Coding questions, can you help me?
kisscool2effects
France
C?ID=159048
Hello everybody,
I have different question about my coding. First, I have permanently a error with my tire pressure, do you known this problem?
Second, I would to know if is possible to configure xds in my car. It's my first car, that haven't long coding helper to ABS modul. In my ABS modul, when I go to adaptation, I have one choice in the drop down menu, but I have test different channel and I see that It's possible to change different parameter. The problem is that haven't description about this different parameter. I have good Tire but I think that my ASR is too permissive, it's possible to change this.
Thanks for your help :)
My code:
Monday,03,November,2014,23:48:37:47342
VCDS Version: 14.10.0.0
Data version: 20141022
Workshop Code: 444 54321 054321
VIN: WVWZZZ7NZDV010066   License Plate:
Mileage: 79730km-49541mi   Repair Order:
Chassis Type: 7N (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 37 42 44 46 4C 4F 52 53
          55 56 61 62 69 6C 72 77 BE BF
VIN: WVWZZZ7NZDV010066   Mileage: 79730km-49541miles
37-Navigation -- Status: Sporadic communication error 1000
56-Radio -- Status: Sporadic communication error 1000
BE-Sliding Door Left -- Status: OK 0000
BF-Sliding Door Right -- Status: OK 0000
Address 01: Engine (J623-CFGB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 G    HW: 03L 907 309 Q
   Component: R4 2,0L EDC   H27 9240
   Revision: 44H27---    Serial number:
   Coding: 001D001A043401080000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM20TDI01103L906018G 003005
   ROD: EV_ECM20TDI01103L906018G.rod
   VCID: 2E59202771AFAB51CD7-807B
   Part No SW: 02E 300 058 K    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3503
   Revision: 05551213    Serial number: 00001206301771
   Shop #: WSC 00020 000 90108
   VCID: 2241C417FD771F3159F-8077
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 R    HW: 7N0 614 109 R
   Component: J104   C3 450M VD67 0023
   Revision: --H07---    Serial number: 00000006086070
   Coding: 0027171
   Shop #: WSC 00020 790 00000
   VCID: 3C7D1A6F7FD349C1733-8069
   Part No SW: 7N0 907 044 F    HW: 7N0 907 044 F
   Component: Clima-Sharan  H01 0202
   Revision: 00001K03
   Coding: 0210104449
   VCID: 336F31539A8D86B9A29-8066
   Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
   Component: BCM PQ35 M    021 0068
   Revision: BC021001
   Coding: 40180A3BE9251AC0408800C1740089E447FD1408636D2D22E484C72000C1
   Shop #: WSC 54321 444 54321
   VCID: 3E791067A9CF5BD15D7-806B
   Subsystem 1 - Part No SW: 7N1 955 119 A    HW: 7N1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    120620  31  0032
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0024
   Coding: 0680BB
                    Reset counter: 66
                    Mileage: 77203 km
                    Date: 2014.09.24
                    Time: 23:21:00
                    Voltage: 12.10 V
Address 10: Park/Steer Assist (J446)       Labels: 1Q0-919-475.clb
   Part No SW: 7N0 919 475 A    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0012
   Revision: --------    Serial number: 28201220600793
   Coding: 318101
   ASAM Dataset: EV_EPHVA18VW4280000 001005
   ROD: EV_EPHVA18VW4280000.rod
   VCID: 3973037BB8E17CE9685-806C
   Part No SW: 7N0 959 655 C    HW: 7N0 959 655 C
   Component: VW10Airbag004 H10 0014
   Serial number: 003LGPEJ3VUX
   Coding: 003034
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
   ROD: EV_AirbaVW10TS6VW428_VW36.rod
   VCID: 3F876D63A6C552D9561-806A
   Serial number: 3493ETS6029828B16DD/
   Serial number: 3503ETS60F0448F16DD
   Serial number: 3513ETS60B03F9016DDV
   Serial number: 3523ETS60F815AE16DD4
   Serial number: 35540TS6068D39D16DD-
   Part No SW: 5K0 953 501 BA    HW: 5K0 953 569 H
   Revision: FF010041    Serial number: 20120814301357
   Coding: 198A240000
   VCID: 6AD1EC378DC70771D1F-803F
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Component: E221__MFL-TK6  H07 0022
   Coding: E20000
   Part No SW: 7N0 920 870 G    HW: 7N0 920 870 G
   Component: KOMBI         H05 0705
   Coding: 140F01
   ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
   VCID: 3669084789FF9391857-8063
   Part No: 7N0 963 271 E
   Component: Zuheizer        051 2940
   Revision: 00051000    Serial number: 09024297000000
   Coding: 0000041
   VCID: 3669084741FF9391857-8063
   Part No SW: 7N0 907 530 T    HW: 7N0 907 530 K
   Component: J533  Gateway H40 1632
   Revision:   H40       Serial number: 310712F2000039
   Coding: 468002
   VCID: 41836B9BD8312429205-8014
                    Fault Status: 00110100
                    Reset counter: 113
                    Mileage: 77924 km
                    Date: 2014.10.03
                    Time: 01:13:50
01304 - Radio
                    Reset counter: 113
                    Mileage: 77924 km
                    Date: 2014.10.03
                    Time: 01:13:50
   Component: IMMO          H05 0705
   Part No SW: 1T0 035 680 P    HW: 1T0 035 680 H
   Component: RNS-MID       H70 5238
   Revision: AB001001    Serial number: VWZ6Z7M9223084
   Coding: 04000402040000A0000D
   VCID: 3B7F1973BADD4EF97A9-806E
   Component: EU West V11  8117
Address 42: Door Elect, Driver (J386)       Labels: 7N0-959-793.clb
   Part No SW: 7N0 959 793 G    HW: 7N0 959 793 G
   Component: TSG FA        H02 0553
   Revision:             Serial number: 0000033897976
   Coding: 01152E20D000411011
   VCID: 46897887F11F0311157-8013
   Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.324 1101
   Revision: 1AH03735    Serial number: 00121950265501
   Coding: 0000258
   VCID: 3D7B176B64C940C944D-8068
Address 4C: Tire Pressure II
   Part No SW: 7N0 907 532     HW: 7N0 907 530 K
   Component: EZE_2         H40 1632
   Coding: 050A0500
   VCID: 6FE7FD23BE25E259861-803A
   Component: J245EE20SKB13  H03 0220
   Component: J394EE20SKB13  H03 0220
Address 52: Door Elect, Pass. (J387)       Labels: 7N0-959-792.clb
   Part No SW: 7N0 959 792 G    HW: 7N0 959 792 G
   Component: TSG BF        H02 0553
   Revision:             Serial number: 0000033930164
   Coding: 01152C20DE00411011
   VCID: 458B7F8BCC1908091CD-8010
02119 - Potentiometer for Vertical Mirror Adjustment
                    Fault Status: 00101100
                    Reset counter: 139
                    Mileage: 77545 km
                    Date: 2014.09.27
                    Time: 16:35:00
   Revision:   H19       Serial number: 00000000366894
   Coding: 0024167
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Component: AFS-ECU       H04 0111
   Coding: 058200000F000200
   ROD: EV_HeadlRegulVWAFSPt.rod
   VCID: 377705438EF56A999E1-8062
   Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329
   Component: LeiMo links  H06 0007
   Coding: 360000
   Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329
   Component: LeiMo rechts  H06 0007
   Coding: 360000
   Part No SW: 7N0 907 534     HW: 7N0 907 530 K
   Component: Batt.regelung H40 1632
   Coding: 230F1859
   VCID: 71E3FB5BA811F4A9905-8024
   Component: J367-BDM  H07 0180
Address 62: Door, Rear Left (J388)       Labels: 7N0-959-794.clb
   Part No SW: 7N0 959 794 H    HW: 7N0 959 794 H
   Component: TSG HL        H01 0553
   Revision:             Serial number: 0000128209631
   Coding: 01006C200000411001
   VCID: 489576BFFB0B1561E7B-801D
Address 69: Trailer (J345)       Labels: 7N0-907-383.clb
   Part No SW: 7N0 907 383     HW: 7N0 907 383
   Component: Anhaenger     H09 0120
   Revision: 3I001003    Serial number: 00008160029705
   Coding: 410C040001000000
   VCID: 73EFF153D20DC6B9629-8026
   Part No SW: 7N0 907 441     HW: 7N0 907 441
   Component: J772__Rearview      0020
   Revision: 00H11000    Serial number: 525 PA8J265653
   Coding: 0030011
   VCID: 6ED9E027792FEB518D7-803B
Address 72: Door, Rear Right (J389)       Labels: 7N0-959-794.clb
   Component: TSG HR        H01 0553
   Revision:             Serial number: 0000128211950
   Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
   Revision: 1B001001    Serial number: 00007663029946
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
Address BE: Sliding Door Left (J558)       Labels: 7N0-959-244.clb
   Part No SW: 7N0 959 244 A    HW: 7N0 959 244 A
   Component: Schiebetuer_l 005 2314
   Serial number: 12259684
   ASAM Dataset: EV_AST A03704
   ROD: EV_AST.rod
Address BF: Sliding Door Right (J731)       Labels: 7N0-959-244.clb
   Component: Schiebetuer_r 005 2314
   Serial number: 12259295
   ROD: EV_AST.rod
End-------------------------(Elapsed Time: 04:08)--------------------------
Dreman
DE
C?ID=92289
1) Gateway Installation List: '4C-Tire Pressure II -- Status: OK 0000' >> everything is ok
Autoscan 'Tire Pressure II /adress 4C' is only a virtual Control Module and 'cannot be reached' >> everything is ok
2) XDS: adress 03, Adaption, set channel 67 to '1' (in my Alhambra 7N, 2012, it's working)
kisscool2effects
France
C?ID=159048
Thanks so mutch Dreman ;), I go to test it.
kisscool2effects
France
C?ID=159048
Hello Dreman,
In my Sharan, the channel 67 is already set to 1. I read, channel 1 to 100 and I constat that isn't coding as my Seat Altea or as my ex Skoda. In this two last vehicule, in channel 9 have the brake asist, but in my Sharan this channel isn't read. When I do my test, I constat that have 3 or 4 channel that is possible to choose with "normal", "early" or "late". Have test with channel 58 (normaly is use for Hill Hold Assist in other car) and set it to "early". When I test in road, have impression that modify the XDS Lock. When I have more time, I tested the different parameter to confirm that or not.
Do you have test to activate Brake Booster in channel 61? Somebody know the feature of this parameter?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Your Sharan uses a TRW ABS/ESP system, while the Altea/Octavia/Superb are using a Continental system. Channel layout and coding table will differ due to the different systems and suppliers.
The brake booster settings are related to the vacuum system and is necessary to make sure the brake system is working effectively. I'd strongly recommend not play with any of these values in the first place. XDS is more a toy, but tweaking some of the others may get you in trouble if you're in situations that are borderline to begin with.
kisscool2effects
France
C?ID=159048
Thanks for your answer Sebastian, that's I wanted to know. Do you Know if in my TRW system, the channel 58 is use for change the XDS Lock or for an other parameter? If it's used by a other parameter, do you know if it's possible to change XDS Lock as Channel 36 in Continental System?
Thanks for your answer :)
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Can you run a control module map (adaptation) on your specific module please? Make sure to use sec. access 50403 for that.
kisscool2effects
France
C?ID=159048
Ok Sebastian, I do this afterwork :)
kisscool2effects
France
C?ID=159048
Sebastian,
the control module map:
;SW:7N0-614-109-R   HW:7N0-614-109-R ---  ABS Brakes
;Component:J104   C3 450M VD69 0023, Coding:0027171
;Wednesday,05,November,2014,18:46:39:47342
;VCDS Version: Release 14.10.0  Data version: 20141022
;VCID: 3C7D1A6F7FD349C1733-8069
;01 N/A
;02 N/A
;03 N/A
A04,0,
;0
A04,1,
;Adaptation
A04,2,
;Tire Pressure
A04,3,
;N/A
A04,4,
;N/A
A05,0,
;2
A05,1,
;Adaptation
A05,2,
;Tire Pressure
A05,3,
;N/A
A05,4,
;N/A
;06 N/A
;07 N/A
;08 N/A
;09 N/A
;10 N/A
;11 N/A
;12 N/A
;13 N/A
;14 N/A
;15 N/A
;16 N/A
;17 N/A
;18 N/A
;19 N/A
;20 N/A
A21,0,
A21,1,
;ERROR:
A21,2,
;Security
A21,3,
;access
A21,4,
;required
;22 N/A
;23 N/A
;24 N/A
;25 N/A
;26 N/A
;27 N/A
;28 N/A
;29 N/A
;30 N/A
A31,0,
;0
A31,1,
;Enabled
A31,2,
;N/A
A31,3,
;N/A
A31,4,
;N/A
;32 N/A
A33,0,
A33,1,
;ERROR:
A33,2,
;Security
A33,3,
;access
A33,4,
;required
;34 N/A
;35 N/A
;36 N/A
;37 N/A
;38 N/A
;39 N/A
A40,0,
A40,1,
;ERROR:
A40,2,
;Security
A40,3,
;access
A40,4,
;required
A41,0,
A41,1,
;ERROR:
A41,2,
;Security
A41,3,
;access
A41,4,
;required
A42,0,
A42,1,
;ERROR:
A42,2,
;Security
A42,3,
;access
A42,4,
;required
;43 N/A
A44,0,
;1
A44,1,
;Enabled
A44,2,
;N/A
A44,3,
;N/A
A44,4,
;N/A
;45 N/A
;46 N/A
;47 N/A
;48 N/A
;49 N/A
;50 N/A
A51,0,
A51,1,
;ERROR:
A51,2,
;Security
A51,3,
;access
A51,4,
;required
;52 N/A
A53,0,
;1
A53,1,
;Rear Axle
A53,2,
;Full
A53,3,
;Delay
A53,4,
;Enabled
;54 N/A
A55,0,
;2
A55,1,
;Brake discs
A55,2,
;drying
A55,3,
;Enabled
A55,4,
;Stage 2
A56,0,
;1
A56,1,
;Trailer
A56,2,
;Function
A56,3,
;Enabled
A56,4,
;N/A
A57,0,
A57,1,
;ERROR:
A57,2,
;Security
A57,3,
;access
A57,4,
;required
A58,0,
;1
A58,1,
;Early
A58,2,
;Enabled
A58,3,
;N/A
A58,4,
;N/A
A59,0,
;1
A59,1,
;Engine
A59,2,
;OFF
A59,3,
;N/A
A59,4,
;N/A
;60 N/A
A61,0,
;0
A61,1,
;Brake Booster
A61,2,
;Deactivated
A61,3,
;N/A
A61,4,
;N/A
;62 N/A
A63,0,
;1
A63,1,
;Test
A63,2,
;Enabled
A63,3,
;N/A
A63,4,
;N/A
;64 N/A
A65,0,
;2
A65,1,
;normal
A65,2,
;Enabled
A65,3,
;N/A
A65,4,
;N/A
;66 N/A
A67,0,
;1
A67,1,
;Enabled
A67,2,
;N/A
A67,3,
;N/A
A67,4,
;N/A
;68 N/A
;69 N/A
;70 N/A
;71 N/A
;72 N/A
A73,0,
;1
A73,1,
;Enabled
A73,2,
;N/A
A73,3,
;N/A
A73,4,
;N/A
;74 N/A
A75,0,
;1
A75,1,
;Enabled
A75,2,
;N/A
A75,3,
;N/A
A75,4,
;N/A
;76 N/A
A77,0,
;1
A77,1,
;Adaptation
A77,2,
;Performed
A77,3,
;N/A
A77,4,
;N/A
;78 N/A
;79 N/A
;80 N/A
A81,0,
;0
A81,1,
;Deactivated
A81,2,
;N/A
A81,3,
;N/A
A81,4,
;N/A
;82 N/A
;83 N/A
;84 N/A
;85 N/A
;86 N/A
;87 N/A
;88 N/A
;89 N/A
;90 N/A
;91 N/A
;92 N/A
;93 N/A
A94,0,
A94,1,
;ERROR:
A94,2,
;Security
A94,3,
;access
A94,4,
;required
;95 N/A
;96 N/A
;97 N/A
;98 N/A
;99 N/A
;100 N/A
;101 N/A
;102 N/A
;103 N/A
;104 N/A
;105 N/A
;106 N/A
;107 N/A
;108 N/A
;109 N/A
;110 N/A
;111 N/A
;112 N/A
;113 N/A
;114 N/A
;115 N/A
;116 N/A
;117 N/A
;118 N/A
;119 N/A
;120 N/A
;121 N/A
;122 N/A
;123 N/A
;124 N/A
;125 N/A
;126 N/A
;127 N/A
;128 N/A
;129 N/A
;130 N/A
;131 N/A
;132 N/A
;133 N/A
;134 N/A
;135 N/A
;136 N/A
;137 N/A
;138 N/A
;139 N/A
;140 N/A
;141 N/A
;142 N/A
;143 N/A
;144 N/A
;145 N/A
;146 N/A
;147 N/A
;148 N/A
;149 N/A
;150 N/A
;151 N/A
;152 N/A
;153 N/A
;154 N/A
;155 N/A
;156 N/A
;157 N/A
;158 N/A
;159 N/A
;160 N/A
;161 N/A
;162 N/A
;163 N/A
;164 N/A
;165 N/A
;166 N/A
;167 N/A
;168 N/A
;169 N/A
;170 N/A
;171 N/A
;172 N/A
;173 N/A
;174 N/A
;175 N/A
;176 N/A
;177 N/A
;178 N/A
;179 N/A
;180 N/A
;181 N/A
;182 N/A
;183 N/A
;184 N/A
;185 N/A
;186 N/A
;187 N/A
;188 N/A
;189 N/A
;190 N/A
;191 N/A
;192 N/A
;193 N/A
;194 N/A
;195 N/A
;196 N/A
;197 N/A
;198 N/A
;199 N/A
;200 N/A
;201 N/A
;202 N/A
;203 N/A
;204 N/A
;205 N/A
;206 N/A
;207 N/A
;208 N/A
;209 N/A
;210 N/A
;211 N/A
;212 N/A
;213 N/A
;214 N/A
;215 N/A
;216 N/A
;217 N/A
;218 N/A
;219 N/A
;220 N/A
;221 N/A
;222 N/A
;223 N/A
;224 N/A
;225 N/A
;226 N/A
;227 N/A
;228 N/A
;229 N/A
;230 N/A
;231 N/A
;232 N/A
;233 N/A
;234 N/A
;235 N/A
;236 N/A
;237 N/A
;238 N/A
;239 N/A
;240 N/A
;241 N/A
;242 N/A
;243 N/A
;244 N/A
;245 N/A
;246 N/A
;247 N/A
;248 N/A
;249 N/A
;250 N/A
;251 N/A
;252 N/A
;253 N/A
;254 N/A
;255 N/A
kisscool2effects
France
C?ID=159048
Sebastian, do you know what the different parameter of adaptation is use for my ABS modul. I share the control map.
kisscool2effects
France
C?ID=159048
Nobody have a listing of different fonctions of adaptation in my ABS modul controler????
