New user in need of assistance - VW Tiguan 5N 1.4 tsi 4wd manual transmission
NikosP
Greece
C?ID=345522
Hi,
I got a VCDS and Hex Can interface in order to help me identify faults and trouble shoot on a used Tiguan I recently bought.
I tried ordering from States but had to go through Uk dealer and managed to get it. Gendan UK are great professionals.
As you can find on the Autoscan copied bellow , there were plenty of issues some real and some just registered , and not sure how to fix since the car is a runner and all works fine ( I think?).
Please if you can identify some significant faults given and point me into the right direction on how to solve, since were I live ( Greece Corfu island) there are no dealers of VW or Car engineers dealing with VW ( I am an engineer but on the marine industry myself so pretty switched on technically ) to trust change me a wheel off my skate if I had to...
The main issues I need to sort out are the following 2 :
A/ I am equipped with an Off-road Button but doesn't work . The odd is that the car when feels a steep slope activates on its own the off-road aids and you can see the light on dial turned on with the off-road aid sign.
Nothing wrong to that , but sometimes the off-road aids activate, when you are just driving on flat tarmac road and when stopped on a traffic light been annoying.
The off-road button is been like dead and doing nothing as to activate or disactivate when that happens and defiantly wont activate on demand.
Please I would be grateful if you can assist me to that cause sometimes is a bit scary trying to start from traffic light and been restricted from abs as the off-road functions are activated.
B/ I installed a 9w2 Bluetooth unit on to my RNS510 and follow the wiring as per instructions , but the RNS doesn't sees the Bluetooth ( if I press phone button on wheel or RNS does only mute the audio and nothing else). Also when I try coding 19 and set 77 , but the 77 channel cannot be reached.
All commands from steering wheel goes right on RNS510 except the phone command that mutes volume.
Again I will be grateful into your assistance.
I have done some reset of ecu 9 pulling power cable and sort negative to discharge) The car learns all abs etc again. But no luck.
tried clear fault codes on central electronic (channel 19) but keep coming up.
I attach autoscan for help.
thank you volumes
nikosP
Sunday,21,October,2018,13:58:45:37191
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
VIN: WVGZZZ5NZAW054863   License Plate: IOO
Mileage: 111650km-69376mi   Repair Order:
Chassis Type: 5N-VW36 (1K0)
Scan: 01 03 08 09 0D 0F 10 14 15 16 17 18 19 1C 20 22 25 26 2B 2E
          32 37 3D 42 44 46 47 4F 52 53 55 56 5D 61 62 6C 72 73 75 76
          77 78 A6
VIN: WVGZZZ5NZAW054863   Mileage: 111650km-69376miles
0D-Slide Door, Left -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
18-Aux. Heat -- Status: Cannot be reached 1100
1C-Position Sensing -- Status: Cannot be reached 1100
20-High Beam Assist. -- Status: Cannot be reached 1100
26-Auto Roof -- Status: Cannot be reached 1100
2B-Steer. Col. Lock -- Status: Cannot be reached 1100
2E-Media Player 3 -- Status: Cannot be reached 1100
32-Differential Locks -- Status: Cannot be reached 1100
3D-Special Function -- Status: Cannot be reached 1100
47-Sound System -- Status: Cannot be reached 1100
5D-Operations -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
73-Entry Assist, P -- Status: Cannot be reached 1100
75-Telematics -- Status: Cannot be reached 1100
76-Park Assist -- Status: Cannot be reached 1100
78-Slide Door, Right -- Status: Cannot be reached 1100
A6-Microphone -- Status: Cannot be reached 1100
Address 01: Engine (CAV)       Labels: 03C-906-027-CAV.clb
   Part No SW: 03C 906 027 BL    HW: 03C 906 027 F
   Component: MED17.5.5       G   8011
   Revision: LAH08---    Serial number:
   Coding: 0000172
   Shop #: WSC 00050 207 90732
   VCID: 6C81C7DE3A82E31752D-8038
Address 03: ABS Brakes        Labels: 5N0-614-109-C4.clb
   Part No SW: 5N0 614 109 M    HW: 5N0 614 109 M
   Component: J104    C4 450 V220 0003
   Revision: --H28---    Serial number: 00000002372359
   Coding: 0011525
   Shop #: WSC 01324 020 00200
   VCID: 353722BA294862DF7D3-8060
   Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000000002
   VCID: 7DA7FA9A5D787A9FF53-8028
13701520 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Tόrsteuergerδt hinten links - kein Signal/Kommunikation]
                    Fault Frequency: 17
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2018.10.20
                    Time: 20:24:58
   Part No SW: 5K0 937 087 D    HW: 5K0 937 087 D
   Component: BCM PQ35 H    011 0028
   Revision: BE011001
   Coding: 4C180A3B9825F3C0400800803400092443553088736D89605C8000000000
   VCID: 363525B6384E69C7749-8062
   Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 03110  012 0203
   Serial number: N1955119   °203!
   Coding: 009795
   Component: RLS 091109 05  54  0402
   Coding: 07304D
00380 - Special Vehicle Control Module (J608)
                    Reset counter: 26
                    Mileage: 111585 km
                    Date: 2013.03.10
                    Time: 16:54:06
                    Voltage: 12.45 V
00830 - Convertible Top Control Module (J256)
                    Reset counter: 26
                    Mileage: 111585 km
                    Date: 2013.03.10
                    Time: 16:54:06
                    Voltage: 12.45 V
                    Reset counter: 26
                    Mileage: 111585 km
                    Date: 2013.03.10
                    Time: 16:54:08
                    Voltage: 12.45 V
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 00:00:05
                        Term 15 Off
                    Voltage: 12.90 V
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.12
                    Time: 20:24:60
                    Voltage: 13.75 V
                    Fault Status: 00101010
                    Reset counter: 70
                    Mileage: 111645 km
                    Date: 2013.03.12
                    Time: 16:57:54
                    Voltage: 12.05 V
Address 0D: Slide Door, Left
Address 0F: Digital Radio
Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
   Part No SW: 1T0 919 475 H    HW: 1T0 919 475
   Component: PARKHILFE PLA H07 0110
   Revision: --------    Serial number: 88520930900609
   Coding: 300002
   VCID: 40D9436E6A8AD777DE5-8014
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0070
   Revision: 00000000    Serial number: 04110903300001
   Coding: 010180
   Shop #: WSC 00000 785 00200
   VCID: 270BF8F2EFE4004FFFF-8072
   Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
   Component: J234__200 VW10 HI   1916
   Revision: 20013000    Serial number: 003E2PNYUQTE
   Coding: 0012336
   VCID: 44D14F7E7292CB57FAD-8010
   Subsystem 1 - Serial number: 6332MTS619253039
   Subsystem 2 - Serial number: 6342MTS670013039
   Subsystem 3 - Serial number: 6351HTS6S7HE66KJ
   Subsystem 4 - Serial number: 6361HTS6PKOE66KR
   Part No SW: 1K0 953 549 CK    HW: 1K0 953 549 CK
   Coding: 0000332
   VCID: 7DA7FA9A51F87A9FF53-8028
   Component: E0221           002 0030
   Part No SW: 5N0 920 871 A    HW: 5N0 920 871 A
   Component: KOMBI         H05 0305
   Coding: 110F00
   VCID: 2F3B10D2C794580F37F-807A
12715520 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerδt fόr Verdeck: keine Kommunikation]
                    Fault Frequency: 218
                    Reset counter: 32
                    Mileage: 110492 km
                    Date: 2018.09.16
                    Time: 13:54:31
13635328 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerδt fόr Sonderfahrzeuge: keine Kommunikation]
                    Reset counter: 32
                    Mileage: 110492 km
                    Date: 2018.09.16
                    Time: 13:54:31
Address 18: Aux. Heat
   Part No SW: 1K0 907 530 AF    HW: 1K0 907 951
   Component: J533  Gateway   H20 0592
   Revision:   H20       Serial number: 261009F2000316
   Coding: F9EB7F2E797FF30D6002
   VCID: 6B83C4C23F8CE42F5B7-803E
20 Faults Found:
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:16:18
01327 - Control Module for Parking Aid (J446)
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:16:22
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:16:19
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:16:18
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:16:18
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:16:22
01302 - Control Module for Telematic (J499)
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:16:22
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:16:22
02649 - Digital Radio Tuner
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:16:22
00484 - Vehicle Position Recognition Control Module (J603)
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:16:22
02749 - Control Module / Control Head for Telephone (J738)
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:16:19
02011 - Right Entry Assistance Control Module (J573)
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:16:18
02054 - Control Module for Differential Locks (J647)
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:16:18
03272 - Control Module for Audio Interface
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:16:22
03604 - Control Module Auomatic Sliding Door, Rear Left
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:16:18
03395 - Control Module for High Beam Assistant
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:16:22
03605 - Control Module Auomatic Sliding Door, Rear Right
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:16:18
02811 - Control Module for Electronic Steering Column Lock (J764)
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:16:22
03753 - Control Module for Microphone
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:16:22
03406 - Control Module for Battery Monitoring
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:17:17
Address 1C: Position Sensing
Address 20: High Beam Assist.
   Part No SW: 0AY 907 554 C    HW: 0AY 907 554 C
   Component: Haldex 4Motion      0041
   Coding: 0000005
   VCID: 4BC364425FCC042F3B7-801E
   Component: IMMO          H05 0305
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC1C63CF6FD27201-803E
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 110364 km
                    Date: 2018.09.13
                    Time: 18:48:56
Address 26: Auto Roof
Address 2B: Steer. Col. Lock
Address 2E: Media Player 3
Address 32: Differential Locks
   Part No SW: 1T0 035 680 P    HW: 1T0 035 680 P
   Component: RNS-MID       H10 5274
   Revision: AB001001    Serial number: VWZ6Z7L8092131
   Coding: 0606044204000081000C
   Shop #: WSC 00028 028 00001
   VCID: 3B233482036CB4AF8B7-806E
   Component: EU West V15  8515
00857 - CD Changer Unit (R41)
                    Fault Frequency: 12
                    Reset counter: 32
                    Mileage: 111656 km
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:23:09
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:23:09
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:47:38
Address 3D: Special Function
   Part No SW: 5N0 959 701 E    HW: 5N0 959 701 E
   Component: Tuer-SG         009 2101
   Coding: 0004096
   VCID: 372B28B2334490CF6FF-8062
01706 - Switch for Mirror-Adjust (E43)
   Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.162 0703
   Revision: 1AH03273    Serial number: 00092530082202
   Coding: 0000258
   VCID: 3A2D318600568DA7901-806E
Address 47: Sound System
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Component: EZE_2         H20 0592
   Coding: 050B0500
   VCID: 6695B5F6286ED947049-8032
   Component: J245EE20SKB13  H01 0220
   Component: J394EE20SKB13  H01 0220
02071 - Local Databus
                    Fault Status: 00101100
                    Reset counter: 72
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 11:50:02
   Part No SW: 5N0 959 702 E    HW: 5N0 959 702 E
   Coding: 0004542
   VCID: 38292B8E3E5A9FB7665-806C
   Part No SW: 3AA 907 801 B    HW: 3AA 907 801 B
   Component: J540 EPB4  VW-49878 0004
   Revision:   H17       Serial number: 00000000001620
   Coding: 0023057
   VCID: 303913AED62A47F72E5-8064
                    Reset counter: 69
                    Mileage: 111638 km
                    Date: 2013.03.12
                    Time: 13:20:45
                    Voltage: 13.60 V
                    Count: 10
                    Hex Value: 0x12EB
                    Hex Value: 0x8001
                    Hex Value: 0x1010
00457 - Control Module for Network (J519)
                    Fault Status: 00101101
                    Reset counter: 70
                    Mileage: 111641 km
                    Date: 2013.03.12
                    Time: 13:54:51
                    Voltage: 9.60 V
                    Count: 141
                    Hex Value: 0x12E3
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Component: AFS-Steuergeraet    0142
   Coding: 1363142
   VCID: 34311FBE22327BD74AD-8060
   Coding: 00000020
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000020
                    Fault Frequency: 13
                    Reset counter: 32
                    Mileage: 111656 km
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:23:09
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:23:09
                    Reset counter: 32
                    Mileage: 111657 km
                    Date: 2013.03.13
                    Time: 13:47:38
Address 5D: Operations
   Part No SW: 1K0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H20 0592
   Coding: F000085A
   VCID: 6889BBCE227ACF37365-803C
Address 62: Door, Rear Left
   Part No SW: 5N0 907 441 A    HW: 5N0 907 441 A
   Component: J772__Rearview      0020
   Revision: 00H07000    Serial number: 525PA8-J9X1263
   Coding: 0020010
   Shop #: WSC 01324 785 00200
   VCID: 2D070ADAC1182A1F053-8078
   Part No SW: 5N0 959 704 D    HW: 5N0 959 704 D
   Coding: 0000144
   Shop #: WSC 01324 020 1012552
   VCID: 392F2E8A055086BF99B-806C
Address 73: Entry Assist, P
Address 75: Telematics
Address 76: Park Assist
Address 77: Telephone
Address 78: Slide Door, Right        Labels: None
   Coding: 0000144
Address A6: Microphone
End----------(Elapsed Time: 02:22, VBatt start/end: 12.5V/12.4V)-----------
siLc
Tallinn, Estonia
C?ID=330192
You have so many modules that cannot be reached. It might be a good start to remove the modules not in the car from the CAN gateway installation list. Except leave 77 for Bluetooth. Rear right door should be on address 62, not 78.
downtime
Finland
C?ID=280813
I have to state this again. The modules not existing in the car physically, won't magically appear there even they are enabled in the gateway installation list.
Now if you look even the very recent support requests on this forum and the attached autoscans there, you notice in 90% of the cases they have some module that cannot be reached. The reason for that being it's enabled in the gateway for god knows what reasons.
Thumb of rule, DO NOT MESS WITH THE GATEWAY INSTALLATION LIST UNLESS YOU KNOW EXACTLY WHAT YOU ARE DOING!!! The modules added to the list don't appear on the car no matter how much it is wished. They need to be installed physically first.
NikosP
Greece
C?ID=345522
Thank you for your help, can I relocate address like you suggest? On rear door? I will try identifying modules and remove. 77 is dead and cannot reach even when Bluetooth module is connected. Any tips on how to get it on? Rns510 connected with 9w2. Thank you volumes
NikosP
Greece
C?ID=345522
Thank you guys, I will try by trial and error to identify keeping original settings.
NikosP
Greece
C?ID=345522
Guys any directions over the off road button issue I got will be greatly appreciated. The system works automatically but the button is not working by pressing to engage or disable. Thank you
NikosP
Greece
C?ID=345522
Hi Downtime,
The list is as appeared on my first autoscan , haven't added any new. So you think safe to remove the ones cannot reach?
downtime
Finland
C?ID=280813
Yes, remove at least these :
Then clear all dtc's run a new autoscan and paste the contents here. Then we'll see what are actual errors and whatnot.
What comes to the offroad function, probably needs coding to ABS, maybe? Haven't done that myself ever so I'm not sure about it.
NikosP
Greece
C?ID=345522
done what suggested stilll no bluetooth module recognised st wheel button only mutes
Tuesday,23,October,2018,20:18:29:37191
VIN: WVGZZZ5NZAW054863   License Plate: IOO231018C
Mileage: 111720km-69419mi   Repair Order:
Scan: 01 03 08 09 10 14 15 16 17 19 22 25 37 42 44 46 4F 52 53 55
          56 61 62 6C 72
VIN: WVGZZZ5NZAW054863   Mileage: 111720km-69419miles
56-Radio -- Status: Not registered 0011
   Coding: 0000172
Readiness: 1110 0101
   Component: J104    C4 450 V227 0003
   Coding: 0011525
   Revision: 00003001
   Coding: 0000000002
          U1111 00 [009] - -
                    Fault Frequency: 30
                    Reset counter: 38
                    Mileage: 111657 km
                    Date: 2018.10.20
                    Time: 20:24:58
   Revision: BE011001
   Coding: 009795
   Coding: 07304D
                    Reset counter: 39
                    Mileage: 111721 km
                    Date: 2013.03.15
                    Time: 20:15:06
                    Voltage: 12.60 V
   Coding: 300002
   Coding: 010180
   Coding: 0012336
   Coding: 0000332
   Coding: 110F00
   Coding: F9AB7F06404003046002
                    Reset counter: 39
                    Mileage: 111721 km
                    Date: 2013.03.15
                    Time: 20:15:06
            000 -  -
                    Mileage: 111721 km
                    Date: 2013.03.15
                    Time: 20:15:05
   Coding: 0000005
9456681 - Key
                    Mileage: 110364 km
                    Date: 2018.09.13
                    Time: 18:48:56
   Coding: 0601044204000081000C
                    Reset counter: 38
                    Mileage: 111720 km
   Coding: 0004096
   Coding: 0000258
   Coding: 050B0500
   Coding: 0004542
   Coding: 0023057
   Coding: 1363142
   Coding: 00000020
   Coding: 00000020
                    Reset counter: 38
                    Mileage: 111720 km
   Coding: F000085A
   Coding: 0020010
   Coding: 0000144
End----------(Elapsed Time: 01:53, VBatt start/end: 12.6V/12.6V)-----------
NikosP
Greece
C?ID=345522
The offroad button is factory installed and the system IS working automatically you have indication on dash and works great, but cannot activate or disactivate with button. turns automatically on over steep hills which is great giving you control going down or up, but sometimes activates on flat road!! and cannot stop it unless I accelerate over 20kms . No retrofit . Makes no sense.. I believe the button should work since fitted?
Forgot to mention that tried coding +512 or 1024 on abs to no luck the 512 turned off abs and esp and the 1024 did none..
Now over the Bluetooth module 9w2 is recently added and the RNS510 is been replaced the old to newer one same model just upgraded firmware AND maps V15. The car didn't had phone fitted before and I added the module. Wiring I follow the RNS instructions of wiring.
Once again thank you volumes for all your assistance I hope a rosstech guy might jump into quote and pass some more info-directions. once again really appreciated you help
NikosP
Greece
C?ID=345522
Apparently I'm left alone into that ..anyhow I have to add the following as feedback in order to be punctual to this thread for people might advice this issues.
When I removed from CAN BUs gate controller 9 installation list , the advised modules shown as 'cannot be reached 1100' from my attached autoscan and funny things started to happen.
Removing sliding door modules ( since no sliding doors installed) The rear,behind the driver, door was refusing to lock when I was using either the central locking from key remote button , but also from drivers locking button. The door was only locking manually from the key hole on the side of the door under the rubber blank provided for manual locking.
Windows started to have mind of their own on when to open or close and sometimes using the remote locking was making the windows going down to 1/4 open...
Reinstalled the sliding door module even if cannot be reached 1100 not visible to system , brought all back to normal?! strange but anyway all is working fine now.
Removing the diff lock module that was shown as cannot be reached 1100 or not able to connect , made the automatic activation of Offroad aids system non functional.
I know because were I live there is a slope hill I need to drive every day and those aids were coming active all times, not after I un installed module and few days after I re activated diflock module and all worked fine?!
Still not a winner for telephone Bluetooth-RNS510-MFDW module activation or connection, maybe canbus or wiring harness incompatible? not sure I will get at it and find solution.
Also Not winning over Offroad manual button activation of offroad aids, but since they activate automatically I am ok , but is annoying sometimes they activate when not in need and also annoying having a button installed that doesn't work.. I will also try to find solution and post. Retrofit of offroad button threads got me to no solution. tried coding etc.. to no luck . I still got a dead button but automatic activated offroad aids...
Once again I want to thank members helped into my thread and request for assistance and I greatly appreciate efforts.
Extremely poor rosstech support that only posted likes over member comments, and no other advice as support team offered into product benefits.
Great product VCDS and HEX CAN No doubt under development and with minimum 5N Tiguan 1.4TSi petrol database, could take advantage of contribution from an owner of such vehicle supporting him technically.
I will stay and update as for the progress of issues. Once again thank you all contributing.
Sometimes staying with errors on your canbus , and not trying to eliminate, maybe isn't a bad thing, and error message can be just VCDS insufficient data into communicating with certain modules? Not sure worked for me though. Invisible or cannot be reached 1100 modules refer to actual controls for a strange reason.
downtime
Finland
C?ID=280813
I’ve never see anything like what you have in your car. Either your can gateway module is busted or someone has totally messed your car electronics.
There should not be any modules like what you have on the installation list. So something seriously wrong.
NikosP
Greece
C?ID=345522
The only thing I can say since I bought this car second hand is that all function in a strange way, and not sure how to make right as by the book sort off.
Extra but ordered by the guy when he bought the car is upgraded ecu so the engine delivers 200Hp, overdrive 6th gear so you can drive from 60-230km with 6 gear. And turbocharger that engages on demand of throttle and not by Rpm range I think from mtm.
Anyhow I agree with you that something ain't right and seems started from 2013/2 as from registered values going wrong from that date.
United States
I thought I replied to this a while ago .. but the forum found a saved draft and restored some of it for me. Sorry about that.
1) This isn't normal:
Cannot be reached​
This Tiguan should have 4 diagnostic capable door modules (42, 52, 62 and 72). That could be as simple as a fuse but it may be necessary to dig into that door to see if any parts or wiring were replaced/repaired.
2) You don't have a 77-Telephone module communicating in the scan to confirm part numbers and coding of it. If that was a VW part number unit (rather than aftermarket) it would be worth checking the wiring to it.
9W2 Bluetooth doesn't support PTT but the steering wheel button should answer incoming calls based on your current 16 coding. The only other option would be 0000132 but that may make the button inoperative entirely.
Coding: 0000332​
0xxx?xx: Multi-Function Steering Wheel (1-4 = LIN 1.3 / 5-8 = LIN 2.0)
1 OR 5 = Multi-Function Steering Wheel w/o Tiptronic and w/o Push-To-Talk (PTT) installed
3 OR 7 = Multi-Function Steering Wheel w/o Tiptronic and with Push-To-Talk (PTT) installed
3) I would try coding 56 to: 0400044204000082000C
You can always change it back to the last value but the Shortpress Steering Wheel Buttons installed position doesn't appear to be correct so I would leave that un-ticked. Either way, make sure to reboot the RNS after each coding change.
4) I'll report back if I spot anything related to the ABS/Offroad concern.
NikosP
Greece
C?ID=345522
Thank you volumes dana,
I suspect that something is going wrong with the Can bus gate.
I get a part number 1K0907530AF which looks like its for golf . The Tiguan 5n uses the 1K0907530L
diagnostic says hardware and software version 7F2211 installed exists isn't compatible to car as per diagnostic results showed.
As I say I am second owner the first gave me no info and digging I find gems and that in 2012 Feb someone programed the ECU to 200Hp and messed with the system.
( this is why I suspect can bus issue, mabe the guy fried it and change it)
Now I reprogrammed from VW dealer the car back to 155Hp and updated, but still got issue with offroad assist aids and I try to figure whats wrong to minimum assistance since here were I live there is poor knowledge and no dealer . So either diY or need to drive to Athens to VW dealers and hopefully solve. But you know I rather be there clued about than go like a dummy and sale me new set of cars all ecteronic and all sensors until they get it right.
I am a marine engineer and mostly I deal with diesel engines , but again with ECU and diagnostics so I am aware f systems etc. but as everyone we cannot be engineers for everything and I admit I have minimum experience with cars , since always a classic bike rider and only last 10 years car driver.
I am strongly convinced that there is something wrong with can bus gate and either not programmed right or installed after and incompatible with the car.
thank once again for you kind assistance into this field of offroad aids that seems to be few knowledge from the community about.
Highly appreciated.
regards
