VW Caddy 1.6 hard starting when cold
tdo4h
South Africa
C?ID=142887
When the vehicle is cold it will not start except if you touch the acc peddle.
No faults on the ecu.
Altitude shows -18?
Need help please.
Tuesday,25,September,2018,17:23:58:26592
VCDS Version: 18.2.1.2
VIN: WV1ZZZ2KZEX022184   License Plate: KILOKOR CADDY
Mileage: 252030km-156604mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52
VIN: WV1ZZZ2KZEX022184   Mileage: 252030km-156604miles
Address 01: Engine (BSF)       Labels: 06A-906-033-BGU.lbl
   Part No SW: 06A 906 033 MG    HW: 06A 906 033 JF
   Component:  BSF S71 1.6 2V     8458
   Revision: --H01---    Serial number:
   Coding: 0040071
   Shop #: WSC 00999 444 64523
   VCID: 70E5F47F63C4F3C4D7-8024
Readiness: 0110 0001
   Part No SW: 1K0 907 379 BK    HW: 1K0 907 379 BK
   Revision: 00H31001
   Coding: 433C400D092403FCC20C02EC901DC080300000
   Shop #: WSC 35110 377 08192
   VCID: 7CFDD04FFF8C87A47B-8028
   Part No SW: 7N0 907 426 BN    HW: 7N0 907 426 BN
   Component: AC Manuell    H20 0505
   Revision: 00001019
   Coding: 0010002002
   Shop #: WSC 35110 790 50316
   VCID: 0103A1BB906EEA4C28-8054
   Part No SW: 5K0 937 085 AA    HW: 5K0 937 085 AA
   Component: BCM PQ35 B+   122 0173
   Revision: BB122001
   Coding: 4B1A583A8025302A08800082900000640101728852028860648000000040
   VCID: 72E1FE77ADC8C1D421-8026
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 10061  26  0512
   Coding: 009795
   Component: VW10Airbag02A H07 0013
   Revision: --------    Serial number: 003HL00NEJHS
   Coding: 000000000000000000000000000000003241
   Shop #: WSC 30127 001 1048576
   VCID: 356B056B942696ECC4-8060
   Part No SW: 1K5 953 521 AD    HW: 5K0 953 569
   Revision: FF010042    Serial number: 20130622201412
   Coding: 0080060000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 6FE7F703B6FAEC3CCE-803A
   Part No SW: 2K0 920 866     HW: 2K0 920 866
   Component: KOMBI         H04 0809
   Coding: 180000
   VCID: 6CDDE00F87EC1724EB-8038
   Part No SW: 7N0 907 530 AK    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1642
   Revision:   H57       Serial number: 010713F1002169
   Coding: 357401
   VCID: 79F3C95BF0BEB28C60-802C
   Component: IMMO          H04 0809
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD1E6178D18091499-803E
Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
   Part No: 1K0 959 793
   Component: Tuersteuergeraet 03 0174
   Coding: 0000000
   VCID: 76E9C26701A0DDF40D-8022
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 140    3501
   Revision: 00H22000
   VCID: 3973095B703E728C20-806C
Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
   Part No: 1K0 959 792
   Coding: 0000000
   VCID: 75EBC56B1CA6D6EC04-8020
End-------------------------(Elapsed Time: 01:46)--------------------------
myounus
Northwest UK
C?ID=321059
Is this actually a fault? Maybe as it's -18 the fuel is sludgy/thicker than normal??
NZDubNurd
New Zealand
C?ID=230482
You mean ambient is -18C???
This is a 1.6 8V petrol - the old engine from the 70's that keeps solidering on forever.
If you are in SA, and it's warm weather, it may be flooding itself if the coolant temp is low (cold start), and it *THINKS* the ambient is super-freezing (-18C)
Where exactly is this -18 displayed? measuring blocks? Check all the temperature blocks in the engine, but even the other modules inputs may be used by the engine for fuelling calcs.
