Coding support for VW UP GTi 2018
silky16v
C?ID=273755
I have a 2018 VW UP GTi and I’m unable to get into any of the coding modules in Cent Elect is this something not yet supported by VCDS?
Also are the Security Access codes available?
Here is the module read for the car:
Chassis Type: AA-VW12 (1S0)
Scan: 01 03 08 09 10 15 17 19 25 44 47 5F 61 AD
VIN: WVWZZZAAZJD206819   Mileage: 2000km-1242miles
AD-Brake Sensors -- Status: OK 0000
Address 01: Engine (J623-DKRA)       Labels: None
   Part No SW: 04C 906 025 F    HW: 04C 907 309 BA
   Component: R3 1.0l TFS   H20 5543
   Revision: D8H20000
   Coding: 00190032232401000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM10TFS01104C906025F 002007
   ROD: EV_ECM10TFS01104C906025F_002.rod
   VCID: 23459D862A21ED5C1A-8076
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels:. 1S0-614-517.clb
   Part No SW: 1S0 614 517 P    HW: 1S0 614 517 P
   Component: EBC 460 ESP   H17 0030
   Serial number: A01RSME
   Coding: B8BF64712BAD02F71D0226F6D4B240905FB000
   ASAM Dataset: EV_Brake1ESPEBC460TRW 002107
   ROD: EV_Brake1ESPEBC460TRW_002_VW25.rod
   VCID: 3C7746FAB79FB2A43B-8068
   Part No SW: 1S0 907 044     HW: 1S0 907 044
   Component: Climatronic   H05 0102
   Revision: K0000000
   VCID: 6CD7B6BA8F7FE224EB-8038
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 1S0 937 090 H    HW: 1S0 937 090 H
   Component: BCM PQ25 1MX4 H82 0752
   Revision: BW082001    Serial number: 5000 135181593
   Coding: 64B829000001000001080FC06CEB8ED079C0706D60CF2D602101000B0900
   VCID: 387F5AEA8BA79E84DF-806C
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 090518 05  50  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H04 0103
   Serial number: 29160001740290076402
   Coding: A4FFFF
Address 10: Park/Steer Assist (J446)       Labels:| 1Sx-919-475.clb
   Part No SW: 1S0 919 475 B    HW: 1Q0 919 475
   Component: PARKHILFE 3K  H03 0013
   Revision: --------    Serial number: 32931813800649
   Coding: 308004
   ASAM Dataset: EV_EPHVA14VW1200000 001009
   ROD: EV_EPHVA14VW1200000.rod
   VCID: 39795FEEB8AD878C20-806C
   Part No SW: 1S0 959 655 C    HW: 1S0 959 655 C
   Component: VW10Airbag02Y H03 0007
   Revision: --------    Serial number: 003UB006MVP%
   Coding: 000000000000000000000000000000003259
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   VCID: 3E734CF2A183A0B415-806A
   Serial number: 3575HRB40145DKL2FP5I
   Serial number: 3585HRB40185DQ1GEI4E
   Serial number: 3557BRB404R57M6QM8TE
Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
   Part No SW: 1S0 920 970 C    HW: 1S0 920 970 C
   Component: KOMBI         H12 0100
   Revision: X0012001    Serial number: 00000000000000
   Coding: 414A010000
   ASAM Dataset: EV_KombiUDSMM9RM10 A05808
   ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
   VCID: 326B68C265DB74D4E1-8066
   Part No SW: 1S0 909 901     HW: 1S0 937 090 H
   Component: GW-K-CAN TP20 H82 0752
   Revision: BW082001
   Coding: 001101
   VCID: 70EFA2CAA35706C4D7-8024
   Part No SW: 5K0 953 234     HW: 1S0 920 970 C
   Component: IMMO          H12 0100
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   VCID: 6ADBB0A28D8BFC1499-803E
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R2 909 144 AN    HW: 6R2 909 144 E
   Component: EPS_TRW_ALow  323 3150
   Serial number: CI5J1233
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016134
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 0407FE1A8FEF0A6403-8050
   Part No SW: 5K0 035 456 E    HW: 5K0 035 456 E
   Component: KonzernAmp 8K H09 6631
   Revision: --------    Serial number: EAA101C0080751
   ASAM Dataset: EV_AudioVerst8KanalSTT3 001003
   ROD: EV_AudioVerst8KanalSTT3.rod
   VCID: 2C5776BA47FF2224AB-8078
   Part No SW: 1S0 035 869 B    HW: 1S0 035 869 B
   Component: MU-E-D-EU     068 7338
   Serial number: 16051800020283
   Coding: 02210100AA00000041111103018000001F000AD60001010001
   ROD: EV_MUEnt4CGen2LGE_VW12.rod
   VCID: 356153DE94B563ECC4-8060
   Part No SW: 1S0 907 534     HW: 1S0 937 090 H
   Component: Batt.regelung H82 0752
   Coding: 032B7856
   Subsystem 1 - Part No SW: 1S0 915 181 D    HW: 1S0 915 181 D
   Component: J367-BDM  H08 0270
   Serial number: 55108I26516061927459
Address AD: Brake Sensors (J939)       Labels: 1S0-907-201.clb
   Part No SW: 1S0 907 201 A    HW: 1S0 907 201 A
   Component: CV-SENSOR     H08 0460
   ASAM Dataset: EV_CVSen 001001
   ROD: EV_CVSen.rod
   VCID: 285F8AAA53070E044F-807C
End-------------------------(Elapsed Time: 02:32)--------------------------
iichel
Eindhoven, NB, NL
C?ID=284912
One could use the labels from the 5C0/6R0/7H0/7E0 BCM, it's all the same on PQ25.
silky16v
C?ID=273755
How would I go about doing that?
Every module under Cent Elect the long coding option doesn’t work just says unavailable
hadez16
C?ID=289891
A new interface (HEX-V2 / HEX-NET) would be helpful here as the experimental coding labels are available there.
With the old interface you have to rely on editorial labels which are not yet maintaned for your car.
The other point:
http://www.ross-tech.com/vag-com/labelsredirect.html
NEtech
Denmark
C?ID=56995
Security Access is not used for this 09-Cent. Elect.
silky16v
C?ID=273755
The other point:
looks like i'll have to wait for it to become available then, not messing about with labels and not paying to upgrade to HEX-NET just for this purpose
maybe time to look at a different diagnostics provider as most of the modern cars i try read now have the same label issues and as some are only available in Europe it takes ages for updates to come through from Ross-Tech
South Molton, UK
VAG have made the messages for many modules much larger in most 2018 onwards models which the earlier VCDS cables such as HEX+CAN cannot support (there's only so much future proofing can be designed in) so the need for HEX-V2 or HEX-NET will become more apparent as all new VAG models move over to the larger messages.
iichel
Eindhoven, NB, NL
C?ID=284912
The Up GTI is loosely based on the Polo 6R (PQ25). give or take 10 year old tech :D
silky16v
C?ID=273755
So is there a guide to sorting the labels or a way of sending what I have to Ross-Tech for them to develop a fix?
United States
I just sent you a file in reply to that e-mail.
LeakyTurnip
C?ID=85240
Hi,
I have the same issue, however I am using the HEX-V2 interface on my wife’s Up! GTI. The few things which I want to tweak all reside in 09-Cent. Elec and there is no mapping label available to allow me to know what can be tweaked.
If you happen to get an furher, would be great to hear.
Hi,
Is yours also a 2018? It would be good to post an Auto-Scan so we can see how similar it is to the one this thread started with.
LeakyTurnip
C?ID=85240
I think it's classed as a MY2019, it was built in September 2018. Autoscan below :)
Sunday,30,December,2018,16:59:37:34079
VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4437.4
Data version: 20181017 DS296.0
VIN: WVWZZZAAZKD109305   License Plate:
Scan: 01 03 08 09 10 15 17 19 25 44 47 5F 61 A9 AD
VIN: WVWZZZAAZKD109305   Mileage: 4350km-2702miles
Address 01: Engine (J623-DKRA)       Labels:. 04E-907-309-V1.clb
   Component: R3 1.0l TFS   H20 6355
   Revision: D8H20000
   ASAM Dataset: EV_ECM10TFS01104C906025F 003009
   ROD: EV_ECM10TFS01104C906025F_003.rod
   VCID: 2312198ACB5DA9EFA39-8076
Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
   Serial number: A01U9HA
   Coding: B8BF64712BAD02FA1DFD26F5D4AE40905FB000
   VCID: 3C20C2F656E3F617823-8068
   Revision: K0000000
   VCID: 6C8032B66683A697523-8038
   Part No SW: 1S0 937 090 J    HW: 1S0 937 090 J
   Component: BCM PQ25 1MX4 H82 0762
   Revision: BW082001    Serial number: 8901 229180600
   Coding: 64B829000001000001080FD06CEB8ED079C0706D60CF2D602101000B0900
   VCID: 3A2CC4EE5C57C82790F-806E
   Component: RLS 090818 05  50  0106
   Coding: 0228DD
   Serial number: 29180001192240098231
   Coding: A4FFFF
   Revision: --------    Serial number: 32931822204120
   Coding: 108004
   VCID: 392EDBE259D1C33F995-806C
   Part No SW: 1S0 959 655 E    HW: 1S0 959 655 E
   Component: VW10Airbag02Y 010 0007
   Revision: --------    Serial number: 003EQ000UDPP
   VCID: 40D8B6063A0B92F7DEB-8014
   Serial number: 357D4RB40555GNIAGH2J
   Serial number: 358D4RB40655FRCQ20OP
   Serial number: 3557BRB404P55PMEG06N
   Coding: 414A010000
   VCID: 323CECCE84A7306758F-8066
   Part No SW: 1S0 909 901     HW: 1S0 937 090 J
   Component: GW-K-CAN TP20 H82 0762
   Revision: BW082001
   Coding: 001101
   VCID: 70B826C64AAB42776EB-8024
   VCID: 6A8C34AE6CF7B8A720F-803E
   Serial number: CI8M0312
   Coding: 000700
   VCID: 04507A166E934ED7BA3-8050
   Revision: --------    Serial number: EAA101C0083420
   VCID: 2C00F2B6A6836697123-8078
   Serial number: 11071800021498
   Coding: 02210100AA00000041111103018000001F000AC60001010001
   VCID: 3536D7D275C9275F7DD-8060
   Part No SW: 1S0 907 534     HW: 1S0 937 090 J
   Component: Batt.regelung H82 0762
   Coding: 032B7856
   Serial number: 65194854156060978615
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 1S0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0003
   Serial number: 180703201041
   VCID: 73B229CA3B3D796F939-8026
   ROD: EV_CVSen.rod
   VCID: 28080EA6B27B4AB7F6B-807C
End----------(Elapsed Time: 01:05, VBatt start/end: 12.2V/12.2V)-----------
Yes, the 'K' in the 10th digit of the VIN means it's a MY 2019, but the BCM is nearly identical to Silky's, so when Dana is back, she should be able to hook you up with a label file to test.
LeakyTurnip
C?ID=85240
That would be great :)
United States
I'll try to get you a file and reply to the email address on-file before the end of the day.
LeakyTurnip
C?ID=85240
That would be awesome, thanks.:o
United States
No problem. Check your yahoo.co.uk address for an email from Support with subject: Address 09: Cent. Elect. (J519 Part No SW: 1S0 937 090 J
