Best way to get full dump of all adaptations and coding?
BikePilot
C?ID=1180
I'm taking my new-to-me B9 A4 to the dealer for the first time. I've done some tweaks I'd like to preserve. Is there a way to save all coding and adaptation in a single go? The closest I understand is to do a full scan to capture coding, then controller channel maps of each controller, one at a time, to capture adaptations. Is there a quicker way?
Thanks!
Dave
Auto-Scan with Debug Level (on the Options screen) set to 2.
This can still take a while, so either use a battery charger, or let the engine idle while you do this.
o33err
C?ID=317589
Does entering a Security Code increase the Adaptations seen on a module?
TBAx
DE
C?ID=287144
Normally, it does not. Security Access codes should just allow changing of these adaptions.
Please someone correct me if I am totally wrong. My experience is primary based of MQB cars.
o33err
C?ID=317589
I too hope that's how it works, else the Debug 2 option isn't going to capture everything.
D-Dub
C?ID=272151
It would be nice if this 'feature' were a more explicit within the app, like an 'extended' auto-scan, or some such.
Or make it the default auto-scan, and add a 'quick' auto-scan for times when just the basic details are desired.
I don't see it as a necessary part of normal, routine diagnostics.
D-Dub
C?ID=272151
Well, it is not so much a part of diagnostics, but of documentation and auditing of all vehicular settings and their state at the time of scan.
Call it preventive maintenance.
BikePilot
C?ID=1180
I would have done it the day I got the car before I started tinkering, had I known it was possible. I’m a big fan of backups!
hadez16
C?ID=289891
I also had to learn that first.
Primarily on non-MQB cars there exist adaptation channels that are not accessible (for read) without a login.
Nevertheless it became a routine for me to use the known logins for creating adpmaps also on MQB...although it might not be necessary...
United States
I agree. CAN modules (which pre-date the B9 in question) will show Error Security access required without a SA code https://forums.ross-tech.com/showth...yle)-2-0T-CCTA&p=118973&viewfull=1#post118973
The MQB maps we reviewed yesterday had all Adp channels with and without a SA codes entered but I like to use one when possible on all vehicles.
In BikePilot's case I believe running complete Debug Level 2 maps should be good enough before the trip to the dealer.
JulianHicks
Kent, UK
C?ID=265735
Is that going to achieve what is desired - that is, all modules?
I thought Debug set to 2 only mapped undocumented modules, that is, modules without a label file?
Julian
From the web site:
Type #1: To create a map from all undocumented control modules in the car, please perform the following procedure:
[Options]
Debug Level: 2
[Apply]
[Auto-Scan]
Select Chassis Type
o33err
C?ID=317589
I think that documentation is out of date or Debug 2 works differently on newer cars. On the first day I bought my car, I ran a Debug 2 Autoscan and it gave me everything, labels or not. The only thing I have noticed is that it doesn't output a .pla and .plb any more but instead an amap.csv and bmap.csv file
JulianHicks
Kent, UK
C?ID=265735
I've just rerun VCDS 18.9.0 with Debug set to 2 on my 2005 A8 D3. It only scanned and dumped variables for ECUs without a label file [4 in my case] and created a .PLA & .PLB for each of those ECUs! [That is, a total of only 8 files for the whole scan].
Hmmm; interesting and illogical :confused:
Shouldn't a Debug value [2 in this case] work consistently in all environments?
Julian
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Somewhat, yeah, for historical reasons.
Debug 2 on non-UDS controllers, all K-line and older CAN stuff, will output PLA/PLB files only a label file doesn't exist already. It was invented back when Ross-Tech needed people to submit this data, in order to make label files. This existed before it was so common to have hundreds of tweakable adaptation channels, before there was so much interest in archival and comparison.
If you need to, you can tell VCDS to dump the contents of an individual controller through the "Controller Channel Map" menu under "Applications" even if there's already a label file, but there's no direct way to force them all. Some people have been known to move the contents of the Labels directory elsewhere, temporarily, to kind of trick VCDS into it, but you need to be careful or be willing to reinstall. :)
Debug 2 on UDS-based controllers will unconditionally dump out all measuring and adaptation values. It's mainly a testing or archival aid, to snapshot the state of things before you make changes or to document the state after. For UDS controllers, label files have much less relevance, just manually documented coding information (if applicable, the new "experimental" stuff isn't in there) and some other internal hints and pointers.
It's very possible to have a mix of those behaviors in the same car, to have some UDS and some non-UDS controllers.
If I had a magic wand, I would make this functionality consistent AND accessible through some friendly menu instead of an arcane debug setting. This already exists, in part, in the "Controller Channel Map" menu. I'd go a little further, and place all the output in a VIN-specific directory under C:\Ross-Tech\VCDS\Logs, potentially with date-time sub-directories under that to maintain history. But I don't have a magic wand, and I have no idea what's on Ross-Tech's development backlog, so I make do. It's not much of a hardship once you know how it works.
Temporarily renaming the Labels folder to, for example, ~Labels should work.
Beware however, that on old, non-UDS cars, especially those with lot of modules like a D3 A8, an Auto-Scan with Debug Level 2 and no labels found can take a really long time. Make sure you have an adequate battery charger properly connected.
D-Dub
C?ID=272151
Is there any reason to not do scans with a vehicle running ? (instead of on a charger)
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
As an exception, I happen to know the VW Atlas (and probably the Teramont, and Skoda Kodiaq) likes to throw over-temp DTCs on the LED headlight controllers if it's left at stationary idle for a long time. Seen that a bunch of times. I've not seen any driver-perceivable effect as a result.
Other than that, no serious reason that I'm aware of, other than the fuel spent and the additional idle time on the engine. There will be certain changes you can't make with VCDS, but you should be able to read all day long.
From a purely electrical standpoint, it should be fine.
But whether letting a car idle for so long is an acceptable practice or not might be questionable. I prefer to avoid doing that if at all possible.
JulianHicks
Kent, UK
C?ID=265735
Just for completeness, from my point of view, anyway; I ran Debug 2 on my 2016 A8 D4.
Can't tell from the Autoscan if modules are UDS or not [might be a useful addition to the log data] but I still didn't get a 'complete' set for all ECUs and I didn't even get a full set of .PLA/.PLB files for the ECUs that didn't have label files. For the record:
ECUs with 'Labels: None' that DID NOT produce a .PLA/.PLB
01, 19, 3B, 6C, 6D, 6F, 88, 89
ECUs with 'Labels: None' or 'Labels: Redir failure!' that DID produce a .PLA/.PLB - Redir failures in RED
06, 09, 20, 36, 42, 47, 52, 56, 57, 62, 72
And finally guys @ Ross Tech; given the comments of 'usefulness' of label files earlier in this thread, do you want the .PLA/.PLB files that VCDS generated for my car?
Wednesday,10,October,2018,11:46:47:53697
VCDS Version: 18.9.0.2
VIN: WAUZZZ4H4GN002801   License Plate:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 20 30 34 36 3B 42 44 46 47
          52 53 55 56 57 5F 62 6C 6D 6F 72 81 88 89 8F 90 AC
VIN: WAUZZZ4H4GN002801   Mileage: 47298km-29389miles
01-Engine                 -- Status: OK 0000
02-Auto Trans             -- Status: OK 0000
03-ABS Brakes             -- Status: OK 0000
04-Steering Angle         -- Status: OK 0000
05-Acc/Start Auth.        -- Status: OK 0000
06-Seat Mem. Pass         -- Status: OK 0000
08-Auto HVAC              -- Status: OK 0000
09-Cent. Elect.           -- Status: OK 0000
15-Airbags                -- Status: OK 0000
16-Steering wheel         -- Status: OK 0000
17-Instruments            -- Status: OK 0000
19-CAN Gateway            -- Status: OK 0000
20-High Beam Assist.      -- Status: OK 0000
30-Special Function II    -- Status: OK 0000
34-Level Control          -- Status: OK 0000
36-Seat Mem. Drvr         -- Status: OK 0000
3B-Sensor Elect.          -- Status: OK 0000
42-Door Elect, Driver     -- Status: OK 0000
44-Steering Assist        -- Status: OK 0000
46-Central Conv.          -- Status: OK 0000
47-Sound System           -- Status: OK 0000
52-Door Elect, Pass.      -- Status: OK 0000
53-Parking Brake          -- Status: OK 0000
55-Headlight Range        -- Status: OK 0000
56-Radio                  -- Status: OK 0000
57-TV Tuner               -- Status: OK 0000
5F-Information Electr.    -- Status: OK 0000
62-Door, Rear Left        -- Status: OK 0000
6C-Back-up Cam.           -- Status: OK 0000
6D-Trunk Elect.           -- Status: OK 0000
6F-Centr. Conv. II        -- Status: OK 0000
72-Door, Rear Right       -- Status: OK 0000
81-Gear Shift             -- Status: OK 0000
89-Multicont. Seat Pass.  -- Status: OK 0000
8F-Pretens. Frt Left      -- Status: OK 0000
90-Pretens. Frt Right     -- Status: OK 0000
AC-Reductant Control      -- Status: OK 0000
Address 01: Engine (J623-CTBA)       Labels: None
   Part No SW: 4H0 907 401 Q    HW: 4G0 907 401 E
   Component: 3.0TDI EDC17  H14 0002
   Revision: 58H14---
   Coding: 0A2A4032052601030800
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TDI0114H0907401Q 001002
   ROD: EV_ECM30TDI0114H0907401Q.rod
   VCID: 326B7DA965FEA0DA13-8066
   Part No SW: 4H1 927 158 CL    HW: 0BK 927 156 AD
   Component: 0BK 30TDIRdWH19 1005
   Revision: --H19---
   ROD: EV_TCMALX51011.rod
   VCID: 7CF79391F73AA6AA89-8028
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 T    HW: 4H0 907 379 T
   Component: ESP PREMIUM   H10 0665
   Coding: 60E5AB8006A7D501E300
   ASAM Dataset: EV_ESPPremi 005024
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 4385286DCA44195288-8016
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.CLB
   Part No SW: 4H0 907 064 GB    HW: 4H0 907 064 GB
   Component: BCM2 2.0      H37 0572
   Coding: 05B76F4E000000000000
   VCID: 6FEDB4DDBE4CCD323C-803A
   Serial number: 3215000075301016
Address 06: Seat Mem. Pass (J521)       Labels: NONE
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000147560992
   Coding: C038320085047201000001010101112131313333283333
   VCID: 356146B59C90B7E236-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 P    HW: 4H0 820 043 P
   Component: Klima 2 Zonen H20 0210
   Coding: 3621002E300000
   ASAM Dataset: EV_AirCondiFront 003001
   ROD: EV_AirCondiFront_002.rod
   VCID: 2D516ED57CC0FF224E-8078
Address 09: Cent. Elect. (J519)       Labels: REDIR FAIL!
   Part No SW: 4H0 907 063 DB    HW: 4H0 907 063 AB
   Component: BCM1 2.0      H20 0311
   Revision: 19020001    Serial number: 00001092140002
   Coding: 0105001440349FE0C9014084A0001800009DC30A2F0802018000089461001700004000240B0000
   VCID: 6BD5A0CD8A54311210-803E
   Subsystem 1 - Part No SW: 4H2 955 119 C    HW: 4H2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 140718  H36 0090
   Serial number:         150204164211
   Coding: 0045F7
   Serial number: 24007920
   Coding: 02004E
   Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
   Component: E1 - LDS  H07 0044
   Serial number: 01 06 2015  00001958
   Component: EVLS-SG  H08 0300
   Serial number: WA120636000012702541
   Coding: 020300
   Serial number: EC3840B7000000000001
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P10051WWD
   Coding: 30333045313430303038554A305234483053
   VCID: 3B75508DB2B46192C0-806E
   Serial number: 3575HRB404P3BA9U2HCU
   Serial number: 3585HRB404P3BA9UEHD1
   Serial number: 3515JRB401E54QJ25POS
   Serial number: 3525JRB401E54QJ2F987
   Serial number: 3554VRB405J3FGI859JZ
   Serial number: 3564VRB405J3FGI8BOTO
Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.CLB
   Revision: --------    Serial number: 01335OES001ET
   Coding: 000034
   VCID: 377D4CBD869C45F224-8062
   Subsystem 1 - Part No SW: 4H0 951 528 J    HW: 4H0 951 528 J
   Component: E221 - MFL  H09 0010
   Serial number: 16 04 2015  B0048356
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4H0 920 910 R    HW: 4H0 920 910 R
   Component: TDieGB------- H53 0803
   Revision: 38081205    Serial number: 658020615592020
   Coding: 33A608001B412600010000
   ASAM Dataset: EV_RBD4K 004050
   ROD: EV_RBD4K.rod
   VCID: 336578AD9AE4A9D218-8066
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 Q    HW: 4H0 919 204 Q
   Component: Analoguhr D4  H05 0225
   Serial number: 2150429000990
   Part No SW: 4H0 907 468 AG    HW: 4H0 907 468 AC
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000001862281
   Coding: C0CD077F08
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: 76E381B9C916FCFAFF-8022
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 52136407171911070810
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 15154000523021200410
Address 20: High Beam Assist. (J844)       Labels: NONE
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04028B6B74745D545420363E00
   VCID: 67DDDCFD96BC157274-8032
Address 30: Special Function II (J843)       Labels: 8K0-907-440.CLB
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000078296
   Coding: 01010101000000000001000202
   VCID: 64C7CBF1678A7E6A51-8030
   Coding: 008000
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F6D74DD76CC8D327C-807A
Address 36: Seat Mem. Drvr (J136)       Labels: NONE
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000147560994
   Coding: C0383B0085057201000001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA7702PU2O
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 377D4CBD8E9C45F224-8062
Address 42: Door Elect, Driver (J386)       Labels: NONE
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H07 0280
   Revision: --------    Serial number: 0000152451232
   Coding: 011F1E015E0162C202083006
   VCID: 489F3F41FB623A0A5D-801C
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0030770572
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   VCID: 39794A85B8885382D2-806C
Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.CLB
   Revision: 00002001    Serial number: 0365208788
   Coding: 011B0E2280B93981F320C784080316470000000000000000000000000000
   Subsystem 1 - Part No: 4H0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4H0 947 135 A    HW: 4H0 947 135 A
   Component: Dachelektroni  H13 0080
   Serial number: A2015000000000838437
   Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93529295
Address 47: Sound System (J525)       Labels: NONE
   Revision: CJ007001    Serial number: 00000000174789
   Coding: 030000
   VCID: 1D31BE1504600FA2DE-8048
Address 52: Door Elect, Pass. (J387)       Labels: NONE
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H07 0280
   Revision: --------    Serial number: 0000152244640
   VCID: 3C775391BFBA66AAC9-8068
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001494872
   ROD: EV_ParkiBrake_VW51.rod
   Coding: 02F6021022630200
   VCID: 34677BB19FEAAEEA01-8060
   Coding: E00200
   Coding: E00200
Address 56: Radio (R)       Labels: REDIR FAIL!
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109FX0F8040437
   Coding: 010103010000000001
   VCID: 2D516ED574C0FF224E-8078
Address 57: TV Tuner (R78)       Labels: NONE
   Part No SW: 4G0 919 129 C    HW: 4G0 919 129
   Component: NGTV-DVB      H04 0690
   Revision: R0043000    Serial number: 06801302049601
   Coding: 03000000
Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6XX-5F.CLB
   Part No SW: 4H0 035 646 A    HW: 4H0 035 666 S
   Component: H-BN-EU       H49 1034
   Revision: --------    Serial number: 493FU0FB001311
   Coding: 02010100000BF1EF45908B1E00000003E00001020000000000
   VCID: 254196F52C30C76286-8070
   Subsystem 1 - Part No: 8R0 060 884 CR
   Component: EUR 2015  2102
   Subsystem 2 - Part No SW: 4H0 919 604 H    HW: 4H0 919 604 H
   Component: DU8 D4 SV NB  H63 0060
   Serial number: AUZ8ZDFY900CJUZ
   Subsystem 3 - Part No SW: 4H2 919 600 L    HW: 4H2 919 600
   Component: E380 BDT D4  H11 0110
   Serial number: 00000000196332
   Component: CD-Database  6208
Address 62: Door, Rear Left (J388)       Labels: NONE
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H07 0280
   Revision: --------    Serial number: 0000151390045
   Coding: 010F1E01400062C202083006
   Shop #: WSC 52891 002 1048576
   Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
   Component: TopView       H07 0330
   Revision: 11001001    Serial number: 82330JF0232953
   Coding: 020E000001000000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
   ROD: EV_CamerSysteTopViewAUDI_008_AU64.rod
   VCID: 2E5369D971C6843A77-807A
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
   Component: HDSG-Modul    H12 0049
   Revision: 10012001    Serial number: 144500094
   Coding: 021004C020
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6FEDB4DDB64CCD323C-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000187206
   Coding: 220000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 63C5C8ED6A847952A8-8036
Address 72: Door, Rear Right (J389)       Labels: NONE
   Component: TSG HR        H07 0280
   Revision: --------    Serial number: 0000151390044
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H2 927 731 A    HW: 4H2 927 731 A
   Component: GSM-RL        H09 0083
   Revision: 0R0D5015    Serial number: SN150417  0185
   ROD: EV_GSM2x3Mono.rod
   VCID: 2C5763D147DAF62A59-8078
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00021483083002
   Coding: 672FF2
   ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00021485080501
   Coding: 272FF2
   Coding: 00060000031F030000030800424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 316972A560F89BC26A-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 151030176
   ROD: EV_RDCMA00100_008.rod
End---------------------(Elapsed Time: 40:09, Deb=2)-----------------------
Julian
