Hello a client of mine changed the pedal of the clutch and dissconected the battery (that is what he told me) now the abs module lost it coding . I need the code for the abs module because i can't get the code through the pr codes here is a autoscan .Thanks
Saturday,15,September,2018,17:26:40:50280
VCDS Version: 18.2.1.2 HEX-NET CB: 0.4411.4
Dealer/Shop Name: Autoservis Arbeni
VIN: WVWZZZ3CZ7P073427 License Plate:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 7D
VIN: WVWZZZ3CZ7P073427 Mileage: 390020km-242347miles
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-018-BKP.clb
Part No SW: 03G 906 018 CE HW: 03G 906 018 CE
Component: R4 2.0l PPD1.5 9384
Revision: --H35--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00028 028 00001
VCID: EA989AF7C5BB011419-80BE
012592 - EGR System
P3130 - 006 - Regulation Range Exceeded - Intermittent
Fault Status: 00010001
Mileage: 390020 km
Time: 02:00:24
RPM: 800 /min
Torque: 16.0 Nm
84.63 %
Load: 85.1 %
Lambda: 0.0 %
Battery Volts: 1.0 V
Readiness: N/A
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0668019350
Coding: 0000000
VCID: B22842972DEB89D461-80E6
Reset counter: 18
Mileage: 390020 km
Time: 02:00:48
Reset counter: 18
Mileage: 390020 km
Time: 02:00:48
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AF HW: 3C0 907 044 AF
Component: ClimatronicPQ46 050 0505
Revision: 00050005 Serial number: 00000000000000
VCID: E582E9CB2CA52E6C34-80B0
00757 - Right Vent Temp Sensor (G151)
010 - Open or Short to Plus
Fault Status: 01111010
Reset counter: 19
Mileage: 390006 km
Time: 00:58:18
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Fault Status: 01110010
Fault Frequency: 8
Reset counter: 19
Mileage: 390006 km
Time: 00:58:22
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 H HW: 3C0 937 049 H
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000004451203
Coding: 00800F0700041A00000A00000F000000000959435C0000
VCID: AE1056E739D3AD3405-80FA
Subsystem 1 - Part No: 3C1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 00028
Fault Status: 01101100
Reset counter: 19
Mileage: 390007 km
Voltage: 12.70 V
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
Component: 03 AIRBAG VW8 031 2522
Revision: 11031000 Serial number: 003B1PL3DVQ5
Coding: 0012339
VCID: B02C489F23E7BBC417-80E4
Subsystem 1 - Serial number: 6332MSME1244023B
Subsystem 2 - Serial number: 6342MSME121F183C
Subsystem 3 - Serial number: 6351HTS6VARIQ963
Subsystem 4 - Serial number: 6361HTS66HBK94L6
00589 - Airbag Igniter 1; Passenger Side (N131)
00590 - Igniter 2 for Passenger Airbag (N132)
01217 - Side Airbag Igniter; Driver Side (N199)
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
Component: Lenksäulenmodul 006 0010
Revision: 00006000 Serial number: 3C5953507
Coding: 0000001
VCID: AA185AF7053BC114D9-80FE
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 852 A HW: 3C0 920 852 A
Component: KOMBIINSTRUMENT VD1 1614
Revision: X0006000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 00011 888 96745
VCID: A10ABDDB780D024C88-80F4
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C069160735
Coding: 3D3D2C04C21002
Part No SW: 3C0 959 433 M HW: 3C0 959 433 M
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 89999 823 99118
VCID: B424448FD7FF87E473-80E0
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1123
Revision: 22007001 Serial number: 00000034169004
Coding: 0000053
VCID: BB366FB3FAA1489CB2-80EE
Fault Status: 01100101
Reset counter: 19
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.134 H07 1806
Shop #: WSC 80093 222 69422
Component: KSG PQ46 ELV 042 0472
Coding: 00910A0801860E763004941570084B0B603CA0
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1123
Revision: 22007001 Serial number: 00000117669003
Coding: 0000052
VCID: BC346CAFFFAF4FA4BB-80E8
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000012
00650 - Clutch Pedal Switch (F36)
Fault Status: 11101010
Fault Frequency: 15
Reset counter: 19
Mileage: 390000 km
Time: 00:00:09
Voltage: 11.49 V
Count: 71
Part No: 1K0 035 186 AD
Component: Radio GR0 034 0033
Revision: 0003404S Serial number: VWZ2Z2G4072508
Coding: 0040401
VCID: E89CE0FFDBB733040F-80BC
00877 - Treble Speaker Rear Right (R16)
Component: PTC-Element 0404
VCID: AD1251EB34D5D62C3C-80F8
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End----------(Elapsed Time: 01:16, VBatt start/end: 12.6V/12.6V)-----------
