2016 Jetta TSI - Horn & Cruise Control issue
TDIGUY
Canada
C?ID=231060
2016 Jetta TSI SE model. 3VW267AJ9GM326990
The car was in an accident and bought it in a semi-completed repair state. Airbags were replaced and the horn and cruise control buttons do not work. The dash shows a cruise control "ERR" as well.
I believe the person before me replaced the clockspring and I also just purchased another clockspring in an attempt to fix the issue but even with the new clockspring (5C0959653) The same issue is still present.
Horn sounds with remote fob when locking so I know that works.
Is there any programming I need to do with VCDS or anybody have any ideas?
TDIGUY
Canada
C?ID=231060
Please post an auto-scan and observe the WD for fuses and tracks, in addition to VCDS measuring blocks for functions of the horn or cruise switches.
Did you save the legacy scan with old clock spring?
JPPSG
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
Thanks for the insight Jack!
I got the car in shambles and the original airbag and clockspring had already been replaced by the previous owner. I'll post up an autoscan later tonight when I get home. What is the WD? I went through all the fuses but I'll do it again just to be certain.
NostraJackAss
ERWIN
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
RTFB = Read the factory Book
WD = Wire diagram
https://forums.ross-tech.com/showth...ad-wiring-diagrams-the-videos-(final-version)
Jef
HQ
An Auto-Scan would be most helpful about now. :)
TDIGUY
Canada
C?ID=231060
Finally got around to pulling an autoscan. I know not the healthiest checkup list but I at least want the horn/steering wheel buttons to function :rolleyes:
Thursday,11,July,2019,12:12:23:61224
VCDS Version: 19.6.0.2 (x64)
VIN: 3VW267AJ9GM326990   License Plate: 2016JETTA
Mileage: 77670km-48261mi   Repair Order:
Chassis Type: AJ-VW36 (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 5F
VIN: 3VW267AJ9GM326990   Mileage: 77670km-48261miles
Address 01: Engine (J623-CZTA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023 AQ    HW: 04E 907 309 AP
   Component: R4 1.4l TFS   H22 2954
   Revision: X5H22---
   Coding: 011A0012232400000000
   Shop #: WSC 00066 790 00015
   ASAM Dataset: EV_ECM14TFS01104E906023AQ 003003
   ROD: EV_ECM14TFS01104E906023AQ.rod
   VCID: 6FEDF96DB672243778-803A
   CAN Converter 01:
21086 - Injector: Cylinder 2 (N31)
          P0202 00 [236] - Circuit Malfunction
                    Mileage: 77015 km
                    Date: 2019.07.09
                    Time: 06:03:02
                    Engine speed: 1786.00 /min
                    Normed load value: 54.5 %
                    Vehicle speed: 95 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 14.418 V
                    Outside air temperature: 16 °C
                    Absolute intake pressure: 116 kPa abs
                    Engine torque: 155.3 Nm
                    Fuel level: 50.00 l
                    E-machine torque actual value: 0.0 Nm
4481 - Cruise Control Switch (E45)
          P0568 00 [047] - Implausible Signal
                    Mileage: 62465 km
                    Date: 2019.05.03
                    Time: 11:52:19
                    Engine speed: 0.00 /min
                    Coolant temperature: 84 °C
                    Intake air temperature: 56 °C
                    Voltage terminal 30: 12.109 V
                    Outside air temperature: 34 °C
                    Absolute intake pressure: 95 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel level: 18.00 l
4482 - Function Restriction due to Implausible Message(s)
          U1112 00 [032] - -
                    Mileage: 69803 km
                    Date: 2019.06.03
                    Time: 07:19:51
                    Engine speed: 1634.50 /min
                    Normed load value: 18.8 %
                    Vehicle speed: 38 km/h
                    Coolant temperature: 90 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 13.970 V
                    Unlearning counter according OBD: 19
                    Outside air temperature: 25 °C
                    Absolute intake pressure: 59 kPa abs
                    Engine torque: 56.8 Nm
                    Fuel level: 11.00 l
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [237] - -
                    Mileage: 77022 km
                    Date: 2019.07.09
                    Time: 06:07:41
                    Engine speed: 1652.00 /min
                    Normed load value: 12.2 %
                    Vehicle speed: 90 km/h
                    Coolant temperature: 92 °C
                    Intake air temperature: 24 °C
                    Outside air temperature: 18 °C
                    Absolute intake pressure: 33 kPa abs
                    Engine torque: 17.2 Nm
                    Fuel level: 50.00 l
10591 - Cylinder 1
          P0301 00 [096] - Misfire Detected
                    Mileage: 77024 km
                    Date: 2019.07.09
                    Time: 06:08:54
                    Engine speed: 1455.50 /min
                    Vehicle speed: 78 km/h
                    Coolant temperature: 91 °C
                    Voltage terminal 30: 14.229 V
                    Absolute intake pressure: 50 kPa abs
                    Engine torque: 59.9 Nm
                    Fuel level: 50.00 l
10592 - Cylinder 2
          P0302 00 [237] - Misfire Detected
                    Mileage: 77022 km
                    Date: 2019.07.09
                    Time: 06:07:42
                    Absolute intake pressure: 105 kPa abs
                    Engine torque: 132.5 Nm
                    Fuel level: 50.00 l
   Part No SW: 09G 927 749 AA    HW: 09G 927 749 AA
   Component: AISIN AG6 G3  129 2944
   Coding: 010200000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW26.rod
   VCID: 78FFC231C33C638FA9-802C
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: A14B400C49240000851402ED9219004120100012
   Shop #: WSC 00066 000 00000
   VCID: 75E1CB05DC2E1EE7B2-8020
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 CK    HW: 5C0 820 047 CK
   Component: J301  Klimaanlage   0210
   Revision: 2001402S    Serial number: 00000003102194
   VCID: 6BD5ED7D4A6AD81754-803E
   Part No SW: 7E0 937 189     HW: 7E0 937 189
   Component: BCM PQ25 MMI3 H80 0736
   Revision: BA080001    Serial number: 18007027161094
   Coding: 7B994B1808AB0B0000392080240884D50FC6702E60004070B00010032844
   VCID: 71E9FF15A84632C76E-8024
   Subsystem 1 - Part No SW: 6R0 959 801 DF    HW: 6R0 959 801 DF  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  019 1467
   Serial number: 14202743151215032718
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 DJ    HW: 6R0 959 802 DJ  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  019 1467
   Serial number: 14102742160107085358
   Coding: 820000
   Subsystem 3 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
   Serial number: 3321503290000309AD1B
   Coding: 280000
   Subsystem 4 - Part No SW: 6R0 959 811 T    HW: 6R0 959 811 T
   Component: J388__TSG_HL  019 1467
   Serial number: 14102745160111110556
   Subsystem 5 - Part No SW: 6R0 959 812 T    HW: 6R0 959 812 T
   Component: J389__TSG_HR  019 1467
   Serial number: 14102744151211154658
                    Fault Status: 00100111
                    Reset counter: 68
                    Mileage: 75211 km
                    Date: 2019.06.30
                    Time: 14:36:32
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    001 0207
   Serial number: 003RXM03GR68
   Coding: 8CCCF000000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411_VW32.rod
   VCID: 63C5855D6ABA9057EC-8036
   Component: BF-Gewichtss.  H12 0021
   Serial number: IBH000000000004EW2S/
   Coding: 303141
   Subsystem 2 - Part No SW: -----------    HW: 480 002 511 15
   Serial number: 35700000000F350D381K
   Subsystem 3 - Part No SW: -----------    HW: 480 002 511 15
   Serial number: 358000000004450D381B
   Subsystem 4 - Part No SW: -----------    HW: 480 021 011 15
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001B91C24B843582
   Subsystem 5 - Part No SW: -----------    HW: 480 021 011 15
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001BF1E054A3B289
   Subsystem 6 - Part No SW: -----------    HW: -----------
   Component: FrontSensor_D  --- ----
   Serial number: -------------------$
   Subsystem 7 - Part No SW: -----------    HW: 480 022 210 15
   Component: FrontSensor_P  000 0189
   Serial number: 3560001AD1DDB595E3E/
12 Faults Found:
9438490 - Igniter for Driver head airbag
          B1005 1A [137] - Resistance Too Low
                    Mileage: 17233 km
                    Date: 2017.10.16
                    Time: 00:03:17
          B1000 1B [136] - Resistance Too High
                    Mileage: 17139 km
                    Date: 2017.06.06
                    Time: 21:33:31
          B1006 1B [137] - Resistance Too High
                    Mileage: 17139 km
                    Date: 2017.06.06
                    Time: 21:33:31
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [136] - Resistance Too High
                    Mileage: 17139 km
                    Date: 2017.06.06
                    Time: 21:33:31
9438491 - Igniter for Driver head airbag
          B1005 1B [136] - Resistance Too High
                    Mileage: 17139 km
                    Date: 2017.06.06
                    Time: 21:33:31
9438235 - Igniter for Front passenger's Head Curtain Airbag
          B1004 1B [136] - Resistance Too High
                    Mileage: 17139 km
                    Date: 2017.06.06
                    Time: 21:33:31
9442075 - Driver's Belt Force Limiter Igniter
          B1013 1B [136] - Resistance Too High
                    Mileage: 17139 km
                    Date: 2017.06.06
                    Time: 21:33:31
9442331 - Passenger's Belt Force Limiter Igniter
          B1014 1B [136] - Resistance Too High
                    Mileage: 17235 km
                    Date: 2018.08.11
                    Time: 00:00:12
9443861 - Driver's Front Airbag Crash Sensor
          B101A 15 [137] - Open or Short to Plus
                    Mileage: 17139 km
                    Date: 2017.06.26
                    Time: 03:14:51
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [136] - Open or Short to Ground
                    Fault Frequency: 12
                    Mileage: 17139 km
                    Date: 2017.09.04
                    Time: 07:28:12
9466352 - Crash Data from Belt Tensioner Stored
          B1071 F0 [137] - Unknown Error Elaboration
                    Mileage: 17139 km
                    Date: 2017.06.06
                    Time: 21:33:25
9447424 - Front crash data stored
          B1028 00 [137] - -
                    Mileage: 17139 km
                    Date: 2017.06.06
                    Time: 21:33:25
   Part No SW: 5C6 920 955 A    HW: 5C6 920 955 A
   Component: KOMBI         H04 1007
   Coding: 270A010000
   Shop #: WSC 00066 790 00320
   VCID: 2D5123657CFE16270A-8078
   Part No SW: 7E0 909 901     HW: 7E0 937 189
   Component: GW-K-CAN TP20 H80 0736
   Revision: BA080001
   Coding: 102201
   VCID: 68DF92719B9CF30F39-803C
                    Fault Frequency: 71
                    Mileage: 1334 km
                    Date: 2016.09.30
                    Time: 08:00:56
   Component: IMMO          H04 1007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADBE8798D90C11F2F-803E
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 48607 km
                    Date: 2019.02.22
                    Time: 11:07:20
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 305    3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 3979073570B6BA8796-806C
   Part No SW: 5C0 035 200     HW: 5C0 035 200
   Component: MU-S-S-US     H22 0245
   Serial number: VWZAZ2R3702130
   Coding: 02630100AA00000011220001001808001F0100D40020010002
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 52AB5099050069DF77-8006
          B11CF 53 [009] - Deactivated
                    Reset counter: 125
                    Mileage: 17233 km
                    Date: 2018.03.17
                    Time: 00:20:03
                    Voltage terminal 30: 7.3 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 0 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 00
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 00
End-------------------------(Elapsed Time: 02:46)--------------------------
                Address 01: Engine       Labels: 04E-907-309-V1.clb
Control Module Part Number: 04E 906 023 AQ    HW: 04E 907 309 AP
  Component and/or Version: R4 1.4l TFS   H22 2954
           Software Coding: 011A0012232400000000
            Work Shop Code: WSC 00066 790 00015
              ASAM Dataset: EV_ECM14TFS01104E906023AQ 003003 (VW36)
                    Mileage: 77015 km
                    Date: 2019.07.09
                    Time: 06:03:02
                    Fuel level: 50.00 l
                    Mileage: 62465 km
                    Date: 2019.05.03
                    Time: 11:52:19
                    Fuel level: 18.00 l
          U1112 00 [032] - -
                    Mileage: 69803 km
                    Date: 2019.06.03
                    Time: 07:19:51
                    Fuel level: 11.00 l
          P0300 00 [237] - -
                    Mileage: 77022 km
                    Date: 2019.07.09
                    Time: 06:07:41
                    Fuel level: 50.00 l
10591 - Cylinder 1
                    Mileage: 77024 km
                    Date: 2019.07.09
                    Time: 06:08:54
                    Fuel level: 50.00 l
10592 - Cylinder 2
                    Mileage: 77022 km
                    Date: 2019.07.09
                    Time: 06:07:42
                    Fuel level: 50.00 l
                    Mileage: 77015 km
                    Date: 2019.07.09
                    Time: 06:03:02
                    Fuel level: 50.00 l
                    Mileage: 62465 km
                    Date: 2019.05.03
                    Time: 11:52:19
                    Fuel level: 18.00 l
          U1112 00 [032] - -
                    Mileage: 69803 km
                    Date: 2019.06.03
                    Time: 07:19:51
                    Fuel level: 11.00 l
          P0300 00 [237] - -
                    Mileage: 77022 km
                    Date: 2019.07.09
                    Time: 06:07:41
                    Fuel level: 50.00 l
10591 - Cylinder 1
                    Mileage: 77024 km
                    Date: 2019.07.09
                    Time: 06:08:54
                    Fuel level: 50.00 l
10592 - Cylinder 2
                    Mileage: 77022 km
                    Date: 2019.07.09
                    Time: 06:07:42
                    Fuel level: 50.00 l
                    Mileage: 77015 km
                    Date: 2019.07.09
                    Time: 06:03:02
                    Fuel level: 50.00 l
                    Mileage: 62465 km
                    Date: 2019.05.03
                    Time: 11:52:19
                    Fuel level: 18.00 l
          U1112 00 [032] - -
                    Mileage: 69803 km
                    Date: 2019.06.03
                    Time: 07:19:51
                    Fuel level: 11.00 l
          P0300 00 [237] - -
                    Mileage: 77022 km
                    Date: 2019.07.09
                    Time: 06:07:41
                    Fuel level: 50.00 l
10591 - Cylinder 1
                    Mileage: 77024 km
                    Date: 2019.07.09
                    Time: 06:08:54
                    Fuel level: 50.00 l
10592 - Cylinder 2
                    Mileage: 77022 km
                    Date: 2019.07.09
                    Time: 06:07:42
                    Fuel level: 50.00 l
