- Sep 3, 2018
- 24
- 14
- Leonartown, MD, USA
- C?ID=342201
VCDS run update to 18.9.0.2 and I'm getting massage:
Unable to find a .ROD files for.
EV_DashBoardVDDMQBAB 009051(VW36)
EV_GatewNF 013020 (VW36)
EV_TrailFunctGener2Hella 001008 (VW36)
EV_DeckLidCONTIAU736 001014 (VW36)
Access to some of the modules requires module selections form the list.
Prior to the update I did not see massage like that.
Any suggestions?
Thanks in advance
Below are scans of the same car before update and after update
Now:
Any suggestions?
Thanks in advance
Friday,07,September,2018,10:33:08:30494
VCDS Version: 18.2.1.5 (x64) HEX-NET CB: 0.4411.4
Data version: 20180518 DS287.2
VIN: 3VV2B7AX3JM002106 License Plate:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 22 2B 3C 42 44 52 5F 69 6C
6D 75 CA
VIN: 3VV2B7AX3JM002106 Mileage: 15525km-9646miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DGUA) Labels:. 06L-907-115-V1.clb
Part No SW: 5NA 907 115 A HW: 06L 907 309 B
Component: R4 2.0l TFSI H30 0004
Revision: 1DH30000
Coding: 012A00122476010FB4000000000000000000000000000000
Shop #: WSC 00066 790 00291
ASAM Dataset: EV_ECM20TFS0115NA907115A 001005
ROD: EV_ECM20TFS0115NA907115A.rod
VCID: 3C34CD1FB71CB9A438-8068
Readiness: 0000 0001
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 Q HW: 09G 927 158
Component: AISIN AQ8 206 3379
Coding: 0002000100000000000000000000000000000000
Shop #: WSC 00066 790 00453
ROD: EV_TCMAQ450031_VW27.rod
VCID: 41CABCEBD0FED44C6B-8014
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 50987000000137
Coding: 0BFA6BA454201B6EC5780300A2C949D0D62AD8A3C045927C18415058C28A4200002864121A1C230935351919323200
Shop #: WSC 01383 790 50316
ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
VCID: 77BE1233CEBA5AFC15-8022
Part No SW: 3Q0 959 435 E HW: 3Q0 959 435 E
Component: VWKESSYMQB 036 0811
Revision: 00036000 Serial number: 0434760327
Coding: 032C0C070F
ASAM Dataset: EV_KessyHellaMQBAB 004039
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 5NN 907 044 A HW: 5NN 907 044 A
Component: AC Automat H35 4301
Revision: 20K08000 Serial number: 00000D00004849
Coding: 0002002410011800100501401211140E
ASAM Dataset: EV_ACClimaPrehVW37X 002023
VCID: 4AD89BC7EDC81714BA-801E
Part No SW: 5Q0 937 087 AS HW: 5Q0 937 087 AP
Component: BCM PQ37BOSCH 034 0243
Revision: -------- Serial number: C864120417023U
ROD: EV_BCMCONTI.rod
VCID: 0C545DDFA73C492448-8058
Subsystem 1 - Part No SW: 5NN 955 119 HW: 5NN 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 170308 034 0373
Serial number: 17030521051340
Subsystem 2 - Part No SW: 8U0 955 559 HW: 8U0 955 559 Labels: 8U0-955-559.CLB
Component: G355_FeuchteS H07 0002
Serial number: 71808607
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H02 0233
Coding: 3200008950FF8728749C8145304097
Shop #: WSC 00066 790 00274
VCID: 3E30C717A100ABB416-806A
Part No SW: 5Q0 959 655 AG HW: 5Q0 959 655 AG
Component: AirbagVW21 004 0336
Serial number: 003NUM057U6/
Coding: 8CCCFC00000000005000001AC20800000065
VCID: 054268FB8456386C17-8050
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH0000000000073RU0R
Coding: 303351
Subsystem 2 - Part No SW: ----------- HW: 480 001 503 17
Serial number: 357000000000D3191223
Subsystem 3 - Part No SW: ----------- HW: 480 001 503 17
Serial number: 358000000003D3191227
Subsystem 4 - Part No SW: ----------- HW: 480 402 503 17
Serial number: 3510001A32527B23351L
Subsystem 5 - Part No SW: ----------- HW: 480 401 901 17
Serial number: 3520001B922A9B34353/
Subsystem 6 - Part No SW: ----------- HW: 480 402 103 17
Serial number: 3550001C724CDB2395AI
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 103 17
Component: FrontSensor_P 000 6149
Serial number: 3560001C724CDB2392BH
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Revision: -------- Serial number: 07041708491719
Coding: 0410
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 075E62F3BE5A2A7C65-8052
Part No SW: 5NA 920 850 A HW: 5NA 920 850 A
Component: KOMBI 361 8311
Coding: 0BA5001AA788CF0502887B095400000020000000
VCID: 3D32C01BAC06B0AC0F-8068
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 518 5286
Serial number: 08051700840113
Coding: 030500347F085900FB0322581E0F00010001050000000000000000000000
Shop #: WSC 00066 790 00064
ROD: EV_GatewNF_VW27.rod
VCID: 2F2EEA53766A523C8D-807A
Subsystem 2 - Part No SW: 5NN 959 442 A HW: 5NN 959 442 A
Serial number: 0201700020200003BL2B
Coding: 2C0000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 0475402904
Serial number: HA1-00003.11.16
Coding: 0101
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 17000075290009
Coding: 0800000000000000
Shop #: WSC 00066 790 00440
ROD: EV_ELVMarquMQBB.rod
VCID: 71AA2C2BA0DE04CCDB-8024
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0080
Serial number: 0431834720
Coding: 01012103
ROD: EV_HREntryHella_VW37.rod
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0080
Serial number: 0434370916
Coding: 010121
Part No SW: 5Q4 959 393 E HW: 5Q4 959 393 B
Component: TSG FS 010 0032
Serial number: 7028702000146
Coding: 00301B200000028000000000
VCID: 45C2A8FBC4D6F86C57-8010
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000005973918
Coding: 011000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2051
Revision: 00000000 Serial number: 0001620982
Coding: 01000010004001
ROD: EV_SteerAssisVWBSMQBA_009.rod
VCID: 40CCB9EFDBF4DD4464-8014
Part No SW: 5Q4 959 392 E HW: 5Q4 959 392 B
Component: TSG BFS 010 0032
Serial number: 8028712700422
Coding: 003013200000028000000000
VCID: 44C4B5FFCFECC16440-8010
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000006065356
Coding: 091000
Part No SW: 3Q0 035 876 A HW: 3Q0 035 876 A
Component: MU-S-NS-US 840 0755
Coding: 02730602BE00000051220001001808001F0500C401200105C6
ROD: EV_MUStd4CDELP_VW27.rod
VCID: 3228E32765587FD4E2-8066
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav H50 8120
Serial number: VWZ6ZHT1300503
Subsystem 2 - Part No SW: 3G0 919 866 BB HW: -----------
Component: NAR 2017 --- 0525
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0447480187
Coding: 0200000200000000
Shop #: WSC 03099 444 12345
VCID: 42C8B3E7D5F8CF5472-8016
Component: RVC Compact H12 0231
Coding: 0123060121002017300040
VCID: 393AD40BB82E8C8C23-806C
Part No SW: 5Q0 959 107 L HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0261
Revision: -------- Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Coding: 0A88
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0570
Coding: 02230602C2823A017F1E06020000
ROD: EV_OCULowMQB.rod
VCID: 43C6B6E3CAE2C65C79-8016
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 013 0005
Coding: 00804073260C
ROD: EV_SunRoofCONTIAU736.rod
End----------(Elapsed Time: 01:46, VBatt start/end: 12.5V/12.5V)-----------
Now:
Friday,19,October,2018,16:12:58:30494
VCDS Version: 18.9.0.2 (x64) HEX-NET CB: 0.4436.4
6D 75 CA
VIN: 3VV2B7AX3JM002106 Mileage: 16964km-10540miles
Revision: 1DH30000
VCID: 3C34CD1FB71CB9AAC9-8068
17158 - Databus
ROD: EV_TCMAQ450031_VW32.rod
VCID: 41CABCEBD0FED4429A-8014
VCID: 77BE1233CEBA5AF2E4-8022
Coding: 032C0C070F
VCID: 4AD89BC7EDC8171A4B-801E
ROD: EV_BCMBOSCH_018.rod
VCID: 0C545DDFA73C492AB9-8058
VCID: 3E30C717A100ABBAE7-806A
0836 - Databus
[FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
Reset counter: 85
Mileage: 16708 km
Date: 2018.10.14
Time: 08:43:57
Voltage terminal 15: 14.4 V
Control Module temperature: 30 °C
Longitudinal_acceleration_vehicle_reference: 0.03 m/s²
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 054268FB84563862E6-8050
Occupant Detection:
Coding: 303351
Coding: 0410
VCID: 075E62F3BE5A2A7294-8052
Coding: 0BA4001AA788CF0502887B095400000020000000
VCID: 3D32C01BAC06B0A2FE-8068
U1110 00 [008] - -
[BAP_TEL_0x28 keine Kommunikation]
Reset counter: 71
Mileage: 16323 km
Date: 2018.10.06
Time: 08:22:09
ROD: EV_GatewNF_VW37.rod
VCID: 2F2EEA53766A52327C-807A
Coding: 2C0000
Coding: 0101
VCID: 71AA2C2BA0DE04C22A-8024
Coding: 01012103
Coding: 010121
VCID: 45C2A8FBC4D6F862A6-8010
Coding: 011000
ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
VCID: 40CCB9EFDBF4DD4A95-8014
VCID: 44C4B5FFCFECC16AB1-8010
Coding: 091000
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 3228E32765587FDA13-8066
VCID: 42C8B3E7D5F8CF5A83-8016
VCID: 393AD40BB82E8C82D2-806C
Coding: 0A88
VCID: 43C6B6E3CAE2C65288-8016
ROD: EV_SunRoofCONTIAU736_006.rod
End----------(Elapsed Time: 01:54, VBatt start/end: 12.5V/12.3V)-----------
