Dynamic lights Audi A4 B8.5 2014
Jrsports
Slovenia
C?ID=31851
Hi!
I am retrofiting dynamic lights on my Audi A4 B8.5.
But i have problem with coding module J519.
Does anybody have dynamic lights installed in their car and maybe can share coding for the module.
I have component protection, but i will have it removed next week.
And one more question what bit does turn off tow module under the ACC.
Friday,14,September,2018,17:10:02:03312
VCDS Version: 18.2.1.2
VIN: WAUZZZ8K6FA071940   License Plate:
Mileage: 61650km-38307mi   Repair Order: New
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 42 44 46 52 53 56 5C 5F 62
          6D 72
VIN: WAUZZZ8K6FA071940   Mileage: 61650km-38307miles
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 KL    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9978
   Revision: 45H25---
   Coding: 12254012244601080000
   Shop #: WSC 28568 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018KL 003009
   ROD: EV_ECM20TDI01103L906018KK.rod
   VCID: 7EF879C0E1FB85B455-802A
   Part No SW: 8K9 927 156 S    HW: 0B5 927 156 K
   Component: 0B5 20 TDIRdW H03 0005
   Revision: --H03---
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 4D9AEE0C1CDDEE2C9C-8018
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 35158C01
   Shop #: WSC 06325 123 12345
   VCID: 09121A1CA035B20C70-805C
   Part No SW: 8K0 907 064 KH    HW: 8K0 907 064 KH
   Component: BCM2 2.0      H15 0711
   Coding: 05A24000000000000000
   VCID: 00040738930FF34427-8054
   Part No SW: 8K1 820 043 BB    HW: 8K1 820 043 BB
   Revision: C1000000    Serial number: 01061120140551
   Coding: 342002E080
   VCID: 69D23A9C8075120C90-803C
   Part No SW: 8K0 907 063 DL    HW: 8K0 907 063 DL
   Revision: 1001606S    Serial number: 00001830666101
   Coding: 2608801181348FE20181408300001D0D4F98C60826090201000008004401030100000024000000
   VCID: 7CFC73C8FFE797A47B-8028
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA171014  H18 0461
   Serial number: 1410150604256
   Coding: 004577
   Serial number: 23414739
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000111140538
   Serial number: CAB80957000000000001
            000 -  -
                    Reset counter: 138
                    Mileage: 61498 km
                    Date: 2018.09.12
                    Time: 20:07:00
02084 - Component Protection
                    Fault Status: 01100101
                    Reset counter: 138
                    Mileage: 61658 km
                    Date: 2018.09.14
                    Time: 00:00:01
                    Reset counter: 135
                    Mileage: 61498 km
                    Date: 2018.09.12
                    Time: 20:07:01
                    Fault Status: 01101100
                    Reset counter: 138
                    Mileage: 61498 km
                    Date: 2018.09.12
                    Time: 20:07:02
                    Reset counter: 138
                    Mileage: 61498 km
                    Date: 2018.09.12
                    Time: 20:07:02
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561 B    HW: 8K0 907 561 B
   Component: ACC3          H09 0100
   Coding: 003369
   Shop #: WSC 06335 000 00000
   VCID: 316292FC6825AACC98-8064
01517 - Control Module for Trailer/Towing Sensor (J345)
                    Reset counter: 135
                    Mileage: 61498 km
                    Date: 2018.09.12
                    Time: 21:03:48
                    Temperature: 47.0°C
                    Voltage: 13.18 V
                    Hex Value: 0x0088
                    Lateral Accel.: 0.00 m/s^2
03263 - Functional Restriction
            000 -  -  - Intermittent
                    Reset counter: 177
                    Mileage: 61505 km
                    Date: 2018.09.12
                    Time: 21:18:06
                    Temperature: 29.0°C
                    Voltage: 14.34 V
                    Hex Value: 0x002F
                    Speed: 46.8 km/h
                    Lateral Accel.: -1.16 m/s^2
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003KFDC4GBX+
   Coding: 30514435363030303030554A304C384B3053
   VCID: 4894DF18F3BF0B04AF-801C
   Serial number: 6334MSME4A3D0845K
   Serial number: 6344MSME4A795459R
   Serial number: 6352QSME4A4A4D52T
   Serial number: 6362QSME2D4A4E7A%
   Serial number: 63732SME5808047C0
   Serial number: 63832SME57084666%
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372NK7000JT
   Coding: 0000FF
   VCID: 448CCB28C7972F6443-8010
   Part No SW: 8K0 920 932 G    HW: 8K0 920 932 G
   Component: KOMBIINSTR.   H36 0567
   Revision: 00100000    Serial number: 65-7175CF
   Coding: 03CD110046000008810001
   VCID: 336E98F4923998DCEA-8066
            000 -  -
                    Reset counter: 135
                    Mileage: 61498 km
                    Date: 2018.09.12
                    Time: 21:03:47
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z14A21029D
   Coding: 80CF07FF00
   VCID: 4C9CE308EFC7E7248B-8018
   Serial number: 6861824803
   Serial number: 14310000076021200181
            000 -  -
                    Reset counter: 138
                    Mileage: 61658 km
                    Date: 2018.09.14
                    Time: 00:00:13
                    Bin. Bits:    10111
                    Voltage: 12.40 V
                    Count: 6
                    Text: FFB0742C03028100
                    Text: 0000000000000000
                    Raw, Form. N/A: 000 000 000
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000124477501
   Coding: 011C13205C00410001
   VCID: 4FA6F4041ED1DC3CEE-801A
   Part No SW: 8K0 909 144 J    HW: 8K0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0026138594
   Coding: 100001010001
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3874AFD8835F7B84DF-806C
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000124573805
   Coding: 011C13205E00410001
   VCID: 4E98E90019DBD534E5-801A
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 10000000454485
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A70B5D0BD53699429-806E
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109K60E7988204
   Coding: 010103020100000001
   VCID: 2B5E80944A09C01CA2-807E
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08006    Serial number: 600214B100002B
   Coding: 0022001
   VCID: 3776ACE4464174FCD6-8062
   Part No SW: 8R1 035 670 J    HW: 8R1 035 670 J
   Component: H-BNT-EU      H49 0897
   Revision: --------    Serial number: 516K/0E7501662
   Coding: 0F0100010106E9FD3F80CF5E00000403040000000000000000
   VCID: 3A70B5D0B553699429-806E
   Subsystem 1 - Part No: 8R0 060 884 CH
   Component: EUR 2014  2004
   Component: DU7 High  H42 0104
   Serial number: A130K-0E3181927
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000002040371
   Component: CD-Database  5950
            000 -  -
                    Reset counter: 138
                    Mileage: 61642 km
                    Date: 2018.09.14
                    Time: 15:19:31
                    Bin. Bits: 00000000 10000000
                    Bin. Bits: 00000100 00000000
                    Bin. Bits: 00000000 00000000
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000125360346
   Coding: 010C13204000210001
   VCID: 4688D120F1AB1D745D-8012
   Part No SW: 8K9 827 851 C    HW: 8K9 827 851 C
   Component: J605  Master  H53 0330
   Revision: --------    Serial number: 8K9827851C
   VCID: 3E78B9C0A97B45B415-806A
   Subsystem 1 - Part No SW: 8K9 827 852 C    HW: 8K9 827 852 C
   Component: J756  Slave  H53 0330
   Serial number: 8K9827852C
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000125360445
End-------------------------(Elapsed Time: 03:27)--------------------------
Best regards
Jan from Slovenia
hadez16
C?ID=289891
New ACC coding without tow bar is 003370. (+7 to last byte)
Regarding your new lights:
Please report back with a new auto-scan after having the component protection removed because this could prevent several light functions from working so the basis for investigation is not that clear.
I'm pretty sure we can solve this then.
Jrsports
Slovenia
C?ID=31851
Hi!
Okay i will first remove component protection.
Thank you for the acc
Best regards
Jan
Jrsports
Slovenia
C?ID=31851
Hi.
Today i removed the component protection.
But i now is the problem with coding.
It gives faults for old non AFS system, does any body know what byte is there for AFS lights with cornering lights.
Monday,08,October,2018,18:33:03:03312
Mileage: 63670km-39562mi   Repair Order: Dynamic
          6D 72
VIN: WAUZZZ8K6FA071940   Mileage: 63670km-39562miles
   Revision: 45H25---
   Revision: --H03---
   Coding: 351DCC01
   Shop #: WSC 35408 003 1048576
   Coding: 342002E080
   Coding: 2600801081348FE20181408300001D0D0F94C70826090201000008004401030100000024000000
   Coding: 004577
   Coding: 02005D
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 227
                    Mileage: 63671 km
                    Date: 2018.10.08
                    Time: 18:18:56
                    Reset counter: 227
                    Mileage: 63671 km
                    Date: 2018.10.08
                    Time: 18:18:56
   Coding: 00F6C0
                    Reset counter: 227
                    Mileage: 63669 km
                    Date: 2018.10.08
                    Time: 15:05:15
                    Temperature: 32.0°C
                    Voltage: 12.93 V
                    Hex Value: 0x002F
                    Speed: 68.4 km/h
                    Lateral Accel.: 0.48 m/s^2
   Coding: 0000DF
   Coding: 03EF11004F000008010000
            000 -  -
                    Reset counter: 187
                    Mileage: 63671 km
                    Date: 2018.10.08
                    Time: 18:18:29
   Coding: 80CF07FF00
   Revision: 00002001    Serial number: 0350857422
   Coding: 01000E3820B930818320023680000047
   Coding: 0022001
   Coding: 0F0100010006A9ED2D80CB5E00000403040000000000000000
End-------------------------(Elapsed Time: 03:57)--------------------------
Best regards
Jan
NEtech
Denmark
C?ID=56995
Test and change Byte 31, from 01 to 02
Jrsports
Slovenia
C?ID=31851
Hi.
Now AFS lights work but, when i am standing still the ligts are not moving is there minimum speed that the lights begin to work?
And one more question the corner light is not turning on, maybe not coded right?
hadez16
C?ID=289891
What cornering light do you mean?
Via fog-lights or do you have static cornering lights in your headlights? That would be confusing as you can either have dynamic lights or static cornering lights in your headlights.
Jrsports
Slovenia
C?ID=31851
Hi.
I have light with static cornering light.
Best regards
Jan
NEtech
Denmark
C?ID=56995
Test and remove Byte 4 Bit 0
Jrsports
Slovenia
C?ID=31851
Hi.
That turns off fog lights when turning.
Jan
