Monday,17,September,2018,19:38:15:09700
-- Windows Based VAG/VAS Emulator Running on Windows XP x86
Version: 18.2.0.3
VIN: WV1ZZZ7HZ4H054761 License Plate: CATHY2
Mileage: 258840km-160835mi Repair Order:
57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ4H054761 Mileage: 258840km-160835miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 038 906 016 HW: 028 101 073 4
Component: R4 1,9L 0000SG 5225
Revision: 12345678 Serial number: VWZ7Z0C8384977
Coding: 0000031
Shop #: 00066 001 57865
VCID: 51A9C00BCBCCDECCC7-5140
17668 - Unit Injector: Cylinder 1 (N240)
P1260 - 000 - Implausible Signal
RPM: 2184 /min
Torque: 122.0 Nm
Speed: 70.0 km/h
Load: 45.9 %
Voltage: 14.14 V
Inj. Quantity: -2.21 mg/str
Temperature: 63.9°C
(no units): 16.0
17674 - Unit Injector: Cylinder 3 (N242)
P1266 - 000 - Implausible Signal
RPM: 2184 /min
Torque: 120.0 Nm
Speed: 70.0 km/h
Load: 45.9 %
Voltage: 14.14 V
Inj. Quantity: 0.40 mg/str
Temperature: 63.9°C
(no units): 16.0
17671 - Unit Injector: Cylinder 2 (N241)
P1263 - 000 - Implausible Signal
RPM: 2184 /min
Torque: 118.0 Nm
Speed: 70.0 km/h
Load: 45.9 %
Voltage: 14.14 V
Inj. Quantity: 1.27 mg/str
Temperature: 63.9°C
(no units): 16.0
17677 - Unit Injector: Cylinder 4 (N243)
P1269 - 000 - Implausible Signal
RPM: 2142 /min
Torque: 128.0 Nm
Speed: 70.0 km/h
Load: 45.9 %
Voltage: 14.14 V
Inj. Quantity: 0.47 mg/str
Temperature: 63.9°C
(no units): 16.0
17084 - MIL Request from Transm. Control Module (SAE) or Control Module Defective (VAG)
P0700 - 000 - - Intermittent
Torque: -98.0 Nm
Voltage: 12.84 V
Bin. Bits: 00000000
(no units): 0.0
Bin. Bits: 00000000
18072 - Control Circuit for Injectors
P1664 - 000 - Electrical Malfunction - Intermittent
RPM: 1890 /min
Torque: 14.0 Nm
Load: 35.7 %
Voltage: 14.21 V
Bin. Bits: 00000100
Temperature: 65.7°C
Bin. Bits: 01010000
Readiness: 0 0 X X X
Address 03: Brakes Labels: 7H0-907-37x-ASR-F.lbl
Part No: 7H0 907 379 E
Component: ASR FRONT MK25 0103
Coding: 0007205
Shop #: 02737 785 00200
VCID: 377D9E93456860FCE9-5124
Address 09: Cent. Elect. Labels:. 7H0-937-049.lbl
Part No: 7H0 937 049 H
Component: BORDNETZ SGVER 1.0 0901
Coding: 0000004
Shop #: 02756 785 00200
01598 - Drive Battery Voltage
002 - Lower Limit Exceeded
Part No: 1C0 909 605 A
Component: 3B AIRBAG VW51 0008
Coding: 13122
Shop #: 02756
VCID: 224B5FC7AEEA15542E-5124
Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
Part No: 7H0 920 950 L
Component: KOMBI+WEGFAHRSP VDO V01
Coding: 03411
Shop #: 00000
VCID: 3467A99F041E8BE4CC-5106
WV1ZZZ7HZ4H054761 VWZ7Z0C8384977
Part No: 6N0 909 901
Coding: 00006
Shop #: 02756
VCID: 70EF658F3086F7C4E8-5124
Address 46: Central Conv. Labels: 7H0-959-433.lbl
Part No: 7H0 959 433
Component: Komfortgerát 0004
Coding: 00021
Shop #: 02737
VCID: 70EF658F3086F7C4E8-4B06
End-------------------------(Elapsed Time: 06:57)--------------------------
