Coding Passat B5 FL
daniel.b
Europe
C?ID=318819
Hey,
I have a problem with one mistake.
-Engine Control Module Incorrectly Coded.
I understand that there is wrong coding. Entering Engine-> Coding - displays the coding 06021, the tooltip window does not display, and you can not change the current coding, when you try to change the value goes back to the previous one.
Passat B5 ALZ
I am asking for help in coding
Saturday,29,September,2018,13:29:13:07292
VCDS Version: 18.2.1.2 (x64)  HEX-NET CB: 0.4422.4
VIN: WVWZZZ3BZ1E256758   License Plate:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
VIN: WVWZZZ3BZ1E256758   Mileage: 147550km-91683miles
   Part No: 3B0 906 018 F
   Component: 1,6l/2V SIMOS3  00HS0002
   Coding: 06021
   Shop #: WSC 00186
   VCID: A306B0DE33C9045C9A-5184
   WVWZZZ3BZ1E256758     VWZ7Z0A3659418
18020 - Engine Control Module Incorrectly Coded
            P1612 - 35-00 -
17851 - Potentiometer for EGR (G212)
            P1443 - 35-00 - Signal too Low
18014 - Rough Road/Engine Torque Signal from ABS
            P1606 - 35-00 - Electrical Malfunction
16514 - Oxygen (Lambda) Sensor B1 S1
            P0130 - 35-00 - Malfunction in Circuit
Readiness: 1010 1101
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 8D0 907 389 D
   Component: ABS/ESP front       D56
   Coding: 04275
   Shop #: WSC 05311
   VCID: B4244382862793E473-5160
   Part No: 3B1 907 044 J
   Component: CLIMATRONIC B5GP    0002
   Coding: 17000
   Shop #: WSC 05311
   VCID: A81CA7F24AEFE704CF-5160
00787 - Temperature Sensor in Fresh Air intake duct (G89)
   Part No: 6Q0 909 605 B
   Component: 0A AIRBAG VW5  04   0006
   Coding: 12353
   Shop #: WSC 05311
   VCID: B620798A905B81F44D-4B3C
Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
   Part No: 3B0 920 805
   Component: KOMBI+WEGFAHRSP VDO V13
   Coding: 05115
   Shop #: WSC 00186
   VCID: DDF2C626552D72ACEC-513C
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 05314
   VCID: F0AC8F92B2BFEFC457-513C
   Part No: 1C0 959 799 A
   Component: 0Y Komfortgerát HLO 0001
   Coding: 00067
   Shop #: WSC 05311
   VCID: B5227E868D5D8AEC44-4B1E
   Subsystem 1 - Part No: 1C0959801
   Component: 0Y Tőrsteuer.FS     0001
   Subsystem 2 - Part No: 1C0959802A
   Component: 0Y Tőrsteuer.BF     0001
End----------(Elapsed Time: 04:32, VBatt start/end: 12.3V/12.3V)-----------
daniel.b
Europe
C?ID=318819
Try Coding: 06031
new coding does not save. When I enter new coding and re-enter coding, old coding is in it.
maybe you need a login...
NostraJackAss
Okay lets see if we can glitch it without a login.
I want you to quickly go to adaption and select 0x01-10-000 and save then immediately go to coding and change the coding, do this a few times & FAST going back and fourth and you might get lucky with a glitch change without a login.
Be sure your WSC, tester # and Importer ID are set in VCDS config first and different from the current controller and don't use all zeros!
NEtech
Denmark
C?ID=56995
What is the story, anything changed etc. ?
Engine is cool (below 70°C)
Ignition OFF for 10 sec.
Ignition ON
Do the Coding.
Ignition OFF for 1 minute!
Then test.
Jef
HQ
There doesn't seem to be a login for coding this ECM. My German is pretty weak... but I can make out Logins for the Cruise Control function, but nothing enabling soft coding.
ECM part number seems good for the VIN as per PL24. I like Jack's suggestion. Also, is battery voltage good? Are you doing this with key on / engine off?
_Val
Latvia
C?ID=356659
As I already sent him PM last year, but I can post now in this topic, so here goes info from Elsa.
Audi A4 B5 (yes, it can be different from 3B60B1 Passat) ALZ codings:
06001 - manual gearbox without ESP
06011 - manual gearbox with ESP
"06" = EU4 emissions.
