Parking Sensors Front and Rear from Car-Systems Poland
Sandpipercruising
C?ID=348277
Hi
I have installed F+R parking sensors which beep as you approach an obstacle and this all works fine. The problem is that there is no graphic display showing on the Bolero and four faults found on the scan, anybody got any ideas as to what the problem might be and how to fix it?
Sunday,07,October,2018,16:59:43:22263
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBKG7NE3E0070343   Mileage: 78536km-48800miles
Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 5517
   Revision: 84H22---
   Coding: 01110012032501090000
   Shop #: WSC 46617 001 1048576
   ASAM Dataset: EV_ECM16TDI01104L906021M 002009
   ROD: EV_ECM16TDI01104L906021P.rod
   VCID: 2F3AE5B4E798230F37F-807A
   Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
   Component: EMB8 EHCB     H31 0356
   Revision: 00000000    Serial number: 6253300000038D
   Coding: 1C078A912427096C007A060441C6243851249000608224F0004300004002
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033.rod
   VCID: 4BC2912473407F2F3B7-801E
Address 08: Auto HVAC (J301)       Labels:. 5G0-907-426.clb
   Part No SW: 5E0 820 047 D    HW: 5E0 820 047 D
   Component: AC Manuell    H02 0604
   Revision: 00001K06
   Coding: 02110104000100001000000000400000
   ASAM Dataset: EV_ACManueBHBVW37X 002017
   ROD: EV_ACManueBHBVW37X_002_SK37.rod
   VCID: 23121984BB50976FA37-8076
   Part No SW: 5Q0 937 084 S    HW: 5Q0 937 084 S
   Component: BCM MQBAB M   H14 0112
   Serial number: 00011325002391
   Coding: 0F0008424207005307A04082B10407080000000000000000000000000000
   Shop #: WSC 73430 790 00104
   ROD: EV_BCMBOSCH_011.rod
   VCID: 48C8AE2862369437165-801C
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 130819  041 0570
   Serial number:         130903061717
   Coding: 065DDD
   Subsystem 2 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY131751YEB
   Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Serial number: 00000000000027757986
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39391603402459
   Coding: 0030051041
   Shop #: WSC 33361 790 09999
   VCID: 44D0BA185E1EB057FAD-8010
12658704 - Databus
          [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                    Reset counter: 217
                    Mileage: 78536 km
                    Date: 2018.10.06
                    Time: 16:58:35
12656921 - Databus
          [Bremsensteuergerät - ESP_24 - kein Signal/keine Kommunikation]
                    Reset counter: 217
                    Mileage: 78536 km
                    Date: 2018.10.06
                    Time: 16:58:35
12666390 - Databus
          [Diagnose-Interface für Datenbus-J533 - Gateway_79 - kein Signal/keine Kommunikation]
                    Reset counter: 217
                    Mileage: 78536 km
                    Date: 2018.10.06
                    Time: 16:58:36
13638913 - Databus
          [Steuergerät für Lenkhilfe-J500 - LH_EPS_03 - kein Signal/keine Kommunikation]
                    Reset counter: 217
                    Mileage: 78536 km
                    Date: 2018.10.06
                    Time: 16:58:35
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   011 0188
   Revision: --------    Serial number: 003P4PJYH9EL
   Coding: 98CCC000000000005C5400CC008800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5AF5F47778138FE7F-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 409 13
   Serial number: 3576U00000097D88DD0-
   Subsystem 2 - Part No SW: -----------    HW: 454 000 409 13
   Serial number: 3586U00000073B888D0O
   Subsystem 3 - Part No SW: -----------    HW: 454 800 509 13
   Serial number: 3516R97A3E2010000002
   Subsystem 4 - Part No SW: -----------    HW: 454 800 409 13
   Serial number: 3526R1EADE201000000C
   Subsystem 5 - Part No SW: -----------    HW: 454 800 508 13
   Serial number: 3556V95E0A2010000005
   Part No SW: 5Q0 953 507 AB    HW: 5Q0 953 549
   Revision: --------    Serial number: 12091304400665
   Coding: 9600
   ROD: EV_SMLSKLOMQB_012_AU37.rod
   VCID: 76B410D0584252C7B49-8022
   Part No SW: 5E0 920 951 E    HW: 5E0 920 951 E
   Component: KOMBI         103 3390
   Coding: 27240A002000A60001080800040000
   Shop #: WSC 73430 031 00104
   ASAM Dataset: EV_DashBoardJCIMQBAB 008011
   ROD: EV_DashBoardJCIMQBAB_008.rod
   VCID: 290E0BACD97C4D3FE9B-807C
   Part No SW: 5Q0 907 530 K    HW: 5Q0 907 530 D
   Component: GW MQB Low    123 1144
   Revision: --------    Serial number: 0001024369
   Coding: 030000040B087300EF000048080F00010001000000000000000000000000
   ROD: EV_GatewLear_009.rod
   VCID: 392EDBEC29DCFDBF99B-806C
   Subsystem 2 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 3778871303
   Part No SW: 5Q4 959 393     HW: 5Q4 959 393
   Component: TSG FS        007 0006
   Serial number: 0000075240555
   Coding: 001000208001020100001100
   VCID: 55F6775CA58439DF9D3-8000
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
   Component: EPS_MQB_ZFLS  127 1021
   Coding: 01
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D26CFFC3DF4C19FB53-8068
   Part No SW: 5Q4 959 392     HW: 5Q4 959 392
   Component: TSG BFS       007 0006
   Serial number: 0000075257401
Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-STD1.clb
   Part No SW: 5E0 035 820 A    HW: 5E0 035 820 A
   Component: MU-S-D-ER     040 0421
   Serial number: S5C01109132301
   Coding: 03730200FF0000001111120100A800002F0000860100010000
   Shop #: WSC 73430 790 00063
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 1D662F7C9D34A19F953-8048
   Subsystem 1 - Part No SW: 5E0 919 605     HW: 5E0 919 605
   Component: ABT_Std_Radio  H50 0022
   Serial number: SKZ8Z9NL2007JR
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 217
                    Mileage: 78536 km
                    Date: 2018.10.06
                    Time: 16:50:18
                    Voltage terminal 30: 11.9 V
                    BAP-BAP_Function_ID: 02
End----------(Elapsed Time: 01:03, VBatt start/end: 12.0V/12.0V)-----------
downtime
Finland
C?ID=280813
Car is Octavia right? First thing you need to re-parameterize the unit with skoda dataset. That will get rid of those epb errors in park assist module.
Then you probably have the 5F adaptations missing for park pilot. Can you post an adamap of 5f module? Go to vcds -> applications-> controller channel maps and put 5f as the module, output csv and then go. Paste the csv content here using CODE taga.
Sandpipercruising
C?ID=348277
Thanks for your prompt response to my problem but it is now solved, the instructions I received with the kit were incorrect. The can bus connections were not pins 6 and 16 as per instructions but pins 8 and 18.Thanks again.
