID: 43D34C0C5B11B54F97B-8016
IDE00001-MAS12708-Production mode-Deactivation of automatic shutdowns of terminal 15	not active 	3
IDE00001-MAS12709-Production mode-Deactivation of automatic rear lid opening	not active 	3
IDE00001-MAS12710-Production mode-Deactivation of terminal 50 request	not active 	3
IDE00820-Activating and deactivating all development messages	not active 	1
IDE02332-Deactivate production mode	0	3
IDE03251-Stop release for start-stop function	According to function requirements 	1
IDE04159-Deactivation of start-stop function	not active 	1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module	20 min	2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus	30 min	2
IDE09735-CU tailgate opener: sensor 1: threshold value 1	69	1
IDE09736-CU tailgate opener: sensor 1: threshold value 2	16	1
IDE09737-CU tailgate opener: sensor 1: threshold value 3	16	1
IDE09738-CU tailgate opener: sensor 1: threshold value 4	16	1
IDE09739-CU tailgate opener: sensor 1: threshold value 5	16	1
IDE09740-CU tailgate opener: sensor 2: threshold value 1	2	1
IDE09741-CU tailgate opener: sensor 2: threshold value 2	31	1
IDE09742-CU tailgate opener: sensor 2: threshold value 3	2	1
IDE09743-CU tailgate opener: sensor 2: threshold value 4	31	1
IDE09744-CU tailgate opener: sensor 2: threshold value 5	224	1
IDE09745-CU tailgate opener: sensor 1: timer value 1	170	1
IDE09746-CU tailgate opener: sensor 1: timer value 2	0	1
IDE09747-CU tailgate opener: sensor 1: timer value 3	9	1
IDE09748-CU tailgate opener: sensor 1: timer value 4	34	1
IDE09749-CU tailgate opener: sensor 1: timer value 5	34	1
IDE09750-CU tailgate opener: sensor 2: timer value 1	11	1
IDE09751-CU tailgate opener: sensor 2: timer value 2	165	1
IDE09752-CU tailgate opener: sensor 2: timer value 3	147	1
IDE09753-CU tailgate opener: sensor 2: timer value 4	204	1
IDE09754-CU tailgate opener: sensor 2: timer value 5	24	1
IDE09755-CU tailgate opener: sensor 1: burst length	16	1
IDE09756-CU tailgate opener: sensor 1: active screening	16	1
IDE09757-CU tailgate opener: sensor 2: burst length	2	1
IDE09758-CU tailgate opener: sensor 2: active screening	31	1
IDE09759-CU for tailgate opener: reset all counters	Unknown (224)	1
IDE09760-CU for tailgate opener: check sum	170	1
IDE09829-CU tailgate opener: foot gestic recognition: timer value 1	2	1
IDE09830-CU tailgate opener: foot gestic recognition: timer value 2	31	1
IDE09831-CU for tailgate opener: play protection increments	6	1
IDE09832-CU for tailgate opener: play protection decrements	25	1
IDE09833-CU for tailgate opener: play protection threshold active	255	1
IDE09834-CU for tailgate opener: play protection threshold inactive	5	1
IDE09835-CU for tailgate opener: play protection decrement interval	60	1
IDE09836-CU tailgate opener: sensor 1: control parameter	16	1
IDE09837-CU tailgate opener: sensor 2: control parameter	16	1
IDE09838-CU tailgate opener: foot gestic recognition: evaluation	0	1
IDE09839-CU for tailgate opener: parameter set version	30	2
IDE10844-Control module rear lid opening: duration status query	4960 ms	1
IDE10845-Control module rear lid opening: vehicle type	FE 	1
ENG153713-ENG129122-Byte12_diverse-environment_scan_step1	not activated 	1
ENG153713-ENG126978-Byte12_diverse-environment_scan_step2	not activated 	1
ENG153713-ENG154598-Byte12_diverse-exeption_drivers_doors_interior_scan	activated 	1
ENG153713-ENG154691-Byte12_diverse-interior_scan_clamp_15_new_concept	activated 	1
ENG153713-ENG154710-Byte12_diverse-open_cabrio_canopy_interior_scan	not activated 	1
ENG153713-ENG154787-Byte12_diverse-suppression_access_detection_for_remotestart	activated 	1
ENG244871-ENG245027-Byte13_vit_lf-lock_via_toggle_by_closed_vehicle_skin	not activated 	1
ENG244871-ENG245033-Byte13_vit_lf-toggle_active	not activated 	1
ENG244871-ENG245019-Byte13_vit_lf-toggle_at _open_door	not activated 	1
ENG244871-ENG129126-Byte13_vit_lf-vit_evaluate_inversbit	not activated 	1
ENG244871-ENG129125-Byte13_vit_lf-vit_exit	not activated 	1
ENG126956-ENG126976-Byte9_VIP-active_vip	activated 	1
ENG126956-ENG154580-Byte9_VIP-Coding_easyclose_locking	not activated 	1
ENG126956-ENG154581-Byte9_VIP-Coding_kick and_close_function	not activated 	1
ENG126956-ENG248655-Byte9_VIP-ECL_Start_ueber_ViP	not activated 	1
ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation	not activated 	1
ENG126956-ENG142121-Byte9_VIP-vip_activation_on_clamp15	not activated 	1
ENG126956-ENG126977-Byte9_VIP-vip_deactivation_on_running_engine	not activated 	1
ENG129011-CAN_signal_transmitting_delay_of_car_roll _away_warning	1.00 s	1
ENG126957-CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff	1.00 s	1
ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off	10.00 s	1
ENG105462-CAN-timeout service-key message	260 ms	1
ENG105634-Correction value LED dimming	1	1
ENG114301-Cycletime for voltage monitoring during sleepmode	100 ms	1
ENG120046-Cyclic interior scan during clamp 15 on	10 s	1
ENG126961-deactivation_time_vip_slidingdoor	15 s	1
ENG126960-Debounce_time_detection	500 ms	2
ENG126959-Debounce_time_driver_presence	200 ms	1
ENG126948-delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle	300 ms	1
ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM	60.00 s	1
ENG105791-Delta value LED dimming curve first point 40 percent dimming	30.00%	1
ENG105792-Delta value LED dimming curve forth point 100 percent dimming	5.00%	1
ENG105793-Delta value LED dimming curve second point 60 percent dimming	15.00%	1
ENG105794-Delta value LED dimming curve third point 80 percent dimming	10.00%	1
ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open	not activated 	1
ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open	not activated 	1
ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery	not activated 	1
ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go	activated 	1
ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start	activated 	1
ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted	not activated 	1
ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation	activated 	1
ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door	activated 	1
ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive	activated 	1
ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection	not activated 	1
ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv"	activated 	1
ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT	activated 	1
ENG123036-ENG99363-DeveloperCoding: Search lights-ZAT active during clamp 58t on	activated 	1
ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load	not activated 	1
ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt	not activated 	1
ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt	not activated 	1
ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible	not activated 	1
ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk	not activated 	1
ENG123037-ENG129114-DeveloperCoding: vehicle environment-reactivate_all_doorhandles	not activated 	1
ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel	left-hand drive 	1
ENG105825-Diagnostic: wait time after power on	500 ms	1
ENG126943-Display_duration_emergency_off	3000 ms	1
ENG126944-Display_duration_error_mode_2_SPN	10 s	1
ENG126941-Display_duration_please_engage_P	10 s	1
ENG105898-Doorknob contact sensor disconnecting time	5400 min	1
ENG244875-duration_A-CAN_wake_up_for_Engine_ECU_wake_up	2000 ms	1
ENG126955-duration_to_ZAT_continuous_actuation_detection	1000 ms	1
ENG129005-duration_to_ZAT_multi_actuation_detection	3000 ms	1
ENG126950-duration_ZAT_debounce	50 ms	1
ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose	10%	9
ENG129029-ENG142127-Easy_close_alignment-Max_time_IDGeber_rear	2.00 s	9
ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose	7.00 s	9
ENG129029-ENG142130-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose	20	9
ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk	50%	9
ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate	400 ms	9
ENG129029-ENG129139-Easy_close_alignment-Timeframe_scan_active	20.00 s	9
ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step	4	5
ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step	2	5
ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4	220 mV/m	5
ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area	40 mV/m	5
ENG126966-environment_scan_cyclic_step1	700 ms	1
ENG126967-environment_scan_cyclic_step2	2000 ms	1
ENG126965-environment_scan_duration_step1	300 min	1
ENG126971-environment_scan_duration_step2	24 H	1
ENG126969-environment_scan_level_bem	2	1
ENG126968-environment_scan_responselevel_reduction	500	1
ENG126970-environment_scan_startdelay_time	5 s	1
ENG126958-Ignition_For_Immobilizer	Default 	1
ENG129016-Initialization_diagnostics_switching_terminal	not activated 	4
ENG107050-Interior scan: deceleration after comfort closing	3200 ms	1
ENG107051-Interior scan: max. engine speed for standing engine	10 km/h	1
ENG107052-Interior scan: opening threshold sliding roof	1%	1
ENG107053-Interior scan: opening threshold window lifter	5.00%	1
ENG107054-Interior scan: Speed - threshold	20 km/h	1
ENG153724-Interior_scans_clamp15_break_at_active_message	5000 ms	1
ENG153725-Interior_scans_clamp15_retry_at_active_message	5	1
ENG98656-internal	0 B	1
ENG129022-ENG142120-internal_keyminder_byte1-aktivate_function_trigger_access_leaving_elv	not activated 	1
ENG129022-ENG129115-internal_keyminder_byte1-allowa_remotestart_to_disable_keys	not activated 	1
ENG129022-ENG120037-internal_keyminder_byte1-Cyclic interior scan during active warning message "Key not found"	not activated 	1
ENG129022-ENG100928-internal_keyminder_byte1-Seat Memory: scan after driver door opening	activated 	1
ENG129022-ENG99649-internal_keyminder_byte1-Seat Memory: scan after driver door opening no KESSY unlocking	activated 	1
ENG129022-ENG99417-internal_keyminder_byte1-Softtouch mounted	installed 	1
ENG129023-ENG99123-internal_keyminder_byte2-Inhibit ID-transmitter for passive go	activated 	1
ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate	activated 	1
ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior	activated 	1
ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing	activated 	1
ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling	not activated 	1
ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate	activated 	1
ENG129020-ENG121989-internal_passive_entry_exit_byte1-Impairment Entry / Exit key on low battery	not activated 	1
ENG129020-ENG125240-internal_passive_entry_exit_byte1-lf_crc	not activated 	1
ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open	activated 	1
ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open	not activated 	1
ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock	not activated 	1
ENG129021-ENG155267-internal_passive_entry_exit_byte2-lf_shutdown	activated 	1
ENG129021-ENG155268-internal_passive_entry_exit_byte2-lf_shutdown_gotrigger	not activated 	1
ENG129021-ENG100246-internal_passive_entry_exit_byte2-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed	activated 	1
ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit	activated 	1
ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL	activated 	1
ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1	not activated 	1
ENG129021-ENG103529-internal_passive_entry_exit_byte2-Passive Entry: second control concept	not activated 	1
ENG107211-Key Minder: delay reunlocking tailgate	500 ms	1
ENG107212-Key Minder: p_keyless_eventsearch_holding_time	10 s	1
ENG107213-Key Minder: p_keyless_eventsearch_retries	2	1
ENG107363-LED dimming curve first point 20 percent dimming	40.00%	1
ENG153886-lf_shutdown_timeout_2nd_operation	5 s	1
ENG107592-MCTX Pause	1 B	1
ENG107593-MCTX pause for Go / Key Minder	20 ms	1
ENG107594-MCTX pause for Go authentification	14 B	1
ENG107595-MCTX settling phase	10 B	1
ENG129013-min_receptiontime_vit	0 ms	1
ENG126945-min_time_for_Terminal_50_request	200 ms	1
ENG244880-Minimum_holdtime_ak	500 ms	1
ENG129003-Number_of_Multiple_ZAT_activations_to_emergency_shutoff	2	1
ENG126940-Number_of_ZAT_activations_to_DTC	10	1
ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout	2.00 s	1
ENG108166-Passive Entry Exit: entry request e-sliding door active time	500 ms	1
ENG108167-Passive Entry Exit: minimum activity time locking sensor	140 ms	1
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY	220 ms	1
ENG108169-Passive Entry Exit: T_ACT_OP_2	5000 ms	1
ENG108297-Proximity Sensor: Comfort Exit-Enlargement	200 ms	1
ENG108298-Proximity Sensor: duration of proximity Signal	10 s	1
ENG108299-Proximity Sensor: lower limit Impuls	2000 µs	1
ENG108300-Proximity Sensor: lower limit proximity-Impuls	12200 µs	1
ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle	10.0 km/h	1
ENG108302-Proximity Sensor: max. Impulslength	75 ms	1
ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls	20400 µs	1
ENG108304-Proximity Sensor: max. intermission-length Diagnostic	14 ms	1
ENG108305-Proximity Sensor: max. length of Diagnosticimpuls	71 ms	1
ENG108306-Proximity Sensor: max. length of Entryimpuls	10400 µs	1
ENG108307-Proximity Sensor: max. length of Exitimpuls	40400 µs	1
ENG108308-Proximity sensor: max. length of signal hall sensor	100 s	1
ENG108309-Proximity Sensor: max. signal-length	120 s	1
ENG108310-Proximity sensor: max. tolerance data bit length	200 µs	1
ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle	20.0 km/h	1
ENG108312-Proximity Sensor: min. enginespeed for a running engine	300 /min	1
ENG108313-Proximity Sensor: min. length of Diagnosticimpuls	42 ms	1
ENG108314-Proximity Sensor: min. length of Entryimpuls	6200 µs	1
ENG108315-Proximity Sensor: min. length of Exitimpuls	24200 µs	1
ENG108316-Proximity sensor: min. tolerance data bit length	120 µs	1
ENG108317-Proximity Sensor: SP_X2	10 min	1
ENG108318-Proximity Sensor: SP_X3	1	1
ENG108319-Proximity Sensor: SP_X4	80	1
ENG108320-Proximity Sensor: SP_X5	1	1
ENG108321-Proximity Sensor: SP_X6	30 min	1
ENG108322-Proximity Sensor: SP_X7	1	1
ENG108323-Proximity Sensor: Time Power On	1960 ms	1
ENG123035-Proximity Sensor: Timervalue for ExitReverseOption	0 ms	1
ENG108325-Proximity sensor: turn-off limit from battery-manager	2	1
ENG108326-Proximity Sensor: upper limit intermission-length	10 ms	1
ENG153707-IDE00047-Rear_lid_power_opening_control_unit_data_set_upload-Parameter set version	0	37
ENG153707-IDE80001-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 1	1	37
ENG153707-IDE80002-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 2	1	37
ENG153707-IDE80003-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 3	0	37
ENG153707-IDE80004-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 4	1	37
ENG153707-IDE80005-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 5	16	37
ENG153707-IDE80006-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 6	16	37
ENG153707-IDE80007-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 7	16	37
ENG153707-IDE80008-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 8	16	37
ENG153707-IDE80009-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 9	2	37
ENG153707-IDE80010-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 10	31	37
ENG153707-IDE80011-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 11	2	37
ENG153707-IDE80012-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 12	31	37
ENG153707-IDE80013-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 13	224	37
ENG153707-IDE80014-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 14	10	37
ENG153707-IDE80015-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 15	10	37
ENG153707-IDE80016-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 16	0	37
ENG153707-IDE80017-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 17	0	37
ENG153707-IDE80018-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 18	9	37
ENG153707-IDE80019-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 19	0	37
ENG153707-IDE80020-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 20	not active 	37
ENG153707-IDE80021-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 21	active 	37
ENG153707-IDE80022-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 22	not active 	37
ENG153707-IDE80023-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 23	Bottom 	37
ENG153707-IDE80024-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 24	Dynamic 	37
ENG153707-IDE80025-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 25	3	37
ENG153707-IDE80026-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 26	not active 	37
ENG153707-IDE80027-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 27	Dynamic 	37
ENG153707-IDE80028-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 28	5	37
ENG153707-IDE80029-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 29	6	37
ENG153707-IDE80030-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 30	active 	37
ENG153707-IDE80031-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 31	19	37
ENG153707-IDE80032-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 32	2	37
ENG153707-IDE80033-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 33	12	37
ENG153707-IDE80034-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 34	4	37
ENG153707-IDE80035-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 35	Do not reset 	37
ENG153707-IDE80036-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 36	16	37
ENG153707-IDE80037-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 37	16	37
ENG153707-IDE80038-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 38	16	37
ENG153707-IDE80039-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 39	16	37
ENG153707-IDE80040-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 40	2	37
ENG153707-IDE80041-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 41	31	37
ENG153707-IDE80042-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 42	2	37
ENG153707-IDE80043-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 43	31	37
ENG153707-IDE80044-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 44	224	37
ENG153707-IDE80045-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 45	10	37
ENG153707-IDE80046-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 46	10	37
ENG153707-IDE80047-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 47	0	37
ENG153707-IDE80048-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 48	0	37
ENG153707-IDE80049-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 49	0	37
ENG153707-IDE80050-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 50	0	37
ENG153707-IDE80051-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 51	6	37
ENG153707-IDE80052-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 52	25	37
ENG153707-IDE80053-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 53	255	37
ENG153707-IDE80054-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 54	5	37
ENG153707-IDE80055-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 55	60	37
ENG153707-IDE80056-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 56	24	37
ENG153707-MAS01078-Rear_lid_power_opening_control_unit_data_set_upload-Vehicle type	34	37
ENG153707-MAS14087-Rear_lid_power_opening_control_unit_data_set_upload-time delay activation	Activation after 2s 	37
ENG120045-Reduced current for transponder-ID request	0 Step	1
ENG126939-rpm_threshold_engine_runnning	100 /min	1
ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol	5 Step	1
ENG108576-Scan Procedure: cycle convenience coverage limiting	65 ms	1
ENG108577-Scan Procedure: Number of Repeats	1	1
ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause	100 ms	1
ENG108579-Scan Procedure: Timeout Authentification Result	150 ms	1
ENG129017-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go	190 ms	1
ENG129018-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi	700 ms	1
ENG108582-Scan Procedure: Timeout LF Repetition	100 ms	1
ENG108585-ScanProcedure: Timeout Entry Response	260 ms	1
ENG108586-ScanProcedure: Timeout Response	100 ms	1
ENG126963-settime_trigger_entry_vehicle	500 ms	1
ENG126962-settime_trigger_exit_vehicle	500 ms	1
ENG129024-ENG120039-Sonstiges_byte1-Backdoor TSG	not activated 	1
ENG129024-ENG103075-Sonstiges_byte1-Battery manager mounted	activated 	1
ENG129024-ENG102728-Sonstiges_byte1-Diagnostic: service 86 - response on event	not activated 	1
ENG129024-ENG98656-Sonstiges_byte1-internal	not activated 	1
ENG129024-ENG102591-Sonstiges_byte1-Response extension for scan procedure	not activated 	1
ENG129024-ENG99430-Sonstiges_byte1-Scan Procedure: Timeoutcontrol active	activated 	1
ENG129024-ENG104010-Sonstiges_byte1-Use default antenna data	not activated 	1
ENG129025-ENG129137-sonstiges_byte2-interiorscan_clamp15_reach_trashhold	not activated 	1
ENG129025-ENG142122-sonstiges_byte2-sad_existing	activated 	1
ENG129025-ENG142123-sonstiges_byte2-trunk_ecu_existing	activated 	1
ENG244883-Speed_ threshold_for_start_request_plausibilisation	10 km/h	1
ENG129007-Speed_threshold_for_driving_cycle_detection	3.0 km/h	1
ENG129006-Speed_threshold_for_moving_vehicle_detection	1.0 km/h	1
ENG129008-Speed_threshold_for_terminal_15_emergency_shutoff	7.0 km/h	1
ENG109053-Standard dimming value ZAT	80%	1
ENG126938-Terminal_15_adaption_body_control_module	Default 	1
ENG126946-Terminal_S_Timeout	30 min	1
ENG102207-Time Sensor Power Off Group 2	3600 min	1
ENG129027-Time_frame_VIP_kick_forecast	5	1
ENG126942-time_to_drive_cycle_detection	1.00 s	1
ENG126947-time_to_ignore_ignition_trigger	35 s	1
ENG126954-time_to_ZAT_Open_circuit_detection	1000 ms	1
ENG126951-time_to_ZAT_Short_circuit_fault_detection	60 s	1
ENG126949-time_ZAT_actuation_detection	3000 ms	1
ENG126952-time_ZAT_lock_after emergency_shutoff	1000 ms	1
ENG126953-time_ZAT_lock_after_normal_shutoff	500 ms	1
ENG129009-Timeframe_request_immobilizer_terminal_approval	10000 ms	1
ENG129019-timeout_convenience_coverage_limiting	75 s	1
ENG129014-Timeout_trigger_terminal_deactivation_central_locking	1.00 s	1
ENG244884-Toggle_offtime_other_doorhandle	2.00 s	1
ENG244885-Toggle_offtime_same_doorhandle	2.00 s	1
ENG109974-Voltage monitoring: overvoltage Delta	500 mV	1
ENG109975-Voltage monitoring: overvoltage for KESSY ECU	16000 mV	1
ENG109976-Voltage monitoring: overvoltage for Keyless Go	27000 mV	1
ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta	0 mV	1
ENG109978-Voltage monitoring: undervoltage Delta	500 mV	1
ENG109979-Voltage monitoring: undervoltage for KESSY ECU	9000 mV	1
ENG109980-Voltage monitoring: undervoltage for Keyless Go	6000 mV	1
ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta	0 mV	1
ENG120047-ZAT init value	0%	1
ENG110364-ZAT nominal voltage	13.0 V	1
ENG110365-ZAT post-carridge during clamp 15 off	10 min	1
ENG153750-ZAT_clamp58xt_signal_factor	0.2	1
ENG153751-ZAT_clamp58xt_signal_offset	3	1
ENG153752-ZAT_first_fall_time_high_low_state	900 ms	1
ENG153753-ZAT_first_rise_time_low_high_state	100 ms	1
ENG153754-ZAT_motor_signal_timer_1	3000 ms	1
ENG153755-ZAT_motor_signal_timer_2	3000 ms	1
ENG153756-ZAT_pwm_offset_1_lower_limit	5%	1
ENG153757-ZAT_pwm_offset_2_lower_limit	10%	1
ENG153758-ZAT_pwm_peak1_upper_limit	90%	1
ENG153759-ZAT_pwm_peak2_upper_limit	100%	1
ENG153760-ZAT_second_fall_time_high_low_state	2000 ms	1
Elapsed Time: 00:56
Here is the scan after power cycle and clear code
;Sunday	8	September	2019	17:00:38:18133
Group	Description	Actual
IDE00019	Voltage terminal 30	12.842	 V
IDE00021	Engine speed	803.5	 /min
IDE00021-MAS02248	Engine speed-Signal state	valid
IDE00030	Status of actuator test	active
IDE00075	Vehicle speed	0	 km/h
IDE00075-MAS02248	Vehicle speed-Signal state	valid
IDE00096-MAS02248	Selector lever position-Signal state	Current
IDE00096	Selector lever position	OK
IDE00322	Status of basic setting	Basic setting ended
IDE00323	Security Access: Number of invalid keys	0
IDE02406	Key number of last identified ID sensor	ID sensor 2
IDE02407	Status of vehicle locking	Vehicle unlocked at single door
IDE02408-MAS00218	Individual door locking: status-Driver door	closed
IDE02408-MAS00219	Individual door locking: status-Front Passenger Door	closed
IDE02408-MAS00220	Individual door locking: status-Left rear door	closed
IDE02408-MAS00221	Individual door locking: status-Right rear door	closed
IDE02409	ID sensor 1 authentication: status	No response
IDE02410	ID sensor 2 authentication: status	No response
IDE02411	ID sensor 3 authentication: status	No response
IDE02412	ID sensor 4 authentication: status	No response
IDE02413	Door handle touch sensor: last operation	Driver door
IDE02414-MAS00080	Driver exterior door handle touch sensor-Coding information	coded
IDE02414-MAS02176	Driver exterior door handle touch sensor-Approach to the inside	not active
IDE02414-MAS02177	Driver exterior door handle touch sensor-Actuation to the inside	not active
IDE02414-MAS02178	Driver exterior door handle touch sensor-Approach to the outside	not active
IDE02414-MAS02179	Driver exterior door handle touch sensor-Actuation to the outside	not active
IDE02414-MAS02451	Driver exterior door handle touch sensor-Pulling actuation: outside door handle	not active
IDE02415-MAS00080	Front passenger exterior door handle touch sensor-Coding information	coded
IDE02415-MAS02176	Front passenger exterior door handle touch sensor-Approach to the inside	not active
IDE02415-MAS02177	Front passenger exterior door handle touch sensor-Actuation to the inside	not active
IDE02415-MAS02178	Front passenger exterior door handle touch sensor-Approach to the outside	not active
IDE02415-MAS02179	Front passenger exterior door handle touch sensor-Actuation to the outside	not active
IDE02415-MAS02451	Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle	not active
IDE02416-MAS00080	Left rear exterior door handle touch sensor-Coding information	Not coded
IDE02416-MAS02176	Left rear exterior door handle touch sensor-Approach to the inside	not active
IDE02416-MAS02177	Left rear exterior door handle touch sensor-Actuation to the inside	not active
IDE02416-MAS02178	Left rear exterior door handle touch sensor-Approach to the outside	not active
IDE02416-MAS02179	Left rear exterior door handle touch sensor-Actuation to the outside	not active
IDE02416-MAS02451	Left rear exterior door handle touch sensor-Pulling actuation: outside door handle	not active
IDE02417-MAS00080	Right rear exterior door handle touch sensor-Coding information	Not coded
IDE02417-MAS02176	Right rear exterior door handle touch sensor-Approach to the inside	not active
IDE02417-MAS02177	Right rear exterior door handle touch sensor-Actuation to the inside	not active
IDE02417-MAS02178	Right rear exterior door handle touch sensor-Approach to the outside	not active
IDE02417-MAS02179	Right rear exterior door handle touch sensor-Actuation to the outside	not active
IDE02417-MAS02451	Right rear exterior door handle touch sensor-Pulling actuation: outside door handle	not active
IDE02418	Proximity sensor driver door: number of triggers	7
IDE02419	Proximity sensor frt.pass. door: number of triggers	2
IDE02420	Proximity sensor left rear door: number of triggers	0
IDE02421	Proximity sensor right rear door: number of triggers	0
IDE02422-MAS01482	Driver door handle: version information-Hardwareversion	22
IDE02422-MAS01483	Driver door handle: version information-Softwareversion	23
IDE02422-MAS04065	Driver door handle: version information-EEPROM	C7
IDE02423-MAS01482	ass. door handle: version information-Hardwareversion	22
IDE02423-MAS01483	ass. door handle: version information-Softwareversion	23
IDE02423-MAS04065	ass. door handle: version information-EEPROM	C7
IDE02424-MAS01482	Left rear door handle: version information-Hardwareversion	0
IDE02424-MAS01483	Left rear door handle: version information-Softwareversion	0
IDE02424-MAS04065	Left rear door handle: version information-EEPROM	0
IDE02425-MAS01482	Right rear door handle: version information-Hardwareversion	0
IDE02425-MAS01483	Right rear door handle: version information-Softwareversion	0
IDE02425-MAS04065	Right rear door handle: version information-EEPROM	0
IDE02426-MAS02398	Key number last identified in left exterior area-ID sensor 1	No
IDE02426-MAS02399	Key number last identified in left exterior area-ID sensor 2	Yes
IDE02426-MAS02400	Key number last identified in left exterior area-ID sensor 3	No
IDE02426-MAS02401	Key number last identified in left exterior area-ID sensor 4	No
IDE02427-MAS02398	Key number last identified in right exterior area-ID sensor 1	No
IDE02427-MAS02399	Key number last identified in right exterior area-ID sensor 2	Yes
IDE02427-MAS02400	Key number last identified in right exterior area-ID sensor 3	No
IDE02427-MAS02401	Key number last identified in right exterior area-ID sensor 4	No
IDE02428-MAS02398	Key number last identified in rear exterior area-ID sensor 1	No
IDE02428-MAS02399	Key number last identified in rear exterior area-ID sensor 2	Yes
IDE02428-MAS02400	Key number last identified in rear exterior area-ID sensor 3	No
IDE02428-MAS02401	Key number last identified in rear exterior area-ID sensor 4	No
IDE02429-MAS02398	Key number last identified in interior area-ID sensor 1	No
IDE02429-MAS02399	Key number last identified in interior area-ID sensor 2	Yes
IDE02429-MAS02400	Key number last identified in interior area-ID sensor 3	No
IDE02429-MAS02401	Key number last identified in interior area-ID sensor 4	No
IDE02430-MAS02398	Key number last identified in luggage compartment area-ID sensor 1	No
IDE02430-MAS02399	Key number last identified in luggage compartment area-ID sensor 2	No
IDE02430-MAS02400	Key number last identified in luggage compartment area-ID sensor 3	No
IDE02430-MAS02401	Key number last identified in luggage compartment area-ID sensor 4	No
IDE02466	Play protection activation counter driver door	0
IDE02467	Play protection activation counter frt.pass. door	0
IDE02468	Play protection activation counter left rear door	0
IDE02469	Play protection activation counter right rear door	0
IDE02482	72-hour signaling counter driver door	0
IDE02483	72-hour signaling counter frt.pass. door	0
IDE02484	72-hr signaling counter left rear door	0
IDE02485	72-hr signaling counter right rear door	0
IDE02486	Data logger triggering	not active
IDE02495	Service key: number of activations	2
IDE02496	Service key: number of timeouts	0
IDE02497	Service key: number of incomplete messages	0
IDE02569-MAS02240	Terminal S: line status-Steering column lock specified value	On
IDE02569-MAS02241	Terminal S: line status-Steering column lock actual value	On
IDE02569-MAS02242	Terminal S: line status-Electronic central electric actual value	On
IDE02570-MAS02240	Terminal 15: line status-Steering column lock specified value	On
IDE02570-MAS02241	Terminal 15: line status-Steering column lock actual value	On
IDE02570-MAS02242	Terminal 15: line status-Electronic central electric actual value	On
IDE02571-MAS02240	Terminal 50: line status-Steering column lock specified value	OFF
IDE02571-MAS02241	Terminal 50: line status-Steering column lock actual value	OFF
IDE02572-MAS02350	Starter button: status-Switch contact 1	not activated
IDE02572-MAS02351	Starter button: status-Switch contact 2	not activated
IDE02579	Park selector lever position	Engaged and locked
IDE02581	Drive train uncoupling	decoupled
IDE02582-MAS00179	Brake activation: switch status-Brake Light Switch	OFF
IDE02582-MAS02248	Brake activation: switch status-Signal state	valid
IDE02582-MAS02253	Brake activation: switch status-Brake test switch	OFF
IDE02589	Rotary latch status	closed
IDE02590-MAS02256	External vehicle locking: SPECIFIED condition-SPECIFIED condition of lock per remote/key	unlocked
IDE02590-MAS02257	External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key	Vehicle not secured
IDE02760-MAS02240	Terminal 15 redundancy: line status-Steering column lock specified value	On
IDE02760-MAS02241	Terminal 15 redundancy: line status-Steering column lock actual value	On
IDE02760-MAS02242	Terminal 15 redundancy: line status-Electronic central electric actual value	On
IDE03008-MAS05971	Stop process prevented-Missing message from Engine Control Module	not active
IDE03008-MAS06116	Stop process prevented-Antenna malfunction of a go-relevant antenna	not active
IDE03008-MAS06118	Stop process prevented-ID sensor not found	not active
IDE03008-MAS06119	Stop process prevented-CAN signal: operation reader coil is set	not active
IDE03009-MAS12704	Start process requested-System error if motor stops	not active
IDE03010-MAS05971	Number of prevented stop processes-Missing message from Engine Control Module	1
IDE03010-MAS06116	Number of prevented stop processes-Antenna malfunction of a go-relevant antenna	0
IDE03010-MAS06118	Number of prevented stop processes-ID sensor not found	2
IDE03010-MAS06119	Number of prevented stop processes-CAN signal: operation reader coil is set	1
IDE03011-MAS12704	Number of requested start processes-System error if motor stops	0
IDE03127-MAS00106	Prevented stop processes (ring memory)-Year	2018
IDE03127-MAS00106	Prevented stop processes (ring memory)-Year	2000
IDE03127-MAS00106	Prevented stop processes (ring memory)-Year	2019
IDE03127-MAS00107	Prevented stop processes (ring memory)-Month	6
IDE03127-MAS00107	Prevented stop processes (ring memory)-Month	10
IDE03127-MAS00107	Prevented stop processes (ring memory)-Month	0
IDE03127-MAS00107	Prevented stop processes (ring memory)-Month	5
IDE03127-MAS00107	Prevented stop processes (ring memory)-Month	12
IDE03127-MAS00108	Prevented stop processes (ring memory)-Day	18
IDE03127-MAS00108	Prevented stop processes (ring memory)-Day	19
IDE03127-MAS00108	Prevented stop processes (ring memory)-Day	0
IDE03127-MAS00108	Prevented stop processes (ring memory)-Day	6
IDE03127-MAS00109	Prevented stop processes (ring memory)-Hours	12
IDE03127-MAS00109	Prevented stop processes (ring memory)-Hours	0
IDE03127-MAS00109	Prevented stop processes (ring memory)-Hours	14
IDE03127-MAS00109	Prevented stop processes (ring memory)-Hours	8
IDE03127-MAS00110	Prevented stop processes (ring memory)-Minutes	3
IDE03127-MAS00110	Prevented stop processes (ring memory)-Minutes	30
IDE03127-MAS00110	Prevented stop processes (ring memory)-Minutes	0
IDE03127-MAS00110	Prevented stop processes (ring memory)-Minutes	42
IDE03127-MAS00110	Prevented stop processes (ring memory)-Minutes	21
IDE03127-MAS00111	Prevented stop processes (ring memory)-Seconds	52
IDE03127-MAS00111	Prevented stop processes (ring memory)-Seconds	36
IDE03127-MAS00111	Prevented stop processes (ring memory)-Seconds	15
IDE03127-MAS00111	Prevented stop processes (ring memory)-Seconds	33
IDE03127-MAS00111	Prevented stop processes (ring memory)-Seconds	0
IDE03127-MAS02886	Prevented stop processes (ring memory)-Last prohibited stop	Missing message from Engine Control Module
IDE03127-MAS02888	Prevented stop processes (ring memory)-Penultimate prohibited stop	ID sensor not found
IDE03127-MAS02890	Prevented stop processes (ring memory)-Third-last prohibited stop	ID sensor not found
IDE03127-MAS02892	Prevented stop processes (ring memory)-Fourth last prohibited stop	CAN signal: operation reader coil is set
IDE03127-MAS02894	Prevented stop processes (ring memory)-Fifth-last prohibited stop	Empty
IDE03128-MAS00106	Requested start processes (ring memory)-Year	2000
IDE03128-MAS00107	Requested start processes (ring memory)-Month	0
IDE03128-MAS00108	Requested start processes (ring memory)-Day	0
IDE03128-MAS00109	Requested start processes (ring memory)-Hours	0
IDE03128-MAS00110	Requested start processes (ring memory)-Minutes	0
IDE03128-MAS00111	Requested start processes (ring memory)-Seconds	0
IDE03128	Requested start processes (ring memory)	Empty
IDE03212	Start-stop conditions	Stop release
IDE03213	Start-stop enabling	No release by coordinator
IDE03527-MAS04444	CAN signals-Wake-up	not active
IDE03527-MAS05102	CAN signals-Driver information: emergency shutdown	not active
IDE03527-MAS05103	CAN signals-Driver information: roll warning	not active
IDE03527-MAS08112	CAN signals-Drive readiness	not active
IDE03527-MAS09771	CAN signals-Driver information comfort switching	not active
IDE03527-MAS10894	CAN signals-Hybrid error	not active
IDE03527-MAS10895	CAN signals-Driver information key position copy workshop	not active
IDE04042-ENG123041	ID sensor history data-Scan 1: Scan_origin_en	Diagnostic
IDE04042-ENG123040	ID sensor history data-Scan 1: Scan_trigger_en	UID_SEARCH
IDE04042-ENG123042	ID sensor history data-Scan 1: Single_scan_en	DIAG_LF_TRANSMISSION
IDE04042-ENG123043	ID sensor history data-Scan 1: Trigger_Information_u8	A2
IDE04042-ENG123045	ID sensor history data-Scan 2: Scan_origin_en	Diagnostic
IDE04042-ENG123044	ID sensor history data-Scan 2: Scan_trigger_en	UID_SEARCH
IDE04042-ENG123046	ID sensor history data-Scan 2: Single_scan_en	DIAG_LF_TRANSMISSION
IDE04042-ENG123047	ID sensor history data-Scan 2: Trigger_Information_u8	A2
IDE04042-ENG123049	ID sensor history data-Scan 3: Scan_origin_en	UID_MONITORING
IDE04042-ENG123048	ID sensor history data-Scan 3: Scan_trigger_en	UID_SEARCH
IDE04042-ENG123050	ID sensor history data-Scan 3: Single_scan_en	INTERIOR_WITH_TRUNK
IDE04042-ENG123051	ID sensor history data-Scan 3: Trigger_Information_u8	A2
IDE05204	Manufacturing dates for driver door handle	0F 13 12 B7 51
IDE05205	Manufacturing dates for frt.pass. door handle	0F 13 12 B7 51
IDE05206	Manufacturing dates for left rear door handle	00 00 00 00 00
IDE05207	Manufacturing dates for right rear door handle	00 00 00 00 00
IDE07028	Time until shut-off terminal S	1800	 s
IDE07159-MAS01155	Control module switch-off: counter-Control module	0
IDE07159-MAS05583	Control module switch-off: counter-Data bus	0
IDE07290-MAS08119	Conditions for turning on the ignition-Request active	Condition not met
IDE07290-MAS08136	Conditions for turning on the ignition-Enabling Steering Column Lock	Condition not met
IDE07290-MAS08137	Conditions for turning on the ignition-Enabling immobilizer	Condition not met
IDE07290-MAS08138	Conditions for turning on the ignition-No active error mode	Condition met
IDE07290-MAS08139	Conditions for turning on the ignition-Key signature validity	Condition met
IDE07359	Dimming of starter button lighting	76
IDE08440	Recommendation energy management	no restriction
IDE80258	Immobilizer status	Electronic steering locking device installed
IDE80258-MAS00106	Immobilizer status-Year	2018
IDE80258-MAS00107	Immobilizer status-Month	10
IDE80258-MAS00108	Immobilizer status-Day	19
IDE80258-MAS00109	Immobilizer status-Hours	0
IDE80258-MAS00110	Immobilizer status-Minutes	42
IDE80258-MAS00111	Immobilizer status-Seconds	50
IDE80258-MAS02349	Immobilizer status-Learn mode	Adapted
IDE80258-MAS06793	Immobilizer status-Number of adapted keys	2
MAS00025	Driver seat belt switch	not connected
MAS00464-MAS00106	Standard - ambient data 1-Year	2019
MAS00464-MAS00107	Standard - ambient data 1-Month	9
MAS00464-MAS00108	Standard - ambient data 1-Day	7
MAS00464-MAS00109	Standard - ambient data 1-Hours	7
MAS00464-MAS00110	Standard - ambient data 1-Minutes	33
MAS00464-MAS00111	Standard - ambient data 1-Seconds	34
MAS00464-MAS00468	Standard - ambient data 1-Unlearning counter	18
MAS00464-MAS00711	Standard - ambient data 1-Odometer reading	8129	 km
MAS01493	Engine running	active
MAS03554	Clutch pedal operation	No
MAS03607	Engine stop in start-stop mode active	active
MAS04004	Transmission code	OK
MAS05104	Driver request: start engine	not active
MAS08076	Exiting the vehicle	Condition not met
MAS08788	Driving Cycle	Condition not met
MAS08790	Driver absence	Condition met
MAS09771	Driver information comfort switching	No switch-off
ENG125217	Active_requirement_light_lag	not activated
ENG129039-ENG129149	Car_keys_RSSI_measurements-Abort_counter	0
ENG129039-ENG129148	Car_keys_RSSI_measurements-Easy_close_function_counter	0
ENG129039-ENG129150	Car_keys_RSSI_measurements-Last_abort_reason	none
ENG129039-ENG29819	Car_keys_RSSI_measurements-RSSI_Value_1	0
ENG129039-ENG29818	Car_keys_RSSI_measurements-RSSI_Value_2	0
ENG129039-ENG29817	Car_keys_RSSI_measurements-RSSI_Value_3	0
ENG129039-ENG29816	Car_keys_RSSI_measurements-RSSI_Value_4	0
ENG102274	Control Module Voltage	12.813	 V
ENG08690	Easy_open_unavailable_reason	Kl15_is_active
ENG129032	ELV_Status	ELV_nicht_entriegelt
ENG114479	Enginestart_variant_coded	--no display--
ENG125220-MAS00106	History last automatic terminal switch off-Year	2019
ENG125220-MAS00107	History last automatic terminal switch off-Month	8
ENG125220-MAS00108	History last automatic terminal switch off-Day	31
ENG125220-MAS00108	History last automatic terminal switch off-Day	28
ENG125220-MAS00108	History last automatic terminal switch off-Day	23
ENG125220-MAS00108	History last automatic terminal switch off-Day	24
ENG125220-MAS00109	History last automatic terminal switch off-Hours	10
ENG125220-MAS00109	History last automatic terminal switch off-Hours	8
ENG125220-MAS00109	History last automatic terminal switch off-Hours	7
ENG125220-MAS00109	History last automatic terminal switch off-Hours	18
ENG125220-MAS00110	History last automatic terminal switch off-Minutes	0
ENG125220-MAS00110	History last automatic terminal switch off-Minutes	50
ENG125220-MAS00110	History last automatic terminal switch off-Minutes	18
ENG125220-MAS00110	History last automatic terminal switch off-Minutes	47
ENG125220-MAS00110	History last automatic terminal switch off-Minutes	38
ENG125220-MAS00111	History last automatic terminal switch off-Seconds	34
ENG125220-MAS00111	History last automatic terminal switch off-Seconds	38
ENG125220-MAS00111	History last automatic terminal switch off-Seconds	31
ENG125220-MAS00111	History last automatic terminal switch off-Seconds	33
ENG125220-MAS00111	History last automatic terminal switch off-Seconds	26
ENG125220-ENG125227	History last automatic terminal switch off-Mileage_shutoff_reason_n	7349	 km
ENG125220-ENG125230	History last automatic terminal switch off-Mileage_shutoff_reason_n-1	7495	 km
ENG125220-ENG125233	History last automatic terminal switch off-Mileage_shutoff_reason_n-2	7807	 km
ENG125220-ENG125236	History last automatic terminal switch off-Mileage_shutoff_reason_n-3	7191	 km
ENG125220-ENG125239	History last automatic terminal switch off-Mileage_shutoff_reason_n-4	7208	 km
ENG125220-ENG125225	History last automatic terminal switch off-shutoff_reason_n	Leaving the car
ENG125220-ENG125228	History last automatic terminal switch off-shutoff_reason_n-1	Leaving the car
ENG125220-ENG125231	History last automatic terminal switch off-shutoff_reason_n-2	Leaving the car
ENG125220-ENG125234	History last automatic terminal switch off-shutoff_reason_n-3	Leaving the car
ENG125220-ENG125237	History last automatic terminal switch off-shutoff_reason_n-4	Leaving the car
ENG129040-ENG129151	History_of_last _reset_reason-Last_1_reset_reason	ECUEXT_RR_WDGM_TEST_EARLY
ENG129040-ENG129152	History_of_last _reset_reason-Last_2_reset_reason	SBC_POWER_ON_RESET
ENG129040-ENG129153	History_of_last _reset_reason-Last_3_reset_reason	SBC_POWER_ON_RESET
ENG129040-ENG129154	History_of_last _reset_reason-Last_4_reset_reason	ECUEXT_RR_SCAN_PROCEDURE_TIMEOUTCONTROL
ENG129040-ENG129155	History_of_last _reset_reason-Last_5_reset_reason	ECUEXT_RR_WDGM_TEST_LATE
ENG129040-ENG129156	History_of_last _reset_reason-Last_6_reset_reason	ECUEXT_RR_WDGM_TEST_EARLY
ENG129040-ENG129157	History_of_last _reset_reason-Last_7_reset_reason	SBC_POWER_ON_RESET
ENG129040-ENG129158	History_of_last _reset_reason-Last_8_reset_reason	SBC_POWER_ON_RESET
ENG129040-ENG129159	History_of_last _reset_reason-Last_9_reset_reason	SBC_POWER_ON_RESET
ENG129040-ENG124545	History_of_last _reset_reason-Last_reset_reason	ECUEXT_RR_WDGM_TEST_LATE
ENG121906	Last_LIN_Message_Kessy	00 00 02 00 FE 00 00 00
ENG121907	Last_LIN_Message_LIN	00 00 04 00 80 FF FF FF
ENG26926-MAS00106	lf_shutdowns-Year	2000
ENG26926-MAS00107	lf_shutdowns-Month	0
ENG26926-MAS00108	lf_shutdowns-Day	0
ENG26926-MAS00109	lf_shutdowns-Hours	0
ENG26926-MAS00110	lf_shutdowns-Minutes	0
ENG26926-MAS00111	lf_shutdowns-Seconds	0
ENG26926-ENG32070	lf_shutdowns-Mileage_lf_shutdown_n	0	 km
ENG26926-ENG32071	lf_shutdowns-Mileage_lf_shutdown_n-1	0	 km
ENG26926-ENG32072	lf_shutdowns-Mileage_lf_shutdown_n-2	0	 km
ENG26926-ENG32073	lf_shutdowns-Mileage_lf_shutdown_n-3	0	 km
ENG120048	Overtemperaturecounter for ADRIMA	0
ENG129034-ENG129128	power_state_door_handle-power_state_bt	active
ENG129034-ENG129127	power_state_door_handle-power_state_ft	active
ENG129034-ENG129129	power_state_door_handle-power_state_hl	not active
ENG129034-ENG129130	power_state_door_handle-power_state_hr	not active
ENG129030	Request_steering_column_lock_terminal_approval	not requested
ENG108452	Reset_counter	14
ENG129033	s_anf_klemmenfreigabe_wfs	not requested
ENG126972	s_klemmenfreigabe_wfs	No enabling
ENG26348-ENG129140	Scan_cycle_data-Car_key_1	0
ENG26348-ENG129140	Scan_cycle_data-Car_key_1	1
ENG26348-ENG129141	Scan_cycle_data-Car_key_2	1
ENG26348-ENG129141	Scan_cycle_data-Car_key_2	0
ENG26348-ENG129142	Scan_cycle_data-Car_key_3	0
ENG26348-ENG129143	Scan_cycle_data-Car_key_4	0
ENG26348-ENG30036	Scan_cycle_data-Mileage_n	7544	 km
ENG26348-ENG30037	Scan_cycle_data-Mileage_n-1	7495	 km
ENG26348-ENG30038	Scan_cycle_data-Mileage_n-10	3793	 km
ENG26348-ENG30039	Scan_cycle_data-Mileage_n-11	3104	 km
ENG26348-ENG30040	Scan_cycle_data-Mileage_n-12	3104	 km
ENG26348-ENG30041	Scan_cycle_data-Mileage_n-13	3034	 km
ENG26348-ENG30042	Scan_cycle_data-Mileage_n-14	1549	 km
ENG26348-ENG30043	Scan_cycle_data-Mileage_n-15	1422	 km
ENG26348-ENG30044	Scan_cycle_data-Mileage_n-16	539	 km
ENG26348-ENG30045	Scan_cycle_data-Mileage_n-17	539	 km
ENG26348-ENG30046	Scan_cycle_data-Mileage_n-18	77	 km
ENG26348-ENG30047	Scan_cycle_data-Mileage_n-19	77	 km
ENG26348-ENG30048	Scan_cycle_data-Mileage_n-2	7223	 km
ENG26348-ENG30049	Scan_cycle_data-Mileage_n-3	6676	 km
ENG26348-ENG30050	Scan_cycle_data-Mileage_n-4	5961	 km
ENG26348-ENG30051	Scan_cycle_data-Mileage_n-5	4111	 km
ENG26348-ENG30052	Scan_cycle_data-Mileage_n-6	4063	 km
ENG26348-ENG30053	Scan_cycle_data-Mileage_n-7	3897	 km
ENG26348-ENG30054	Scan_cycle_data-Mileage_n-8	3797	 km
ENG26348-ENG30055	Scan_cycle_data-Mileage_n-9	3793	 km
ENG26348-ENG30076	Scan_cycle_data-Retry_count_n	8
ENG26348-ENG30077	Scan_cycle_data-Retry_count_n -6	9
ENG26348-ENG30078	Scan_cycle_data-Retry_count_n-1	9
ENG26348-ENG30079	Scan_cycle_data-Retry_count_n-10	9
ENG26348-ENG30080	Scan_cycle_data-Retry_count_n-11	10
ENG26348-ENG30081	Scan_cycle_data-Retry_count_n-12	9
ENG26348-ENG30082	Scan_cycle_data-Retry_count_n-13	6
ENG26348-ENG30083	Scan_cycle_data-Retry_count_n-14	14
ENG26348-ENG30084	Scan_cycle_data-Retry_count_n-15	9
ENG26348-ENG30085	Scan_cycle_data-Retry_count_n-16	10
ENG26348-ENG30086	Scan_cycle_data-Retry_count_n-17	9
ENG26348-ENG30087	Scan_cycle_data-Retry_count_n-18	28
ENG26348-ENG30088	Scan_cycle_data-Retry_count_n-19	9
ENG26348-ENG30089	Scan_cycle_data-Retry_count_n-2	10
ENG26348-ENG30090	Scan_cycle_data-Retry_count_n-3	15
ENG26348-ENG30091	Scan_cycle_data-Retry_count_n-4	9
ENG26348-ENG30092	Scan_cycle_data-Retry_count_n-5	9
ENG26348-ENG30093	Scan_cycle_data-Retry_count_n-7	16
ENG26348-ENG30094	Scan_cycle_data-Retry_count_n-8	19
ENG26348-ENG30095	Scan_cycle_data-Retry_count_n-9	0
ENG26348-ENG30114	Scan_cycle_data-Scan_reason_n	Passenger_door
ENG26348-ENG30115	Scan_cycle_data-Scan_reason_n-1	Driver_door
ENG26348-ENG30116	Scan_cycle_data-Scan_reason_n-10	Passenger_door
ENG26348-ENG30117	Scan_cycle_data-Scan_reason_n-11	Driver_door
ENG26348-ENG30118	Scan_cycle_data-Scan_reason_n-12	Driver_door
ENG26348-ENG30119	Scan_cycle_data-Scan_reason_n-13	trunk
ENG26348-ENG30120	Scan_cycle_data-Scan_reason_n-14	rear_left_door
ENG26348-ENG30121	Scan_cycle_data-Scan_reason_n-15	rear_right_door
ENG26348-ENG30122	Scan_cycle_data-Scan_reason_n-16	Passenger_door
ENG26348-ENG30123	Scan_cycle_data-Scan_reason_n-17	Passenger_door
ENG26348-ENG30124	Scan_cycle_data-Scan_reason_n-18	rear_left_door
ENG26348-ENG30125	Scan_cycle_data-Scan_reason_n-19	rear_left_door
ENG26348-ENG30126	Scan_cycle_data-Scan_reason_n-2	Driver_door
ENG26348-ENG30127	Scan_cycle_data-Scan_reason_n-3	Driver_door
ENG26348-ENG30128	Scan_cycle_data-Scan_reason_n-4	Driver_door
ENG26348-ENG30129	Scan_cycle_data-Scan_reason_n-5	Driver_door
ENG26348-ENG30130	Scan_cycle_data-Scan_reason_n-6	Passenger_door
ENG26348-ENG30131	Scan_cycle_data-Scan_reason_n-7	Driver_door
ENG26348-ENG30132	Scan_cycle_data-Scan_reason_n-8	Driver_door
ENG26348-ENG30133	Scan_cycle_data-Scan_reason_n-9	Passenger_door
ENG26348-ENG30134	Scan_cycle_data-Scan_trigger_n	Reset_stop_car
ENG26348-ENG30135	Scan_cycle_data-Scan_trigger_n-1	Set_stop_car
ENG26348-ENG30136	Scan_cycle_data-Scan_trigger_n-10	Set_stop_car
ENG26348-ENG30137	Scan_cycle_data-Scan_trigger_n-11	Reset_stop_car
ENG26348-ENG30138	Scan_cycle_data-Scan_trigger_n-12	Set_stop_car
ENG26348-ENG30139	Scan_cycle_data-Scan_trigger_n-13	Reset_stop_car
ENG26348-ENG30140	Scan_cycle_data-Scan_trigger_n-14	Reset_stop_car
ENG26348-ENG30141	Scan_cycle_data-Scan_trigger_n-15	Set_stop_car
ENG26348-ENG30142	Scan_cycle_data-Scan_trigger_n-16	Reset_stop_car
ENG26348-ENG30143	Scan_cycle_data-Scan_trigger_n-17	Set_stop_car
ENG26348-ENG30144	Scan_cycle_data-Scan_trigger_n-18	Reset_stop_car
ENG26348-ENG30145	Scan_cycle_data-Scan_trigger_n-19	Set_stop_car
ENG26348-ENG30146	Scan_cycle_data-Scan_trigger_n-2	Reset_stop_car
ENG26348-ENG30147	Scan_cycle_data-Scan_trigger_n-3	Reset_stop_car
ENG26348-ENG30148	Scan_cycle_data-Scan_trigger_n-4	Set_stop_car
ENG26348-ENG30149	Scan_cycle_data-Scan_trigger_n-5	Set_stop_car
ENG26348-ENG30150	Scan_cycle_data-Scan_trigger_n-6	Set_stop_car
ENG26348-ENG30151	Scan_cycle_data-Scan_trigger_n-7	Set_stop_car
ENG26348-ENG30152	Scan_cycle_data-Scan_trigger_n-8	Reset_stop_car
ENG26348-ENG30153	Scan_cycle_data-Scan_trigger_n-9	Set_stop_car
ENG125222-ENG129124	Selective_catalytic_reduction-Possible_Engine_Start	OK
ENG125222-ENG129123	Selective_catalytic_reduction-SCR_install_state	not installed
ENG129035-MAS00106	service_key_internal_status-Year	2019
ENG129035-MAS00106	service_key_internal_status-Year	2000
ENG129035-MAS00107	service_key_internal_status-Month	9
ENG129035-MAS00107	service_key_internal_status-Month	0
ENG129035-MAS00108	service_key_internal_status-Day	0
ENG129035-MAS00108	service_key_internal_status-Day	7
ENG129035-MAS00109	service_key_internal_status-Hours	7
ENG129035-MAS00109	service_key_internal_status-Hours	0
ENG129035-MAS00110	service_key_internal_status-Minutes	23
ENG129035-MAS00110	service_key_internal_status-Minutes	0
ENG129035-MAS00111	service_key_internal_status-Seconds	32
ENG129035-MAS00111	service_key_internal_status-Seconds	0
ENG129035-MAS00111	service_key_internal_status-Seconds	31
ENG129035-ENG129135	service_key_internal_status-checksum_comparison_service_key1	OK
ENG129035-ENG129136	service_key_internal_status-checksum_comparison_service_key2	not OK
ENG129031	Steering_column_lock_terminal_approval	No enabling
ENG125218	Suppression_ignition_message	not activated
ENG129036	To_block_terminal_upshift	not active
ENG129037	Trigger_terminal_deactivation_central_locking	not activated
ENG129038	Valid_time_control_section_diagnostics	0	 s
ENG08630-ENG09181	WFS_key_signature-clap_15_activateing_signature	2
ENG08630-ENG09176	WFS_key_signature-signature_key_1	07 77
ENG08630-ENG09177	WFS_key_signature-signature_key_2	00 FC
ENG08630-ENG09178	WFS_key_signature-signature_key_3	00 00
ENG08630-ENG09179	WFS_key_signature-signature_key_4	00 00
ENG08630-ENG09180	WFS_key_signature-signature_key_5	00 00
Elapsed Time: 01:06
Lot of channels are not accessible and the adaptation channels look completely different. I guess VCDS is not able to read it anymore? Should I start looking for ODIS?
Uhm, the second map in the post above looks more like a Measuring Value Map than an Adaptation Channel map.
OEMplusCC
C?ID=160054
What did I screw up selecting check boxes? I'm pretty sure I picked Adaptation but Ill double check. Thanks
OEMplusCC
C?ID=160054
Hi Uwe
I double checked and I was reading adaptation channels correctly. I figured out that the weird behavior was caused by having "Easy Open option" enabled in the infotainment system. I know, weird but read my full post here to get the full picture what I'm doing.
https://forums.ross-tech.com/showth...-Open-Retrofit&p=176122&viewfull=1#post176122
Any help is appreciated, please post to my main thread. I feel like keeping that info together will be useful for others :thumbs:
