Audi A6 C7 Facelift Saloon rear camera retro fit coding
DaveN
Ireland
C?ID=62381
Hi
I got the kufatec kit for the RVC for >2015 C7, mine is a 2017. I did the wiring and camera install and then used their dongle, but no dice there is no picture only the sensor information.
Scan below, I'm getting a 5F coding error which is only since using the dongle, any advice on what I am missing.
I thought the dongle would do the required coding but it doesnt look like it to me.
I've contacted kufatec but its driving me mad as I've traced all the wiring which looks good so it must be coding.
Dave N
Sunday,07,October,2018,12:24:05:21606
VCDS Version: 18.9.0.2 (x64)
VIN: WAUZZZ4GXHN088186   License Plate: 171
Mileage: 27700km-17211mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 36 3B 42 44 46 52 53 55
          5F 62 72 AC
VIN: WAUZZZ4GXHN088186   Mileage: 27700km-17211miles
Address 01: Engine (J623-DDDA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 HA    HW: 04L 907 309 AA
   Component: R4 2.0l TDI   H20 3830
   Revision: 8DH20---
   Coding: 0A254012242401080000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TDI01104L906021HA 004003
   ROD: EV_ECM20TDI01104L906021HA_004.rod
   VCID: 6BDFE8AB82D1961210-803E
   Part No SW: 4G1 927 153 B    HW: 0CJ 927 156
   Component: 0CK 20TDI RdW H03 0004
   Revision: --H03---    Serial number: 0000001066
   Coding: 100001
   ASAM Dataset: EV_TCMDL382021 002024
   ROD: EV_TCMDL382021_AU57.rod
   VCID: 2953D2A348AD4402A2-807C
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  002 0572
   Serial number: 75117071160363001574
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 06A29E41604579829B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41836A03D0DDAC429A-8014
   Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
   Component: BCM2 2.0      H61 0825
   Coding: 01B8704E000000000000
   VCID: 7CFDDBF7FFBF01AA89-8028
   Serial number: 3216000310830004
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 10011700041460
   Coding: 34210978210000
   VCID: 63CF808B6A01DE52A8-8036
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0368
   Revision: 15020001    Serial number: 00001560597301
   Coding: 0105001440349FE041014083800018004F9DC3082F08020100000894E100140200400024030000
   VCID: 74EDF3D7D7EF49EAC1-8020
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 161106  H38 0080
   Serial number:         161118210045
   Coding: 004DF7
   Serial number: 20055425X81A955547A0
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 11 01 2017  00000991
   Subsystem 4 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 7668426800PAG0MUFU03
   Component: Airbag10.43   H82 0092
   Revision: --------    Serial number: 003P100CC86O
   Coding: 30333130313630323639554A305234473053
   VCID: 3B7F18EBB231C692C0-806E
   Serial number: 3575HRB405N492DA7OOS
   Serial number: 3585HRB405P480GQEGP4
   Serial number: 3515JRB400257HS4LGSV
   Serial number: 3525JRB400257HS4F28Z
   Serial number: 3554VRB400A57J2CJ8BB
   Serial number: 3564VRB400A57J2CL9MQ
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 91560QA3001OD
   Coding: 000034
   VCID: 3B7F18EBBA31C692C0-806E
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 09 01 2017  D0004873
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G8 920 987 R    HW: 4G8 920 987 R
   Component: TDieGb        H15 0225
   Revision: 15001308    Serial number: 658131216596000
   Coding: 33AF0D000B410008010000
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K.rod
   VCID: 48957727F3E79D0A5D-801C
   Part No SW: 4G8 907 468 H    HW: 4G8 907 468
   Revision: --------    Serial number: 00000002488565
   Coding: C0CD074418
   VCID: 3D7B16F3AC25C8A2FE-8068
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 4087662504
   Voltage stabilizer:
   Serial number: 16070500000000000796
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04028264747464545425363E00
   VCID: 67D7949B9639B27274-8032
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0113
   Serial number: 17011700040604
   Coding: 22
   Revision: AA000000    Serial number: 00000226698609
   Coding: 0078130000006001000001010101102030303232203232
   VCID: 77F7C4DBC69922F2E4-8022
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720UVBF4
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 336F30CB9A610ED218-8066
   Component: TSG FA        H03 0511
   Coding: 011C16015E01620002080002
   VCID: 4797741BF6F9927254-8012
   Component: RCevo         H54 0202
   Revision: 00000002    Serial number: 0000537238
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A711DEFBD0BFF9ADB-806E
   Revision: 00002001    Serial number: 0428730909
   Coding: 011B062280B90080C320088400010E470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 B
   Component: Sensor, DWA  005 0002
   Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00027728635
   Component: TSG BF        H03 0511
   VCID: 4689791FF1F38B7AAF-8012
   Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
   Component: EPB-4         H01 0018
   Revision: --------    Serial number: 00000002062700
   ASAM Dataset: EV_ParkiBrake 001033
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 326135CF657B07DA13-8066
   Coding: 04FE02102A630200
   VCID: 346D33D79F6F09EA01-8060
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 021 G    HW: 4G1 035 021 D
   Component: MU-H-LND-EU   053 0910
   Serial number: A733A0H7531579
   Coding: 017501010000000013111102000A00332F0006E7F1700100DF
   VCID: 1E39F17F01E3B3BAC7-804A
   Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9GY806V42
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349QAG000C5
   Compact Disc Database:
   Component: Gracenote2  --- 1015
7179 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 199
                    Mileage: 27700 km
                    Date: 2018.10.07
                    Time: 12:17:43
                    Voltage terminal 30: 11.7 V
                    BAP-BAP_Function_ID: 02
   Component: TSG HL        H03 0511
   Coding: 010814004001620002080002
   VCID: 49937223E0ED640242-801C
   Component: TSG HR        H03 0511
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 163200969
   ROD: EV_RDCMA00100_008.rod
   VCID: 2F673CBB76492A327C-807A
End-------------------------(Elapsed Time: 04:55)--------------------------
DaveN
Ireland
C?ID=62381
Issue resolved, the Kufatec module does not so all the coding. All working with some additional VCDS coding
