I have a someone with a 2007 MK5 Jetta who has an interesting issue with his Halogen high beams (these are non-BiXenon headlights). The issue is that whenever he switches on the high-beams, they stay on for only a few seconds before going out, leaving only the low-beams lit. The issue is noted in both the Live Data, and during and the Output test. The relays, and fuses in the engine bay and under the dashboard were individually checked and swapped out for good measure. Can someone look at the Auto Scan below, and tell me if there is an issue with the coding?
Thursday,25,October,2018,19:01:40:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VirtualBox)
VCDS Version 18.9.0.2
VIN: WVWZZZ1KZ7M193560 License Plate: OCT 31,18
Mileage: 139220km-86507mi Repair Order:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ7M193560 Mileage: 139220km-86507miles
44-Steering Assist -- Status: Cannot be reached 1100
Address 01: Engine Labels: None
Part No SW: 03B 906 021 NH HW: 06G 906 024 AN
Component: R4 1)9L EDC%G000AG% 9245
Revision: --H07-(- Serial number: VRZ7Z0G9582302
Coding: 0000078
Shop #: WSC 65602 002 00000
VCID: 6DD7BFEF74132C49B4D-8038
005785 - Powertrain Data Bus
P1699 - 005 - Missing Message from Steering Wheel Electronics
001384 - Cruise Control Switch (E45)
P0568 - 008 - Implausible Signal - Intermittent
Readiness: 0 5 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 043 N HW: 02E 927 770 AE
Component: GSG DSG 081 1306
Revision: 04508010 Serial number: 00000703290241
Shop #: WSC 00066 000 00000
VCID: 1F4B9527CE3F0ED9761-804A
18275 - Powertrain Data Bus
P1867 - 000 - Missing Message from Steering Wheel (J527)
Fault Frequency: 255
Mileage: 139216 km
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021121
Shop #: WSC 02366 000 00000
VCID: 73E3A9971237FAB9629-8026
01487 - System Function Test
01486 - System Function Test Activated
Part No SW: 1K0 820 047 FT HW: 1K0 820 047 FT
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
VCID: 7BF381B73A67B2F93A9-802E
Address 09: Cent. Elect.
Component: 2K AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD16W1Y.
Coding: 0012875
VCID: 3D774FAF64F37CC944D-8068
Subsystem 1 - Serial number: 6332MSME194E2652E
Subsystem 2 - Serial number: 6342MSME187A5F3DY
Subsystem 3 - Serial number: 6351HSME0D2D33001
Subsystem 4 - Serial number: 6361HSME0D384E15G
Part No SW: 1K0 953 549 AP HW: 1K0 953 549 AP
Component: Lenksäulenmodul 636 0070
Coding: 0010011
VCID: 0009F65B5381D1216FB-8055
Part No SW: 1K0 920 963 B HW: 1K0 920 963 B
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0G9082302
Coding: 0019403
Shop #: WSC 00011 888 96745
VCID: 2B5371F78A87E279EA9-807E
Fault Frequency: 11
Reset counter: 113
Mileage: 139216 km
Time: 02:22:49
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 280407F1001008
Coding: 3F3F034007001003
VCID: 2F6B65E7BE9F9E59C61-807A
Reset counter: 112
Mileage: 139216 km
Time: 02:23:26
Component: IMMO 3HL 1610
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1134
Revision: 32008001 Serial number: 00000078178512
Coding: 0000692
VCID: 3B7341B77AE772F97A9-806E
Address 44: Steering Assist
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 81900A000106087F2D068F0DF0085FC6D0F8A0
Shop #: WSC 00066 123 12345
VCID: 0303F9574297CA39729-8056
Subsystem 2 - Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Subsystem 3 - Part No: 1K0 951 178 A
Component: Innenraumueberw.003 0203
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1134
Revision: 32008001 Serial number: 00000559178402
Coding: 0000692
VCID: 3C7142AB7FE975C1733-8069
00097 - Front Passengers Central Locking (Safe) Motor (V162)
Fault Status: 01101100
Reset counter: 114
Fault Status: 01101000
Reset counter: 114
Mileage: 139216 km
Part No SW: 1K0 035 186 T HW: 1K0 035 186 T
Component: Radio BVX 034 0046
Revision: 00034000 Serial number: VWZ1Z2G4744338
Coding: 0040400
Shop #: WSC 00066 123 00000
VCID: 377B5D8746CF56999E1-8062
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1120
Revision: 11006001 Serial number: 00000001621724
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1120
Revision: 11006001 Serial number: 00000001625519
Coding: 0000144
VCID: 3E7548A369F567D15D7-806B
Reset counter: 114
Mileage: 139216 km
End-------------------------(Elapsed Time: 02:34)--------------------------
