Hope someone can help.
Checked out a friends Audi A6 3l tdi. He has a dpf problem on the car.
Doing a scan showed there was a fault code on the engine regarding the differential pressure sensor.
Tried to do a forced regen on the dpf, thinking the sensor error might have been a once off with the fault frequency 1 and the sensor giving a reading at the time.
So the regen started and after a few seconds aborted because of safety measures or something.
The measured soot level went up from someting in the 20 to over 60 after the partial regen. It then adjusted the calculated soot level to kind of fit the measured one.
My thoughts are that the sensor is maybe giving the wrong values and thus now have a too high soot level registered to want to do a regen.
Plans are to first replace the sensor. 059 906 051 A
Do I need to reset the learned values somewhere or can I just replace the sensor? And will it then when having hopefully different and correct readings adjust the measured and calculated soot values in order to do a regen again?
Will try and place the scans below
Sorry for the scan to be posted like this. Would appreciate advise on how to do the window posts for the scans.
First scan
Second Scan
First scan
Monday,03,September,2018,20:11:37:02456
VCDS Version: 18.2.1.2 (x64) HEX-NET CB: 0.4411.4
VIN: WAUZZZ4G0BN023614 License Plate: CF 214510
Mileage: 127357km-79135mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 22 28 34 36 3B 42 44 46
52 53 55 56 5F 62 6C 72 82
VIN: WAUZZZ4G0BN023614 Mileage: 127357km-79135miles
Address 01: Engine (J623-CDUC) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0003
Revision: 53H37---
Coding: 0A254012052601020000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TDI0114G0907401F 001003
ROD: EV_ECM30TDI0114G0907401F.rod
VCID: A6009880D9EE1574FD-80F2
5162 - Diesel Particle Filter; Differential Pressure Sensor
P2453 00 [237] - Implausible Signal
Mileage: 125119 km
Date: 2018.07.13
Time: 14:25:04
Engine speed: 0.00 /min
Coolant temperature: 34 °C
Intake air temperature: 15 °C
Voltage terminal 30: 12.100 V
Sensor for particle filter differential press: raw value: 235 hPa
Particle filter: difference pressure: 206 hPa
Particle filter: offset for differential press.: 29 hPa
Particle filter: differential pressure: dynamic offset: 0 hPa
Outside air temperature: 13.0 °C
Particle filter: soot mass measured: 23.24 g
Particle filter: soot mass calculated: 23.26 g
5618 - Engine Off Timer Performance
P150A 00 [096] - -
Readiness: 1 1 0 0 0
Second Scan
Monday,03,September,2018,21:21:31:02456
VIN: WAUZZZ4G0BN023614 License Plate: CF 210514 - 2
Mileage: 127362km-79139mi Repair Order:
VIN: WAUZZZ4G0BN023614 Mileage: 127362km-79139miles
Revision: 53H37---
P2453 00 [229] - Implausible Signal
Mileage: 127362 km
Date: 2018.09.03
Time: 21:14:05
Coolant temperature: 89 °C
Intake air temperature: 37 °C
Voltage terminal 30: 11.900 V
Sensor for particle filter differential press: raw value: 213 hPa
Particle filter: difference pressure: 183 hPa
Outside air temperature: 17.5 °C
Particle filter: soot mass measured: 61.60 g
Particle filter: soot mass calculated: 61.92 g
