I retrofitted a Highline Camera to a 2018 Passat B8 Estate, The camera works fine and the lines move when the steering wheel is moved.
Watching this video, there are some options (1:30 onwards)
What is required to enable the extra view options, only thing on the screen was for brightness
https://www.youtube.com/watch?time_continue=90&v=TRY4tPUyLVY
Wednesday,03,October,2018,12:25:41:58336
VCDS Version: 18.9.0.2 (x64)
Workshop Code: 212 00152 014238
VIN: WVWZZZ3CZJE072107 License Plate: PASSAT CAMERA
Mileage: 15150km-9413mi Repair Order:
Chassis Type 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 52 5F 69 6C
6D A5 BB BC CA CF
VIN: WVWZZZ3CZJE072107 Mileage: 15150km-9413miles
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DFCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 FN HW: 04L 907 309 M
Component: R4 2.0l TDI H25 2011
Revision: B4H25---
Coding: 011D0012036505083000
Shop #: WSC 05311 115 00305
ASAM Dataset: EV_ECM20TDI01104L906026FN 004002
ROD: EV_ECM20TDI01104L906026FN_004.rod
VCID: 7BFFD093F206809280-802E
Part No SW: 0D9 300 043 C HW: 02E 927 770 AS
Component: DQ250-6F MQB H54 5201
Revision: 06454104 Serial number: TFK01708150609
Shop #: WSC 05311 115 00062
ROD: EV_TCMDQ250021.rod
VCID: 1A31F5171D7C599A3B-804E
Part No SW: 5Q0 614 517 CH HW: 5Q0 614 517 AH
Component: ESC H62 0743
Revision: 00000000 Serial number: 62527000001173
Coding: 0FEC928F34270B6E4778060040CA49F0492CD0E2600292713862F078CAA9420000000012121212B835351919323200
Shop #: WSC 00015 115 08193
ROD: EV_Brake1UDSContiMK100IPB_036_VW48.rod
VCID: 79F3CA9BF83AB28292-802C
Part No SW: 3Q0 959 435 F HW: 3Q0 959 435 F
Component: VWKESSYMQB 027 0906
Revision: 00027000 Serial number: 0454729106
Coding: 102F0F0723
ROD: EV_KessyHellaMQBAB_VW48.rod
VCID: 3D7B1E8BAC924EA2FE-8068
Part No SW: 5G0 907 044 DN HW: 5G0 907 044 DN
Component: Climatronic H04 2001
Revision: 00001K10
Coding: 1212012420211001111550000010182A
ROD: EV_ACClimaBHBVW37X_006_VW48.rod
VCID: 76E9C1A7C924DDFAFF-8022
Air quality sensor:
Part No SW: 5Q0 937 086 BK HW: 5Q0 937 086 BF
Component: BCM PQ37BOSCH 034 0242
Revision: -------- Serial number: 865830081701LP
ROD: EV_BCMBOSCH_018.rod
VCID: 040DAB6F8FF8FF6AF1-8050
Subsystem 1 - Part No SW: 3G2 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 170813 043 0607
Serial number: 170901030646
Component: RLHS 047 0105
Serial number: S5Y17M09D18H08M35S15
Coding: 00A8DD
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 21 04 2017 10001772
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY172151HGA
Serial number: 00000000000070704021
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418617259
Coding: 0471155911
Shop #: WSC 00152 212 14238
ROD: EV_EPHVA18AU3700000_009_VW48.rod
VCID: 4B9F4053E226F01270-801E
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 C HW: 3Q0 907 572 C
Component: ACC BOSCH MQB H04 0195
Coding: 320467DA59FFC728949C8045
ASAM Dataset: EV_ACCBOSCHVW48X 001009
ROD: EV_ACCBOSCHVW48X.rod
VCID: 356B06AB94A296E236-8060
Part No SW: 3Q0 959 655 BK HW: 3Q0 959 655 BK
Component: Airbag VW21 006 0703
Revision: -------- Serial number: 003W6PHGLJZ2
Coding: 98FCC0C0000000005C5400CF008800000065
Shop #: WSC 05314 000 00001
VCID: 0815BF5FB3D0DB0A9D-805C
Belt Pretensioner left:
Serial number: 3G2857705E0244R00963
Coding: 80000D
Belt Pretensioner right:
Serial number: 3G2857706E0245R00132
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 000 609 17
Serial number: 3570000000022280E82A
Subsystem 4 - Part No SW: ----------- HW: 454 000 609 17
Serial number: 35800000000E4380E82Q
Subsystem 5 - Part No SW: ----------- HW: 454 802 908 17
Serial number: 351003E8624120000006
Subsystem 6 - Part No SW: ----------- HW: 454 802 908 17
Serial number: 35200CD8024120000009
Subsystem 7 - Part No SW: ----------- HW: 454 800 409 17
Serial number: 355007118E1100000003
Part No SW: 5Q0 953 521 BB HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF033033 Serial number: 20170909301781
Coding: 0C10
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
VCID: 73EFF8B3DA56C8D2D8-8026
Part No SW: 3G0 920 791 C HW: 3G0 920 791 C
Component: KOMBI 406 3193
Coding: 27A40918678C060001886B2B1001000000000000
ROD: EV_DashBoardVDDMQBAB_VW48.rod
VCID: 2953DADB481AC202A2-807C
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 08091710521370
Coding: 030300045F087300FB00025C1C0F00010001070000000000000000000000
ROD: EV_GatewNF_VW48.rod
VCID: 336F38B39AD688D218-8066
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29170001993430097367
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 75886000001709081207
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 17000225485017
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71E3F2BBA04AFAC22A-8024
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 E HW: 3Q0 907 566
Component: MRR1Rear H20 0510
Revision: --------
Coding: 54C002
VCID: 3A711597BDBC799ADB-806E
Component: TSG FS 020 0041
Serial number: 170717EGH02257
Coding: 003F0A20D001028000001000
VCID: 438F6873CA76385288-8016
Component: EPS_MQB_ZFLS 128 1072
Coding: 9107
Shop #: WSC 00015 115 00305
ROD: EV_SteerAssisMQB_013.rod
VCID: 458B766BC4420662A6-8010
Component: TSG BFS 020 0041
Serial number: 300817EHU26904
Coding: 003F0020DE01028000001000
VCID: 42816D77D56C315A83-8016
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER 851 0842
Coding: 02840201FF00000051110101008808001F0506F6012000008F
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 32613DB765CC81DA13-8066
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZJT2025788
Subsystem 2 - Part No SW: 5NA 919 866 HW: -----------
Component: ECE1 2018/19 --- 1030
Part No SW: 5Q0 907 383 G HW: 5Q0 907 383 D
Component: Anheanger H21 0203
Serial number: 00006789,./0,(
Coding: 0100000202000000
VCID: 3B7F1093B2864092C0-806E
Component: RVC Compact H12 0231
Coding: 01000001E3000007000040
Shop #: WSC 12345 123 123456
VCID: 39730A9BB8BA7282D2-806C
10489856 - No Basic Setting
B2010 00 [009] - -
Reset counter: 242
Mileage: 15150 km
Date: 2018.10.03
Time: 12:18:37
passive
Part No SW: 5Q0 959 107 L HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0261
Revision: -------- Serial number: 31527493900000
Coding: 0280
VCID: 4183627BD06A2A429A-8014
Part No SW: 3Q0 980 653 F HW: 3Q0 980 653
Component: MQB_B_MFK H13 0171
Serial number: 08091711P23791
Coding: 00040802000004010002134F8150A900940094000020
Component: TSG HFS 020 0041
Serial number: 270817EHQ23799
Coding: 000E00200101028000001000
Component: TSG HBFS 020 0041
Serial number: 270817EHQ21957
Address CA: Sunroof
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
Address CF: Lane Chge Asst 2
End-------------------------(Elapsed Time: 05:46)--------------------------
