vw golf mk7 seat pretensioners
raf0468
C?ID=120244
Hi to all and thanks to admin for letting me be here..
i have sent details to be verified..
i have a golf7 which i have changed front pretensioners from donor vehicle, airbag light on off as normal.
i have message in dis "proactive passenger protection function restricted"
can vcds code donor pretensioners to the airbag ecu if so how..
vcds scan shows "pretensioners not configured as the fault.
thanks..
jakematic
NC USA
C?ID=129085
Welcome.
Please post a complete Auto-Scan so we can see what modules and version the vehicle has.
That way someone will be able to answer your question better. THanks-Jake
raf0468
C?ID=120244
here is full scan i did a few days back all faults are rectified apart from air bag configuration...
VIN: WVWZZZAUZEW098518   License Plate: GOLF 7 FULL
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A9
42-Door Elect, Driver -- Status: Cannot be reached 0100
Address 01: Engine (J623-CUNA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EQ    HW: 04L 907 309 A
   Component: R4 2,0L EDC   H22 6284
   Revision: 81H22---
   Coding: 011D0032036505082000
   ASAM Dataset: EV_ECM20TDI01104L906021EQ 002006
   ROD: EV_ECM20TDI01104L906021ER.rod
   VCID: 78FA6443C3A2CDDEA3D-802D
   Part No SW: 0D9 300 040 J    HW: 02E 927 770 AN
   Component: DQ250-6F MQB  H52 4027
   Revision: 05652104    Serial number: TFK01307160011
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 1E3652DB01C653EE891-804B
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 T    HW: 5Q0 907 379 H
   Component: ESC           H31 0556
   Revision: 00000000    Serial number: 6216300000012A
   Coding: 01FA8AA134290974037C060141CB2980512C90C0608294F5F862507AC109
   ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
   VCID: 4D94E5971CA0987620B-8018
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0705
   Revision: 00001K06
   Coding: 00120104202100011005000000101000
   ROD: EV_ACClimaBHBVW37X_SE37.rod
   VCID: 66C63A3B99164B2E011-8033
   Air quality sensor:
459021 - Databus
                    Reset counter: 182
                    Mileage: 10382 km
                    Date: 2014.09.30
                    Time: 21:14:07
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011323200403
   Coding: 03001A46C24122FB0BA44080B10C0728100A000000000000000000000000
   ROD: EV_BCMBOSCH_SE37.rod
   VCID: 77F8677FCEBCC2A6AA7-8022
   Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A
   Component: WWS    130802  042 0551
   Serial number:         130813180557
   Component: RLFS  024 0042
   Serial number: Y13M08D22H23M48S26S1
   Coding: 00A8DD
   Serial number: 000000000ZY132042FNB
   Serial number: 00000000000057027873
549909 - Databus
                    Reset counter: 182
                    Mileage: 10382 km
                    Date: 2014.09.30
                    Time: 21:14:07
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
   Component: PARKHILFE PLA 011 0029
   Revision: --------    Serial number: 61131313600324
   Coding: 0131061051
   ASAM Dataset: EV_EPHVA2CAU3700000 003014
   ROD: EV_EPHVA2CAU3700000_VW37.rod
   VCID: 3D74B557AC0028F6B0B-8068
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
   Component: ACC Bosch MQB H03 0141
   Serial number: 03071376510605
   Coding: 001C1300FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001013
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   VCID: 3564AD779430F0B678B-8060
   Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
   Component: AirbagVW20    011 0361
   Serial number: 003M1R04S49C
   VCID: 4A9EEE8BEDCE8F4E059-801F
   Seat belt tensioner; left:
   Serial number: 34169677B21021470636
   Coding: 333135
   Seat belt tensioner; right:
   Serial number: 34169676B20021440309
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 908 13
   Serial number: 35767000000879398D0%
   Subsystem 4 - Part No SW: -----------    HW: 480 000 708 13
   Serial number: 3586700000012D916D0V
   Subsystem 5 - Part No SW: -----------    HW: 480 401 908 13
   Serial number: 3516502C310EDE434318
   Subsystem 6 - Part No SW: -----------    HW: 480 401 908 13
   Serial number: 3526502C110EDE41708C
   Subsystem 7 - Part No SW: -----------    HW: 480 400 908 13
   Serial number: 3556502AF10EDE45718W
9634901 - Control Module for Front Left Belt Tensioner
          B1304 55 [009] - Not configured
                    Reset counter: 182
                    Mileage: 10382 km
                    Date: 2014.09.30
                    Time: 21:14:07
9635157 - Control Module for Front Right Belt Tensioner
          B1305 55 [009] - Not configured
                    Reset counter: 182
                    Mileage: 10382 km
                    Date: 2014.09.30
                    Time: 21:14:07
   Part No SW: 5Q0 953 507 AG    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 20081304220640
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 7BF07B4FF294E6C6CEF-802E
   Part No SW: 5G6 920 970 A    HW: 5G6 920 970 A
   Component: KOMBI         314 2210
   Coding: 27AD09082F90260001882A01000000
   VCID: 2E56821B7166C36E391-807B
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0000928733
   Coding: 030100040B087300EF00027E1C0F00010001000000000000000000000000
   ROD: EV_GatewLear_AU37.rod
   VCID: 3B70BB4FB21426C68EF-806E
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N
   Component: E221__MFL-DC1  H06 0038
   Serial number: 27130000784540103271
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 8046690903
131658 - Door Control Module - Driver's Door
          U0199 00 [009] - No Communications
                    Reset counter: 182
                    Mileage: 10382 km
                    Date: 2014.09.30
                    Time: 21:14:07
   Part No SW: 3Q0 909 144 D    HW: 3Q0 909 144 E
   Component: EPS_MQB_ZFLS  502 5011
   Coding: 8301
   ASAM Dataset: EV_SteerAssisMQB 009026
   ROD: EV_SteerAssisMQB.rod
   VCID: 3360936F9A44EE8656F-8066
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 13081304080712
   Coding: 003F0020DE01048000801000
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 3E76B25BA10633EEA91-806B
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
   Serial number: 00000000000002458942
   Coding: 050000
65570 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 182
                    Mileage: 10382 km
                    Date: 2014.09.30
                    Time: 21:14:07
65572 - Local Data Bus
          U10BA 00 [009] - No Communication
                    Reset counter: 182
                    Mileage: 10382 km
                    Date: 2014.09.30
                    Time: 21:14:07
Address 55: Xenon Range (J745)       Labels: 7P6-907-357.clb
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029E01000B000200
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
   Part No SW: 5G0 035 820 A    HW: 5G0 035 820 A
   Component: MU-S-D-ER     040 0421
   Serial number: V5C02108130655
   Coding: 02730000FF00000021111201002800001F0202060100010001
   ROD: EV_MUStd4CPASE_SE37.rod
   VCID: 1F486FDF06CC5AE6827-804A
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H50 0022
   Serial number: VWZ8Z9NJ70111R
   Component: SAS-GEN 2     H06 0011
   Serial number: 130608200339
   VCID: EBD0CB0F02F4F646DEF-80BE
John ler
C?ID=144693
Did you sort out this problem , I have the same both front belts only but can't remove fault ?? Thanks
John ler
C?ID=144693
Anyone or the opp I still have same fault code
raf0468
C?ID=120244
sorry did not see your earlier post, no it could not be done with vcds,
had someone with odis on line who coded them in for customer.
