Tiguan 2015 cliamte heating issue.... help
akersgarage
C?ID=179893
I have a 2015 Tiguan with a heating issue
Customer is complaining of no/very little heat coming from vents when setting in middle at 22. At both sides (drivers and passenger side)
I can confirm this. Basically its blowing near enough cold air when set at 22.
Customer has had the car a while and recons its not what it used to be.
No faults logged at all. In any system.
I have checked the coding of the heating unit. All seems coded OK
I have checked the live date of the temp control flaps again they seem to be working as they should
Only thing I noticed is when set at 22 (in the middle) the readings are lower than 50%, they reading 40% both pretty much the same.
I have also checked the Evaporator temp sensor and it is reading as expected..
I did basic settings on all the motors via VCDS and they all working as they should.
Wondering if anyone can help with this at all..
Thursday,27,September,2018,11:57:04:45930
VCDS Version: 18.2.1.2 (x64)
VIN: WVGZZZ5NZFW098715   License Plate:
Chassis Type: 5N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4C 52 53 56 61
          62 72
VIN: WVGZZZ5NZFW098715   Mileage: 31600km-19635miles
   Part No SW: 03L 906 018 LE    HW: 03L 907 309 AE
   Component: R4 2.0l TDI   H28 9978
   Revision: 41H28---    Serial number: 00000000000000
   Coding: 00190032040501080000
   Shop #: WSC 00420 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906018LE 003012
   ROD: EV_ECM20TDI01103L906018E_VW36.rod
   VCID: 78F83995C36021841F-802C
   Part No SW: 5N0 614 109 BN    HW: 5N0 614 109 BN
   Component: J104   C6 450M VD28 0021
   Revision: --H07---    Serial number: 00000008762601
   Coding: 0040251
   VCID: 78F839950B6021841F-802C
   Part No SW: 5K0 907 044 HA    HW: 5K0 907 044 HA
   Component: Climatronic   H19 1414
   Revision: 00001004
   Coding: 0010004003
   VCID: 71EE04B1A01A70CCD8-8024
   Part No SW: 5K0 937 086 Q    HW: 5K0 937 086 Q
   Component: BCM PQ35 M    122 0174
   Revision: BC122001
   Coding: 48180A3F8025F1C0408800C0340081644BD1AA88436D81206480C7000041
   VCID: 428C9B7DDD3CBB5471-8016
   Subsystem 1 - Part No SW: 5N2 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 10031  013 0204
   Serial number: N2955119   °204!
   Coding: 009795
   Component: RLS 180315 05  54  0403
   Coding: 02304D
   Subsystem 3 - Part No: 5C0 951 171
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 S    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0043
   Revision: --------    Serial number: 56291505901499
   Coding: 149203
   ASAM Dataset: EV_EPHVA2C000000000 002014
   ROD: EV_EPHVA2C000000000.rod
   VCID: 4B92B659E2767A1C82-801E
   Component: J234__20E VW10 HI   2518
   Revision: 28020000    Serial number: 003L7P4Z8Y19
   Coding: 0012357
   VCID: 7CF025853F580DA47B-8028
   Subsystem 1 - Serial number: 6332MTS680010625
   Subsystem 2 - Serial number: 6342MTS655830625
   Subsystem 3 - Serial number: 6351HTS6ENV8GDKJ
   Subsystem 4 - Serial number: 6361HTS6FVEAGDKR
   Part No SW: 5K0 953 521 DP    HW: 5K0 953 569 AG
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20150225100162
   Coding: 1082040000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DF62881EC4204AC4C-8028
   Serial number: 0778819
   Coding: 820000
   Part No SW: 5N0 920 983 G    HW: 5N0 920 983 G
   Component: KOMBI         H03 0705
   Coding: 411F01
   VCID: 397EFC91B8EAF88C20-806C
   Part No SW: 7N0 907 530 AQ    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1653
   Revision:   H58       Serial number: 120315F1001796
   Coding: 356003
   VCID: 7F0AD289EE4E16BC5E-802A
   Component: IMMO          H03 0705
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADC13DD8DCC831499-803E
   Revision: A1001003    Serial number: 7670242252
   Coding: 020100
   VCID: 2B52D6D94AB65A1CA2-807E
   Part No SW: 2K0 035 279 C    HW: 2K0 035 279 C
   Component: RNS315-EU   H85 0501
   Serial number: VWZAZ2R0746679
   Coding: 0400040104000C0000009002
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 2A5CD3DD4D4C431459-807E
   Component: EUR_W_V7  0066
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0504
   Revision: 13110009    Serial number: 0009534938
   Coding: 0202B4
   VCID: 3878F99583E0E184DF-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1504
   Serial number: 00000009259356
   Coding: 000090
   Part No: 5N0 909 144 R
   Component: EPS_ZFLS Kl. 201    3501
   Revision: 00H22000
   Shop #: WSC 01324 785 00200
   VCID: 408891751330A94467-8014
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0504
   Revision: 15110009    Serial number: 0009545161
   Coding: 0202B4
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1504
   Serial number: 00000009249457
   Coding: 000090
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000584901
   Coding: 0026167
   VCID: 3878F9954BE0E184DF-806C
   Component: Batt.regelung H58 1653
   Coding: 030F1859
   VCID: 71EE04B1A81A70CCD8-8024
   Component: J367-BDM  H07 0180
   Serial number: 32069824191491672203
End-------------------------(Elapsed Time: 02:53)--------------------------
How about the vent temperatures, the interior temperature, and the sun intensity values? If one or more of those is wonky, I could see this affecting what the system does.
And then of course there's the question whether hot water is reaching and freely flowing through the heater core.
Jef
HQ
Can you do the Adapt flap end stops in Basic Settings?
[Select]
[08 - Heating/Air Conditioning]
[Basic Settings - 04]
Select "Adapt flap end stops" from the drop-down list
[Go!]
The basic setting takes approximately 20 seconds.
Finished Correctly should be displayed
[Stop]
[Done, Go Back]
If you change the temp from lowest to highest quickly, can you hear the airflow change in the vent system?
gigi123
C?ID=30490
Along the lines with the 2 previous posts, do you get A LOT of heat when temp is set at max? In other words, is it just a "calibration" issue or is the heater not working?
Not sure in UK, but in USA ppl use wrong coolant all the time (universal is not really universal :( ), and that clogs the heater core.
