Mk7 Golf steering problem
Phatheadz
New Zealand
C?ID=344149
Hello. Help needed. I have heavy steering in a mk7 golf. The steering assist light is red. The ESP and TPMS are both orange and the start/stop and park break both have a fault. I have tried different ways of fixing this fault from forum ad wiki none will work. This exact same thing has happened before, after plugging it in to laptop for 5 minutes at the VW agent and $200 dollars later it was fixed. I would prefer to fix this myself if possible and keep the money in my pocket. Thanks
 Saturday,22,September,2018,09:55:41:19189
VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.2
VIN: WVWZZZAUZEW024177   License Plate: HEJ855
Mileage: 216912km-134782mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEW024177   Mileage: 216912km-134782miles
Address 01: Engine (J623-CXSA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 DF    HW: 04E 907 309 A
   Component: R4 1.4l TFS   H08 9024
   Revision: WAH08---
   Coding: 01250012232415082000
   Shop #: WSC 05200 824 00000
   ASAM Dataset: EV_ECM14TFS01104E906016DF 002007
   ROD: EV_ECM14TFS01104E906016DF.rod
   VCID: 698FBEE5C9FD4D1FC6A-803C
17158 - Databus
          U1123 00 [047] - Received Error Message
                    Mileage: 216832 km
                    Date: 2018.09.20
                    Time: 08:34:16
                    Engine speed: 654.50 /min
                    Normed load value: 16.1 %
                    Coolant temperature: 91 °C
                    Intake air temperature: 28 °C
                    Voltage terminal 30: 13.216 V
                    Mass flow through throttle valve: 5.4 kg/h
                    Median injection timing: 0.686 ms
                    Engine operating condition: Idling
                    Driver-side belt buckle status-Bits 0-7: 177
                    Engine torque: 16.2 Nm
          U0428 00 [047] - -
                    Mileage: 216832 km
                    Date: 2018.09.20
                    Time: 08:34:16
                    Engine speed: 638.50 /min
                    Voltage terminal 30: 13.193 V
                    selected gear-Bits 0-7: 0
   Part No SW: 0CW 300 047 S    HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 5210
   Revision: 00043014    Serial number: CU501305257756
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 4BC3646DA341BF0FD46-801E
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Revision: 00000000    Serial number: 614130000009ED
   Coding: 01FA8AA1242211700378060741CA2980512488C0608294F300220078C102
   VCID: 7BA3F4ADB361CF8F246-802E
0295 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 5
                    Mileage: 216912 km
                    Date: 2018.09.21
                    Time: 09:43:00
8277 - Databus
          [FCAN: EPS_DSR_Status signal is invalid]
                    Reset counter: 5
                    Mileage: 216912 km
                    Date: 2018.09.21
                    Time: 09:43:00
          C1146 02 [137] - Signal Failure
                    Reset counter: 5
                    Mileage: 216912 km
                    Date: 2018.09.21
                    Time: 09:43:24
32951 - Control Module for Electronic Parking Brake
          C10E2 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 5
                    Mileage: 216912 km
                    Date: 2018.09.21
                    Time: 09:43:00
   Part No SW: 5G0 907 426 M    HW: 5G0 907 426 M
   Component: AC Manuell    H01 0705
   Revision: 00001K06
   Coding: 00120004200100001000000000000000
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: 35372295D5C5D9FF922-8060
   Part No SW: 5Q0 937 084 S    HW: 5Q0 937 084 S
   Component: BCM MQBAB M   H14 0112
   Serial number: 00011315200223
   Coding: 03001842C24100530BA44080B10403081000000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 48C95B61B2375417F94-801C
   Component: WWS    130518  042 0551
   Serial number:         130525145032
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY131081SDT
   Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Serial number: 00000000000056806684
545300 - Databus
          [Gateway_78 Datenbus empfangener Fehlerwert EPS_Lastinfo]
                    Reset counter: 2
                    Mileage: 216832 km
                    Date: 2018.09.20
                    Time: 08:34:14
   Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
   Component: AirbagVW20    011 0361
   Serial number: 003F5R05H6PH
   VCID: 40D943419A076C57314-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 002 805 13
   Serial number: 357670000001D2814D0R
   Subsystem 2 - Part No SW: -----------    HW: 480 002 805 13
   Serial number: 358670000003F3302D0P
   Subsystem 3 - Part No SW: -----------    HW: 480 403 105 13
   Serial number: 3516502C31050664004K
   Subsystem 4 - Part No SW: -----------    HW: 480 403 105 13
   Serial number: 3526502C31050663D3E3
   Subsystem 5 - Part No SW: -----------    HW: 480 402 705 13
   Serial number: 3556502C9105EDD3314I
   Part No SW: 5Q0 953 507 AE    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 28051304400713
   Coding: 0500
   Shop #: WSC 40195 333 37120
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   VCID: 79AFEEA5B95DFD9F36A-802C
   Part No SW: 5G0 920 861     HW: 5G0 920 861
   Component: KOMBI         204 3360
   Coding: 27A419082380000800082A00000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 008011
   ROD: EV_DashBoardJCIMQBAB_008.rod
   VCID: 6695B5D9D8E36267EB8-8032
   Part No SW: 5Q0 907 530 L    HW: 5Q0 907 530 E
   Component: GW MQB Mid    124 1144
   Revision: --------    Serial number: 0000638718
   Coding: 030100042B086400EF0000481C0F00010001000000000000000000000000
   ROD: EV_GatewLear_009_VW37.rod
   VCID: 3A2D31A9FCDB36877F0-806E
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H14 0035
   Serial number: 27130000598450043195
   Coding: 280000
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 4772770603
   Part No SW: 5Q0 959 393 A    HW: 5Q0 959 393
   Component: TSG FS        012 0006
   Serial number: 01061306071421
   Coding: 003002208001040000001000
   VCID: 3D273AB5EDF501BF5A2-8068
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001580280
   Coding: 0D0000
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1063
   Coding: 0002
   VCID: 44D14F518E1F707715C-8010
15116 - Internal Fault
          B200F F0 [008] - Unknown Error Elaboration
          [Rotorlage Sensor: Radius Überwachung  Radius vergrößert sich um mehr als 40 digits im Uncontrolled-Zustand bei stehendem Rotorwinkel (delta<10°). Ursache kann ein Kurzschluss in Signalen des Sensorelements sein.]
                    Fault Frequency: 38
                    Reset counter: 30
                    Mileage: 216486 km
                    Date: 2018.09.15
                    Time: 00:06:13
                    Motor status: 00
                    Supply voltage: 12.50 V
                    Temperature: 43.0 °C
                    KFC: 3B
                    KFA: 00 0C
                    Environmental conditions: 73
                    Rotorlagesensorspannung AMR Sinus: 0.129 V
                    Rotorlagesensorspannung AMR Kosinus: 7.245 V
                    Rotorlagesensorspannung AMR Sinus 2: 0.122 V
                    Rotorlagesensorspannung AMR Cosinus 2: 5.577 V
                    Rotorlagesensorspannung Hall 1: 0.0 V
                    Rotorlagesensorspannung Hall 2: 0.0 V
                    Aktueller Sinus-Offset für ASIC: -0.0 mV
                    Aktueller Cosinus-Offset für ASIC: -0.1 mV
                    aktuelle Sinusverstärkung für ASIC: 0.185
229504 - Internal Control Module Memory Check Sum Error
          B2000 00 [153] -  -
          [Steuergerät defekt - Interne Störung]
          MIL ON - Confirmed - Not Tested Since Memory Clear
                    Fault Frequency: 38
                    Reset counter: 30
                    Mileage: 216486 km
                    Date: 2018.09.15
                    Time: 00:06:13
                    Motor status: 00
                    KFC: 3B
                    KFA: 00 0C
15873 - Steering angle sensor
                    Reset counter: 2
                    Mileage: 216832 km
                    Date: 2018.09.20
                    Time: 08:34:14
                    Motor status: 00
                    Supply voltage: 0.00 V
                    Temperature: 25.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Environmental conditions: 5F
                    uAdSensI_U5VFiltered_xdu16: 5.07820 V
                    uioUdNotFilt_xdu16: 0.06 V
                    uAdSensI_SwitchedKl30_xdu16: 0.07 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
   Part No SW: 5Q0 959 392 A    HW: 5Q0 959 392
   Component: TSG BFS       012 0006
   Serial number: 19051304081027
   Coding: 003000208001040000801000
   VCID: 3C2137B1F6EF08B76DC-8068
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001583853
   Coding: 050000
   Part No SW: 5G0 035 819 A    HW: 5G0 035 819 A
   Component: MU-S--ER      040 0421
   Serial number: V1C03105130649
   Coding: 02730000FF00000021510001000900001F0100060100010001
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 270BF8DD1F69BB6F10E-8072
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H50 0022
   Serial number: VWZ8Z9NJ7001X2
End----------(Elapsed Time: 01:09, VBatt start/end: 12.9V/12.8V)-----------
Phatheadz
New Zealand
C?ID=344149
Have tried doing setting as in the box below but when it gets to
"In Basic Settings, pick [MAS00815] Steering angle sensor
[Go!]
It should show Running"
It never comes up with "finished correctly"
 We haven't verified this on a car yet but this should be what ODIS is doing when it runs the G85 calibration, but in VCDS terms:
1) Test step: Edge detection
Start the engine
Point the front wheels straight ahead
[44-Steering Assist]
[Security Access - 16]
Enter 19249
[Do It!]
Select these in [Adv Meas Values]:
[IDE04510-MAS03732] Steering angle sensor: slope detection index - Steering angle speed negative dropping slope on curve
[IDE04510-MAS03733] Steering angle sensor: slope detection index - Steering angle speed negative rising slope on curve
[IDE04510-MAS03734] Steering angle sensor: slope detection index - Steering angle speed positive dropping slope on curve
[IDE04510-MAS03735] Steering angle sensor: slope detection index - Steering angle speed positive rising slope on curve
[IDE04510-MAS03736]Steering angle sensor: slope detection index - Index mark
Slowly turn the steering wheel to the right and left, passing the index mark (approx. 45°) until all 4 slope detection indexes have been recognised (detected) and the index mark is set to (1).
[Done, Go Back]
2) Test step: Steer. angle sens. calibration
[Basic Settings - 04]
[Show Measuring Data]
Select the following items:
[IDE02216-IDE05795] Steering angle sensor: basic setting - End basic setting
[IDE02216-MAS03161] Steering angle sensor: basic setting - Start
[Go!]
- Turn the steering wheel slowly to the right and then to the left mechanical stop.
- Turn the steering wheel back to the mid position, the status should be indicated as Permitted. (IDE02216-MAS03161 or IDE02216-IDE05795 ?)
Note: in a test on the car it never showed permitted in either of those?
(after one or both show permitted, stop moving wheel and point straight)
Wait for it to show Finished correctly?
[Stop]
Note: in a test on the car there were no faults and no warning lamps.
3) Test step: Evaluation of basic setting (no VCDS needed)
Turn the steering wheel to the right end stop.
Turn the steering wheel to the left end stop.
Turn the steering back to its center position.
Check the yellow fault lamp on the dash.
The fault lamp on the dash must go out.
Stop the engine.
Check and clear DTCs
downtime
Finland
C?ID=280813
This seems bad :
   Coding: 0002
                    Fault Frequency: 38
                    Reset counter: 30
                    Mileage: 216486 km
                    Date: 2018.09.15
                    Time: 00:06:13
                    Motor status: 00
                    KFC: 3B
                    KFA: 00 0C
          B2000 00 [153] -  -
                    Fault Frequency: 38
                    Reset counter: 30
                    Mileage: 216486 km
                    Date: 2018.09.15
                    Time: 00:06:13
                    Motor status: 00
                    KFC: 3B
                    KFA: 00 0C
                    Reset counter: 2
                    Mileage: 216832 km
                    Date: 2018.09.20
                    Time: 08:34:14
                    Motor status: 00
                    KFC: 3E
                    KFA: 00 01
My guess is that your steering assist module in steering rack is kaput.
