The car was sitting while I had to the timing chain tensioner; the battery definitely went flat during that time. No apparent water inside the passenger compartment, but it has previously had an issue with the sunroof and water ingress. Here's the autoscan, thanks!
Thursday,20,September,2018,20:58:04:19576
VCDS Version: 18.2.1.2 (x64) HEX-NET CB: 0.4411.4
VIN: WVGMM77L55D064447 License Plate:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGMM77L55D064447 Mileage: 194050km-120577miles
Address 01: Engine Labels: 077-907-560-AXQ.lbl
Part No SW: 4D0 907 560 DB HW: 8E0 907 560
Component: 4.2L V8/5V G 0020
Revision: 00000000 Serial number: VWZ3Z0E7311304
Coding: 0007875
Shop #: WSC 31414 000 00000
VCID: E99AF732C1351A0C10-5160
18053 - Powertrain Data Bus
P1645 - 008 - Missing Message from AWD Controller
18034 - Powertrain Data Bus
P1626 - 008 - Missing Message from TCU - MIL ON
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller
18005 - Powertrain Databus
P1597 - 008 - Missing Message from Level Control System (J197)
Readiness: 0010 1101
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 R HW: 5WK 470 26
Component: 17 Kessy 6610
Revision: 66105312 Serial number: VWZ3Z0E7311304
Coding: 0131304
VCID: B4245646D67797E473-5160
Component: ELV XXXX
00576 - Terminal 15
009 - Open or Short to Ground
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
013 - Check DTC Memory
00183 - Interior Access/Start Authorization Antenna 1 (R138)
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
VCID: F7BEA14A8781BCFC96-5160
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 H
Component: CLIMAtronic R/L X 3716
Coding: 0020030
VCID: B5226B42DD0D8EEC44-5160
010 - Open or Short to Plus
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 M
Component: 3001
Coding: 0105692
VCID: C6C01C8EB0EB1574DD-5160
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 H
Component: 01 Airbag 8.4E++H01 0562
Revision: BB38727 Serial number: 0000157?
Coding: 0012337
VCID: A81CB2361ABFE304CF-5160
Subsystem 1 - Part No: 7L0 959 339 D
Component: BF-Gewichtsens. 005 0007
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 D
Component: Lenksäulenmodul 3301
Coding: 0000032
VCID: C0CC0A9692CF3B44E7-5160
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 981
Component: KOMBIINSTRUMENT RB8 3110
Coding: 0007231
VCID: F6A0AC4E808BC5F48D-5160
01310 - Level Control System Control Module (J197)
02053 - Control Module for Transfer Case (J646)
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: F0AC9A56E2EFEBC457-5160
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint 2200
VCID: C5C21B828DED1E6CD4-5160
Address 37: Navigation Labels: 7L6-919-887-DVD.lbl
Part No: 7L6 919 887 C
Component: Navigation 0814
Coding: 0000101
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 E
Component: 2L HSG 0201
Coding: 0000085
VCID: BE30746EE83B4DB495-4B1E
Subsystem 1 - Part No: 7L0 959 701 H
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 H
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 D
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 D
Component: Tuersteuergeraet HR 0201
00576 - Terminal 15
01312 - Powertrain Data Bus
00486 - Front Passengers Outside Door Handle Central Locking Button (E370)
007 - Short to Ground
Address 47: Sound System Labels:
VCID: D5E2CBC22C4DAEECA4-5160
Note: Excessive Comm Errors
Address 56: Radio Labels: 7L6-035-186-CD.lbl
Part No: 7L6 035 186 A
Component: Radio 0814
Coding: 0004062
VCID: B12A5F522965A2CC18-5160
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L0 955 119 K
Component: Front Wiper 4027
Coding: 0000855
Shop #: WSC 31414 000 376832
VCID: BC347E66FE275FA4BB-5160
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 31414
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 N HW: 7L0 907 383 N
Component: J345 Anhaenger 0080
Revision: 4A012001 Serial number: 00000366920397
Coding: 0016386
Shop #: WSC 00512 001 24584
VCID: BFCE096AEF3144BC9E-5160
00576 - Terminal 15
Fault Status: 01101000
Reset counter: 0
Address 6E: Ctrl Head Roof Labels: None
Part No: 7L6 919 044 K
Component: DACHDISPLAY 0538
Revision: 00700538 Serial number: 2009289.06
End----(Elapsed Time: 09:17, VBatt start/end: 12.3V/12.3V. VIgn 0.0V)------
