Retrofitted BCM to mk5 golf - now having Canbus drive errros
Christiank
Denmark
C?ID=253485
Hey,
I've retrofitted BCM to my Golf 5 some months ago.
I did install a FLA/HBA mirror when the BCM conversion was done.
However since I did the BCM swap I have had a wierd can drive wire problem - I can scan the scan, not showing any can errors. Then I can drive the car for several days without problems, then out of nowhere error can show (bringing airbag and ESP light in cluster, also makes the PDC buzzer do a really annoying bip when stopping for red lights) - I can then shut car off, start it again and errors are gone (airbag light still shows untill cleared with VCDS).
Tried several things to solve this issue, without luck so I now need some help trying to sort this out.
- checked canbus wirering for the GW, FLA mirror, Headlight range unit (All these places has been touched for the install of FLA mirror)
- installed new Gateway
- tried to do a new solder joint for the FLA canbus wires to the GW drive wires, no luck after 2 tries
- made new canbus wirering for the FLA mirror - this time connected to 55-Headlight Range module
- tried to re-do the solder joints where FLA mirror meets the Can drive wires for the Headlight module
- tried to unplug FLA mirror and code BCM & GW not to have FLA mirror
nothing of this has worked so really out of stuff to try out
Here's a auto scan that shows the errors
Saturday,15,September,2018,15:03:13:31035
VCDS Version: 18.1.0.2 (x64)
Data version: 20180122 DS285.1
VIN: WVWZZZ1KZ5W036030   License Plate:
Chassis Type: 1K-VW35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 20 25 42 44 46 52 55 5F 61 62 65
          72 7D
VIN: WVWZZZ1KZ5W036030   Mileage: 363240km-225706miles
20-High Beam Assist. -- Status: Not registered 0011
65-Tire Pressure -- Status: Not registered 0011
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 021 MP    HW: 03G 906 021 AN
   Component: R4 2,0L EDC G000SG  4660
   Revision: --H11---    Serial number: XXXXXXXXXXXXXX
   Coding: 0000072
   Shop #: WSC 01324 020 00200
   VCID: 79F9BF1630A0698DF2-802C
8 Faults Found:
012547 - Motor for Intake Manifold Flap (V157)
               P3103 - 000 - Malfunction
                    Fault Frequency: 11
                    Mileage: 363109 km
                    Date: 2018.08.26
                    Time: 20:17:13
                    Voltage: 12.24 V
                    Bin. Bits: 00001100
                    Torque: 0.0 Nm
                    Torque: 351.4 Nm
001681 - Fan 1 Control Circuit
               P0691 - 000 - Short to GND
                    Mileage: 363109 km
                    Date: 2018.08.26
                    Time: 20:17:20
                    Voltage: 12.24 V
                    Bin. Bits: 00001100
                    Temperature: 63.9°C
                    Duty Cycle: 9.7 %
001668 - Glow Plug Control Module (J179)
               P0684 - 000 - Implausible Signal
                    Fault Status: 01110000
                    Mileage: 363124 km
                    Date: 2018.09.11
                    Time: 19:37:36
                    RPM: 1197 /min
                    Load: 6.7 %
                    Voltage: 14.52 V
                    Bin. Bits: 00001100
                    Temperature: 15.3°C
                    Bin. Bits: 10110000
005785 - Powertrain Data Bus
               P1699 - 000 - Missing Message from Steering Wheel Electronics - Intermittent
                    Fault Frequency: 35
                    Voltage: 12.08 V
                    Bin. Bits: 00001101
                    Bin. Bits: 00000000
                    (no units): 0.0
049478 - No Communication with Diagnostic Gateway
               U0146 - 000 -  - Intermittent
                    Fault Frequency: 124
                    Voltage: 12.08 V
                    Bin. Bits: 11001101
                    Bin. Bits: 00000000
                    (no units): 0.0
006272 - Powertrain Data Bus
               P1880 - 000 - Missing Message from Diagnostic Gateway - Intermittent
                    Fault Frequency: 12
                    Voltage: 12.08 V
                    Bin. Bits: 11001101
                    Bin. Bits: 00000000
                    (no units): 0.0
                    Fault Frequency: 35
                    Voltage: 12.08 V
                    Bin. Bits: 00001101
                    Bin. Bits: 00000000
                    (no units): 0.0
005685 - Powertrain Data Bus
               P1635 - 000 - Missing Message from A/C Controller - Intermittent
                    Fault Frequency: 24
                    Voltage: 12.08 V
                    Bin. Bits: 11001101
                    Bin. Bits: 00000000
                    (no units): 16.0
Readiness: 1 1 0 0 1
   Revision: 00H31001
   Coding: 113B400D09250000880B02E790190062310800
   Shop #: WSC 12345 678 12345
   VCID: 76E3B42AC1BE06F59F-8022
                    Fault Status: 00101101
                    Reset counter: 147
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:27:31
                    Count: 2
                    Count: 28672
                    Count: 8193
                    Count: 41216
                    Count: 65531
                    Reset counter: 147
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:27:36
                    Count: 2
                    Count: 14
                    Count: 13056
                    Count: 8208
                    Count: 45824
                    Count: 65531
                    Reset counter: 147
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:27:31
                    Count: 2
                    Count: 2
                    Count: 28928
                    Count: 8233
                    Count: 41216
                    Count: 65532
   Part No SW: 1K8 907 044 CE    HW: 1K8 907 044 CE
   Component: Climatronic   H08 0405
   Revision: 00001K05
   Coding: 001000C002
   Shop #: WSC 00020 999 12345
   VCID: 74E78E22DFC214E5A1-8020
9480469 - Control Circuit for A/C Compressor
          B10A9 15 [008] - Open or Short to Plus
                    Reset counter: 187
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:27:36
9477872 - AC Compressor First Run-In
          U8E5850 F0 [009] - Not Performed
                    Reset counter: 147
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:06:21
   Part No SW: 1K0 937 087 BA    HW: 1K0 937 087 AL
   Component: BCM PQ35  H+  112 0903
   Revision: AF112771
   Coding: 46180BB8C421F1A02008008D20008DD807F1008E637D8540E44420040040
   Shop #: WSC 33361 790 00056
   VCID: 71E98736A8D021CD4A-8024
   Subsystem 1 - Part No SW: 1K1 955 119 B    HW: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  12  0401
   Coding: 00FFD5
   Component: RLS 140712 05  54  0403
   Coding: 0750AD
                    Reset counter: 147
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:06:21
                    Voltage: 11.65 V
                        Term 50 Off
                    Fault Status: 00101010
                    Reset counter: 187
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:27:40
                    Voltage: 14.15 V
                        Term 50 Off
03395 - Control Module for High Beam Assistant
                    Reset counter: 187
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:45:12
                    Voltage: 12.20 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331618400023
   Coding: 0011051001
   Shop #: WSC 00066 790 00321
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: N/A
   VCID: 377D792E8E34BFFD44-8062
No ASAM data for: "EV_EPHVA18VW364GP00" (VW35)
12666400 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Frequency: 55
                    Reset counter: 187
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:27:33
12666402 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Frequency: 24
                    Reset counter: 187
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:27:31
12718592 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Frequency: 155
                    Reset counter: 187
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:27:31
12670224 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Frequency: 43
                    Reset counter: 187
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:27:31
   Part No SW: 1K0 909 605 D    HW: 1K0 909 605 D
   Component: 01 AIRBAG VW8   022 0600
   Revision: 05022000    Serial number: 0033JD0F8V28
   Coding: 0012337
   Shop #: WSC 01371 785 00200
   VCID: 2D515B46B468052D2E-8078
   Subsystem 1 - Serial number: 6332MSME4C4A5203
   Subsystem 2 - Serial number: 6342MSME74384E02
   Subsystem 3 - Serial number: 6351HSME32087E02
   Subsystem 4 - Serial number: 6361HSME4D0B5C02
            004 - No Signal/Communication - Intermittent - MIL ON
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Coding: 0000532
   VCID: 7AFBA01A35A66295FB-802E
   Subsystem 1 - Part No: 5K0 959 542 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H31 0037
   Coding: 00000130
   Part No SW: 1K8 920 885 G    HW: 1K8 920 885 G
   Component: KOMBI         H03 1008
   Coding: 170F080000
   Shop #: WSC 01234 567 56789
   VCID: 3B75651EB21C9B9DA0-806E
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 200917F1001107
   Coding: 350032
   VCID: 7BF5A51EFA9C5B9DE0-802E
            000 -  -
                    Fault Frequency: 8
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:06:22
03406 - Control Module for Battery Monitoring
                    Reset counter: 147
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:09:50
   Part No SW: 5K0 857 511 B    HW: 8P0 857 511 C
   Component: FLA           H04 0006
   Revision: AA001002
   Coding: 02018B6B74745D545420363E00
   VCID: 2D515B467468052D2E-8078
                    Reset counter: 187
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:27:45
   Component: IMMO          H03 1008
   Serial number: VWZ7Z0D0121566
   Shop #: WSC 00020 999 00000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB905A8D06D2150B-803E
   Part No SW: 5K0 959 701 J    HW: 5K0 959 701 J
   Component: Tuer-SG         009 2105
   Coding: 0006270
   VCID: 39797F167020A98DB2-806C
   Part No: 1K1 909 144 G
   Component: EPS_ZFLS Kl.8       1401
   VCID: 2F6D414EBE64773D1C-807A
   Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
   Component: Tuer-SG         009 2119
   Coding: 0004222
   VCID: 33654D3E524C53DD78-8066
   Part No: 1T0 907 357
   Component: Dynamische LWR      0002
   Coding: 0000003
   Shop #: WSC 01392 785 00200
   VCID: 74E78E2217C214E5A1-8020
   Part No SW: 5C0 035 680 C    HW: 5C0 035 680 C
   Component: MU-S-ND-ER    H20 0252
   Serial number: VWZAZ2R8769189
   Coding: 02730601000000001111110101880A001F0106C400200100CF
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 2149B77630B0D14D9A-8074
   Subsystem 1 - Part No SW: 3G0 919 866 AQ    HW: -----------
   Component: ECE1 2017  --- 0730
6714 - Databus
                    Reset counter: 147
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:06:26
                    Voltage terminal 30: 11.5 V
                    Network diagnosis-Status: Enabled
6922 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 187
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:43:30
                    Voltage terminal 30: 12.1 V
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 187
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:27:52
                    Voltage terminal 30: 14.2 V
                    BAP-BAP_Function_ID: 02
0001 - Antenna 1 for Radio
          B1119 13 [009] - Open Circuit
                    Reset counter: 147
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:06:22
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Electrical OK
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Electrical OK
                    Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
   Component: Batt.regelung H56 1682
   Coding: F00008FE
02071 - Local Databus
                    Fault Status: 01101100
                    Reset counter: 147
                    Mileage: 363243 km
                    Date: 2018.09.15
                    Time: 14:07:23
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0202
   Coding: 0000016
   VCID: 306F4232A35A68C505-8064
   Part No SW: 3AA 907 273 F    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0011
   Serial number: 30000000060897
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_005.rod
8398082 - Tire Pressure Sensor(s)
          C111A 31 [009] - No Signal
                    Reset counter: 53
                    Mileage: 355883 km
                    Date: 2018.03.08
                    Time: 12:11:09
                    Vehicle speed: 58 km/h
                    Outside air temperature: -1.0 °C
                    Reception level antenna 1: 490 mV
                    Offset level antenna 1: 190 mV
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Component: Tuersteuergeraet 06 0213
   Coding: 0000016
   VCID: 31694736A85061CD0A-8064
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 D    HW: 1K0 963 235 D
   Component: PTC-Element         0404
   Revision: 00700000    Serial number:
   VCID: 2C5756428F720C2539-8078
End-------------------------(Elapsed Time: 02:49)--------------------------
golfi_vend
Tartu, Estonia
C?ID=195131
You do have other issues rather than only just Powertrain.
I would suggest:
Fix CAN-GW coding and remove extra GND from the LIN pin of Battery monitoring, also remove it's coding.
Start unplugging modules that are retrofitted on powertrain to rule out a bad module.
I don't know, but I think You should rewire Headlight-module and Light-assist module to Extended-bus to free some traffic on Powertrain.
BCM is connected to Convience-Bus, so it can't pull Powertrain down.
Christiank
Denmark
C?ID=253485
I would suggest:
Yes a few other errors, but these I know why is there hehe :)
The canbus drive errors is what drives me crazy - I don't have the 61-battery control module installed yet, however I have bought the GND module to put at the batteri - side. Just need the connector for it, then it can be installed. Not sure if this has anything to do with the can error though? :/
Also how do you suggest the CAN-GW coding should be changed? Coding is 350032 , and the install list just missing 65-tyre pressure - think this is why it says coding is wrong.
I did actually try to wire the HBA to EXT-can before I installed to Can-drive but then it can't find the mirror - So guess these things has to run on Can drive?
Yeah BCM is Conv-can but since my error isn't consistent but it comes and goes without any pattern to it. The error can be running for a short drive and then when the car is shutted off, I can then start the car and the errors are gone. Then other days I can drive the car for several days without any issues, then it appears the day after - nothing is done different than the day before
golfi_vend
Tartu, Estonia
C?ID=195131
https://forums.ross-tech.com/showth...-an-R32-engine&p=135996&viewfull=1#post135996
What i meant about coding, was the installation list. But yes, if You have TPMS without sensors, coding that out is good idea, but it will cause the Incorrectly coded fault. Let 65 - TPMS be at this moment, but deal with 61 - Battery for now.
I would recommend to check GW pin T20e/12 and remove GND from there(Later GW-s have LIN wire there for alternator and Battery module). Little bit can also be read from above link.
If You receive Your Battery unit connector, then connect it there with corresponding coding.
If You say HBA can't be reached on Extended-Bus then leave it on Powertrain. Xenon module can run on Extended, but i wonder if there is any actual need for it, specially If you're not running AFS or DLA.
Christiank
Denmark
C?ID=253485
Will try install the battery module this weekend - see if it helps anything on the drive train errors :) - Or will this just clear the error from 61-battery?
Not sure why the Xenon module is needed for my car either? I do have original VW mounted Bi-Xenons on my mk5 and yeah these can't have curve light or any other nice options other cars have hehe
United States
Don't let me distract you from following golfi_vend's advice. His advice is great.
In the event this isn't cause by the retrofits I wanted to note something. 44-steering assist including the wiring to/from it could be causing this and MK60EC1 ABS modules aren't exactly noted for reliability. I wouldn't do much with 44 beyond inspecting the wiring to it but ... after exhausting all other possibilities you might want to consider driving with the ABS unplugged if you don't mind an inop speedometer and every warning on the dash blaring in your face. That would allow you to see if all of the communication codes return rather than just a few for ABS.
Christiank
Denmark
C?ID=253485
Hi Dana,
Acutally I'm about to swap from Gen2 to Gen3 steering rack - hopefully next week, so the wire harness will be changed. Will have a look and see if it looks like any water has gone to the "Car side" harness the can wire connector plugs into.
Also changed the engine ECU from my old to a new one while I did the BCM conversion to get the GRA showing in my 3D cluster - Guess I could try swap back and see if the error has some to with my new ECU is from a 2010 BKD Touran?
This is my old ECU:
Part No SW: 03G 906 016 KC HW: 028 101 190 3
Component: R4 2,0L EDC G000SG 8457
Revision: 12345678
This is my new one
Revision: --H11---
Then I also have this - but HW is to old to show GRA in cluster
Part No SW: 03G 906 021 KK HW: 03G 906 021 KK
Component: R4 2,0L EDC G000SG 9183
Revision: --H06---
