I have searched the Internet but haven't found any consistent information on this, is Group #4 the correct location for checking battery and/or charging system voltage through the VCDS?
A drop of 1.5-2.0 volts suggests a large resistance between the battery and the measuring point, so it's that difference in voltage which is too high.When you say it seems high, do you mean the amount of voltage or are you referring to a large variance between the scan tool reading and the battery/alternator reading?
I concur.A drop of 1.5-2.0 volts suggests a large resistance between the battery and the measuring point, so it's that difference in voltage which is too high.
This suggests a faulty connection somewhere between the two points, possibly due to a loose or corroded connection, and from what you say a connection that becomes higher resistance when the engine is warmed up which IMHO points more towards a loose connection.
So you had fitted a non-OEM alternator?Well, I removed the performance alternator and sent it to the manufacturer for evaluation/repair, I’ll wait to see what they find if anything.
In the meantime, I reinstalled the original factory VW alternator and so far, it is operating much better than the performance unit, voltage is staying at or close to 14+ volts even at operating temps. With loads.
Time will tell if that was the problem.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
