VCDS 18.9.0.2 : 17-Instruments -- Status: Cannot be reached 0100
DaveN
Ireland
C?ID=62381
Hi
I have been using 18.9.0.2 and see the following when doing a AutoScan;
The module is readable via the 'Select' path with no faults.
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G8 920 987 R    HW: 4G8 920 987 R
   Component: TDieGb        H15 0225
   Revision: 15001308    Serial number: 658131216596000
   Coding: 33AF0D000B410008010000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K.rod
   VCID: 48957727F3E79D0A5D-801C
Is there a known issue with the autoscan?
Complete scan below, this does show 6C issue but that is okay as it is an calibrated RVC ( Kufatec have confirmed the dtc is okay) ;
Thanks to Sebastian for the 6c label file.
Tuesday,16,October,2018,13:09:43:21606
VCDS Version: 18.9.0.2 (x64)
VIN: WAUZZZ4GXHN088186   License Plate: 171 CLEAN 5F RVC
Mileage: 28003km-17400mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 36 3B 42 44 46 52 53 55
          5F 62 6C 72 AC
VIN: WAUZZZ4GXHN088186   Mileage: 28003km-17400miles
Address 01: Engine (J623-DDDA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 HA    HW: 04L 907 309 AA
   Component: R4 2.0l TDI   H20 3830
   Revision: 8DH20---
   Coding: 0A254012242401080000
   ASAM Dataset: EV_ECM20TDI01104L906021HA 004003
   ROD: EV_ECM20TDI01104L906021HA_004.rod
   VCID: 6BDFE8AB82D1961210-803E
   Part No SW: 4G1 927 153 B    HW: 0CJ 927 156
   Component: 0CK 20TDI RdW H03 0004
   Revision: --H03---    Serial number: 0000001066
   Coding: 100001
   ASAM Dataset: EV_TCMDL382021 002024
   ROD: EV_TCMDL382021_AU57.rod
   VCID: 2953D2A348AD4402A2-807C
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  002 0572
   Serial number: 75117071160363001574
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 06A29E41604579829B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41836A03D0DDAC429A-8014
   Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
   Component: BCM2 2.0      H61 0825
   Coding: 01B8704E000000000000
   VCID: 7CFDDBF7FFBF01AA89-8028
   Serial number: 3216000310830004
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 10011700041460
   Coding: 34210978210000
   VCID: 63CF808B6A01DE52A8-8036
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0368
   Revision: 15020001    Serial number: 00001560597301
   Coding: 0105001440349FE041014083800018004F9DC3082F08020100000894E100140200400034030000
   VCID: 74EDF3D7D7EF49EAC1-8020
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 161106  H38 0080
   Serial number:         161118210045
   Coding: 004DF7
   Serial number: 20055425X81A955547A0
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 11 01 2017  00000991
   Subsystem 4 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 7668426800PAG0MUFU03
   Component: Airbag10.43   H82 0092
   Revision: --------    Serial number: 003P100CC86O
   Coding: 30333130313630323639554A305234473053
   VCID: 3B7F18EBB231C692C0-806E
   Serial number: 3575HRB405N492DA7OOS
   Serial number: 3585HRB405P480GQEGP4
   Serial number: 3515JRB400257HS4LGSV
   Serial number: 3525JRB400257HS4F28Z
   Serial number: 3554VRB400A57J2CJ8BB
   Serial number: 3564VRB400A57J2CL9MQ
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 91560QA3001OD
   Coding: 000034
   VCID: 3B7F18EBBA31C692C0-806E
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 09 01 2017  D0004873
   ROD: EV_RBD4K.rod
   Part No SW: 4G8 907 468 H    HW: 4G8 907 468
   Revision: --------    Serial number: 00000002488565
   Coding: C0CD074418
   VCID: 3D7B16F3AC25C8A2FE-8068
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 4087662504
   Voltage stabilizer:
   Serial number: 16070500000000000796
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04028264747464545425363E00
   VCID: 67D7949B9639B27274-8032
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0113
   Serial number: 17011700040604
   Coding: 22
   Revision: AA000000    Serial number: 00000226698609
   Coding: 0078130000006001000001010101102030303232203232
   VCID: 77F7C4DBC69922F2E4-8022
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720UVBF4
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 336F30CB9A610ED218-8066
   Component: TSG FA        H03 0511
   Coding: 011C16015E01620002080002
   VCID: 4797741BF6F9927254-8012
   Component: RCevo         H54 0202
   Revision: 00000002    Serial number: 0000537238
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A711DEFBD0BFF9ADB-806E
   Revision: 00002001    Serial number: 0428730909
   Coding: 011B062280B90080C320088400010E470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 B
   Component: Sensor, DWA  005 0002
   Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00027728635
   Component: TSG BF        H03 0511
   VCID: 4689791FF1F38B7AAF-8012
   Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
   Component: EPB-4         H01 0018
   Revision: --------    Serial number: 00000002062700
   ASAM Dataset: EV_ParkiBrake 001033
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 326135CF657B07DA13-8066
   Coding: 04FE02102A630200
   VCID: 346D33D79F6F09EA01-8060
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 021 G    HW: 4G1 035 021 D
   Component: MU-H-LND-EU   053 0910
   Serial number: A733A0H7531579
   Coding: 017501010000000013111102000A00332F0006E7F1700100DF
   VCID: 1E39F17F01E3B3BAC7-804A
   Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9GY806V42
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349QAG000C5
   Compact Disc Database:
   Component: Gracenote2  --- 1015
   Component: TSG HL        H03 0511
   Coding: 010814004001620002080002
   VCID: 49937223E0ED640242-801C
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 4S0 980 556 A    HW: 5Q0 980 556 B
   Component: RVC Compact   H12 0201
   Coding: 0275010100002007000040
   Shop #: WSC 17873 123 50804
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
   ROD: EV_CamSysRVRVCPANAAU57X_002.rod
   VCID: 397302E3B80DF482D2-806C
10489856 - No Basic Setting
          B2010 00 [009] -  -
                    Reset counter: 219
                    Mileage: 27995 km
   Component: TSG HR        H03 0511
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 163200969
   ROD: EV_RDCMA00100_008.rod
   VCID: 2F673CBB76492A327C-807A
End-------------------------(Elapsed Time: 04:54)--------------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Please create a control module map of your #19 (Gateway) and attach it here.
DaveN
Ireland
C?ID=62381
Hi Sebastian, what do I need to do enter the #19 and run the additional codes?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
VCDS > Applications > Control Module Maps
Address: 19
Function: Meas. Values
Output: CSV
START
Then you should find a new file "blockmap_19-4G8-920-987-R_YOURVIN.CSV" in C:\Ross-Tech\VCDS\Logs\, copy the content here for us to review.
DaveN
Ireland
C?ID=62381
it does not seem to start a log file VCDS> applications > Controller Channel Maps but it doesn't seem to output a log file/csv
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Check the measuring values, there should be some info about the communication to the instrument cluster.
DaveN
Ireland
C?ID=62381
Hi, I captured measuring blocks on the CAN and Instruments but nothing seems particularly odd.
Sunday,21,October,2018,13:42:20:21606
Data version: 20181017 DS296.0
Mileage:    Repair Order: CAN MEASURE
                Address 19: CAN Gateway  (4G8 907 468 H)
13:42:10
  IDE01864-MAS03173   Status of current bus communication-Databus drivetrain active
  IDE01864-MAS03174   Status of current bus communication-Comfort data bus active: local wakeup event
  IDE01864-MAS03175   Status of current bus communication-Databus extended active
  IDE01864-MAS03176   Status of current bus communication-Display and control head databus active
  IDE01864-MAS03181   Status of current bus communication-Flexray databus active
  IDE01864-MAS07380   Status of current bus communication-Data bus Sensor/Hybrid Sleep mode
  IDE01866   MOST system condition Light off
  IDE01867-IDE01863   MOST hardware parameter-MOST light performance Decrease 0 dB
  IDE01868   Ring break diagnostic result 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  ENG107689-IDE01868   Automatic loop break diagnosis-Ring break diagnostic result 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Sunday,21,October,2018,13:37:46:21606
Mileage:    Repair Order: INST_MEASURE
                Address 17: Instruments  (4G8 920 987 R)
13:37:29
  IDE00019   Voltage terminal 30 12.3 V
  IDE00021   Engine speed 828.00 /min
  IDE00025   Coolant temperature 39.00 °C
  IDE00075   Vehicle speed 0 km/h
  IDE03880-MAS03119   MOST address-Functional block: diagnostic instance 17
  IDE03880-MAS03425   MOST address-Physical address 04 01
  IDE03881-MAS02200   MOST Transceiver Status-Highest measured temperature 0 °C
  IDE03881-MAS02201   MOST Transceiver Status-Temperature 0 °C
  MAS03121   Ring break diagnostic line status Supply voltage
  ENG107688-MAS03117   MOST_adress-Group address N/A
  ENG107688-MAS03118   MOST_adress-Logic address N/A
  ENG107688-MAS03119   MOST_adress-Functional block: diagnostic instance N/A
Below is a compare of a previously passing autoscan and one since the camera in stall. There are some minor start/stop changes and then the Kufatec instructions and dongle activity. The car is actually working fine bar the non calibrated camera but it is still functional.
Prechange
Saturday,11,August,2018,17:18:57:21606
VCDS Version: 18.2.1.5 (x64)
Data version: 20180518 DS287.2
Mileage: 25406km-15786mi   Repair Order:
          5F 62 72 AC
VIN: WAUZZZ4GXHN088186   Mileage: 25406km-15786miles
   Revision: 8DH20---
   VCID: 6BDFE8AB82D1961CE1-803E
Address 02: Auto Trans (J217)       Labels:* Redir Fail!
   Coding: 100001
   ROD: EV_TCMDL382021_AU48.rod
   VCID: 2953D2A348AD440C53-807C
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   VCID: 41836A03D0DDAC4C6B-8014
   VCID: 7CFDDBF7FFBF01A478-8028
   VCID: 63CF808B6A01DE5C59-8036
   Coding: 0105001440349FE041014083800018000F9DC3082F08020100000894E100140200400024030000
   VCID: 74EDF3D7D7EF49E430-8020
   Coding: 004DF7
   Coding: 02006D
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   VCID: 3B7F18EBB231C69C31-806E
   Coding: 000034
   VCID: 3B7F18EBBA31C69C31-806E
   ROD: EV_RBD4K.rod
   VCID: 48957727F3E79D04AC-801C
   Coding: C0CD074418
   ROD: EV_GatewPkoUDS_002.rod
   VCID: 3D7B16F3AC25C8AC0F-8068
   Voltage stabilizer:
   Revision: AA001002
   VCID: 67D7949B9639B27C85-8032
Address 28: HVAC, Rear (E265)       Labels:| 4G0-919-158.clb
   Coding: 22
   VCID: 77F7C4DBC69922FC15-8022
   ROD: EV_SARA2.rod
   VCID: 336F30CB9A610EDCE9-8066
   VCID: 4797741BF6F9927CA5-8012
   VCID: 3A711DEFBD0BFF942A-806E
   VCID: 4689791FF1F38B745E-8012
   VCID: 326135CF657B07D4E2-8066
   VCID: 346D33D79F6F09E4F0-8060
   Coding: E01E00
   Coding: E01E00
   VCID: 1E39F17F01E3B3B436-804A
   VCID: 49937223E0ED640CB3-801C
   VCID: 2F673CBB76492A3C8D-807A
End-------------------------(Elapsed Time: 04:39)--------------------------
After camera install
          5F 62 6C 72 AC
   Revision: 8DH20---
   Coding: 100001
   Coding: 004DF7
   Coding: 02006D
   Coding: 000034
   ROD: EV_RBD4K.rod
   Coding: C0CD074418
   Voltage stabilizer:
   Revision: AA001002
   Coding: 22
   ROD: EV_SARA2.rod
   Coding: E01E00
   Coding: E01E00
          B2010 00 [009] -  -
                    Reset counter: 219
                    Mileage: 27995 km
DaveN
Ireland
C?ID=62381
Hi, I noticed today the auto scan as decoding my A6 4G as "Chassis Type: 4G-AU57 (4G8)" which I think is a A7 . I dont have a log file older than 18.2.
is there a mismatch in the decoding of the chassis that could be behind the autoscan behaviour?
You're reading something into this "mismatch" that isn't there. Look at your CAN Gateway:
DaveN
Ireland
C?ID=62381
Uwe, thanks for the response. Just trying to debug the issue. Symptom of being an engineer. I have a hex-can cable would a newer generation cable give me some more information!
DaveN
Understood. :)
Only for the fault code in the backup camera, and I believe the extended text that's missing in this case would just say, "RearView system not calibrated".
BTW, the measuring values you posted from your CAN gateway are by no means the "map" that Sebastian asked for in post #4. Now I'm not sure exactly what he's looking in there, but...
DaveN
Ireland
C?ID=62381
Uwe, I couldn't manage to get the csv file generated that Sebastian had suggested. I tried the Applications > Controller Channel Maps and set the address to #19 and the output to csv. Clicked Go. There it would run access #19 but no log file would get dumped out to the /Logs.
Is there another debug mode that needs to be enabled?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The channels map was intended to clarify the communication status of both the CAN as well as the MOST connection of your instrument cluster. Sadly, the HEX+CAN system you are using doesn't support that feature. I am currently pressed by time, so I can't look into this any further myself but maybe somebody else does?
DaveN
Ireland
C?ID=62381
I am looking at upgrading to a HEX-V2 at the moment so we can pause this discussion until I have a new scan.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Well, it was working before, and not after, so that should tell you something.
What EXACTLY do the Kufatec instructions have you do with VCDS?
How EXACTLY did you connect the camera's CAN wiring into the car?
Any possibility that during the camera install, you managed to disconnect/reconnect the instrument cluster to the wrong CAN bus somehow? Convenience vs. extended vs. infotainment vs. powertrain? That's the only explanation I can think of for diagnostic comms working but gateway pings not.
DaveN
Ireland
C?ID=62381
The #19 installation list address the 6C ( There are two 6C modules listed the FL uses the second one)
Address #9 had byte35 set bit 4 to 1
The Kufatec Dongle is then used which according to them does some further coding, they do not want to be more specific than coding and adaptation they confirmed it does no #17 instruments coding.
The CAN connection on the camera is labeled CAN-HIGH and CAN-LOW in the Kufatec cabling, these were matched up to quaddlock grey 12 pin block in the radio unit as pin 12= can low. Pin 6 Can High, the cable feeds from the rear to the front and up behind the unit. The power is from a switched live rather than an permanent live.
As I didn't modify the Instrument Custer connectivity it can only really be the camera connectivity on CAN, I may try disconnecting it completely to see if it resolves the issue though opening it all back up is not what I want to do. I may try doing it back at the luggage area.
DaveN
Ireland
C?ID=62381
Today I had another go.
In the #19 installation list I noticed 17 was in twice. I deselected the first one and restarted the car. The restart reset both on in the installation list but it must have reinitialsed the can controller as the “not reachable” error is now gone and the auto scan works cleanly except for a 6c calibration message.
Patience lead to figuring it out. Thanks
