VW Golf Mk7 Folding Mirrors -Rear Pass Window Error
LukeLewis24
C?ID=271228 (NRRT)
Hi all, wondering if anyone can help.
I fitted folding wing mirrors to my 5 door golf and had to change the two door modules to allow the movements as the old module didn't allow.
I thought I had fitted the correct ones but the rear window (Passenger side) now does not work on the divers door controller or the rear passenger door itself.
Can anyone elaborate on what I have missed? or what part number door modules I need if I got he wrong ones?
Many thanks!!
Scan of the car is below
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZFP007976   Mileage: 39506km-24547miles
Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 N    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 7636
   Revision: 84H22---
   Coding: 01250012036505092000
   Shop #: WSC 00028 028 00071
   ASAM Dataset: EV_ECM16TDI01104L906021N 002012
   ROD: EV_ECM16TDI01104L906021N_002.rod
   VCID: 306F7E9E6B0EDFC497-8064
   Part No SW: 0CW 300 047 R    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5201
   Revision: 00043014    Serial number: CU501406187039
   Shop #: WSC 00028 028 00067
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 4A9B0C76ED928514B9-801E
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 907 379 M    HW: 5Q0 907 379 H
   Component: ESC           H31 0571
   Revision: 00000000    Serial number: 61804000000623
   Coding: 01FA8AA1142009730380060741C92580512890C06082A4F3F842F078C202
   VCID: 46833846F98A61745D-8012
8352 - Databus
                    Fault Frequency: 217
                    Reset counter: 172
                    Mileage: 36421 km
                    Date: 2018.06.29
                    Time: 16:12:35
16401 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Reset counter: 155
                    Mileage: 39116 km
                    Date: 2018.10.06
                    Time: 08:08:30
   Part No SW: 5G0 907 426 Q    HW: 5G0 907 426 Q
   Component: AC Manuell    H02 0907
   Revision: 00001K06
   Coding: 00120104202100001000000000000000
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: 397943BAB8741E8C20-806C
   Part No SW: 5Q0 937 084 AG    HW: 5Q0 937 084 AG
   Component: BCM MQBAB M   H18 0134
   Serial number: 01011416902088
   Coding: 03001842C24102730BA44080B10403281000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7DF197AAECDCE2AC4C-8028
   Component: WWS    140617  042 0551
   Serial number:         140621103524
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S3Y14M07D01H04M35S07
   Coding: 00A8DD
   Serial number: 000000000ZY1414629M6
   Serial number: 00000000000059976875
          B1263 01 [008] - Electrical Failure
                    Fault Frequency: 12
                    Reset counter: 171
                    Mileage: 1048574 km
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Serial number: 01071403210549
   Coding: 001C1300FE0739
   VCID: 387F46BE837E0784DF-806C
1542 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
                    Reset counter: 150
                    Mileage: 38664 km
                    Date: 2018.09.17
                    Time: 17:15:28
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 14.4 V
                    Vehicle speed: 2.29 m/s
                    Acceleration: 0.28 m/s²
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR06MW9D
   Shop #: WSC 00028 028 00055
   VCID: 7F0D6DA2E6D0F0BC5E-802A
   Belt Pretensioner left:
   Serial number: 34169677B01071470211
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676B30061490780
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 706 14
   Serial number: 3576700000041D30501C
   Subsystem 4 - Part No SW: -----------    HW: 480 002 506 14
   Serial number: 358670000000D540501E
   Subsystem 5 - Part No SW: -----------    HW: 480 402 306 14
   Serial number: 3516502A31697522734
   Subsystem 6 - Part No SW: -----------    HW: 480 402 006 14
   Serial number: 3526502B7156E9E502BM
   Subsystem 7 - Part No SW: -----------    HW: 480 402 306 14
   Serial number: 3556502BF16975231257
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 02071404221353
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   VCID: 7BF599B2F2C8EC9C72-802E
   Part No SW: 5G1 920 941     HW: 5G1 920 941
   Component: KOMBI         204 4270
   Coding: 27A51A082790260001893E011400000000000000
   VCID: 66C3D8C6994A4174BD-8032
16776980 - Databus
                    Reset counter: 29
                    Mileage: 35262 km
                    Date: 2018.05.11
                    Time: 11:52:06
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2186
   Revision: --------    Serial number: 27061410800999
   Coding: 030100040B087300FF00005C1C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewConti 011017
   ROD: EV_GatewConti_011_VW37.rod
   VCID: 428B2456D5A25D5471-8016
   Component: E221__MFL-DC1  H14 0035
   Serial number: 27130001233320113311
   Coding: 2DFFFF
   Serial number: 4849563603
   Serial number: 041115BK317085
   Coding: 00130220D001028000001000
   VCID: 43852152CAB8545C7A-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000005858757
   Coding: 0D0000
65571 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 178
                    Mileage: 36035 km
                    Date: 2018.06.11
                    Time: 12:45:55
65573 - Local Data Bus
          U10BA 00 [009] - No Communication
                    Reset counter: 98
                    Mileage: 36035 km
                    Date: 2018.06.11
                    Time: 12:45:55
          B1487 54 [024] - Missing Calibration / Basic Setting
                    Reset counter: 138
                    Mileage: 36421 km
                    Date: 2018.06.29
                    Time: 16:10:43
65799 - Door Warning / Enrty Lighting
          B1775 01 [009] - Electrical Failure
                    Reset counter: 98
                    Mileage: 36035 km
                    Date: 2018.06.11
                    Time: 12:45:54
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41892B5AD0A4464C68-8014
   Serial number: 05071402091980
   Coding: 00110020DE01048100801000
   VCID: 3F8D2DA2A65030BC1E-806A
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Fault Frequency: 47
                    Reset counter: 172
                    Mileage: 35270 km
                    Date: 2018.05.11
                    Time: 13:01:06
   Part No SW: 5G0 035 820 A    HW: 5G0 035 820 A
   Component: MU-S-D-ER     041 0421
   Serial number: V5C00107140298
   Coding: 02730000FF00000021111201000800001F0202060100010001
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 1F4D8D22069050BC3E-804A
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H60 0030
   Serial number: VWZ8Z9PS202E4N
End-------------------------(Elapsed Time: 03:48)--------------------------
myounus
Northwest UK
C?ID=321059
Hi Luke
Did you fit the switch on the driver's door panel also? You shouldn't have had to change the door controllers as they are normally all compatible and merely require coding to enable the feature which can be activated/deactivated from the infotainment unit.
kamold
Australia
C?ID=241363
Hi Luke
Not true.
There are 'lowline' door control modules that have fewer pins and therefor have no way of controlling extra functions like folding mirrors, ambient lighting, puddle lights etc.
The driver's door though is the only one that needs to be changed normally.
To the OP:
Do you have a copy of the coding from your original door control modules? Always good to compare if you swap modules.
I note that in your passenger and driver door control modules, your byte 6 coding do not match - this is the window motor variant. It has to be the same as the actual motors in the doors. Your driver's side is set to variant 5, but your passenger side is set to variant 3.
You also have byte 7 in the passanger side set to 'LIN-databus inactive'. This is the connection to the rear door control module. Change this (bit 0) and you should have control of the rear passenger door again.
Then the coding of your driver's door control module looks wrong, as it can't find a light circuit. Then the window regulators need to be run all the way down, hold for 5 seconds, then all the way up, hold for 5 seconds to clear the basic settings fault so they they will autorun.
LukeLewis24
C?ID=271228 (NRRT)
hi,
i changed the door switch and the previous modules had not enough pins.
I shall give the coding a go and let you know how I get on. Thanks!!
