What’s everyone using for vcds
Matt k
C?ID=345211
I have a acer laptop at the moment and it’s fine just rubbish battery so have to have a lead running to the car to plug it in , thinking maybe get a refurb netbook just for vcds get s good few hours batteries life
Cheers Matt
D-Dub
C?ID=272151
I'm using this cheapo windows tablet/laptop @ https://forums.ross-tech.com/showthread.php?14128-windows-10-tablet-for-vcds-rca-cambio-10-1
it is slow as heck, and not sure if I would want to use it on a daily basis for professional work, but it works well enough for the shade tree mechanic in me, and the battery lasts sufficiently through an all afternoon+ workload.
If I were to need something more professional, I would look for slightly older used mac laptops with full size usb ports, and run windows on them fulltime for vcds.
Matt k
C?ID=345211
Think I will do the same get something cheap and small with good battery even if I get a new battery for my acer not sure it will last long still . So think a netbook . Not sure I would want to use my MacBook Pro out in the car tbh
Cheers Matt
Matt k
C?ID=345211
Yeah good idea but not really wanting to use my MacBook Pro out on the car thinking maybe a little netbook or smiting they doesn’t matter if dropped
D-Dub
C?ID=272151
whenever @Uwe gets around to making a full fledged IOS app replacement for windows vcds, then an ipad (mini/regular/pro) would be a nice device for vcds.
and hex-net web doesn't count.
:D :banghead: :popcorn:
:D
D-Dub
C?ID=272151
I have no doubt, if you created a native ios app, and an IOS compatible obd interface (either bluetooth or lightning or even wifi based like hex-net+windows vcds), it would outsell your legacy products.
You realize iOS only has something on the order of a 20% market share, right?
hadez16
C?ID=289891
The way you work with VCDS would need a change too then...
A typical iOS App has no more than 2 buttons or so...
"Analyze it"
"Fix it"
Seems challenging...
D-Dub
C?ID=272151
Market share of what ? where ?
http://gs.statcounter.com/os-market-share/mobile/united-states-of-america
https://deviceatlas.com/blog/android-v-ios-market-share
/shrug
Despite any market share stats, please show me any type of hand held form factor that could be suitable for vcds/automotive-centric type diagnostics, that isn't either a full fledged laptop, a clunky wintab like I have, or perhaps an MS surface tablet (or clone).
If you built an IOS (or even a multi-platform native mobile app) ecosystem for vehicle diagnostics, then it would be something incredible for the form factor.
There are even multi-platform development systems that will let you build apps for all major platforms from a single code base.
An ipad or ipad pro in an otterbox type of case, with a modernized vcds app + interface, how could one *not* want to buy one.
Heck I have a hex-net and I would sell it and switch to an IOS based diagnostics system in a heartbeat.
and I don't even like apple that much. But they make undeniably great hardware, and they continue to support that hardware far longer than the android ecosystem.
And there has not been a good android tablet since the nexus 7 2013.
But anyway, I did not mean to derail the thread, your company will do whatever it is you want it to do. Its merely my own opinion where the future lies and I think you're missing out, and your (potential) customers are missing out.
10" Chuwi tablet running Win 10 Pro
iichel
Netherlands, eastern part
C?ID=284912
/shrug
Following your reasoning, an Android based tablet-app should then be preferable?
Matt k
C?ID=345211
Cheers for that and it runs fine ?
iichel
C?ID=284912
Well I've always used VCDS on VirtualBox (the free Virtual Machine software by Oracle) and I never had any issues.
However, -Uwe- made me aware that de device management layer of the VM might make things a bit complicated when, for example, updating the firmware of my Hex V2.
After this, to avoid connection problems and bricking etc, I switched to using the Bootcamp option of OSX and it works like a charm.
It takes some time to switch OS'es and make life a bit more complicated when accessing documents, they are all on the OSX partition.
But I managed to get used to it and with a good AFS driver (apple file system) it works just fine.
Mike@Gendan
Swansea, UK
C?ID=57030
If you're using VCDS for complex tasks (e.g. coding), it's always going to be preferable to have a physical keyboard rather than a virtual on-screen keyboard which covers a large portion of the display when in use.
Were VCDS to be made into an iOS app you would be sacrificing that.
While more cumbersome to carry around, VCDS still works better on a laptop type device than a keyboard-less tablet (IMHO)
mattylondon
United Kingdom
C?ID=219022
I use an Asus X102BA with Win8, 10.2 inch touch screen, proper keyboard, small and light. Only upgrade is an SSD. Perfect for VCDS!
Matt k
C?ID=345211
That’s what I want is the battery life good ??
