2018 Atlas S 4Motion Towing
FrankG
C?ID=350615
VIN 1V2GR2CA0JC54XXXX
I purchased a 2018 atlas S 4motion.
Dealership had no models in stock with a tow hitch so I bought this one.
I have found that adding a tow hitch and wiring is not as simple as it used to be on older vehicles.
I have found that a J345 module needs to be added.?
https://parts.vw.com/p/Volkswagen_2...cal-Installation-Kit/70292409/3CN055203A.html
I am not sure if my vehicle has the wiring needed for the J345.
factory-fitted 1M5 trailer hitch preparation
I am not sure if my S 4motion needs one.
Can I just use a Tee harness that taps into the rear lights.
https://www.etrailer.com/Custom-Fit...en/Atlas/2018/118754.html?vehicleid=201863265
I am not sure where to look for the J345 harness if needed.
I am aware of the now 2000 lb weight limit with aftermarket hitch.
I have seen that if the j345 is added other modules need to be programmed also.
Any advice and guidance would be greatly appreciated.
jyoung8607
FoRT
Garrettsville, OH
C?ID=25607
Many people here (myself included) can look that up for you, based on the VIN. You've redacted the last part of yours. However, I just had a S with 4Motion as a service loaner for my SEL Premium, and I checked its PR-coding list in PL24, and it DOES have PR-1M5 trailer prep. That should mean you have the wiring sitting there to plug in a trailer control module, so in terms of electronics, all you need is the kit you mentioned.
Please note that retrofit kit only has the wiring for a 4-pin connector, not a 7-pin, so you won't have aux/battery charge for a camper, or electric brake actuation for heavier stuff. I don't know if PR-1M5 alone gets you the prewiring to the driver's footwell for an electric brake controller, but you're limited to 2000 lbs for post-sale retrofit so it shouldn't be a problem. Factory towing equipped Atlases are rated for 5000 lbs and have proper 7-pin support with prewiring to add your own EBC.
Yes, that's the correct and supported way to retrofit trailer wiring.
Meh. I'm given to understand some folks on VWVortex have used it successfully. If your Atlas had LED taillights, a splice-in kit might not work or might cause problems, but I think the S with 4Motion package still has incandescents.
If it were my vehicle, I would do it up the factory correct way. But, if you're extremely cost-conscious, much of the towing module's intelligence either a) doesn't apply to your base model, or b) can be replicated by the driver. When a trailer is detected, it:
1. Invokes some anti-sway protection in the ABS/stability control module, so try to load your trailer correctly and don't drive like a moron.
2. Disables auto start/stop, you can do this manually with the button, or permanently with VCDS if that's your thing.
3. Disables the Eco driving profile/shift program, make sure to use Normal or Sport.
4. Monitors the trailer connection when the Atlas alarm is set, and sets the alarm off if the trailer is unexpectedly disconnected.
5. Disables the lane change assist and rear traffic assist driver aids, since their view is blocked, but you don't have those options anyway.
6. Prevents the power tailgate from opening except from the button on the tailgate itself, you don't have a power tailgate.
7. Tweaks park distance control logic to not complain about your trailer when in reverse, don't think you have PDC.
Cargo area in the back, behind the plastic panel over the cargo pocket in the left rear corner of the Atlas.
Yup. The short version: the structure and powertrain are basically fine with 5000 lbs, but without the factory towing package, you don't have the transmission cooler and VW won't support you retrofitting one. A trans cooler, be it factory or aftermarket, won't get airflow with the active air shutters at the bottom of the grille; factory towing-equipped Atlases come without them. VW legally can't support you in removing a device they used during EPA mileage testing of that vehicle. It can be done, but you're on your own without manufacturer support.
Yes, VCDS should be able to do that.
Thanks Jason! I spoke to the OP in a brief pre-sales phone conversation yesterday and asked him to post in our forum hoping that you'd be able to add clarity.
To the OP, I haven't checked enough Atlas VINs to know if all Vr6 S and SE models have PR-1M5 trailer prep but posting the VIN here would be the best way to confirm if the dealer didn't already.
jyoung8607
FoRT
Garrettsville, OH
C?ID=25607
Great, now I'm the Atlas towing guy. Pays just as well as being the Phaeton guy I guess. :)
I believe every V6 will have either PR-1M5 trailer prep or PR-1D6 factory towing. I don't know about the 2.0Ts. VIN check is always best, as you say.
FrankG
C?ID=350615
Yes I spoke with Dana and she hoped that you would answer...
I was unsure of I should post my complete vin..
2556
jyoung8607
FoRT
Garrettsville, OH
C?ID=25607
2556
PR-1M5 confirmed. Here's a copy of your vehicle build data and PR-codes. Apologies for the crappy formatting, PL24's version of this doesn't paste very well. If you want, PM me your email address and I can send you a more readable PDF version.
Vehicle Identification No. 1V2GR2CA0JC542556
Model Atlas
ATL
Date of production 14.11.2017
Year 2018
Sales type CA12UR
Engine Code CDVC
Transmission Code QVK
Axle drive 8A
Equipment WW
Roof color 2R
Carpet color code
Exterior color / Paint Code 2R / D7X
Seat combination no.
Number of Z-Orders
Lockable wheel bolts	1PA	Standard wheel bolts
Vehicle class differentiation
units/platform components	0MY	Vehicle class differentiation -3CN-
drive-off assistance	UG5	Hill hold control / hill descent control
Emission standard	7CE	Emission standard LEV 3/Tier 3 70
Trailer hitch	1M5	Trailer hitch preparation
airbag	4UM	Airbag für Fahrer und Beifahrer (NAR)
mit Beifahrer-Airbag-Deaktivierung
(zweistufig)
Aktivkohlebehälter / Ottopartikelfilter	1E7	Activated carbon canister (ORVR), for
intensified evaporation system,
siphoning device for fueling
Aerials	8L6	"diversity" window antenna
Exterior mirror setting	6XC	Exterior mirrors: power-adjustable
Follow-on warranty	EA0	Without subsequent warranty
Left exterior mirror	5SH	Left exterior mirror, flat (US)
Electronic engine sound measures	GM1	Standard electronic engine sound
Right exterior mirror	5RR	Right exterior mirror, convex (US)
Alternative drive system	0K0	Without alternative drive system
Drive type	1X1	Four-wheel drive
"Multimedia"video/DVD/notebook connection	9WT	Mirror Link
Equipment levels	A8B	basic outfit
Area monitoring systems	6K0	Without forward collision warning/
autonomous emergency braking
Brake type in rear	1KZ	Disc brakes in rear
batteries	J0V	Battery 420 A (70 Ah)
Brake type, front	1LI	Disc brakes in front
Component part sets with
country-specific design requirements	B0D	Assembly kit, USA corresponding vehicle
version (not California), various parts
vehicle tools and jack	1S1	vehicle tools and jack
Brake systems	1AS	Electronic stability control (ESC)
Front passenger seat control	4V0	Without front passenger seat control
Owner's manuals	0VM	Information kit in American English
Operating voltage	9Z0	Operating voltage 12 V
Heated washer nozzles	9T0	Without heated washer nozzles
CD ROM/DVD/SD card	7QA	Without CD/DVD for navigation
"Charism"	2H5	Driving profile selection and
conventional shock absorber
Chrome package	QJ3	Chrome package
(type 2)
General operating permit, alterations	C00	Operating permit, initial registration
Roof rails/roof load rack	3S1	Bright roof rails
Roof insert/convertible top	3FA	roof without cut out
Suspension system in rear	1JA	Rear shock absorption, basic design 1
Suspension system in front	G02	Shock absorption in front
Insert for the filling up of unleaded
fuel/fuel type	2G4	Insert for the filling up of unleaded
fuel
ECO function for driving profiles and
Drive select	EF1	ECO function
Installation differentiation for components	0EW	Installation differentiation for
transmission AQ450
-- vehicle components --
Theft protection system	7AA	Electronic immobilizer
Inserts	5MB	Decorative inserts
Scuff plates	7M0	Plastic scuff plates in door apertures
Park distance control	7X0	Without park distance control
Extended safety system	7W0	Without extended safety system
Electric interface for external use
UI5	External, USB type A, 1x USB socket
Manufacturing sequence differentiation	0FA	Standard manufacturing sequence
fire extinguisher	6A0	without fire extinguisher
Pedestrian protection	VL0	Standard pedestrian protection measures
Pedal cluster	VF0	Standard pedal cluster
Headlight activation	8K2	Separate daytime running light
-- NAR --
Parking brake	UH1	Parking brake
Vehicle tracing system	7G0	Without preparation for VTS
(vehicle tracking system)
Vehicle specifications	F0A	No special purpose vehicle, standard
equipment
Alternators	9G2	Alternator 100-150 A
Weight category rear axle	0YC	Weight range 3
installation control only, no
requirement forecast
Weight category front axle	L05	Suspension range 05
Base engine	TV0	6-cyl. petrol engine 3.6 l assembly 03H.D
Luggage netting/pocket on backrest(s)	4U5	Luggage pockets on backrest
Luggage compartment cover	3U0	Without luggage compartment cover
Tie down straps/net/pocket	6M0	Without tie down straps/net/pocket
cruise control system	8T2	Electronic cruise control system (CCS)
Garage door opener	VC0	Ohne Garagentoröffner
Transmission specifications	G1G	8-speed automatic transmission for
four-wheel drive
Rear seats	3KQ	Rear seat bench/backrest, split folding
and 2 seats in 3rd row of seats
Heating and air-conditioning system	KH9	Electronically controlled air
conditioning system and auxiliary
heater HVAC unit
Headlamps	8IT	LED headlamps
Head-up display	KS0	Without head-up display
Hybrid drive	20A	Without electric motor (hybrid)
Customized installation	FC0	Without individual installation
Interior light in footwell	6T0	Without interior light in footwell
Instrument clusters	U5C	Instrument cluster, mph speedometer
- USA -
Breakaway interior rearview mirror	4L2	Breakaway interior rearview mirror,
dimming
Body style	K8G	Hatchback
Camera/distance sensor	QK0	Without multifunction camera
Fuel tank capacity	0M6	Fuel tank
child safety	4H3	Manual child lock
Child seats	QA0	without child seat
Folding table	1U8	W/o folding table on front seat backrest
Climatic zones	0Y4	Cold and tropical climatic zones (US)
Compass/road sign display	QR8	without road sign recognition
Seat ventilation/massage seat	4D0	Without seat ventilation/massage seat
headrest for seat, rear	3Q9	Three rear head restraints
Head restraints	5ZF	Front head restraints
Fuel quantity for initial filling	1Z0	Initial standard fuel filling
Fuel systems	1A5	Fuel system for SI engine
Body measures	5C1	Body measures for increased safety
requirements
Camera systems/accident sensors	KA1	With rear view camera system (type 1)
refrigerant	KK3	Refrigerant R1234yf
Paint preservative/transit coating	5K7	Transport protection film (minimum
protection) with additional transport
protection measures
Light package (lighting)	QQ0	Without add. lights (interior lighting)
Steering system arrangement	L0L	Left-hand drive
Reading lamp	8S1	Reading light in front
steering	1N3	Speed-related variable steering assist
(Servotronic)
Backrest release	3H0	Without backrest release for front seats
Light control systems	8G0	Without Light Assist
Load edge protection	2P1	Plastic loading edge protection
Lumbar support	7P0	Without lumbar support
in seat backrests
steering wheels	2ZA	Multi-function steering wheel
Driving on the left/on the right	AV2	Driving on the right (NAR)
Speaker installation	8RL	6 speakers (passive)
Headlight range control	8Q0	Without headlight range control
Center armrest	6E3	Front center armrest
Versions	FM0	Basic equipment variant
Multi-function display/trip computer	9S6	Multi-function display/trip computer
"Colour"
center console	3D4	center console
Driver alert system	EM0	Without driver alert system
Engine cooling	8Z6	Hot country
Engine specifications	D3B	6-cylinder SI engine 3.6 l/206 kW (24V)
VR6, FSI, homogeneous
base engine is T05/TA0/TH0/TV1/TV0
Navigation device	7Q0	without navigation system
rear fog lamp	8TA	witout rear fog lamp
Front fog lamp/additional headlamp	8WA	Without fog lights
Online services	EL0	Without online service
Upgrading measures	GP0	Vehicles w/o special upgrade measures
Hubcaps	1NL	Trims for alloy wheels
Wheels	CF8	Alloy wheels 8J x 18
Radios	I8C	.
Smoker's/non-smoker's package	9JF	Non-smoking package (NAR)
Regional code for radio	ER3	Regional code " NAR " for radio
Tire pressure monitoring system	7K6	Tire pressure monitoring system
tire	Q83	All-season tires 245/60 R18 105T (NAR)
Spare wheel/breakdown kit	1G6	Space-saving spare wheel
Wheelbases	0B8	Wheelbase
Restraint systems, front	4QQ	3-point seat belts in front with
pretensioner and height adjustment,
US label
Call feature	NZ0	without emergency call control unit
Side airbag	4X3	Side airbag in front, with curtain
airbag
Gearshift knob/handle	6Q1	Gearshift knob/handle in plastic
Special labels/plates	0SC	Labels in English
Tail lamp assemblies	8SJ	Tail light cluster, normal design (NAR)
Locking mechanism for boot lid/cover
rear	4E0	Tailgate/trunk lid unlocking
from outside
Service indicator	QI7	Service indicator 10 000 miles or
1 year (fix)
Seat belt check	9P7	Visual and acoustic seat belt reminder,
electric contact in buckle
Outer rear seat belts	3ZD	3-point seat belts, outer rear with US
label
seat covers	N4C	Seat trim covers in fabric
Seat adjustment	3L1	Manual height adjustment for left front
seat
seat heater	4A0	Without seat heater
Start-stop system/regenerative braking	7L6	Start/stop system with brake energy recovery
sun visors	5XQ	Sonnenblenden mit Spiegel
Audio-response system/voice control	QH0	without voice control
Lane change assist/lane keeping system	7Y0	Without lane change assist
Side and rear windows	4KF	Side windows in heat-insulating glass,
from B-pillar and rear window dark
tinted
Sunroof roller blind for rear/side windows	3Y0	without roller blind
power outlet	7B3	12-volt outlet(s)
Bumper	2JB	Standard bumpers
starter	7U2	Preparation for retrofitting, engine
starter plus remote start feature
Headlamp washer system	8X0	Without headlamp washer system
Windshield wiper intermittent control/
light/rain sensor	8N4	Windshield wiper intermittent control
with potentiometer (four speeds)
Nameplate set	0NB	Nameplate set in basic version
Door and lid locking system	4K0	Central locking w/ radio remote control
and interior controls
Type approval countries/countries with
special requirements	BU2	Legal requirements for USA 2
States with CARB requirement
Carrier frequency for remote control	5D2	Carrier frequency 315 MHz
Partition	3CA	Without partition
Door and side trim panels	3LM	door and side trim panels
TV reception/digital radio reception	QV0	without TV/digital radio reception
Front underbody guard	1SA	Without additional front underbody guard
Identification plates	1EB	Ohne Typschild
Delivery equipment	2A0	Without delivery equipment
First aid kit / warning triangle	1T0	Without first-aid material, without warning triangle
Front seats	Q1A	Standard seats in front
Telephone / telematics	9ZX	Telephone preparation for cellphone
Additional warning lights	9TE	Additional retro-reflectors (door area)
LongLife Service Regime	QG1	LongLife Service Regime
Heat accumulator system/auxiliary heater	7E0	W/o heat accumulator/auxiliary heating
Windshield Glass	4GF	Windshield in heat-insulating glass
Additional tires (snow tires)	2WA	without spare tyre
floor mats	0TA	without floor mats
Decorative trims	4ZC	Decorative trims
Additional child seat anchors	3B7	Child seat anchors as per Canadian
requirements a. ISOFIX child seat system
Auxiliary heating system	9M0	Without auxiliary heater/parking heater
Also, here's a parts diagram for the trailer control module and factory receiver hitch. You won't have exactly the same wiring and connectors, if you're using the retrofit kit, but it might help you understand where the retrofit module gets mounted and connected.
FrankG
C?ID=350615
OK,
I pulled the trigger and ordered the VCDS software.
I have the J345 on order, none in stock 100 miles from my location.
Any tips on the programming needed for this module, I am not sure what other modules need to be programmed on the CAN bus for this to work.
Not sure if there is a manual with the module, so I may be jumping ahead with the questions.
jyoung8607
FoRT
Garrettsville, OH
C?ID=25607
For this exact vehicle, I think all you'll need to do is recode the ECM (address 01) and the new trailer module itself (address 69). I will try to look up the specific byte/bit settings later. If you had ACC, lane change assist, the advanced 360 view cameras, or a power tailgage, there would be more to do.
When you get your VCDS interface, please post a complete Auto-Scan so we can see exactly how your Atlas is equipped. In the meantime, I will try to look up the specific byte/bit settings you'll need.
It will probably come with something called SVM action codes, which are magic codes a dealer tech can enter into their diagnostic tool and have the factory database back in the Fatherland tell it exactly how to update your vehicle. We won't be using those here, but I'd keep them on file just in case.
jyoung8607
FoRT
Garrettsville, OH
C?ID=25607
Following up to myself...
Ideally we'd like to see your first Auto-Scan before making changes, but in general, here's the steps you'll be following.
Set a non-zero WSC/Importer/Equipment number:
It's an identifier that gets saved in the module, as a record of who changed its settings last. VW official dealer tools get theirs assigned centrally. It doesn't matter that much what you use in VCDS if you don't have an official dealer ID and equipment ID set.
1. [ Options ]
2. If you haven't already, connect your new interface to your PC and hit [ Test ]
3. [ User Interface and Identification ]
4. Set WSC to any five-digit number other than 00000 or 12345.
5. Set Importer to 444 (the importer number for USA)
6. Set equipment number to any five-digit number other than 0000 or 12345.
7. [ Save ]
Run an Auto-Scan:
Physically install your new trailer retrofit module and wiring:
Left as an exercise for the reader. ;)
Add your new trailer module to the CAN gateway installation list:
(Ignition ON, Engine OFF)
1. [ Select ]
2. [ 19-CAN Gateway ]
3. [ Installation List ]
4. Check 69 - Trailer in the list
5. [ Save coding ]
6. [ Close controller, Go Back ]
Recode your ECM to know about the trailer module:
1. [ Select ]
2. [ 01 - Engine ]
3. [ Coding ]
4. Paste the new coding into the New coding field.
5. [ Do It! ]
6. [ Close Controller, Go Back ]
The exact coding bit for a trailer is undocumented for this ECM. :mad: Comparing my SEL Premium to an S, I narrowed it down to two possible bit settings, byte 8 bit 4 or bit 7. Flipping undocumented bits in the Long Coding Helper will be kind of opaque for a newbie, so I prepared two complete coding values to try. I'm assuming your existing ECM coding will match the V6 S I have on file, which is:
012A00124424010860000000000000000000000000000000
If yours differs from this in ANY way, ANY digit, STOP and post your Auto-Scan here for additional advice. If that does match yours, here's the two new values to try. I'm not sure which one will work; we will need to scan the car afterward for errors and perhaps try the other. Any feedback from Ross-Tech or NETech or whomever welcome.
012A00124424010870000000000000000000000000000000
012A001244240108E0000000000000000000000000000000
Set the initial coding on your trailer controller module:
Do the exact same thing as above, but go into module 69-Trailer, and use this coding value:
That should be correct for a USA vehicle, trailer prep/retrofit WITHOUT an aux/battery charge line.
Run an Auto-Scan again:
We want to make sure your changes worked and didn't leave any errors/faults behind.
Again, except for setting those WSC values, DO NOTHING BEFORE RUNNING AN AUTO-SCAN. That's your backup in case anything goes awry. Run one before you touch anything on your car. Then, when you're done installing the module and making the coding changes, run another one. We'll need to verify it worked, particularly the ECM coding. Post both the before and after results here.
FrankG
C?ID=350615
First Auto-Scan
I should hopefully have time to install the module this weekend.
Tuesday,30,October,2018,17:22:01:27182
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
VIN: 1V2GR2CA0JC542556   License Plate:
Chassis Type: CA-VW41 (3Q0)
Scan: 01 02 03 08 09 15 16 17 19 22 42 44 4B 52 5F D6 D7
VIN: 1V2GR2CA0JC542556   Mileage: 1907km-1184miles
Address 01: Engine (0-32-CDVC)       Labels:. 03H-907-309-V1.clb
   Part No SW: 03H 906 026 E    HW: 03H 907 309 K
   Component: VR6 3.6l FSI  H21 6024
   Revision: 52H21000
   Coding: 012A00124424010860000000000000000000000000000000
   Shop #: WSC 06401 444 00000
   ASAM Dataset: EV_ECM36FSI01103H906026E 001005
   ROD: EV_ECM36FSI01103H906026E.rod
   VCID: 270BF87FEF6BB6DFFFF-8072
   CAN Converter 01:
11954 - EVAP System
          P0456 00 [101] - Very Small Leak Detected
                    Mileage: 1889 km
                    Date: 2018.10.28
                    Time: 13:22:48
                    Engine speed: 0.00 /min
                    Normed load value: 20.4 %
                    Vehicle speed: 255 km/h
                    Coolant temperature: 98 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 12.340 V
                    Outside air temperature: 10 °C
                    Air mass: actual value:: 0.00 g/s
                    Engine torque: 41.3 Nm
                    Fuel: tank fill level: 30.0 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Intake camshaft bank1 active operating mode-Bits 0-7: 0
                    Overrun cut-off-Bits 0-7: 0
   Part No SW: 09G 927 158 A    HW: 09G 927 158
   Component: AISIN AQ8     206 3387
   Coding: 0000000100000000000000000000000000000000
   Shop #: WSC 09003 957 00200
   ROD: EV_TCMAQ450031_VW41.rod
   VCID: 313F1627D1AFF86F21B-8064
25548 - Implausible Data Received from Engine Control Module
          U0401 00 [032] - -
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 52927000000290
   Coding: 44FC6B8D84241A6EC57C0305A2C96922D62158A3C045967E00415058C20A4200002F641C12141A118DDB45506CC8CF
   ROD: EV_Brake1UDSContiMK100IPB_036_VW41.rod
   VCID: 76B5E53B78419F57B49-8022
Address 08: Auto HVAC (J301)       Labels:* None
   Part No SW: 3CN 907 426 D    HW: 3CN 907 426 D
   Component: AC Manuell    H04 2002
   Revision: 00001K00
   Coding: 1602060620001800100020400200000C
   ASAM Dataset: EV_ACManueBHBVW416 001002
   ROD: EV_ACManueBHBVW416.rod
   VCID: 44D14FF37E1D7DC7FAD-8010
   Fresh Air Blower Back:
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 7285009302ÿÿÿÿ
   ROD: EV_BCMBOSCH_018.rod
   VCID: 065595FB08A18FD7A49-8052
   Part No SW: 3Q0 959 655 BN    HW: 3Q0 959 655 BN
   Component: Airbag VW21   006 0713
   Revision: --------    Serial number: 003SUMHWIIEA
   Coding: 8CCCDC00000000005000001A420800000065
   VCID: 0B43A4CF13C3F2BFFB7-805E
   Occupant Detection:
   Component: Occ.Detection  H13 0022
   Serial number: IBH0000J170007YUKT0L
   Coding: 303030
   Subsystem 2 - Part No SW: -----------    HW: 454 000 209 17
   Serial number: 3570000000087634682G
   Subsystem 3 - Part No SW: -----------    HW: 454 001 708 17
   Serial number: 35800000000BC994482W
   Subsystem 4 - Part No SW: -----------    HW: 454 800 810 17
   Serial number: 3510027A44012000000$
   Subsystem 5 - Part No SW: -----------    HW: 454 800 610 17
   Serial number: 3520034AA40120000001
   Subsystem 6 - Part No SW: -----------    HW: 454 800 510 17
   Serial number: 35500BB543A11000000G
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 454 800 610 17
   Component: FrontSensor_P  304 0149
   Serial number: 35600A6E32E11000000M
   Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 26101708491501
   Coding: 0410
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 025D89EB2489B3F7881-8056
   Part No SW: 3CN 920 850 A    HW: 3CN 920 850 A
   Component: KOMBI         370 0310
   Coding: 0BA4170DAB80CF0502082B001000000020000000
   VCID: 3D273A171DF70C0FB53-8068
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 19101700841363
   Coding: 030500347F087300FB0320481E0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 33331C2F2BB3CA7F537-8066
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 26170001871910061439
   Coding: 30FFFF
   Serial number: 8429345404
   Serial number: HA1-00031.08.17
   Coding: 0301
   VCID: 4CC167D3564DB58732D-8018
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 130617A00800K6
   Coding: 003003200100020000000000
   VCID: 41DF46E7610F68EFD1B-8014
   Serial number: 00000000000006935853
   Coding: 011000
65648 - Controls for Window Regulator; Driver Side
          B1315 29 [008] - Signal Implausible
                    Reset counter: 95
                    Mileage: 1706 km
                    Date: 2018.10.20
                    Time: 14:56:57
   Revision: 00000000    Serial number: 0002126041
   Coding: 01000310004001
   ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
   VCID: 40D943E36A0561E7DE5-8014
   Serial number: 01101700841596
   Coding: 000000070100135000010000000000000000000000000000000000000000
   VCID: 72BDD92B14298377981-8026
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 050517060509X4
   Serial number: 00000000000007089432
   Coding: 091000
   Part No SW: 5G6 035 868     HW: 5G6 035 868
   Component: MU-E--ER      671 8395
   Serial number: 01091700020857
   Coding: 02140600BE00000041220001001000009F0000D40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001041
   ROD: EV_MUEnt4CGen2LGE_VW12.rod
   VCID: 70B9D3231A25B1676E5-8024
   Part No SW: 7P5 941 591 AA    HW: 7P5 941 591 A
   Component: LED1L         H06 0003
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: 7BA3F40F4363C23FCB7-802E
0800 - Bulb for Low-Beam Headlamp
          C1198 F6 [040] - Over-Temp Protection Active
                    Fault Frequency: 9
                    Reset counter: 0
                    Mileage: 933 km
                    Date: 2018.09.22
                    Time: 19:16:22
   Component: LED1R         H06 0003
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW37.rod
                    Fault Frequency: 9
                    Reset counter: 0
                    Mileage: 933 km
                    Date: 2018.09.22
                    Time: 19:16:44
End----(Elapsed Time: 01:40, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
FrankG
C?ID=350615
The 012A0012442401086 matches, so I will try replacing the 6 with the 7 then auto-scan for errors then try E to see which works
Go the OP verified. Moving to Retrofits.
FrankG
C?ID=350615
Installed the module today...
Started the vehicle by mistake and it burped up some codes...
The long coding for the 69-Trailer differs on mine
0100000202000000
Not sure if I should still change the second digit to a 2 since there is a difference.
FrankG
C?ID=350615
Here is the auto scan post install, starting engine with error codes.
Thursday,01,November,2018,18:45:28:27182
Workshop Code: 444 02173 020173
Scan: 01 02 03 08 09 15 16 17 19 22 42 44 4B 52 5F 69 D6 D7
VIN: 1V2GR2CA0JC542556   Mileage: 1910km-1186miles
   Revision: 52H21000
   Coding: 012A00124424010870000000000000000000000000000000
   Shop #: WSC 02173 444 20173
   CAN Converter 01:
23132 - No Communications with Control Module for Access/Start Authorization
          U100A 00 [039] - -
          [Access and start authorizationNo communication]
                    Mileage: 1910 km
                    Date: 2018.11.01
                    Time: 00:44:30
                    Coolant temperature: 54 °C
                    Voltage terminal 30: 12.040 V
                    Outside air temperature: 19 °C
                    Air mass: actual value:: 0.08 g/s
                    Engine torque: 0.0 Nm
                    Fuel: tank fill level: 24.0 l
Readiness: 1110 0101
0297 - Steering Angle Sensor
          B1168 F2 [137] - Not Initialized
                    Reset counter: 69
                    Mileage: 1910 km
                    Date: 2018.11.01
                    Time: 00:46:04
   Revision: 00001K00
   Occupant Detection:
   Coding: 303030
   Coding: 0410
   Coding: 30FFFF
   Coding: 0301
   Coding: 011000
                    Reset counter: 95
                    Mileage: 1706 km
                    Date: 2018.10.20
                    Time: 14:56:57
5262656 - Steering Angle Sensor
                    Reset counter: 69
                    Write only channel
   Coding: 091000
   Part No SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
   Component: Anhaenger     H27 0260
   Revision: 8C001004    Serial number: 0443191565
   Coding: 0200000202000000
                    Fault Frequency: 9
                    Reset counter: 0
                    Mileage: 933 km
                    Date: 2018.09.22
                    Time: 19:16:22
                    Fault Frequency: 9
                    Reset counter: 0
                    Mileage: 933 km
                    Date: 2018.09.22
                    Time: 19:16:44
End----------(Elapsed Time: 01:41, VBatt start/end: 12.2V/12.2V)-----------
NEtech
Denmark
C?ID=56995
Use the long coding helper button for changing coding.
Change it back to original 6
Then change Byte 5 for Trailer.
0100000202000000
Yes change Byte 0, according long coding helper to 02, for North America.
FrankG
C?ID=350615
I used the coding helper to make the changes... still have errors..
Friday,02,November,2018,07:46:33:27182
Gateway Installation List:  3Q0 907 530 G
65-Tire Pressure -- Status: Cannot be reached 0100
FrankG
C?ID=350615
I put all programming back to stock.
I removed power.
I removed the J345 module.
Left no power for 15 minutes.
Have error codes that will not clear.
Auto-Scan below
Friday,02,November,2018,08:41:42:27182
Scan: 01 02 03 08 09 15 16 17 19 22 42 44 4B 52 5F 65 D6 D7
   Revision: 52H21000
   CAN Converter 01:
                    Reset counter: 70
                    Mileage: 1910 km
                    Date: 2018.11.01
                    Time: 00:05:14
   Revision: 00001K00
   Occupant Detection:
   Coding: 303030
   Coding: 0410
   Coding: 30FFFF
131595 - Tire Pressure Monitoring Module
          U0127 00 [009] - No Communications
          [Timeout Knoten 0x0B / 65 - Steuergerät für Reifendrucküberwachung]
                    Reset counter: 70
                    Mileage: 1910 km
                    Date: 2018.11.01
                    Time: 00:03:29
                    Supply voltage: Terminal 30: 11.9 V
                    Terminal 15: On
   Coding: 0301
   Coding: 011000
                    Reset counter: 70
                    Mileage: 1910 km
                    Date: 2018.11.01
                    Time: 00:05:43
                    Write only channel
   Coding: 091000
Address 65: Tire Pressure
End----(Elapsed Time: 01:39, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Friday,02,November,2018,08:37:06:27182
Jef
HQ
ST?ID=85088
Reset counter: 70
Mileage: 1910 km
Date: 2018.11.01
Time: 00:05:43
Write only channel
G85 Steering Angle Sensor relearn info
Frank got a "Finished Correctly" statement after the lock to lock turn and level out steering wheel.
FrankG
C?ID=350615
I must have enabled module 65 by mistake.
Removed the check mark and no other codes.
Friday,02,November,2018,09:50:20:27182
   Revision: 52H21000
   CAN Converter 01:
   Revision: 00001K00
   Occupant Detection:
   Coding: 303030
   Coding: 0410
   Coding: 30FFFF
   Coding: 0301
   Coding: 011000
   Coding: 091000
End----------(Elapsed Time: 01:37, VBatt start/end: 12.7V/12.6V)-----------
