Hi, I had my clocks on my Mk7 R upgraded to the AID from the mk7.5 pics(https://www.vwroc.com/forums/topic/...active-info-display-92-discover-pro-retrofit/). The only issue was that I was getting a fault on the screen (!) "Error: Range Calcuation", even though the range calculation was working great. I saw on another thread (https://www.golfmk7.com/forums/showthread.php?t=36902&p=631624) that they fixed this with a CAN Gateway upgrade, so I tried it. PN before was 5Q0 907 530 Q HW: 5Q0 907 530 F and after was SW: 3Q0 907 530 G HW: 3Q0 907 530 C.
The fault has indeed gone, but so has the functionality of the Dynamic Chassis Control. The button does nothing and the onscreen "Race" etc is blank.
I would appreciate any advice.
Thursday,13,September,2018,12:13:09:22150
VCDS Version: 18.2.1.5 (x64)
Data version: 20180518 DS287.2
VIN: WVWZZZAUZEWXXXXX License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 42 44 52 55 5F
A9
VIN: WVWZZZAUZEWXXXXX Mileage: 16285km-10119miles
Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 B HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00322466050B3004
ASAM Dataset: EV_ECM20TFS0205G0906259B 001003
ROD: EV_ECM20TFS0205G0906259B.rod
VCID: 2D511DBB7C47B82CBF-8078
Part No SW: 0D9 300 011 R HW: 02E 927 770 AQ
Component: DQ250-6A MQB H52 4311
Revision: 05852204 Serial number: TFK01403300025
ROD: EV_TCMDQ250021.rod
VCID: 2447F89F2F8D796460-8070
10657 - RPM Signal from ECU
P0726 00 [002] - Implausible Signal
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AB HW: 5Q0 907 379 H
Component: ESC H31 0557
Revision: 00000000 Serial number: 60744000000088
Coding: 01FA93A15429296C037F070141C56980C92A94C0E08296F7F84250F8C208
VCID: 7CF7E0FFF7BDE1A478-8028
Revision: 00021000 Serial number: 0331862505
Coding: 030C0C
VCID: 3A7B26E7BD091F942A-806E
Part No SW: 5G0 907 044 AA HW: 5G0 907 044 AA
Component: Climatronic H02 0805
Revision: 00001K06
Coding: 00120014200100011005000000101000
VCID: 66C3A29799314B74BE-8032
Air quality sensor:
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011409702133
Coding: 03111A46C20122F30B244080B11C07281800000000000000000000000000
ROD: EV_BCMBOSCH_012.rod
VCID: 7BF5E3E3F2B3E69C71-802E
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140329 042 0551
Serial number: 140404080331
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y14M04D13H01M56S47S9
Coding: 00A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY140770PAY
Serial number: 00000000000029345719
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.014 H02 0007
Serial number: WOO2860322/
Coding: 181901
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 87
Mileage: 16285 km
Date: 2018.09.13
Time: 11:47:23
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 F HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0142
Revision: -------- Serial number: 39331410003532
Coding: 0071151011
ROD: EV_EPHVA18AU3700000_002_VW27.rod
VCID: 3E732AF7A12133B416-806A
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 B HW: 5Q0 907 572 B
Component: ACC Bosch MQB H04 0200
Serial number: 11041476510622
Coding: 001C1300FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001014
VCID: 366332D78911FBF4CE-8062
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 HW: 5Q0 907 376
Component: DAEMPFUNGS-SG H15 0115
Serial number: 06031441350466
ROD: EV_DRCONTITEMIC_VW27.rod
VCID: 76E3F2D7C991BBF40E-8022
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR04Z9JB
VCID: 7F0D17F3E6ABFABC5D-802A
Belt Pretensioner left:
Component: BeltPretRevFL H35 0341
Serial number: 34169661C31031450332
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0341
Serial number: 34169662C01041450140
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 004 14
Serial number: 35767000000F417C5F01
Subsystem 4 - Part No SW: ----------- HW: 480 001 004 14
Serial number: 3586700000090D4C5F01
Subsystem 5 - Part No SW: ----------- HW: 480 402 703 14
Serial number: 351650299153FB94628I
Subsystem 6 - Part No SW: ----------- HW: 480 402 503 14
Serial number: 35265029F153FB94D2F$
Subsystem 7 - Part No SW: ----------- HW: 480 402 703 14
Serial number: 3556502C3153FB920089
Part No SW: 5Q0 953 507 EC HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 10041404220613
Coding: 0C10
ROD: EV_SMLSKLOMQB_013_AU37.rod
Part No SW: 5G1 920 791 A HW: 5G1 920 791 A
Component: KOMBI 407 3193
Coding: 27AD0018BF80260001886E010400000000000000
VCID: 2A5B16A74DA9AF145A-807E
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [008] - -
Mileage: 16285 km
Date: 2018.09.13
Time: 11:47:38
9634288 - Transmission Control Module
B1301 F0 [008] - Not Authorized
Mileage: 16285 km
Date: 2018.09.13
Time: 11:47:39
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 31081710804126
Coding: 030100042B085900EF00027E9C0F00010001000000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 33650BC39A63EEDCE9-8066
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H06 0038
Serial number: 29140000427140014121
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 8491223103
8526363 - Unknown Error Code
B189C F0 [009] - Unknown Error Elaboration
Reset counter: 87
Mileage: 16242 km
Date: 2018.09.13
Time: 11:00:58
Supply voltage: Terminal 30: 14.7 V
Terminal 15: On
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Component: Haldex4Motion H52 7076
Serial number: HA1-00004.03.14
Coding: 0001
VCID: 46834217F9F16B745E-8012
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000091083003
Coding: DD00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 346708DF9F6DE9E4F0-8060
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 09041401100574
Coding: 001F1220D001048100001000
VCID: 408F540FDBD5454464-8014
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8103
ROD: EV_SteerAssisMQB_010.rod
VCID: 356135DB9417F0ECC7-8060
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 07041404080059
Coding: 003F1020DE01048100801000
VCID: 3F8D57F3A62B3ABC1D-806A
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 02A603000B000200
Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H05 0012
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H05 0012
Coding: 2E0000
Part No SW: 5NA 035 020 C HW: 5NA 035 020
Component: MU-H-ND-EU H54 1161
Serial number: A845E0JS041786
Coding: 02730001FF0000005111120100880A001F0107F601200000BE
VCID: 316901CB607FDCCC9B-8064
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H50 9120
Serial number: VWZ6ZHT1212796
Subsystem 2 - Part No SW: V03 959 800 QT HW: -----------
Component: ECE 2018/2019 --- 0169
Compact Disc Database:
Component: Gracenote2 --- 1016
B2000 87 [009] - Missing message
Reset counter: 86
Mileage: 16242 km
Date: 2018.09.13
Time: 10:45:42
Voltage terminal 30: 15.0 V
Software module: status-SW_Status_Consistency: 00 08 00
Software module: status-SW_Status_Device: Mmx2Mmx2Mmx2M
7191 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 86
Mileage: 16242 km
Date: 2018.09.13
Time: 10:45:28
Voltage terminal 30: 15.1 V
BAP-BAP_Function_ID: 19
Part No SW: 5G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0006
Serial number: 140324201482
End-------------------------(Elapsed Time: 04:47)--------------------------
