Anyone have a Label File for Audi 8EC 1.8t 01 Engine Control Module
Cristian G
Hawkesbury, Australia
C?ID=223794
:confused:
Hi guys,
I'm trying to fault find a code I'm getting on my engine, but the Label file is missing for the control module.
Does anyone have a label file for an 8EC Audi A4 1.8t?
Ive sent the control module map and scan to the support email address, but was hoping someone here might be able to help more quickly.
Here is my scan:
Thursday,30,October,2014,21:34:36:18055
VCDS Version: 12.12.3.0
Data version: 20140822
VIN: WAUZZZ8E96A025982   License Plate: CPG535
Mileage: 130570km-81132mi   Repair Order:
Scan: 01 02 03 08 09 15 16 17 25 31 33 46 56
VIN: WAUZZZ8E96A025982   Mileage: 130570km/81132miles
   Part No SW: 8E0 909 518 AQ    HW: 8E0 909 018 B
   Component: 1.8L R4/5VT     G   0010
   Coding: 0011581
   Shop #: WSC 06335 000 00000
   VCID: 7F0D218A2DBBFBE6E27-5124
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
            P1297 - 001 -
17544 - Fuel Trim: Bank 1 (Add)
            P1136 - 001 - System too Lean - MIL ON
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 8E3 910 155 T    HW: 01J 927 156 HT
   Component: V30 01J 1.8l5VT RdW 0010
   Revision: 00000010    Serial number: 00000001212464
   Coding: 0000001
   Shop #: WSC 21010 822 83252
   VCID: 39790F92731F15D69C3-5142
   Part No SW: 8E0 910 517 D    HW: 8E0 614 517 AK
   Component: ESP8 front      H04 0120
   Coding: 0004872
   VCID: 285FDAD69BB59C5EF3D-807D
   Part No: 8E0 820 043 AJ
   Component:   A4 Klimaautomat   2831
   Coding: 00000
   Shop #: WSC 06335
   VCID: 69D99FD2133F65562C3-5124
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  ECE 0504
   Coding: 00001
   Shop #: WSC 06335
   VCID: 3B75159A292327C68EF-4B02
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H11 3530
   Revision: 91H1135    Serial number: 0036M005ALVC
   Coding: 0033722
   VCID: 3B75159A7A2327C68EF-806E
   Subsystem 1 - Serial number: 6332DRB401A1872BN
   Subsystem 2 - Serial number: 6342DRB401D0CE99%
   Subsystem 3 - Serial number: 6352ARB400739256E
   Subsystem 4 - Serial number: 6362ARB40071E94DV
   Subsystem 5 - Serial number: 63729RB4007E2FCD3
   Subsystem 6 - Serial number: 63829RB4007E2F77-
   Part No: 8E0 953 549 Q
   Component: Lenks·ulenmodul     0601
   Coding: 02141
   Shop #: WSC 06335
   VCID: 418967724BCF4D16D43-4AE8
   Part No SW: 8E0 920 901 C    HW: 8E0 920 901 C
   Component: KOMBI+WFS 3     H12 0110
   Revision: 0110        Serial number: AUX6Z0E0062549
   Coding: 0006741
   Shop #: WSC 16490 959 86059
   VCID: 2541D3E2EFA78136C8B-5124
   Coding: 0006741
Address 33: OBD-II        Labels:
   VCID: 55A1A322AC47D1B698B-5124
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 BQ
   Component: Komfortger·t T01    3332
   Coding: 06896
   Shop #: WSC 21000
   VCID: 810927728B4F0D16143-4B02
   Subsystem 1 - Part No: 8E2959802F
   Component: Tırsteuer.FS BRM 0406
   Subsystem 2 - Part No: 8E2959801B
   Component: Tırsteuer.BF BRM 0205
   Subsystem 3 - Part No: 8E0959801A
   Component: Tırsteuer.HL BRM 0205
   Subsystem 4 - Part No: 8E0959802A
   Component: Tırsteuer.HR BRM 0205
Address 56: Radio        Labels: 8E0-035-1xx-56.lbl
   Part No: 8E0 035 152 B
   Component: chorus II   GRO    0004
   Coding: 01006
   Shop #: WSC 06335
   VCID: 1F4DC10A9DFB5BE6827-4AE8
The Engine address 01 is the file I'm chasing.
The fault code I'm chasing is the 17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!) P1297 - 001 -.
It's only started coming up since I replaced the crank case ventilation pipe on top of the oil filter housing.
I've run the output tests and all seems good, but I cannot access stye Advanced Measuring blocks as the label file is missing.
Any help is appreciated.
Thanks Guys.
Cristian
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Hello Cristian, you should receive a file via email later today. Please let me know if that worked for you.
Cristian G
C?ID=223794
Thanks Sebastian,
Yes I did receive it, but had mixed results.
It worked in 14.9 BETA, but failed in 14.10 RELEASE.
I'm fried tonight, so going to have another look at it tomorrow in 14.10 RELEASE.
Regards
Cristian
Cristian G
C?ID=223794
Hey Sebastian,
I finally got the scan done on Sunday night.
The label file worked.
Here is the scan.
Saturday,15,November,2014,19:53:24:18055
VCDS Version: 14.10.0.0
Data version: 20141022
Mileage: 131117km-81467mi   Repair Order:
Scan: 01 02 03 08 09 15 16 17 25 31 46 56
VIN: WAUZZZ8E96A025982   Mileage: 131110km-81467miles
Address 01: Engine        Labels: User\06B-906-018-AVJ.lbl
   Coding: 0011581
   VCID: 7F0D218A2DBBFBD9161-5142
            P1297 - 001 -
            P0300 - 001 -  - Intermittent
16686 - Cylinder 2
            P0302 - 001 - Misfire Detected - Intermittent
16685 - Cylinder 1
            P0301 - 008 - Misfire Detected - Intermittent
16891 - Idle Control System RPM
            P0507 - 001 - Higher than Expected.
Readiness: 0000 1100
   Coding: 0000001
   VCID: 39790F92731F15E9685-5124
   Coding: 0004872
   VCID: 285FDAD69BB59C6107B-807D
   Coding: 00000
   Shop #: WSC 06335
   VCID: 69D99FD2133F6569D85-5124
   Coding: 00011
   Shop #: WSC 06335
   VCID: 3B75159A292327F97A9-4B02
   Coding: 0033722
   VCID: 3B75159A7A2327F97A9-806E
   Coding: 02141
   Shop #: WSC 06335
   VCID: 418967724BCF4D29205-4B02
   Coding: 0006741
   VCID: 2541D3E2EFA781093CD-5142
   Coding: 0006741
   VCID: 2541D3E2EFA781093CD-5124
   Coding: 06896
   Shop #: WSC 21000
   VCID: 0109A7720B4F8D29605-4AE8
   Coding: 01006
   Shop #: WSC 06335
   VCID: 1F4DC10A9DFB5BD9761-4AE8
End-------------------------(Elapsed Time: 02:30)--------------------------
I can now access the advanced measuring blocks as well.
Also now that we know it works, should I move the file in with the rest often label files or leave it in the user folder?
Thanks for your help.
Regards
Cristian
It should make no difference whether it's in the User folder or in the main Labels folder.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
...and the next update to VCDS (as well as all future versions) will have this file out of the box, so /Labels/User/ is fine for now. :)
