Hey,
I have a problem with one mistake.
-Engine Control Module Incorrectly Coded.
I understand that there is wrong coding. Entering Engine-> Coding - displays the coding 06021, the tooltip window does not display, and you can not change the current coding, when you try to change the value goes back to the previous one.
Passat B5 ALZ
I am asking for help in coding
Passat B5 ALZ
Saturday,29,September,2018,13:29:13:07292
VCDS Version: 18.2.1.2 (x64) HEX-NET CB: 0.4422.4
VIN: WVWZZZ3BZ1E256758 License Plate:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
VIN: WVWZZZ3BZ1E256758 Mileage: 147550km-91683miles
Address 01: Engine Labels: Redir Fail!
Part No: 3B0 906 018 F
Component: 1,6l/2V SIMOS3 00HS0002
Coding: 06021
Shop #: WSC 00186
VCID: A306B0DE33C9045C9A-5184
WVWZZZ3BZ1E256758 VWZ7Z0A3659418
18020 - Engine Control Module Incorrectly Coded
P1612 - 35-00 -
17851 - Potentiometer for EGR (G212)
P1443 - 35-00 - Signal too Low
18014 - Rough Road/Engine Torque Signal from ABS
P1606 - 35-00 - Electrical Malfunction
16514 - Oxygen (Lambda) Sensor B1 S1
P0130 - 35-00 - Malfunction in Circuit
Readiness: 1010 1101
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 D
Component: ABS/ESP front D56
Coding: 04275
Shop #: WSC 05311
VCID: B4244382862793E473-5160
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 J
Component: CLIMATRONIC B5GP 0002
Coding: 17000
Shop #: WSC 05311
VCID: A81CA7F24AEFE704CF-5160
00787 - Temperature Sensor in Fresh Air intake duct (G89)
Part No: 6Q0 909 605 B
Component: 0A AIRBAG VW5 04 0006
Coding: 12353
Shop #: WSC 05311
VCID: B620798A905B81F44D-4B3C
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 805
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 05115
Shop #: WSC 00186
VCID: DDF2C626552D72ACEC-513C
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 05314
VCID: F0AC8F92B2BFEFC457-513C
Part No: 1C0 959 799 A
Component: 0Y Komfortgerát HLO 0001
Coding: 00067
Shop #: WSC 05311
VCID: B5227E868D5D8AEC44-4B1E
Subsystem 1 - Part No: 1C0959801
Component: 0Y Tőrsteuer.FS 0001
Subsystem 2 - Part No: 1C0959802A
Component: 0Y Tőrsteuer.BF 0001
End----------(Elapsed Time: 04:32, VBatt start/end: 12.3V/12.3V)-----------
