Achraf
Pirate
I'm new in this forum. I have Audi A3 1.6 8p model 2011.
I had frequently a problem with injectors, I replaced till now 3. The symptoms were loss of power, vibration at idle and noise during acceleration.
The last weekend, I updated the software of the ECU engine from 5xxx to 9978. After that I did an adaption of injectors. At the end of adaptation, I tested my car and all previous symptoms are gone. Two hours later, I tested it on a high way and suddenly 2 lamps are set in my dashboard, engine management lamp which was blinking and Emission control lamp. Afterwards, I stopped immediately my car and I tried to start it again, then a vibration on my engine was begun. By diagnosing My ECU engine, I noticed a logged dtc related to flow meter where the signal is too high and no failure on my injectors:
So in order to confirm that my flow meter is bad, I unplugged it and I started my car, at idle the gauge of rotation speed was not stable, it was moving between 800 and 950 tr/min. After that I run, I noticed really a smooth acceleration with a loss of power.
After that I plugged again and I recorded the values gotten from flow meter :
The test was done between 900 and 1200 tr/min.
By the way, I checked the air filter, It's clean. I replaced the gasoline filter, I emptied the Tank and I Cleaned it.
What can be the cause in your opinion?
Thanks in advance for any help you can provide!
[b]Removed. Data from a clone/pirate copy of VCDS is not welcome here.[/b]
