Aux heater retrofit, coding side
darkchina811
ITALY
C?ID=333184
I am just about to finish the Webasto aux heater retrofit. yesterday I did the fuel line, then ran the "fill fuel line" procedure and the hose is full up to the heater.
tomorrow I will have a mechanic connect the coolant hoses, then top-up and bleed the circuit.
that should be the end of the hardware side.
then I need to code and do basic settings.
since the aux heater is not a very diffused retrofit, I am finding difficult to get info about where to code/adapt.
ok, module 18 goes to gateway installation list.
I think there is coding on modules 08 and 09.
is that all? how about other coding or adaptations?
and then, how do I do basic settings, how do I initialize the heater?
darkchina811
ITALY
C?ID=333184
see attached scan. no matter what I do, the heater has no basic settings, and I don't know how to perform them...
Friday,14,September,2018,19:20:30:06888
VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.2
VIN: WVWZZZAUZHW0xxxxx   License Plate:
Mileage: 20995km-13045mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 18 19 42 44 52 5F
VIN: WVWZZZAUZHW0xxxxx   Mileage: 20995km-13045miles
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 B    HW: 5Q0 963 272 B
   Component: STH-MQB       006 0069
   Coding: 1305
   ASAM Dataset: EV_AuxilParkiHeateWOS 002014
   VCID: 3537DDC715C0D82F922-8060
   Subsystem 1 - Part No SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000001256652
0376 - No Basic Setting
          B2010 00 [009] -  -
          [INITIAL OPERATION MISSING]
                    Reset counter: 150
                    Mileage: 20995 km
                    Date: 2018.09.14
                    Time: 19:14:00
                    Operating condition of parking heater: System malfunction
                    71
                    Coolant temperature of parking heater: 68 ∞C
                    Coolant temperature: 69 ∞C
                    Engine running status: detected
                    Fuel level: 11 l
                    Heater output: 0 W
End----------(Elapsed Time: 01:48, VBatt start/end: 12.6V/12.5V)-----------
darkchina811
ITALY
C?ID=333184
I have coded modules 08, 09 and 17 to tell them the Aux Heater is present.
however, I am not getting the menu under the Climatronic screen.
darkchina811
ITALY
C?ID=333184
I browsed through ALL pages of that section and found very little cars with Aux Heater. just scans, no admaps :(
myounus
Northwest UK
C?ID=321059
Darkchina
The scan says 'initial operation missing'. Go to 18 and choose the option for basic settings. It will cycle through the operations then complete. Save and then exit.
iichel
Netherlands, eastern part
C?ID=284912
Perhaps it would be good to tell us a bit more about the car and show an autoscan with, for example, the module fitted.
darkchina811
ITALY
C?ID=333184
I made some progress. the fuel line was not filled up, that's why I could not complete the test.
FYI, the "fuel line filling" under Basic Settings does not work, always gives an error. I had to fill the line by manually activating the metering pump from the Output Tests.
I was then able to complete the "heater operation for production" under Basic Settings, and the error about initial operation was cleared.
the "heater operation for customer service" does not work as well and always gives an error. anyway, I would like to know the difference between the two things.
it seems like it's working, although it makes a bad smell like of burning plastic. I am not sure it is because the heater is brand new or if it's sympthom of a problem.
I will keep you posted.
golfi_vend
Tartu, Estonia
C?ID=195131
Posted 3 cars with admaps to Reference Scan section
https://forums.ross-tech.com/showthread.php?15694-VW-Passat-B8-MY15-2-0TDI-140kw
https://forums.ross-tech.com/showthread.php?15695-VW-Golf-MK7-MY15-1-4TSI-103kw
https://forums.ross-tech.com/showthread.php?15696-VW-Golf-MK7-MY2015-1-4TSI-81kw-CNG
I think You will be intrested in these adaption channels:
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating,activated ,40
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer,not activated ,40
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off,not activated ,40
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high,activated ,40
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill,not activated ,40
, but i think in Your MIB2 case they will be named something like this:
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated ,60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated ,60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ,60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated ,608
Also:
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,activated ,53
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,Comfort data bus ,53
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
But please, autoscan and admaps!
darkchina811
ITALY
C?ID=333184
thank you very much, I just scanned the car and will compare now to yours :)
Sunday,16,September,2018,21:29:53:06888
VIN: WVWZZZAUZHW024283   License Plate:
Mileage: 21070km-13092mi   Repair Order:
VIN: WVWZZZAUZHW024283   Mileage: 21070km-13092miles
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H25 2833
   Revision: R7H25---
   Coding: 0119003223241D082000
   Shop #: WSC 21385 002 1048576
   ASAM Dataset: EV_ECM14TFS01104E906027HB 001005
   ROD: EV_ECM14TFS01104E906027HB.rod
   VCID: 6B833BBF03045EDFB46-803E
   CAN Converter 01:
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CC    HW: 5Q0 614 517 AG
   Component: ESC           H62 0637
   Revision: 00000000    Serial number: 91596000011507
   Coding: 01FA6AA1242219704779060841C62980562498E2608294730020507AC00203
   Shop #: WSC 131071 102 209715
   ROD: EV_Brake1UDSContiMK100IPB_035_VW27.rod
   VCID: 74B120C35E3A812765C-8020
   Part No SW: 5G0 907 044 BE    HW: 5G0 907 044 BE
   Revision: 00001K08
   Coding: 00020004104111011005004000101022
   Air quality sensor:
   Part No SW: 5Q0 937 084 BR    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0138
   Serial number: 01011415700037
   Coding: 00000846C20102FB4B644080B11407281400000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 094F613729B8ECCF26A-805C
   Component: WWS    160522  043 0551
   Serial number:         160601172917
   Coding: 0E4DFD
   Component: RLHS  042 0105
   Serial number: S5Y17M06D01H13M38S50
   Coding: 06A8DD
   Serial number: 000000000ZY15028208R
   Serial number: 00000000000030139763
   Part No SW: 5Q0 919 298 D    HW: 5Q0 919 298
   Component: PARKHILFE PLA H11 0042
   Revision: --------    Serial number: 61131402901978
   Coding: 0031161041
   ASAM Dataset: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_003_VW37.rod
   VCID: 40D9BC135A026D87314-8014
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Component: AirbagVW20    015 0388
   Serial number: 003F6R1V1W4Y
   VCID: 41DFB9175108648F3EA-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 506 16
   Serial number: 35767000000432B44C1Q
   Subsystem 2 - Part No SW: -----------    HW: 480 001 506 16
   Serial number: 358670000008B4C4DB17
   Subsystem 3 - Part No SW: -----------    HW: 480 400 306 16
   Serial number: 3516502BB205729313D3
   Subsystem 4 - Part No SW: -----------    HW: 480 401 105 16
   Serial number: 3526502AF2076340F201
   Subsystem 5 - Part No SW: -----------    HW: 480 401 106 16
   Serial number: 35565029B21160C1025X
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 13061608490829
   Coding: 0400
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 0D4755275DD0F0EF0A2-8058
   Part No SW: 5G1 920 750 B    HW: 5G1 920 750 B
   Component: KOMBI         303 8311
   Coding: 03A501002390000D02083B001400000000000000
   VCID: 26150A8BD866A3B72B8-8072
16777034 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_DoorLocking_0x0D keine Kommunikation]
                    Reset counter: 195
                    Mileage: 21060 km
                    Date: 2018.09.16
                    Time: 15:29:53
   Coding: 1305
   Part No SW: 5Q0 907 530 AL    HW: 5Q0 907 530 E
   Component: GW MQB Mid    127 1265
   Revision: --------    Serial number: 0005024934
   Coding: 030100043F085700FB000248080F00010001050000000000000000000000
   ROD: EV_GatewLear_013_VW37.rod
   VCID: 7BA30BFF7364CE5F246-802E
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160001142480026234
   Coding: 28FFFF
   Serial number: 8442320304
   Serial number: 300516EEU02971
   Coding: 003B0320D000040100001000
   VCID: 43D3B31F4B14769F2C6-8016
   Coding: 8307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2DCEFB3CDE37577F0-806E
   Serial number: 280516EER24731
   Coding: 003B0120DE00040100801000
   VCID: 42DDB61B540E7F97270-8016
   Part No SW: 3Q0 035 824 B    HW: 3Q0 035 824 B
   Component: MU-S--ER      710 0744
   Coding: 02730000AA0000005111000100080A001F0206D40120010003
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 2C01F8A3C68A99E7FDC-8078
   Subsystem 1 - Part No SW: 3G0 919 605 B    HW: 3G0 919 605 B
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9SJT00QNA
End----------(Elapsed Time: 01:49, VBatt start/end: 12.4V/12.4V)-----------
darkchina811
ITALY
C?ID=333184
;SW:04E-906-027-HB   HW:04E-907-309-BH ---  Engine
;Component:R4 1.4l TFS   H25 2833, Coding:0119003223241D082000
;EV_ECM14TFS01104E906027HB,001005,EV_ECM14TFS01104E906027HB.rod
;Sunday,16,September,2018,21:30:23:06888
;VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.2
;VCID: 6B833BBF03045EDFB46-803E
IDE01945-Engine run-in oil pressure,not active ,1
IDE02248-Individually adjustable maximum speed limit,300.0 km/h,2
IDE02632-MAS00478-Activation of static maximum speed limit-Reserved,0 ,1
IDE02632-Activation of static maximum speed limit-,OFF ,1
IDE02633-Deactivation of static maximum speed limit,00 00 ,2
IDE04158-Activation of start-stop function,active ,1
IDE06648-Activation of interior auxil. heating,active ,1
Elapsed Time: 00:02
;SW:5G0-907-044-BE   HW:5G0-907-044-BE ---  Auto HVAC
;Component:Climatronic   H03 1001, Coding:00020004104111011005004000101022
;EV_ACClimaBHBVW37X,003018,EV_ACClimaBHBVW37X_003_VW37.rod
;Sunday,16,September,2018,21:30:43:06888
IDE01067-Retention of driver's seat heater level,active ,1
IDE01479-Gear ratio of engine - A/C compressor,0.00 ,1
IDE01483-Blower voltage for voice operation,not activated ,1
IDE01488-Retrofitting of parking heater without CAN,not installed ,1
IDE01493-Air quality sensor sensitivity,Maximum ,1
IDE01503-Runtime for compressor run-in basic setting,60 s,1
IDE01536-Post-heating of parking heater,10 min,1
IDE03176-Duration of compressor run in,60 s,1
IDE03251-Stop release for start-stop function,According to function requirements ,1
IDE04159-Deactivation of start-stop function,not active ,1
IDE06544-Speed switch-off threshold for compressor run-in (engine speed),1500 /min,1
IDE06545-Blower voltage for production routines,6.0 V,1
IDE06546-Interior target temperature for production routines,22 °C,1
IDE06593-Recirculation air for production routines,No effect ,1
IDE07108-Climate modes,Matching coding ,1
IDE07398-Blower logic for manual adjustment,Matching coding ,1
IDE07585-Hand heater function during cold start,active ,1
IDE07865-Automatic Activation of front windshield heater at MAX-Defrost,not active ,1
IDE07948-Retention of frt.pass. seat heater level,active ,1
IDE80006-Analysis 6,not activated ,1
IDE80007-Analysis 7,00000000 00000000  ,2
IDE80008-Analysis 8,active ,1
MAS05739-CO2 compressor on-time reduction,Matching coding ,1
MAS06564-Window condensation exterior reduction at high humidity,Matching coding ,1
MAS07251-Cut-in behavior,Matching coding ,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,6 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,40 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,60 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,80 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,100 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,0 %,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 %,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,40 %,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,60 %,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 %,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 %,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,2 %,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,2 %,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,10 %,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,21 %,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,85 %,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 %,12
ENG122846-ENG101574-dimming_characteristic_3-X1,0 ,12
ENG122846-ENG99557-dimming_characteristic_3-X2,10 ,12
ENG122846-ENG102140-dimming_characteristic_3-X3,50 ,12
ENG122846-ENG102936-dimming_characteristic_3-X4,100 ,12
ENG122846-ENG103548-dimming_characteristic_3-X5,220 ,12
ENG122846-ENG113992-dimming_characteristic_3-X6,253 ,12
ENG122846-ENG99777-dimming_characteristic_3-Y1,3 %,12
ENG122846-ENG100480-dimming_characteristic_3-Y2,3 %,12
ENG122846-ENG100773-dimming_characteristic_3-Y3,6 %,12
ENG122846-ENG100631-dimming_characteristic_3-Y4,21 %,12
ENG122846-ENG102174-dimming_characteristic_3-Y5,100 %,12
ENG122846-ENG113993-dimming_characteristic_3-Y6,100 %,12
ENG122847-ENG101574-dimming_characteristic_4-X1,0 ,12
ENG122847-ENG99557-dimming_characteristic_4-X2,10 ,12
ENG122847-ENG102140-dimming_characteristic_4-X3,50 ,12
ENG122847-ENG102936-dimming_characteristic_4-X4,100 ,12
ENG122847-ENG103548-dimming_characteristic_4-X5,220 ,12
ENG122847-ENG113992-dimming_characteristic_4-X6,253 ,12
ENG122847-ENG99777-dimming_characteristic_4-Y1,2 %,12
ENG122847-ENG100480-dimming_characteristic_4-Y2,2 %,12
ENG122847-ENG100773-dimming_characteristic_4-Y3,5 %,12
ENG122847-ENG100631-dimming_characteristic_4-Y4,10 %,12
ENG122847-ENG102174-dimming_characteristic_4-Y5,85 %,12
ENG122847-ENG113993-dimming_characteristic_4-Y6,100 %,12
ENG122848-ENG101574-dimming_characteristic_5-X1,0 ,12
ENG122848-ENG99557-dimming_characteristic_5-X2,10 ,12
ENG122848-ENG102140-dimming_characteristic_5-X3,50 ,12
ENG122848-ENG102936-dimming_characteristic_5-X4,100 ,12
ENG122848-ENG103548-dimming_characteristic_5-X5,220 ,12
ENG122848-ENG113992-dimming_characteristic_5-X6,253 ,12
ENG122848-ENG99777-dimming_characteristic_5-Y1,2 %,12
ENG122848-ENG100480-dimming_characteristic_5-Y2,2 %,12
ENG122848-ENG100773-dimming_characteristic_5-Y3,5 %,12
ENG122848-ENG100631-dimming_characteristic_5-Y4,21 %,12
ENG122848-ENG102174-dimming_characteristic_5-Y5,85 %,12
ENG122848-ENG113993-dimming_characteristic_5-Y6,100 %,12
Elapsed Time: 00:10
;SW:5Q0-937-084-BR   HW:5Q0-937-084-AJ ---  Cent. Elect.
;Component:BCM MQBAB H   H18 0138, Coding:00000846C20102FB4B644080B11407281400000000000000000000000000
;EV_BCMCONTI,013000,EV_BCMBOSCH_013.rod
;Sunday,16,September,2018,21:31:04:06888
;VCID: 094F613729B8ECCF26A-805C
IDE00001-ENG115730-Production mode-Aussenbeleuchtung,not active ,3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active ,12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms,12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms,12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,0 ms,12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0 ,12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,12
IDE01550-Service position,170.49 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,active ,4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,4
IDE02488-DWA Interior monitoring,100 %,1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,8
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %,8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %,8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %,8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,Enabled ,8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.25 °,14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.00 %/s,14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,OFF ,14
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.00 km/h,14
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.00 °C,14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.00 °C,14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.00 °C,14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 °,14
IDE03638-ENG116676-static AFS light-Upper speed threshold,50.00 km/h,14
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte ,8
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,5 ,8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,MFG ,8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10 ,8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00 %,8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,active ,14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active ,14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Fog light ,8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic ,8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx,8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx,8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 seconds ,8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,8
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C,8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C,8
IDE04927-ENG126845-Window heater-FSH Automatik,active ,8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,4
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,driver door contact thatcham ,4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,2 sekunden verzoegerung ,4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,8
IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,not active ,8
IDE05142-ENG116706-Access control-Autounlock NAR,not active ,8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active ,8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,8
IDE05142-ENG115722-Access control-Electrical rear lid,not active ,8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active ,8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,active ,8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,8
IDE05142-ENG115755-Access control-Notschließfunktion,active ,8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always ,8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always ,8
IDE05142-ENG115758-Access control-Valet Parking,not active ,8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active ,8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung ,8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,8
IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10,00 ,560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11,00 ,560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12,38 ,560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13,42 ,560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16,00 ,560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17,00 ,560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08 ,560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18 ,560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2,00 ,560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20,10 ,560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21,20 ,560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23,00 ,560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24,00 ,560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26,0C ,560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27,1A ,560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3,00 ,560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4,48 ,560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5,4C ,560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36 ,560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40 ,560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8,37 ,560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9,41 ,560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,minimize ,560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize ,560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,minimize ,560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,minimize ,560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,minimize ,560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,minimize ,560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize ,560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize ,560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,minimize ,560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,minimize ,560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0,100 ,560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1,100 ,560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10,0 ,560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11,0 ,560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100 ,560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100 ,560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16,100 ,560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17,100 ,560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100 ,560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100 ,560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2,0 ,560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23,100 ,560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24,100 ,560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25,127 ,560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26,100 ,560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27,10 ,560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28,86 ,560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29,86 ,560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3,0 ,560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30,89 ,560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31,0 ,560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32,0 ,560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33,0 ,560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0 ,560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4,100 ,560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5,100 ,560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6,100 ,560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7,100 ,560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8,100 ,560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9,100 ,560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0 ,560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0 ,560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12,100 ,560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13,100 ,560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2,0 ,560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20,10 ,560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21,10 ,560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23,10 ,560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24,10 ,560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27,100 ,560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3,0 ,560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4,0 ,560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5,0 ,560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0 ,560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0 ,560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2,0 ,560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0 ,560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3,0 ,560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4,31 ,560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5,31 ,560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0 ,560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0 ,560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0 ,560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0 ,560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,00 ,560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,00 ,560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,22 ,560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,23 ,560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,41 ,560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,42 ,560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16 ,560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18 ,560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,00 ,560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,39 ,560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,3A ,560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,00 ,560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,00 ,560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2E ,560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,2A ,560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,00 ,560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,02 ,560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00 ,560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00 ,560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00 ,560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,00 ,560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,43 ,560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,44 ,560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,1C ,560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,1D ,560
IDE05145-ENG115873-Light configuration-Lasttyp 0,12 - Blinkleuchten ,560
IDE05145-ENG115892-Light configuration-Lasttyp 1,12 - Blinkleuchten ,560
IDE05145-ENG116062-Light configuration-Lasttyp 10,not active ,560
IDE05145-ENG116081-Light configuration-Lasttyp 11,not active ,560
IDE05145-ENG116100-Light configuration-Lasttyp 12,10 - allgemeine Scheinwerfer ,560
IDE05145-ENG116119-Light configuration-Lasttyp 13,10 - allgemeine Scheinwerfer ,560
IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
IDE05145-ENG116176-Light configuration-Lasttyp 16,37 - allgemeine LED bis 12W ,560
IDE05145-ENG116195-Light configuration-Lasttyp 17,37 - allgemeine LED bis 12W ,560
IDE05145-ENG116214-Light configuration-Lasttyp 18,38 - LED Blinkleuchten ,560
IDE05145-ENG116233-Light configuration-Lasttyp 19,38 - LED Blinkleuchten ,560
IDE05145-ENG115910-Light configuration-Lasttyp 2,not active ,560
IDE05145-ENG116252-Light configuration-Lasttyp 20,34 - LED Bremsleuchten ,560
IDE05145-ENG116271-Light configuration-Lasttyp 21,34 - LED Bremsleuchten ,560
IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
IDE05145-ENG116309-Light configuration-Lasttyp 23,34 - LED Bremsleuchten ,560
IDE05145-ENG116328-Light configuration-Lasttyp 24,34 - LED Bremsleuchten ,560
IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
IDE05145-ENG116366-Light configuration-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung ,560
IDE05145-ENG116385-Light configuration-Lasttyp 27,32 - allgemeine LED bis 12W ,560
IDE05145-ENG116404-Light configuration-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116423-Light configuration-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG115929-Light configuration-Lasttyp 3,not active ,560
IDE05145-ENG116442-Light configuration-Lasttyp 30,36 - LED Kleinleistung ,560
IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
IDE05145-ENG115948-Light configuration-Lasttyp 4,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG115967-Light configuration-Lasttyp 5,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG115986-Light configuration-Lasttyp 6,11 - Abblendlicht ,560
IDE05145-ENG116005-Light configuration-Lasttyp 7,11 - Abblendlicht ,560
IDE05145-ENG116024-Light configuration-Lasttyp 8,10 - allgemeine Scheinwerfer ,560
IDE05145-ENG116043-Light configuration-Lasttyp 9,10 - allgemeine Scheinwerfer ,560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,only_if_closed ,560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,only_if_closed ,560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,Always ,560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always ,560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,only_if_closed ,560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,only_if_closed ,560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,0 ,560
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,0 ,560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,0 ,560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,0 ,560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,18 ,560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,19 ,560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,2 ,560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,4 ,560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,0 ,560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24 ,560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24 ,560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,24 ,560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,24 ,560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,27 ,560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,8 ,560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25 ,560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,0 ,560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,43 ,560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,0 ,560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,0 ,560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,0 ,560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,0 ,560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,13 ,560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,14 ,560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,0 ,560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,0 ,560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,22 ,560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,23 ,560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,0 ,560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,0 ,560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,0 ,560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0 ,560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,30 ,560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,0 ,560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0 ,560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0 ,560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,0 ,560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,0 ,560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,15 ,560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,15 ,560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0 ,560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0 ,560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0 ,560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0 ,560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0 ,560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0 ,560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0 ,560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,0 ,560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,8 ,560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,8 ,560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,8 ,560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,8 ,560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,30 ,560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,0 ,560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,0 ,560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,0 ,560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0 ,560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0 ,560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0 ,560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0 ,560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,22 ,560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,23 ,560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0 ,560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,9 ,560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,10 ,560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,9 ,560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,10 ,560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,24 ,560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0 ,560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0 ,560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0 ,560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0 ,560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0 ,560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,0 ,560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,0 ,560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,6 ,560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,7 ,560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0 ,560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,0 ,560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,31 ,560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,31 ,560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,9 ,560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5,10 ,560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0 ,560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0 ,560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,2 ,560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,4 ,560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,30 ,560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,30 ,560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
IDE05822-DWA Vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 63 0A 78 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 24 42 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 03 32 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 03 22 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 03 22 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 24 22 0C FA 0A 34 95 0D 09 A3 21 43 34 02 02 02 02 02 02 B1 10 22 29 67 ,172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,30 s,24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,1.10 °C,24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,33.00 °C,24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,32.00 °C,24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,33.00 °C,24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,32.00 °C,24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,37.50 °C,24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,36.50 °C,24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,37.50 °C,24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,36.50 °C,24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,41.00 °C,24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,40.00 °C,24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,41.00 °C,24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,40.00 °C,24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,8
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active ,4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,active ,4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,4
IDE07356-Position during interval mode,31.49 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,not active ,12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,12
IDE08542-IDE02021-Access control 2-Comfort closing,active ,8
IDE08542-IDE02022-Access control 2-Comfort opening,active ,8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active ,8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active ,8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active ,8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,8
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,active ,8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active ,8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active ,8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,active ,8
IDE08542-ENG125656-Access control 2-Regenschliessen_art,once ,8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,not active ,8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,not active ,8
IDE08542-ENG154261-Access control 2-Reserved_4,not active ,8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,active ,8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,active ,8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,not active ,8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active ,8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,not active ,8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active ,8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active ,8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,not active ,8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active ,8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active ,8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,0 ms,8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,active ,8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,not active ,8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,active ,8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active ,8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,2
IDE08787-ENG101416-Auxiliary functions-Reserved_1,not active ,2
IDE08787-ENG99458-Auxiliary functions-Reserved_2,not active ,2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active ,2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
IDE09595-ENG115658-Characteristic curve-x0,0 lx,18
IDE09595-ENG101574-Characteristic curve-X1,2000 lx,18
IDE09595-ENG99557-Characteristic curve-X2,4000 lx,18
IDE09595-ENG102140-Characteristic curve-X3,6000 lx,18
IDE09595-ENG102936-Characteristic curve-X4,8000 lx,18
IDE09595-ENG103548-Characteristic curve-X5,10200 lx,18
IDE09595-ENG148955-Characteristic curve-y1_0,0 ,18
IDE09595-ENG148956-Characteristic curve-y1_1,40 ,18
IDE09595-ENG148957-Characteristic curve-y1_2,90 ,18
IDE09595-ENG148958-Characteristic curve-y1_3,140 ,18
IDE09595-ENG148959-Characteristic curve-y1_4,190 ,18
IDE09595-ENG148960-Characteristic curve-y1_5,245 ,18
IDE09595-ENG148961-Characteristic curve-y2_0,0 ,18
IDE09595-ENG148962-Characteristic curve-y2_1,60 ,18
IDE09595-ENG148963-Characteristic curve-y2_2,110 ,18
IDE09595-ENG148964-Characteristic curve-y2_3,160 ,18
IDE09595-ENG148965-Characteristic curve-y2_4,210 ,18
IDE09595-ENG148966-Characteristic curve-y2_5,255 ,18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,0 ,20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,0 ,20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,0 ,20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225 ,20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225 ,20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225 ,20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225 ,20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225 ,20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225 ,20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225 ,20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225 ,20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225 ,20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed ,2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed ,2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed ,2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung,3000 ms,10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit,1000 ms,10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige,0 s,10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz,25 ,10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor,0 ,10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS,393210 lx,10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS,393210 lx,10
IDE09733-ENG147405-LED bar setting values-Sperrzeit,0 s,10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
IDE10298-Alternating park position 1,7.49 °,2
IDE10299-Alternating park position 2,29.49 °,2
MAS05055-lower turn position,31.49 °,2
MAS05056-upper turn position,170.49 °,2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,active ,8
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,0 ,60
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0 ,11
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 ,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 ,22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 ,22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00 ,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00 ,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00 ,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00 ,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00 ,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00 ,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00 ,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00 ,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00 ,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00 ,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00 ,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00 ,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00 ,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00 ,8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00 ,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00 ,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00 ,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00 ,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00 ,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00 ,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00 ,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00 ,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00 ,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.00 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00 ,10
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,100 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links ,16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12,Abbiegelicht links ,16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,100 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts ,16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13,Abbiegelicht rechts ,16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,100 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,41 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,only_if_closed ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Blinken links Hellphase ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,100 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,42 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,only_if_closed ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Blinken rechts Hellphase ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,10 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake light ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,10 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake light ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,Parking light right ,16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,minimize ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,100 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,10 ,16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,00 ,16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,00 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,34 - LED Bremsleuchten ,16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Brake light ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,Blinken links aktiv (beide Phasen) ,16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24,minimize ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,100 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,10 ,16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,00 ,16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,00 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,34 - LED Bremsleuchten ,16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Brake light ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Parking light right ,16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,Blinken rechts aktiv (beide Phasen) ,16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25,minimize ,16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,Coming Home oder Leaving Home aktiv ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,10 ,16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27,100 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2A ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1A ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,Coming Home oder Leaving Home aktiv ,16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27,Brake light ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,86 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,86 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,minimize ,16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4,minimize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,100 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,31 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,43 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,48 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht vorn (Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4,Blinken links Hellphase ,16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4,Coming Home oder Leaving Home aktiv ,16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,minimize ,16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5,minimize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,100 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,31 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,44 ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,4C ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht vorn (Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right ,16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5,Blinken rechts Hellphase ,16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5,Coming Home oder Leaving Home aktiv ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,100 ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,11 - Abblendlicht ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,100 ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,11 - Abblendlicht ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,10 - allgemeine Scheinwerfer ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,10 - allgemeine Scheinwerfer ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske,63 ,1
ENG126648-ENG148864-LIN-Mirrormode-Stage,0 ,1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50 ,12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %,12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %,12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %,12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %,12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %,12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %,12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts,2 ,8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer,10 min,8
Elapsed Time: 01:46
;SW:5G1-920-750-B   HW:5G1-920-750-B ---  Instruments
;Component:KOMBI         303 8311, Coding:03A501002390000D02083B001400000000000000
;EV_DashBoardVDDMQBAB,009051,EV_DashBoardVDDMQBAB_009_VW37.rod
;Sunday,16,September,2018,21:32:58:06888
;VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.2
;VCID: 26150A8BD866A3B72B8-8072
IDE00295-Oil temperature display,On ,1
IDE00301-Distance,21070 km,3
IDE00342-ESI: Resetting ESI,no warning ,1
IDE00343-Language version,English ,1
IDE00500-Hour,21 H,1
IDE00501-Minute,32 min,1
IDE00502-Year,2018 yr,2
IDE00503-Month,9 mon,1
IDE00504-Day,16 d,1
IDE00510-ESI: distance driven from inspection,75 km,3
IDE00511-ESI: time from inspection,2 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
IDE00515-ESI: oil quality,good oil quality ,1
IDE00518-ESI: thermal load,0 km,2
IDE00819-Day counter,804 d,2
IDE01153-SIA: maximum value of distance to service,15000 km,2
IDE02489-Display depiction,Version 1 ,1
IDE03329-Driving profiled for range remaining,5.3 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,Kilometers ,3
IDE03346-MAS01230-Units adjusted-Date,mm_dd_yy ,3
IDE03346-MAS02201-Units adjusted-Temperature,Degrees Celsius ,3
IDE03346-MAS03032-Units adjusted-Volume,Liter ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Kilometers per liter ,3
IDE03348-MAS01456-Speed warning-Speed,130 ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,0 km,2
IDE03352-FIX: Time since last time-dependent inspection,2 d,2
IDE03372-Source for synchronization of time,internal clock ,1
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
IDE03867-Deactivate seat belt warning,Yes ,1
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
IDE06588-Ignition active message: actuator,No display ,1
MAS03685-Digital speedometer,No display ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,9 l,1
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32 ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC ,12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00 ,12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00 ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05 ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,14 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0E ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1E ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,32 ,12
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00 ,12
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,0A ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,32 ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64 ,12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,DC ,12
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,FD ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,03 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,03 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,10 ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,1E ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,55 ,12
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64 ,12
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00 ,12
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96 ,12
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05 ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05 ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17 ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32 ,12
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64 ,12
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0E ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 41 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00 ,12
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A ,12
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,96 ,12
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD ,12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01 ,12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01 ,12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,07 ,12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0E ,12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,1E ,12
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64 ,12
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
ENG119882-init_fuel_algorithm,No ,1
ENG130585-Leaving_warning_delay,1.6 s,1
ENG126396-Scale_switching_algorithm,lowbeam_foglight ,1
ENG130584-Statistic_phev_mileage,5 km,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,35 s,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.40 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
ENG112418-ENG99298-total_range_gas-State,not active ,4
Elapsed Time: 00:26
;SW:5Q0-963-272-B   HW:5Q0-963-272-B ---  Aux. Heat
;Component:STH-MQB       006 0069, Coding:1305
;EV_AuxilParkiHeateWOS,002014,EV_AuxilParkiHeateWOS.rod
;Sunday,16,September,2018,21:33:32:06888
;VCID: 3537DDC715C0D82F922-8060
IDE00470-Initial fuel filling,Yes ,1
IDE06640-MAS01167-Transfer fuel pump-Actuation time,15 s,5
IDE06640-MAS05078-Transfer fuel pump-Minimum tank level,127 l,5
IDE06640-MAS05079-Transfer fuel pump-Fuel reserve amount,100 ml,5
IDE06640-MAS05080-Transfer fuel pump-Maximum standing time,0.0 H,5
IDE06640-MAS05689-Transfer fuel pump-Activation delay,10 s,5
IDE06642-MAS05071-Coolant change-over valve-Temperature difference: engine/parking heater,5 °C,4
IDE06642-MAS05072-Coolant change-over valve-Maximum engine rpm,2000 /min,4
IDE06642-MAS05073-Coolant change-over valve-Residual heat: threshold,55 °C,4
IDE06642-MAS05074-Coolant change-over valve-Note engine rpm,No ,4
IDE06686-Insufficient voltage threshold,11.3 V,1
IDE06687-CO2 adjustment,165 ,1
IDE06688-Auxil. heater activation,active ,1
IDE06689-Low voltage detection: time limit,20.0 s,1
IDE06690-MAS05059-Auxil. heat control parameters-Lower temperature threshold: ambient temperature,5.0 °C,11
IDE06690-MAS05060-Auxil. heat control parameters-Upper temperature threshold: ambient temperature,12.0 °C,11
IDE06690-MAS05061-Auxil. heat control parameters-Temperature hysteresis: ambient temperature for USA vehicle,3.0 °C,11
IDE06690-MAS05062-Auxil. heat control parameters-Lower temperature threshold: coolant temperature via CAN,72 °C,11
IDE06690-MAS05063-Auxil. heat control parameters-Upper temperature threshold: coolant temperature via CAN,88 °C,11
IDE06690-MAS05064-Auxil. heat control parameters-Lower temperature threshold for partial load after full load,74 °C,11
IDE06690-MAS05065-Auxil. heat control parameters-Lower temperature threshold for starting from control pause,76 °C,11
IDE06690-MAS05066-Auxil. heat control parameters-Upper temperature threshold for full load after partial load,84 °C,11
IDE06690-MAS05067-Auxil. heat control parameters-Upper temperature threshold for control pause,88 °C,11
IDE06690-MAS05068-Auxil. heat control parameters-Temperature threshold for control mode,82 °C,11
IDE06691-MAS05064-Parking heat control parameters-Lower temperature threshold for partial load after full load,58 °C,7
IDE06691-MAS05065-Parking heat control parameters-Lower temperature threshold for starting from control pause,60 °C,7
IDE06691-MAS05066-Parking heat control parameters-Upper temperature threshold for full load after partial load,82 °C,7
IDE06691-MAS05067-Parking heat control parameters-Upper temperature threshold for control pause,88 °C,7
IDE06691-MAS05068-Parking heat control parameters-Temperature threshold for control mode,82 °C,7
IDE06691-MAS05069-Parking heat control parameters-Temperature threshold for activation of fresh air blower,45 °C,7
IDE06691-MAS05070-Parking heat control parameters-Control behavior,Continuous ,7
IDE06692-Note request for aux. heater from A/C system,Do not ignore ,1
IDE06693-Evaluate air pressure via CAN,Yes ,1
IDE06694-MAS05076-Minimum burn time-Time,300 s,2
IDE06694-MAS05077-Minimum burn time-Temperature threshold offset,4 °C,2
MAS01488-MAS03873-recirc. pump-Duty cycle,not active ,5
MAS01488-MAS05072-recirc. pump-Maximum engine rpm,12750 /min,5
MAS01488-MAS06093-recirc. pump-Lowest temperature for request of exterior water pump,-20 °C,5
MAS01488-MAS06094-recirc. pump-Lowest activation temperat. for request of exterior water pump,150 s,5
MAS01488-MAS06095-recirc. pump-Maximum temperature for request of exterior water pump,180 s,5
MAS05075-Evaluate ethanol content,Yes ,1
MAS09096-Recirc. pump locking mechan.,1 ,1
ENG119729-activacion_of_simulated_flamme_run_for_emv_measuring,No ,1
ENG119721-development_data_on_CAN,not active ,1
Elapsed Time: 00:05
;SW:5Q0-907-530-AL   HW:5Q0-907-530-E ---  CAN Gateway
;Component:GW MQB Mid    127 1265, Coding:030100043F085700FB000248080F00010001050000000000000000000000
;EV_GatewLear,013020,EV_GatewLear_013_VW37.rod
;Sunday,16,September,2018,21:33:52:06888
;VCID: 7BA30BFF7364CE5F246-802E
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation,12.1 V,2
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering,12.1 V,2
IDE01457-Energy management deactivation stage,Mode not active ,1
IDE01844-Increase idle speed request,Mode not active ,1
IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,Not coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brakes 1,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded ,32
IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,Not coded ,32
IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics,Not coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,coded ,32
IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,coded ,32
IDE01996-SFT00025-Installation list: specified installations-Gateway,1 ,32
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,Not coded ,32
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,Not coded ,32
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,Not coded ,32
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant,Not coded ,32
IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor,Not coded ,32
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded ,32
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded ,32
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32
IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Not coded ,32
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded ,32
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded ,32
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,Not coded ,32
IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1,coded ,32
IDE01996-SFT00096-Installation list: specified installations-Tachograph,Not coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded ,32
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,Not coded ,32
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,Not coded ,32
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,Not coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery Regulation Auxiliary Accumulator 1,Not coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System,Not coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded ,32
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,Not coded ,32
IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side,Not coded ,32
IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side,Not coded ,32
IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management,Not coded ,32
IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left,Not coded ,32
IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right,Not coded ,32
IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module,Not coded ,32
IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof,Not coded ,32
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2,Not coded ,32
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32
IDE01996-ENG118302-Installation list: specified installations-Node_0x85,Not coded ,32
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32
IDE01996-ENG118324-Installation list: specified installations-Node_0x9C,Not coded ,32
IDE02200-Component protection showroom mode,not active ,1
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,59 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,EFB ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111 ,15
IDE03903-Production process data 1,00 00 ,2
IDE04159-Deactivation of start-stop function,Mode not active ,1
IDE04330-Transfer of release code for a SWaP function,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,384
IDE06425-MAS06026-Roller test bench mode: functional-Activation stages,not activated ,1
IDE06425-MAS06277-Roller test bench mode: functional-Malfunction states,no error ,1
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated ,4
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated ,4
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated ,4
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated ,4
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated ,4
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,not activated ,4
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated ,4
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,activated ,4
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated ,4
IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips independent of driver profile selection ,4
IDE06753-MAS19094-Efficiency program display-Convenience_consumption_air_condition_ventilation_rear,activated ,4
IDE06753-MAS19095-Efficiency program display-Convenience_consumption_mirror_heating_dependency,Until_temperature_threshold_with_after-run_with_switch ,4
IDE08348-Start/stop start voltage limit,12.0 V,1
IDE10748-MAS11262-Range gain-Range gain AC system,activated ,3
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated ,3
IDE10748-MAS11264-Range gain-Range gain window defogger,activated ,3
IDE10748-MAS11265-Range gain-Range gain seat heater front,activated ,3
IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated ,3
IDE10748-MAS11267-Range gain-Range gain rear heater,activated ,3
IDE10748-MAS11268-Range gain-Range gain fog light,activated ,3
IDE10748-MAS11269-Range gain-Range gain rear fog light,not activated ,3
IDE10748-MAS11270-Range gain-Range gain windshield heating,activated ,3
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated ,3
IDE10748-MAS11272-Range gain-Range gain mirror heater,activated ,3
IDE10748-MAS11273-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,not activated ,3
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,not activated ,3
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,not activated ,3
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,not activated ,3
IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3
IDE10748-MAS12689-Range gain-Catalogue range display,activated ,3
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated ,3
IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,activated ,3
IDE10748-MAS19099-Range gain-Convenience_consumption_means_plug,activated ,3
IDE10748-MAS19100-Range gain-Convenience_consumption_air_condition_ventilation_manually,activated ,3
IDE10748-MAS19132-Range gain-Consumption_mirror_heating_in_heated_rear_window,activated ,3
ENG125878-ENG125896-AGW_Calibration-AGW_Brightness_Start_Sequence,100 %,10
ENG125878-ENG126255-AGW_Calibration-AGW_fade_in_deactivation_threshold,100 ,10
ENG125878-ENG125890-AGW_Calibration-AGW_Time_Fade_In,0 ms,10
ENG125878-ENG125892-AGW_Calibration-AGW_Time_Fade_In_Start,0 ms,10
ENG125878-ENG125891-AGW_Calibration-AGW_Time_Fade_Out,0 ms,10
ENG125878-ENG125893-AGW_Calibration-AGW_Time_Fade_Out_Start,0 ms,10
ENG125878-ENG125895-AGW_Calibration-AGW_Time_Start_Delay,0 ms,10
ENG125878-ENG125894-AGW_Calibration-AGW_Time_Start_Sequence,0 ms,10
ENG125879-ENG125897-AGW_Function_Releases-AGW_Enabling_Brightness,active ,3
ENG125879-ENG125898-AGW_Function_Releases-AGW_Enabling_Flash_Frequency,active ,3
ENG125879-ENG125899-AGW_Function_Releases-AGW_Enabling_Supression_Symbol,active ,3
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,0 ms,12
ENG137060-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen,Mode not active ,4
ENG137060-ENG98711-EM_energy_management_warning_displays-Charge level,Mode not active ,4
ENG137075-EM_heating_power_quota_adjustment,1000 W,1
ENG137062-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature,-50.0 °C,2
ENG137062-ENG137099-EM_start_stop_requirement_ambient_temperature-Minimum_temperature,-50.0 °C,2
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled ,32
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled ,32
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled ,32
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled ,32
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning,Enabled ,32
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics,Enabled ,32
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,Enabled ,32
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled ,32
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled ,32
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled ,32
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not enabled ,32
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled ,32
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled ,32
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled ,32
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway,Enabled ,32
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled ,32
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled ,32
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control,Enabled ,32
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,Enabled ,32
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled ,32
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled ,32
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,Enabled ,32
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics,Enabled ,32
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled ,32
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant,Enabled ,32
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,Enabled ,32
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled ,32
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled ,32
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance,Enabled ,32
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,Enabled ,32
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multifunction module,Enabled ,32
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled ,32
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled ,32
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled ,32
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,Enabled ,32
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,Enabled ,32
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled ,32
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph,Enabled ,32
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled ,32
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,Enabled ,32
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled ,32
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled ,32
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled ,32
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance,Enabled ,32
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery Regulation Auxiliary Accumulator 1,Enabled ,32
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head Up Display,Enabled ,32
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled ,32
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System,Enabled ,32
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled ,32
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled ,32
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled ,32
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled ,32
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled ,32
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled ,32
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled ,32
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled ,32
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled ,32
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,Enabled ,32
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled ,32
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled ,32
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Control Unit Lane Change Assistant 2,Enabled ,32
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled ,32
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled ,32
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled ,32
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled ,32
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled ,32
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled ,32
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled ,32
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled ,32
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled ,32
ENG137058-ENG118474-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x09,Enabled ,32
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled ,32
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled ,32
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled ,32
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled ,32
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled ,32
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled ,32
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled ,32
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled ,32
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled ,32
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled ,32
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled ,32
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled ,32
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled ,32
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled ,32
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled ,32
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled ,32
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled ,32
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled ,32
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled ,32
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled ,32
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled ,32
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled ,32
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled ,32
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled ,32
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled ,32
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled ,32
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled ,32
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled ,32
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled ,32
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled ,32
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled ,32
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled ,32
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled ,32
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled ,32
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled ,32
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled ,32
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled ,32
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled ,32
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled ,32
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled ,32
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled ,32
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled ,32
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled ,32
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled ,32
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled ,32
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled ,32
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled ,32
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled ,32
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled ,32
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled ,32
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled ,32
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled ,32
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled ,32
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled ,32
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled ,32
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled ,32
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled ,32
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled ,32
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled ,32
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled ,32
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled ,32
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled ,32
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled ,32
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled ,32
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled ,32
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled ,32
ENG137058-ENG118542-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x85,Enabled ,32
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled ,32
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled ,32
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled ,32
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled ,32
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled ,32
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled ,32
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled ,32
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled ,32
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled ,32
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled ,32
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled ,32
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled ,32
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled ,32
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled ,32
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled ,32
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled ,32
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled ,32
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled ,32
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled ,32
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled ,32
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled ,32
ENG137058-ENG118564-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9C,Enabled ,32
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled ,32
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled ,32
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled ,32
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled ,32
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled ,32
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled ,32
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled ,32
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled ,32
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled ,32
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled ,32
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled ,32
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled ,32
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled ,32
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled ,32
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled ,32
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled ,32
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled ,32
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled ,32
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled ,32
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled ,32
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled ,32
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled ,32
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled ,32
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled ,32
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled ,32
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled ,32
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled ,32
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled ,32
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled ,32
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled ,32
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled ,32
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled ,32
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled ,32
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled ,32
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled ,32
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled ,32
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled ,32
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled ,32
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled ,32
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled ,32
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled ,32
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled ,32
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled ,32
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled ,32
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled ,32
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled ,32
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled ,32
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled ,32
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled ,32
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled ,32
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled ,32
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled ,32
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled ,32
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled ,32
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled ,32
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled ,32
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled ,32
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled ,32
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled ,32
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled ,32
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled ,32
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled ,32
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled ,32
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled ,32
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled ,32
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled ,32
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled ,32
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled ,32
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled ,32
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled ,32
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled ,32
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled ,32
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled ,32
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled ,32
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled ,32
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled ,32
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled ,32
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled ,32
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled ,32
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled ,32
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled ,32
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled ,32
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled ,32
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled ,32
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled ,32
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled ,32
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled ,32
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled ,32
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled ,32
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled ,32
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled ,32
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled ,32
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled ,32
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled ,32
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled ,32
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled ,32
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Databus drivetrain ,2
ENG137065-GW_routing_0,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137066-GW_routing_1,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137067-GW_routing_2,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137068-GW_routing_3,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137069-GW_routing_4,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137070-GW_routing_5,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137071-GW_routing_6,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137072-GW_routing_7,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137073-GW_routing_8,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137074-GW_routing_9,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG118779-IDE02583-Multi_function_steering_wheel_control_module Coding Value-Steering wheel Tiptronic switch,not installed ,3
ENG118779-MAS06614-Multi_function_steering_wheel_control_module Coding Value-Version,CCS ,3
ENG118779-MAS09758-Multi_function_steering_wheel_control_module Coding Value-Temperature sensor,not installed ,3
ENG118779-ENG118724-Multi_function_steering_wheel_control_module Coding Value-development_1,active ,3
ENG118779-ENG118725-Multi_function_steering_wheel_control_module Coding Value-development_2,not active ,3
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,not activated ,1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,5
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,5
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,5
Elapsed Time: 00:26
;SW:3Q0-035-824-B   HW:3Q0-035-824-B ---  Information Electr.
;Component:MU-S--ER      710 0744, Coding:02730000AA0000005111000100080A001F0206D40120010003
;EV_MUStd4CDELP,001001,EV_MUStd4CDELP_VW27.rod
;Sunday,16,September,2018,21:34:25:06888
;VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.2
;VCID: 2C01F8A3C68A99E7FDC-8078
IDE00346-Summertime-automatic,Europe ,1
IDE00758-Base volume of telephone,50 %,1
IDE00759-Base volume of speech output,50 %,1
IDE00760-Microphone sensitivity,0 dB,1
IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF ,1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF ,1
IDE02121-CD eject button,Enabled ,1
IDE02122-Developer mode,activated ,1
IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-MAS03001-Electrical test of loudspeakers-Mode,automatic ,49
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,49
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,49
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,49
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,49
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,49
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,49
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,49
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,49
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,49
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,49
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,49
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,49
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,49
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,49
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,49
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,49
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,49
IDE02502-Confirmation of installation change,36 2D ,2
IDE02699-Number 1 for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE03471-ENG117847-Vehicle configuration-advanced_range_display,OFF ,30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,On ,30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,OFF ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,OFF ,30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,OFF ,30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,OFF ,30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG125049-Vehicle configuration-Joker_button_1,Not Present ,30
IDE03471-ENG125050-Vehicle configuration-Joker_button_2,Not Present ,30
IDE03471-ENG127492-Vehicle configuration-LGI,OFF ,30
IDE03471-ENG130246-Vehicle configuration-LTE_modul,activated ,30
IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,On ,30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,OFF ,30
IDE03471-ENG117845-Vehicle configuration-online_dictation,OFF ,30
IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,OFF ,30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,Data & language service active ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi,OFF ,30
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo,OFF ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
IDE03471-ENG126143-Vehicle configuration-RVC_video_input,FBAS ,30
IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation,no restriction ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,no_region ,30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,Not Present ,30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi,activated ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,1 ,30
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold,OFF ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On ,30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability,OFF ,30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,blocked ,30
IDE03471-ENG137647-Vehicle configuration-UOTA,OFF ,30
IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,OFF ,30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
IDE03471-ENG117836-Vehicle configuration-VZAPro,OFF ,30
IDE03471-ENG127494-Vehicle configuration-VZO,OFF ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,OFF ,30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
IDE04295-Bluetooth: Preferred connection profile for phone book data,PBAP ,1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128 ,40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,5 ,40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128 ,40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128 ,40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128 ,40
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,-128 ,40
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,-128 ,40
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,-128 ,40
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128 ,40
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,-128 ,40
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,-128 ,40
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,-128 ,40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128 ,40
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,-128 ,40
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,-128 ,40
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,-128 ,40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128 ,40
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,-128 ,40
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,-128 ,40
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-3 ,40
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,-128 ,40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128 ,40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128 ,40
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,-128 ,40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,6 ,40
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,-128 ,40
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,-128 ,40
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,-128 ,40
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,-128 ,40
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,-128 ,40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128 ,40
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,-128 ,40
IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
IDE10604-Menu entries for mobile online services,not activated ,1
IDE11122-Country identification: country of sale HMI,IT ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,21
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked ,21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,21
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,21
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked ,21
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked ,21
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,21
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked ,21
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked ,21
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,21
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,21
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,21
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked ,21
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,21
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked ,21
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,21
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked ,21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,21
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,21
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked ,21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,21
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,21
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,21
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,21
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,21
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked ,21
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,21
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked ,21
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,21
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,21
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,21
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,21
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked ,21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked ,21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,21
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked ,21
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked ,21
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked ,21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,21
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,21
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,21
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,non_blocked ,21
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked ,21
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked ,21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,21
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked ,21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,21
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,non_blocked ,21
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked ,21
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked ,21
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,21
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked ,21
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,21
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,21
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked ,21
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,21
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked ,21
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked ,21
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,non_blocked ,21
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked ,21
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked ,21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked ,21
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked ,21
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked ,21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked ,21
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked ,21
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,21
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,21
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked ,21
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked ,21
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked ,21
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked ,21
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,21
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,21
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,21
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked ,21
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,21
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,21
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,21
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked ,21
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,21
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,21
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked ,21
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked ,21
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked ,21
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,21
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,21
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked ,21
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked ,21
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked ,21
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked ,21
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked ,21
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked ,21
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,21
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,21
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked ,21
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked ,21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked ,21
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked ,21
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,21
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked ,21
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,21
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked ,21
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked ,21
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked ,21
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,21
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked ,21
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked ,21
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,21
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,21
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,21
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,21
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked ,21
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked ,21
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,21
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked ,21
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked ,21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,21
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,21
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,21
MAS00951-Bluetooth,On ,1
MAS01968-Fan,normal ,1
MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz,6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz,6
MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz,6
MAS03782-WLAN,On ,1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated ,60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated ,60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated ,60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated ,60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated ,60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated ,60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated ,60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated ,60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated ,60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated ,60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated ,60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated ,60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated ,60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated ,60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated ,60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated ,60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated ,60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated ,60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated ,60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated ,60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated ,60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated ,60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated ,60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated ,60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated ,60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated ,60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated ,60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated ,60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated ,60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated ,60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated ,60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated ,60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated ,60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,activated ,60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated ,60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,activated ,60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated ,60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated ,60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated ,60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated ,60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated ,60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated ,60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated ,60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated ,60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated ,60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated ,60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated ,60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated ,60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated ,60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated ,60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated ,60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated ,60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated ,60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated ,60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated ,60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,activated ,60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated ,60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated ,60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated ,60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated ,60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,activated ,60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,activated ,60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated ,60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated ,60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated ,60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated ,60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated ,60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,activated ,60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated ,60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated ,60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated ,60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,not activated ,60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated ,60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated ,60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated ,60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated ,60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated ,60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not activated ,60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not activated ,60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not activated ,60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,not activated ,60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated ,60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated ,60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated ,60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated ,60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated ,60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated ,60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated ,60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated ,60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated ,60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated ,60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated ,60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated ,60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated ,60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated ,60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated ,60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated ,60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated ,60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated ,60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated ,60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,activated ,60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated ,60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated ,60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated ,60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated ,60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated ,60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated ,60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated ,60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ,60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated ,60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated ,60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,not activated ,60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated ,60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,not activated ,60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated ,60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated ,60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated ,60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated ,60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated ,60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated ,60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated ,60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated ,60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated ,60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated ,60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated ,60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated ,60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated ,60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated ,60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated ,60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated ,60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated ,60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated ,60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated ,60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated ,60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated ,60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated ,60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated ,60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated ,60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated ,60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated ,60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated ,60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,activated ,60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated ,60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated ,60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated ,60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated ,60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated ,60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated ,60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated ,60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated ,60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated ,60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated ,60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated ,60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated ,60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not activated ,60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated ,60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated ,60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated ,60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated ,60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated ,60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated ,60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated ,60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated ,60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated ,60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated ,60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated ,60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated ,60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated ,60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated ,60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated ,60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated ,60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated ,60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated ,60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated ,60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated ,60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated ,60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated ,60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated ,60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated ,60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated ,60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ,60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated ,60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated ,60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,activated ,60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated ,60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated ,60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated ,60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated ,60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated ,60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated ,60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated ,60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,activated ,60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated ,60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated ,60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated ,60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated ,60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated ,60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated ,60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated ,60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not activated ,60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended ,64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Databus Infotainment ,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated ,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,activated ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus Infotainment ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus ,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,activated ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment ,64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated ,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Comfort data bus ,64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated ,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not activated ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated ,64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15 ,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment ,64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated ,64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment ,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment ,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available ,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Databus Infotainment ,8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available ,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Databus Infotainment ,8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Not available ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,Not available ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not available ,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Available ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0 ,6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50 ,6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100 ,6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0 ,6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50 ,6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100 ,6
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,8 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,20 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,60 %,12
ENG141636-ENG142049-Key_code_monitoring-monitoring_keycode_0x00_0x07,00 ,32
ENG141636-ENG142050-Key_code_monitoring-monitoring_keycode_0x08_0x0F,00 ,32
ENG141636-ENG142051-Key_code_monitoring-monitoring_keycode_0x10_0x17,00 ,32
ENG141636-ENG142052-Key_code_monitoring-monitoring_keycode_0x18_0x1F,00 ,32
ENG141636-ENG142053-Key_code_monitoring-monitoring_keycode_0x20_0x27,00 ,32
ENG141636-ENG142054-Key_code_monitoring-monitoring_keycode_0x28_0x2F,00 ,32
ENG141636-ENG142055-Key_code_monitoring-monitoring_keycode_0x30_0x37,00 ,32
ENG141636-ENG142056-Key_code_monitoring-monitoring_keycode_0x38_0x3F,00 ,32
ENG141636-ENG142057-Key_code_monitoring-monitoring_keycode_0x40_0x47,00 ,32
ENG141636-ENG142058-Key_code_monitoring-monitoring_keycode_0x48_0x4F,00 ,32
ENG141636-ENG142059-Key_code_monitoring-monitoring_keycode_0x50_0x57,00 ,32
ENG141636-ENG142060-Key_code_monitoring-monitoring_keycode_0x58_0x5F,00 ,32
ENG141636-ENG142061-Key_code_monitoring-monitoring_keycode_0x60_0x67,00 ,32
ENG141636-ENG142062-Key_code_monitoring-monitoring_keycode_0x68_0x6F,00 ,32
ENG141636-ENG142063-Key_code_monitoring-monitoring_keycode_0x70_0x77,00 ,32
ENG141636-ENG142064-Key_code_monitoring-monitoring_keycode_0x78_0x7F,00 ,32
ENG141636-ENG142065-Key_code_monitoring-monitoring_keycode_0x80_0x87,00 ,32
ENG141636-ENG142066-Key_code_monitoring-monitoring_keycode_0x88_0x8F,00 ,32
ENG141636-ENG142067-Key_code_monitoring-monitoring_keycode_0x90_0x97,00 ,32
ENG141636-ENG142068-Key_code_monitoring-monitoring_keycode_0x98_0x9F,00 ,32
ENG141636-ENG142069-Key_code_monitoring-monitoring_keycode_0xA0_0xA7,00 ,32
ENG141636-ENG142070-Key_code_monitoring-monitoring_keycode_0xA8_0xAF,00 ,32
ENG141636-ENG142071-Key_code_monitoring-monitoring_keycode_0xB0_0xB7,00 ,32
ENG141636-ENG142072-Key_code_monitoring-monitoring_keycode_0xB8_0xBF,00 ,32
ENG141636-ENG142073-Key_code_monitoring-monitoring_keycode_0xC0_0xC7,00 ,32
ENG141636-ENG142074-Key_code_monitoring-monitoring_keycode_0xC8_0xCF,00 ,32
ENG141636-ENG142075-Key_code_monitoring-monitoring_keycode_0xD0_0xD7,00 ,32
ENG141636-ENG142076-Key_code_monitoring-monitoring_keycode_0xD8_0xDF,00 ,32
ENG141636-ENG142077-Key_code_monitoring-monitoring_keycode_0xE0_0xE7,00 ,32
ENG141636-ENG142078-Key_code_monitoring-monitoring_keycode_0xE8_0xEF,00 ,32
ENG141636-ENG142079-Key_code_monitoring-monitoring_keycode_0xF0_0xF7,00 ,32
ENG141636-ENG142080-Key_code_monitoring-monitoring_keycode_0xF8_0xFF,00 ,32
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04 01 52 04 52 10 52 40 52 32 00 64 00 3C 00 7C 01 1D 01 50 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 02 00 A8 ,40
ENG117809-p_damping_Display,5 ms,1
ENG117808-p_HMI_Display,13 %,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
Elapsed Time: 00:36
darkchina811
ITALY
C?ID=333184
ok since then I have made a lot of progress. the Aux Heater works and I got the menu in the MIB2 screen, it's so convenient how it can be programmed to start up at a given time, and with heating or ventilation.
what is happening now is, despite 100% functionality, module 18 keeps logging two errors. what I mean is that if I clear these errors, next time the heater starts I'll get them again.
(see below log)
today I actually went to a Webasto dealer who told me, after I briefly explained the situation: "if it works, why do you even bother?".
well, while I will admit he might have a point, I am just not satisfied if I don't understand whats going on. in my belief, a 100% functional system should not log any error.
I feel like the error about the fuel pump could be just a wrong configuration, but I won't know more until I find out what a FUEL "TRANSFER" PUMP is.
the other error about non-detecting a flame leaves me speechless. the heater works just fine.
does anybody have any clue?
Thursday,11,October,2018,14:11:32:06888
VCDS Version: 18.9.0.1 (x64)  HEX-V2 CB: 0.4436.4
VIN: WVWZZZAUZHW0xxxxx   License Plate:
                Address 18: Aux. Heat       Labels: 5Q0-963-272.clb
Control Module Part Number: 5Q0 963 272 B    HW: 5Q0 963 272 B
  Component and/or Version: STH-MQB       006 0069
           Software Coding: 1309
            Work Shop Code: WSC 01357 011 00200
              ASAM Dataset: EV_AuxilParkiHeateWOS 002014 (VW37)
                      VCID: 3537DDC715C0D82F7D0-8060
0368 - Fuel Transfer Pump
          B137D 52 [009] - Not activated
                    Reset counter: 211
                    Mileage: 22213 km
                    Date: 2018.10.07
                    Time: 21:14:26
                    Operating condition of parking heater: Start
                    76
                    Coolant temperature of parking heater: 19 ∞C
                    Coolant temperature: 17 ∞C
                    Engine running status: not recognized
                    Fuel level: 48 l
                    Heater output: 0 W
0056 - No Flame Detected
          B1389 F0 [008] - During Initial Start Attempt
                    Reset counter: 251
                    Mileage: 22213 km
                    Date: 2018.10.07
                    Time: 21:14:51
                    74
                    Fuel level: 48 l
                    Heater output: 5000 W
darkchina811
ITALY
C?ID=333184
it's finally solved.
the "no flame detected" just stopped happening, actually a while ago, maybe there was some air into the fuel line going to the Webasto.
the "fuel transfer pump" error was cleared after changing BYTE 03 in module 01 engine from 32 to 3A. I was helped by a fellow member here :)
the bit is still non documented in the label file, that's why I was not able to switch it earlier.
below is current autoscan, for reference.
Thursday,08,November,2018,22:13:51:06888
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
Workshop Code: 011 01357 000000
Mileage: 24505km-15226mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 18 19 20 42 44 52 5F 65
VIN: WVWZZZAUZHW0xxxxx   Mileage: 24505km-15226miles
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H25 2833
   Revision: R7H25---
   Coding: 0119003A23241D082000
   Shop #: WSC 21385 002 104857
   ASAM Dataset: EV_ECM14TFS01104E906027HB 001005
   ROD: EV_ECM14TFS01104E906027HB.rod
   VCID: 6B833BBF03045EDF5B7-803E
   CAN Converter 01:
Readiness: 0100 0001
   Part No SW: 5Q0 614 517 CC    HW: 5Q0 614 517 AG
   Component: ESC           H62 0637
   Revision: 00000000    Serial number: 91596000011507
   Coding: 01FA6AA1242219704779060841C62980562498E2608294730020500A400203
   Shop #: WSC 131071 102 209715
   VCID: 74B120C35E3A81278AD-8020
   Part No SW: 5G0 907 044 BM    HW: 5G0 907 044 BM
   Component: Climatronic   H04 1601
   Revision: 00001K08
   Coding: 00020004104111011005004000101022
   Shop #: WSC 00028 028 00068
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   VCID: 73B323DF5B34861F937-8026
   Air quality sensor:
   Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
   Serial number: 01061633700891
   Coding: 00000946C20102FB0B244080B11407281400000000000000000000000000
   Shop #: WSC 01357 011 00000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 045170030E9AB1A7BAD-8050
   Component: WWS    160522  043 0551
   Serial number:         160601172917
   Coding: 0E4DFD
   Component: RLHS  042 0105
   Serial number: S5Y17M06D01H13M38S50
   Coding: 06A8DD
   Serial number: 000000000ZY15028208R
   Serial number: 00000000000030139763
   Part No SW: 5Q0 919 298 D    HW: 5Q0 919 298
   Component: PARKHILFE PLA H11 0042
   Revision: --------    Serial number: 61131402901978
   Coding: 0031161041
   ASAM Dataset: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: 40D9BC135A026D87DE5-8014
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Component: AirbagVW20    015 0388
   Serial number: 003F6R1V1W4Y
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 41DFB9175108648FD1B-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 506 16
   Serial number: 35767000000432B44C1Q
   Subsystem 2 - Part No SW: -----------    HW: 480 001 506 16
   Serial number: 358670000008B4C4DB17
   Subsystem 3 - Part No SW: -----------    HW: 480 400 306 16
   Serial number: 3516502BB205729313D3
   Subsystem 4 - Part No SW: -----------    HW: 480 401 105 16
   Serial number: 3526502AF2076340F201
   Subsystem 5 - Part No SW: -----------    HW: 480 401 106 16
   Serial number: 35565029B21160C1025X
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 13061608490829
   Coding: 0400
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 0D4755275DD0F0EFE53-8058
   Part No SW: 5G1 920 750 B    HW: 5G1 920 750 B
   Component: KOMBI         303 8311
   Coding: 03A501802290000D02083B041400000000000000
   VCID: 26150A8BD866A3B7C49-8072
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 B    HW: 5Q0 963 272 B
   Component: STH-MQB       006 0069
   Coding: 1309
   VCID: 3537DDC715C0D82F7D3-8060
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000180382
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0004271482
   Coding: 030100043F085700FB000248080F00010001050000000000000000000000
   ROD: EV_GatewLear_013_VW37.rod
   VCID: 7CA108E3766AC967C2D-8028
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160001142480026234
   Coding: 28FFFF
   Serial number: 8442320304
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 3G0 857 511 AE    HW: 3G0 857 511 AE
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 0101000000000000000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001017
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   Serial number: 300516EEU02971
   Coding: 003B0220D000040100001000
   VCID: 43D3B31F4B14769FC37-8016
   Coding: 8307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2DCEFB3CDE3757901-806E
   Serial number: 280516EER24731
   Coding: 003B0020DE00040100801000
   VCID: 42DDB61B540E7F97C81-8016
   Part No SW: 3Q0 035 824 B    HW: 3Q0 035 824 B
   Component: MU-S--ER      710 0744
   Coding: 02730000AA0000005111000100080A001F0200D40120010003
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2C01F8A3C68A99E712D-8078
   Subsystem 1 - Part No SW: 3G0 919 605 B    HW: 3G0 919 605 B
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9SJT00QNA
   Serial number: 40000000018766
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3431E0C31EBAC1274AD-8060
End----------(Elapsed Time: 01:47, VBatt start/end: 12.6V/12.5V)-----------
Theo931
C?ID=229297
coding auxilary heater
I noticed that you changed the coding of the auxilary heater from 1305 to 1309.
Why did you do that, what does the code change do ?
I just did the same retrofit and i now have the code 1305, so i am very curious why you changed it in 1309.
hope to hear soon of you.
grtz. Theo
(the netherlands)
darkchina811
ITALY
C?ID=333184
I honestly don't remember, but I think it's documented in the label file, so just connect and check it out :)
the few autoscan examples I could find around with Webasto all had same coding I guess.
Theo931
C?ID=229297
Thanks for the answer.
Everything seems to be working with the 1305 code, but i think i'm gonna change it to 1309 because every other scan has that code. You said that you also changed something in the modul 17-instrument but what did you change ? I can not find anything in that modul related to the auxilary heater.
other question:
I've had auxilary heaters in my previous cars and i noticed some difference. In my old cars when the heater was running for say 15 min. and i turned the ignition on the water temperature was about 60-80 degrees and when i start the engine temperature dropped about 10 degrees and then went up to 90 degrees during driving.
Now with this heater when it is running for 15 min. and i turn on the ignition the temperature cauge doesn't move or to max. 60 degrees and when i start the engine temperature goes within a minute to 90 degrees.
Does your car have the same behavior?
darkchina811
ITALY
C?ID=333184
out of the blue I don't remember changing anything in module 17, check if you see something very obvious in the long coding or just forget it, I might have not changed anything... or your cluster does not have it.
when I run the heater for 20 minutes the water temperature goes straight up to 90 degrees and does not move anymore. but I don't remember if the needle moves after ignition on or after engine on.
Jacek
Poland
C?ID=360566
Could you put the current autoscan and admmap into the fully working webasto of your car.
darkchina811
ITALY
C?ID=333184
the autoscan at post #13 is for Webasto reference. what admaps do you need?
Jacek
Poland
C?ID=360566
Yes admaps all modules where you need to add Webasto.
