No Communication with ABS module - Seat Ibiza 2012
Jamie_B
C?ID=345393
Hi, I cannot connect to the ABS module in my wife's Ibiza.
Does anybody have any ideas as to why this would be the case?
Thursday,11,October,2018,12:18:47:25280
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
VIN: VSSZZZ6JZDR082683   License Plate:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZDR082683   Mileage: 86310km-53630miles
03-ABS Brakes -- Status: Cannot be reached 1100
   Part No SW: 03L 906 023 LE    HW: 03L 906 023 Q
   Component: R4 1.6l TDI   H33 9978
   Revision: --H33---    Serial number:
   Coding: 00114016002500080000
   ASAM Dataset: EV_ECM16TDI02103L906023LE 003011
   ROD: EV_ECM16TDI02103L906023LL.rod
   VCID: 74B1DFB4AE3D03A78AD-8020
7332 - Mass Air Flow Sensor (G70)
          P0103 00 [036] - Signal too High
                    Engine speed: 0.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 17 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 11.068 V
                    Engine speed: 0 /min
                    Battery voltage: 11.4 V
                    EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
                    Throttle_actuator_commanded_value-ANG_SP_THR[0]: 96.001 %
                    Air mass: specified value-MAF_SP_MMV: 239.95 mg/stroke
                    Air mass: actual value (mg/stroke)-MAF_MES: 0 mg/stroke
6086 - No Communication with ABS Brake Control Module
          U0121 00 [173] - -
                    Fault Frequency: 44
                    Mileage: 86278 km
                    Date: 2018.09.27
                    Time: 10:56:21
                    Coolant temperature: 58 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 12.311 V
                    Driver request torque-TQI_DRIV_SUB: 0.00 Nm
                    Control Module temperature-TECU: 13 °C
Readiness: 1 1 0 0 0
Address 03: ABS Brakes
   Component: LENKW.SENSOR  H06 0060
   Serial number: 090465LGL0009A
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5FD9C907159F7EC9-802A
336900 - Databus
                    Reset counter: 64
                    Mileage: 86315 km
                    Date: 2018.10.11
                    Time: 00:10:10
                    Voltage terminal 15: 12.10 V
                    Voltage terminal 30: 12.35 V
                    Terminal 15 status: On
Address 08: Auto HVAC        Labels: 6J0-820-045.clb
   Part No SW: 6J0 820 045 A    HW: 6J0 820 045 A
   Component: J301  Klimaanlage   0330
   Revision: 00 26 08    Serial number: 0000002542340-
   Shop #: WSC 06402 785 00200
   VCID: 2411EFF452DDD327DAD-8070
                    Reset counter: 64
                    Mileage: 86315 km
                    Date: 2013.03.03
                    Time: 00:10:09
   Part No SW: 6R0 937 087 K    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0254
   Revision: BF046001    Serial number: 0434 195120431
   Coding: 24882BE88861250092200EF06E0B0CC8008043EC608C0040200000000000
   Shop #: WSC 64564 324 38760
   VCID: 45D75270B5A7CA2FED3-8010
   Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3110
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 3110
   Coding: 020000
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Subsystem 5 - Part No: 1K8 951 171 A
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10AirbagA0D H10 0020
   Revision: --------    Serial number: 003GX01AXG3T
   Coding: 003044
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD614C9C392557001-801E
   Serial number: 3495RRB400G4UHC4B93O
   Serial number: 3505RRB400G4UHC4JOC5
12854016 - Databus
          [Kombi1 DLC Error]
                    Fault Frequency: 81
                    Reset counter: 64
                    Mileage: 86315 km
                    Date: 2018.10.11
                    Time: 00:10:11
12656896 - Databus
          [Bremse8 Time Out Error]
                    Reset counter: 64
                    Mileage: 86315 km
                    Date: 2018.10.11
                    Time: 00:10:14
   Part No SW: 6J0 920 904 C    HW: 6J0 920 904 C
   Component: KOMBI         H04 0508
   Coding: 410A00
   VCID: 2B0304C833831C5F1B7-807E
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Bremse: keine Kommunikation]
                    Reset counter: 64
                    Mileage: 86315 km
                    Date: 2018.10.11
                    Time: 00:10:10
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H46 0254
   Revision: BF046001
   Coding: 022300
   VCID: 70B9D3A4DAA53F876E5-8024
                    Reset counter: 64
                    Mileage: 86315 km
                    Date: 2013.03.03
                    Time: 00:10:11
   Component: IMMO          H04 0508
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC1CCFCF9C557201-803E
   Part No: 6R0 423 156 B
   Coding: 11221
   Shop #: WSC 06402
   VCID: 2F3B10D80E5B607F37F-807A
            79-00 - Please Check Fault Codes
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
   Part No: 6J0 959 441
   Component: MF-Modul       0007 0001
   Coding: 0000001
   Shop #: WSC 77005 000 00000
   VCID: 70B9D3A4D6A53F876E5-8024
Address 56: Radio (J503)       Labels: None
   Part No SW: 6J2 035 153 H    HW: 6J2 035 153 H
   Component: Radio         H15 0302
   Revision: R0000000    Serial number: SEZAZ2M4945439
   Coding: 0503020002
   Shop #: WSC 04941 000 00000
   VCID: 2B0304C833031C5F1B7-807E
00856 - Radio Antenna
                    Fault Status: 01111011
                    Reset counter: 64
                    Mileage: 86315 km
                    Date: 2013.03.03
                    Time: 00:10:20
End----------(Elapsed Time: 01:32, VBatt start/end: 12.1V/12.4V)-----------
thanks
Sebastian
Magdeburg, Germany
HN0-nnnnnn
As you can see from the scan - all other modules can't communicate with it either. Start by checking fuses.
Jamie_B
C?ID=345393
I've checked all the fuses for the ABS module. (including the ones at the battery)
Should I be checking other fuses?
Gone But Not Forgotten
Hello OP and welcome to the VCDS forum.
How about just measure for the voltage with aid of WD in RTFB and all inputs at the module plug & to isolate it is a module or a condition in the car?
If Woody only JPPSG, this thread never would of happened.
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
123 load lights if you dont!
Are you sure the ABS module is not a free recall repair for campaign?
Jamie_B
C?ID=345393
I've had a look over the wiring with a multimeter and the ABS module is getting power to the connector plug.
Still no communication possible via VCDS.
Is it looking like a new module required?
Jamie_B
C?ID=345393
I only checked for voltage. I'm assuming I'll need to check for current also?
iichel
Eindhoven, NB, NL
C?ID=284912
when checking power, always load test the wire
check the power on 1 and 25 (permanent +12V) and 28 or 25 (not sure you have ESP9.0i or ESP8.2i).
check GND to be OK on 13 and 38
furthermore, check communications on can powertrain on pins 15 and 26.
it is not often that these modules fail. i'd look for power, GND and and communications first.
Jamie_B
C?ID=345393
I found the issue , it was a broken wire which was a pain in the ass to trace but I got there.
Now the only issue I have is that the travtion control light remains on permanently and the code I have on VCDS points to a Steering Angle Sensor recalibration. I've not had much time so not looked into it a great deal but what I found was a security code i'd need of 40168 and that didn't work.
Anybody any ideas?
Jamie_B
C?ID=345393
  Sunday,28,October,2018,15:20:13:25280
   Shop #: WSC 131071 102 209715
No Fault Found
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 130248DB817500B4C82B12EA81D400821400
   Shop #: WSC 00788 648 00255
   VCID: 025D896CE4493D17881-8056
                    Fault Status: 01100101
                    Reset counter: 64
                    Mileage: 86315 km
                    Date: 2013.03.20
                    Time: 00:12:06
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x1251
                    Hex Value: 0x1B99
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
   Coding: 01
1140738 - Steering angle sensor
                    Reset counter: 64
                    Mileage: 86315 km
                    Date: 2018.10.28
                    Time: 00:12:40
                    Voltage terminal 15: 11.80 V
                    Voltage terminal 30: 12.10 V
   Coding: 030000
   Coding: 020000
   Coding: 003044
   Coding: 410A00
   Revision: BF046001
   Coding: 022300
   Coding: 11221
   Shop #: WSC 06402
   Coding: 0000001
   Coding: 0503020002
                    Reset counter: 64
                    Mileage: 86315 km
                    Date: 2013.03.20
                    Time: 00:13:22
End----------(Elapsed Time: 01:17, VBatt start/end: 14.3V/14.3V)-----------
Have you tried driving in parking lot in figure eights and backward or selecting basic settings available or adaption menu's and or does VCDS captions provide any procedures you missed?
I don't see any data in the wiki so you may need SVM unless RT wants to weigh in with more specific data.
Thank you for posting the scan.........
We don't have Seat or Skoda in the USA.........
This one should be pretty standard.
ABS module:
Check that Steering Angle sensor produces plausible values in MVB 005.1
Security Access with 40168, then Basic Settings, Group 060 for the steering angle sensor. I would think you have to move the steering wheel some and then re-center it before doing the Basic Setting.
That was what I thought too but would think there would be a fault if it was the same but was not sure.
