MK5 Jetta Halogen headlight issue with high beam
NitrousOxide
Jamaica
C?ID=269481
I have a someone with a 2007 MK5 Jetta who has an interesting issue with his Halogen high beams (these are non-BiXenon headlights). The issue is that whenever he switches on the high-beams, they stay on for only a few seconds before going out, leaving only the low-beams lit. The issue is noted in both the Live Data, and during and the Output test. The relays, and fuses in the engine bay and under the dashboard were individually checked and swapped out for good measure. Can someone look at the Auto Scan below, and tell me if there is an issue with the coding?
Thursday,25,October,2018,19:01:40:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VirtualBox)
VCDS Version 18.9.0.2
VIN: WVWZZZ1KZ7M193560   License Plate: OCT 31,18
Mileage: 139220km-86507mi   Repair Order:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ7M193560   Mileage: 139220km-86507miles
44-Steering Assist -- Status: Cannot be reached 1100
   Part No SW: 03B 906 021 NH    HW: 06G 906 024 AN
   Component: R4 1)9L EDC%G000AG% 9245
   Revision: --H07-(-    Serial number: VRZ7Z0G9582302
   Coding: 0000078
   Shop #: WSC 65602 002 00000
   VCID: 6DD7BFEF74132C49B4D-8038
005785 - Powertrain Data Bus
               P1699 - 005 - Missing Message from Steering Wheel Electronics
001384 - Cruise Control Switch (E45)
               P0568 - 008 - Implausible Signal - Intermittent
Readiness: 0 5 0 0 0
   Part No SW: 02E 300 043 N    HW: 02E 927 770 AE
   Component: GSG DSG         081 1306
   Revision: 04508010    Serial number: 00000703290241
   Shop #: WSC 00066 000 00000
   VCID: 1F4B9527CE3F0ED9761-804A
18275 - Powertrain Data Bus
            P1867 - 000 - Missing Message from Steering Wheel (J527)
                    Fault Frequency: 255
                    Mileage: 139216 km
   Revision: 00H11001
   Coding: 0021121
   Shop #: WSC 02366 000 00000
   VCID: 73E3A9971237FAB9629-8026
01487 - System Function Test
            000 -  -  - Intermittent
01486 - System Function Test Activated
            000 -  -
   Part No SW: 1K0 820 047 FT    HW: 1K0 820 047 FT
   Component: Climatic PQ35   141 0909
   Revision: 00141027    Serial number: 00000000000000
   VCID: 7BF381B73A67B2F93A9-802E
Address 09: Cent. Elect.
   Component: 2K AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD16W1Y.
   Coding: 0012875
   VCID: 3D774FAF64F37CC944D-8068
   Subsystem 1 - Serial number: 6332MSME194E2652E
   Subsystem 2 - Serial number: 6342MSME187A5F3DY
   Subsystem 3 - Serial number: 6351HSME0D2D33001
   Subsystem 4 - Serial number: 6361HSME0D384E15G
   Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
   Component: Lenksäulenmodul 636 0070
   Coding: 0010011
   VCID: 0009F65B5381D1216FB-8055
            000 -  -
   Part No SW: 1K0 920 963 B    HW: 1K0 920 963 B
   Component: KOMBIINSTRUMENT 3HL 1610
   Revision: V0003000    Serial number: VWZ7Z0G9082302
   Coding: 0019403
   Shop #: WSC 00011 888 96745
   VCID: 2B5371F78A87E279EA9-807E
                    Fault Frequency: 11
                    Reset counter: 113
                    Mileage: 139216 km
                    Time: 02:22:49
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 280407F1001008
   Coding: 3F3F034007001003
   VCID: 2F6B65E7BE9F9E59C61-807A
                    Reset counter: 112
                    Mileage: 139216 km
                    Time: 02:23:26
   Component: IMMO            3HL 1610
   Component: J386  TUER-SG FT    1134
   Revision: 32008001    Serial number: 00000078178512
   Coding: 0000692
   VCID: 3B7341B77AE772F97A9-806E
Address 44: Steering Assist
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 81900A000106087F2D068F0DF0085FC6D0F8A0
   Shop #: WSC 00066 123 12345
   VCID: 0303F9574297CA39729-8056
   Subsystem 2 - Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Subsystem 3 - Part No: 1K0 951 178 A
   Component: Innenraumueberw.003 0203
   Component: J387  TUER-SG BT    1134
   Revision: 32008001    Serial number: 00000559178402
   Coding: 0000692
   VCID: 3C7142AB7FE975C1733-8069
00097 - Front Passengers Central Locking (Safe) Motor (V162)
                    Fault Status: 01101100
                    Reset counter: 114
                    Fault Status: 01101000
                    Reset counter: 114
                    Mileage: 139216 km
   Part No SW: 1K0 035 186 T    HW: 1K0 035 186 T
   Component: Radio BVX       034 0046
   Revision: 00034000    Serial number: VWZ1Z2G4744338
   Coding: 0040400
   Shop #: WSC 00066 123 00000
   VCID: 377B5D8746CF56999E1-8062
            000 -  -
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1120
   Revision: 11006001    Serial number: 00000001621724
   Coding: 0000144
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1120
   Revision: 11006001    Serial number: 00000001625519
   Coding: 0000144
   VCID: 3E7548A369F567D15D7-806B
                    Reset counter: 114
                    Mileage: 139216 km
 End-------------------------(Elapsed Time: 02:34)--------------------------
Since the BCM didn't talk in this scan, its coding isn't visible...
NitrousOxide
Jamaica
C?ID=269481
I have another scan earlier in which it did:
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl   Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000000637801
   Coding: E4010E2700041500470A00000F000000000859035C0000
   VCID: 6BD3B1F74A072279AA9-803E
   Component: Wischer 060607 020  0501
   Coding: 00038805
   Shop #: WSC 12345
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     230407 020  0105
   Coding: 00208933
   Shop #: WSC 12345
                    Fault Status: 01111100
                    Reset counter: 67
                    Mileage: 137830 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.05 V
                    Fault Status: 00101100
                    Fault Frequency: 19
                    Reset counter: 92
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.95 V
                    Fault Frequency: 16
                    Reset counter: 107
                    Mileage: 137759 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.40 V
            007 - Short to Ground
                    Fault Status: 01110111
                    Reset counter: 67
                    Mileage: 137804 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.10 V
                    Reset counter: 67
                    Mileage: 138625 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.95 V
Both high-beams do actually come on during this period
Trowbridge, UK
Seems the right high beam bulb is taking too much current - which triggers the bulb failure system to turn the high beam off and log the fault.
Are standard power bulbs fitted, or have uprated higher power bulbs been fitted?
NitrousOxide
Jamaica
C?ID=269481
These are standard H7 12 Volt 55 Watt bulbs. Cycled through Phillips, Osram, and Sylvania branded bulbs to be sure.
Trowbridge, UK
Sounds like time to check the wiring to the right main beam for shorts to ground. Remove/unplug the bulb and trace/check with a meter.
I agree, The right side wiring should be checked.
Next, I couldn't locate a single scan in our collection with that 09 coding so I suspect it isn't correct. The following appear to be common coding strings for non-Xenon cars with 3C0 937 049 AD:
NAR VINs with 3C0 937 049 AD:
14058E234004150007140000001400000008730B5C0000
RoW (ZZZ) VINs with 3C0 937 049 AD:
E48D0F2700041500471400001400000000087B075C0001​
If you were to use one of those as a baseline and fine tune it with the LCH please start with the RoW market value.
Lastly, the faults in 16
Coding: 0010011
.. may be worth looking into since the High beak stalk signal is sent through it in addition to the 01-Engine module being unhappy about the configuration:
I did NOT confirm the installed 1K0 953 549 AP module is correct for the vehicle but I think the coding should be 0011041:
0?xxxxx: Vehicle Type
0 = Normal​
0x?xxxx: Transmission
1 = Automatic Transmission​
0xx?xxx: Steering Wheel
1 = 3-Spoke Steering Wheel without Multifunction​
0xxx?xx: Additional Equipment
N/A​
0xxxx?x: Board Computer / Cruise Control System (CCS)
4 = with Board Computer and with Cruise Control System (CCS)​
0xxxxx?: Rear Wiper
1 = Rear Wiper not installed​
Gone But Not Forgotten
It is Dana for legacy yeah........
Retrofits............?
Yeah that BCM 0x09 & steering 0x16 has been superseded like a ton of times!
FOD!
or
BCM is toasters possibly in addition to wiring issue.
Vehicle Identification No.WVWZZZ1KZ7M193560
ModelJetta
JE
Date of production14.06.2007
Year2007
Sales type1K212C
Engine CodeBXE
Transmission CodeJPL
Axle drive6A
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PCWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation units/platform components0HMVehicle class differentiation -1KM- Build status corresponds to production in Mexico
tail pipe0P0Rear exhaust tailpipe (standard)
drive-off assistanceUG0Without hill start assist/hill descent control/comfort driving assist
Emission standard0GGEmission standard EU4
Trailer hitch1D0without trailer towing
airbag4UFAirbag for driver and front passenger with front passenger airbag deactivation
Aktivkohlebehälter / Ottopartikelfilter1E0Without activated charcoal canister
Aerials8ZHAntenna for AM/FM reception, "diversity"
Exterior mirror setting6XNExterior mirrors, power-adjustable/ separately heated
Left exterior mirror5SJLeft exterior mirror, convex
Right exterior mirror5RVRight exterior mirror, aspherical
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WCWithout "Multimedia" in vehicle
Equipment levelsA8CComfort equipment
Brake type in rear1KFDisc brakes in rear
batteriesJ1DBattery 380 A (72 Ah)
Brake type, front1ZMDisc brakes in front (Geomet D)
Components with special surface6FFExterior mirror housing and various attachments colour coded to vehicle
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0NComponent parts set, complying with vehicle type for Great Britain, various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VFInformation kit in English
Operating voltage9Z0Operating voltage 12 V
brake wear indicator9U1brake wear indicator
Heated washer nozzles9T0Without heated washer nozzles
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
Chrome packageQJ1Chrome package
General operating permit, alterationsC08Operating permit, alteration
Roof rails/roof load rack3S0Without roof rails/roof load rack
Roof insert/convertible top3FAroof without cut out
Suspension system in rear1JARear shock absorption, basic design 1
Suspension system in frontG56Shock absorption in front
Load-through hatch/ski bag3X0without load through system
Insert for the filling up of unleaded fuel/fuel type2G5Filler neck module 1 without insert
Installation differentiation for components0ESInstallation differentiation for transmission DQ250 -- vehicle components --
Theft protection system7ALAnti-theft alarm system, interior monitoring, backup horn and towing protection
Inserts5MADecorative inserts
Scuff plates7M5Without impact protection film for door sill
Park distance control7X0Without park distance control
Electric interface for external useUF0Without electric interface
Manufacturing sequence differentiation0FLMexico manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Without extended pedestrian protection measures
Pedal clusterVF0Standard pedal cluster
Headlight activation8K8Low beam assistant with "Coming Home" function
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Weight category rear axle0YFWeight range 6 installation control only, no requirement forecast
Weight category front axleL13Suspension range 13 installation control only, no requirement forecast
Base engineT714-cylinder diesel engine 1.9 l unit 03G.1
Luggage netting/pocket on backrest(s)4U5Luggage pockets on backrest
Luggage compartment cover3U0Without luggage compartment cover
cruise control system8T2Electronic cruise control system (CCS)
Garage door openerVC0without Garage door opener
Luggage compartment trim5A7Comfort luggage compartment trim with service lid/snap-on cover
Transmission specificationsG1A6-speed automatic transmission
Brackets3P1Bracket for first aid kit and warning triangle
handle for hand brake lever6PChandbrake lever grip (leather)
Rear spoiler5J0Without rear spoiler
Rear window wiper and washer system8M0Without rear window wiper and washer system
Rear seats3KBUnsplit rear seat bench, split folding backrest, with center armrest
Heating and air-conditioning system9APClimatic air-conditioning system (semi-automatic)
Headlamps8BKTwin headlamps for driving on the left, with integrated high beam
Customized installationFC0Without individual installation
Interior light in footwell6T1Interior light in footwell
Instrument clustersU5BInstrument insert, mph speedometer Great Britain
Breakaway interior rearview mirror4L6Breakaway interior rearview mirror, auto-dimming
Sticker (customized or special edition)0KAWithout decals and emblems
Body styleK8BNotchback
Cassette and CD storage unit4W0without cassette / CD tray
coolbox1W2Glove compartment cooling system
Electronic map cooling systemQS0Without electronic map cooling system
Child seatsQA0without child seat
Climatic zones0Y1Standard climatic zones
Compass/road sign displayQR0Without compass
headrest for seat, rear3T2Three rear head restraints
Head restraints3J1Hight-adjustable head restraints for front seats
Fuel tank treatment2LDFuel tank without differentiation of special material treatment (fluorination/co-extrusion)
Fuel quantity for initial filling1Z2Increase in initial standard fuel filling
Fuel systems0F8Cooled fuel system for diesel engine
Body measures5C0Without special body measures
Child seat anchors in front3G0Without child seat anchora in front (ISOFIX)
Rear license plate bracket6P1Rear license plate carrier (ECE)
Front license plate bracket6W1Front license plate carrier (large)
Paint preservative/transit coating5K5Transport protection film with additional transport protection measures
Paint coatingFB0standard paint coating
Rear cargo area3GAWithout luggage compartment floor
Steering system arrangementL0RRight-hand drive
Reading lamp8S4Two reading lights front, two rear
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H0Without backrest release for front seats
Air duct, front areaVK0Air duct, standard
Load edge protection2P1Plastic loading edge protection
Lumbar support7P4Manually adjustable lumbar support in front seats
steering wheels1MHLeather-wrapped steering wheel
Speaker installation8RM8 speakers (passive)
Headlight range control8Q1Headlight range control
Center armrest6E3Front center armrest
Multi-function display/trip computer9Q1Multi-function display/trip computer
Engine cooling8Z5not hot country
Engine specificationsD3W4-cyl. turbo diesel engine 1.9 l/77 kW TDI with unit-injector system base engine is T71/TG0/TD0/T5X
Left vanity mirror4SDVanity mirror, left, illuminated
Right vanity mirror4TDVanity mirror, right, illuminated
Navigation device7Q0without navigation system
rear fog lamp8TDRear fog light for driving on the left
Front fog lamp/additional headlamp8WAWithout fog lights
Rear of platform module base4P1Rear floor panel module, type 2
Platform group class7PAPlatform group class 1
Hubcaps1NLTrims for alloy wheels
WheelsCM5Alloy wheels 6.5J x 16
Radios8YLRadio with CD player
Smoker's/non-smoker's package9JBSmoker's package, ashtrays in front and rear
Tire pressure monitoring system7K0Without tyre pressure monitor
tireHH7Tires 205/55 R16 91V
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G2Spare wheel with full tyre, steel
Restraint systems, front3QT3-point seat belts in front, with tensioner and height adjustment
P15"Light & Sight" package
RCC"RCD 300", 4 x 20 W, 8 loudspeakers front and rear
WD2Anti-theft alarm system "Plus" incl. single door opening
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q2Gearshift knob/handle in leather
Special labels/plates0SSLabels in English and French
Locking mechanism for boot lid/cover rear4E0Tailgate/trunk lid unlocking from outside
Front seat, left3TFFront left comfort seat
Front seat, right3SFComfort seat, front right
Nameplates for sales nameQD3Lettering for sales name
Seat belt check9P3Seat belt reminder, electric contact in buckle
Outer rear seat belts3ZB3-point seat belts, outer rear with ECE label
Center rear seat belts3C73-point seat belt for center rear seat
seat coversN3LCircular-knit velour seat covers
Seat adjustment3L3Manual height adjustment for front seats
seat heater4A0without seat heater
Safety head restraint system3K0w/o safety head restraint system
Side lights7R3Side turn signal lights (white)
Horns8Y1Two-tone horn
Side and rear windows4KCSide and rear windows in heat-insulating glass
Protective side molding4B0with no protective side strip
Sunroof roller blind for rear/side windows3Y0without roller blind
Supertone system and tone sequence control9J0Without supertone system and tone sequence control
power outlet7B212 volt socket in luggage compartment
Bumper2JCComfort bumpers
Rear stabilizer0BGRear stabilizer
Front stabilizer bar0AGFront stabilizer bar
Drawers under front seatsQN3Drawers under front seats
Heavy-duty/sports version2UAStandard design
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N3intermittent windscreen wiper with rain sensor
Nameplate set1DGNameplate set "TDI"
Special alarm systems9A0Without taxi alarm system
Door storage compartments in front3YRDoor pockets with insert mats
Mass damper for steering wheels1Q1Mass damper for steering wheel, 26.5Hz
Door and lid locking system4K3Central locking w/ radio remote control, interior controls and SAFELOCK
Type approval countries/countries with special requirementsB09Type approval country GB/Northern Ireland
Carrier frequency for remote control5D1Carrier frequency 433.92 to 434.42 Mhz
Partition3CAwithout partition
Door and side trim panels4AFDoor and side trim panel in foam film and woven fabric
doors0A24 doors
TV reception/digital radio receptionQV0without TV/digital radio reception
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EXSpecial identification plate for EU
Delivery equipment2A8Delivery equipment, water border
First aid kit / warning triangle1T0Without first-aid material, without warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Preparation for rotating beacon/siren combination9F0Without preparation for rotating beacon/siren combination
Telephone / telematics9W0Without car phone preparation/ installation
Additional warning lights9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG1LongLife Service Regime
Heat accumulator system/auxiliary heater7E6electric air additional heater
Windshield Glass4GFWindshield in heat-insulating glass
Washer fluid level indicator8W0without washer water level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Additional body panels, side6EAWithout additional side body covers (stone guard)
Additional child seat anchors3B4Child seat anchors for child seat system ISOFIX
Auxiliary heating system9M0Without auxiliary heater/parking heater
