- Apr 21, 2014
- 11
- 5
- Hawkesbury, Australia
- C?ID=223794
Hi guys,
I'm trying to fault find a code I'm getting on my engine, but the Label file is missing for the control module.
Does anyone have a label file for an 8EC Audi A4 1.8t?
Ive sent the control module map and scan to the support email address, but was hoping someone here might be able to help more quickly.
Here is my scan:
Thursday,30,October,2014,21:34:36:18055
VCDS Version: 12.12.3.0
Data version: 20140822
VIN: WAUZZZ8E96A025982 License Plate: CPG535
Mileage: 130570km-81132mi Repair Order:
Scan: 01 02 03 08 09 15 16 17 25 31 33 46 56
VIN: WAUZZZ8E96A025982 Mileage: 130570km/81132miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 8E0 909 518 AQ HW: 8E0 909 018 B
Component: 1.8L R4/5VT G 0010
Coding: 0011581
Shop #: WSC 06335 000 00000
VCID: 7F0D218A2DBBFBE6E27-5124
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 001 -
17544 - Fuel Trim: Bank 1 (Add)
P1136 - 001 - System too Lean - MIL ON
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 8E3 910 155 T HW: 01J 927 156 HT
Component: V30 01J 1.8l5VT RdW 0010
Revision: 00000010 Serial number: 00000001212464
Coding: 0000001
Shop #: WSC 21010 822 83252
VCID: 39790F92731F15D69C3-5142
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK
Component: ESP8 front H04 0120
Coding: 0004872
VCID: 285FDAD69BB59C5EF3D-807D
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AJ
Component: A4 Klimaautomat 2831
Coding: 00000
Shop #: WSC 06335
VCID: 69D99FD2133F65562C3-5124
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0504
Coding: 00001
Shop #: WSC 06335
VCID: 3B75159A292327C68EF-4B02
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H11 3530
Revision: 91H1135 Serial number: 0036M005ALVC
Coding: 0033722
VCID: 3B75159A7A2327C68EF-806E
Subsystem 1 - Serial number: 6332DRB401A1872BN
Subsystem 2 - Serial number: 6342DRB401D0CE99%
Subsystem 3 - Serial number: 6352ARB400739256E
Subsystem 4 - Serial number: 6362ARB40071E94DV
Subsystem 5 - Serial number: 63729RB4007E2FCD3
Subsystem 6 - Serial number: 63829RB4007E2F77-
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenks·ulenmodul 0601
Coding: 02141
Shop #: WSC 06335
VCID: 418967724BCF4D16D43-4AE8
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 901 C HW: 8E0 920 901 C
Component: KOMBI+WFS 3 H12 0110
Revision: 0110 Serial number: AUX6Z0E0062549
Coding: 0006741
Shop #: WSC 16490 959 86059
VCID: 2541D3E2EFA78136C8B-5124
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006741
Address 33: OBD-II Labels:
VCID: 55A1A322AC47D1B698B-5124
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BQ
Component: Komfortger·t T01 3332
Coding: 06896
Shop #: WSC 21000
VCID: 810927728B4F0D16143-4B02
Subsystem 1 - Part No: 8E2959802F
Component: Tırsteuer.FS BRM 0406
Subsystem 2 - Part No: 8E2959801B
Component: Tırsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tırsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tırsteuer.HR BRM 0205
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 152 B
Component: chorus II GRO 0004
Coding: 01006
Shop #: WSC 06335
VCID: 1F4DC10A9DFB5BE6827-4AE8
End ---------------------------------------------------------------------
The Engine address 01 is the file I'm chasing.
The fault code I'm chasing is the 17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!) P1297 - 001 -.
It's only started coming up since I replaced the crank case ventilation pipe on top of the oil filter housing.
I've run the output tests and all seems good, but I cannot access stye Advanced Measuring blocks as the label file is missing.
Any help is appreciated.
Thanks Guys.
Cristian
