Q2 - Visual Parking
LukeLewis24
C?ID=271228 (NRRT)
Hi All,
I have a Q2 that has the rear parking sensors fitted.
On the A3's you had the option used coding to turn on the visual parking onto the screen.
I do the same process but cant seem to do this on the Q2, has anyone managed to figure out the coding?
Many thanks!!
Scan is below
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
VIN: WAUZZZ8V8EA015023   Mileage: 40326km-25057miles
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 5514
   Revision: 83H22---
   Coding: 02190012030501082000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
   ROD: EV_ECM20TDI01104L906021DS_002.rod
   VCID: 79F983BAF8F4DE8C60-802C
18115 - Oxygen (Lambda) Sensor B1 S1
          P0132 00 [032] - Signal too High
21125 - Invalid Data Received from Airbag Control Module
          U0452 00 [032] - -
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Revision: 00000000    Serial number: 61603000000176
   Coding: 12F18AA224210A710177060241C6294851245080608294F2006100040508
   ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
   VCID: 7BF599B2F2C8EC9C72-802E
   Part No SW: 8V0 820 043     HW: 8V0 820 043
   Component: AC Automat    H13 0031
   Revision: 20021000    Serial number: 00000000098454
   Coding: 03100104002000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
   VCID: 6FEDBDE2B6B0803CCE-803A
   Serial number: 9D19CFA6000000000001
329988 - Motor for Defroster Flap
          B1090 71 [008] - Actuator stuck
                    Reset counter: 25
                    Mileage: 39465 km
                    Date: 2018.05.26
                    Time: 11:10:13
                    Voltage terminal 30: 14.5 V
                    Interior temperature: 16.0 °C
                    Outside air temperature: 16 °C
                    Defroster flap: specified value: 70
                    Defroster flap: actual value: 0
                    Defroster flap: actual value: 0.0 %
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011316201669
   Coding: 07000A42C24120DD03844004B31C07A80000000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 77FD8582CEE0C8FC16-8022
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130521  041 0580
   Serial number:         130601090809
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8V0 941 531 J    HW: 8V0 941 531 J
   Serial number: 13 04 2013  00000986
   Subsystem 3 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY1313529MY
   Serial number: 00000000000056922016
   Subsystem 5 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Component: G355_FeuchteS  H07 0002
   Serial number: 20401466
267030 - Siren / Alarm Horn for Anti-Theft Alarm System
          U1137 00 [008] - Implausible Message
                    Reset counter: 50
                    Mileage: 1048574 km
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H09 0033
   Revision: --------    Serial number: 60831315901380
   Coding: 0000050001
   ASAM Dataset: EV_EPHVA14AU3700000 002018
   ROD: EV_EPHVA14AU3700000_002_AU37.rod
   VCID: 387F46BE837E0784DF-806C
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    011 0361
   Serial number: 003M2R01VTVH
   Coding: 98CCC0000C0000005C5400CA00C800000065
   VCID: 4B950972E2E89C1C82-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 002 905 13
   Serial number: 3576700000005D813D0S
   Subsystem 2 - Part No SW: -----------    HW: 480 002 905 13
   Serial number: 3586700000024D813D0U
   Subsystem 3 - Part No SW: -----------    HW: 480 400 806 13
   Serial number: 3516502AD10CBDF2131I
   Subsystem 4 - Part No SW: -----------    HW: 480 400 806 13
   Serial number: 3526502AB10CBDF2510I
   Subsystem 5 - Part No SW: -----------    HW: 480 402 404 13
   Serial number: 3556502A50FEADA3924Z
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 506 13
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502A110CBDF271BN
   Subsystem 7 - Part No SW: -----------    HW: 480 400 506 13
   Component: PedP_Sensor_P  001 6149
   Serial number: 22965029F10CBDF5438-
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 400 506 13
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502AB10CBDF152DQ
   Part No SW: 8V0 953 521     HW: 5Q0 953 549 A
   Revision: --------    Serial number: 10061304400191
   Coding: 8418
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   Part No SW: 8V0 920 970 N    HW: 8V0 920 970 N
   Component: KOMBI         H03 2210
   Coding: 278509002A8046000100EA00000000
   VCID: 479D3542FE80787CA6-8012
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0000684275
   Coding: 030100040B0876005B000248080B00000001000000000000000000000000
   ROD: EV_GatewLear_009_VW37.rod
   VCID: 3B7559B2B2482C9C32-806E
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 02 06 2013  B0199807
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004050393708
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 25051306070500
   Coding: 00108E204001040000001002
   VCID: 3F8D2DA2A65030BC1E-806A
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 81
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D7157AAAC5C22AC0C-8068
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 24051303110882
   Coding: 001086204001040000001002
   VCID: 3E7350A6A15A39B415-806A
65578 - Motors for Central Locking
          B122B 12 [008] - Short to Plus
                    Fault Frequency: 142
                    Reset counter: 57
                    Mileage: 38963 km
                    Date: 2018.04.25
                    Time: 10:28:43
65579 - Motors for Central Locking
          B122B 11 [009] - Short to Ground
                    Fault Frequency: 46
                    Reset counter: 17
                    Mileage: 38923 km
                    Date: 2018.04.24
                    Time: 11:51:52
65593 - Switch for Central Locking
          B122D 29 [009] - Signal Implausible
                    Fault Frequency: 62
                    Reset counter: 16
                    Mileage: 38949 km
                    Date: 2018.04.25
                    Time: 10:08:15
   Component: LWR-ECU       005 0070
   Coding: 019C000001000000
   VCID: 75E18F8AD4ECBAEC04-8020
   Part No SW: 8V0 035 874 A    HW: 8V0 035 874
   Component: MU-S-ND-ER    040 0370
   Serial number: A7F00206131660
   Coding: 01730301FF00000021111101000A00002F0004460100010006
   ASAM Dataset: EV_MUStd4CPASE 002018
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 3A7B5CB6BD72159429-806E
   Subsystem 1 - Part No SW: 8V0 919 866 A    HW: -----------
   Component:  ECE 2013  --- 0021
   Subsystem 2 - Part No SW: 8V0 919 603 A    HW: 8V0 919 603 A
   Component: DU Std  H47 0013
   Serial number: AUZ8Z9DG6014A3
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000017041300010679
   Part No SW: 5Q0 959 595 A    HW: 5Q0 959 595
   Component: TSG HFS       010 0006
   Serial number: 30051304080693
   Coding: 000086204001040000001002
   VCID: 41892B5AD0A4464C68-8014
   Component: TSG HBFS      010 0006
   Serial number: 30051301100696
End-------------------------(Elapsed Time: 03:56)--------------------------
hadez16
C?ID=289891
Since 2016 respectively since the introduction of MIB2 this is not possible anymore in the Audi world.
Don't ask why, I don't know ;)
Your scan seems to be from an A3 8V.
