Audi a4 b7 auto gearbox replacement/softcoding help
vagcom pro
Verified VCDS-User
C?ID=342235
Hi Guys
Need some help one of my friend replaced auto gearbox on audi a4 b7 2007 which is convertible. the issue is the gearbox he replaced is from avant not convertible. trying to do adaptations and getting this error gearbox incompatible due to no soft coding now he is asking me to come down as i have got vagcom. my question is will vagcom let me do soft coding but my only concern is that the gearbox is same ie both are 7 speed cvt but different codes ie old one was JZU and new one is GYJ. he has got old ecu and new ecus with him. can any one possible suggest if its possible if so how? i have read online on rosstech website for adaptations should i just follow that or i will need more than vagcom such as VAS.
Thank You
vagcom pro
Verified VCDS-User
C?ID=342235
Tuesday,04,September,2018,11:42:00:22147
VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.2
VIN: WAUZZZ8H37K035123   License Plate:
Mileage: 170270km-105800mi   Repair Order:
Chassis Type: 8H (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
          67 69 75 76 77
VIN: WAUZZZ8H37K035123   Mileage: 170270km-105800miles
Address 01: Engine        Labels: 03G-906-016-BPW.clb
   Part No SW: 03G 906 016 KP    HW: 03G 906 016 KP
   Component: R4 2,0L EDC  000CG  9226
   Revision: --H05---    Serial number:
   Coding: 0000076
   Shop #: WSC 66565 257 00032
   VCID: 7BA3F4EE0FE008EF246-802E
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 8E0 910 157 H    HW: 01J 927 156 HT
   Component: V30 01J 2.0l PD RdW 0030
   Revision: 00000008    Serial number: 00000000902622
   Coding: 0000000
   Shop #: WSC 06325 000 00000
   VCID: 2C0107B2BA0E5F57FDC-8078
18249 - Engine Control Module / Transmission Control Module Incompatible
            P1841 - 005 -
                    Fault Status: 01100101
                    Fault Frequency: 15
                    RPM: 96 /min
                    (no units): 1.0
                    Torque: -40.0 Nm
                    Temperature: 21.0°C
                    T.B. Angle: 0.0°
                    Bin. Bits: 0101 0 0
   Part No SW: 8E0 910 517 H    HW: 8E0 614 517 BF
   Component: ESP8 FRONT      H06 0140
   Coding: 0004406
   Shop #: WSC 00672 785 00200
            000 -  -
                    Hex Value: 0x00C0
                    Hex Value: 0x4702
                    Hex Value: 0x0024
                    Hex Value: 0x01B1
                    Hex Value: 0x0000
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Hex Value: 0x00C0
                    Hex Value: 0x4702
                    Hex Value: 0x0014
                    Hex Value: 0x0BB1
                    Hex Value: 0x0000
                    Fault Status: 00101101
                    Hex Value: 0x0000
                    Hex Value: 0x0202
                    Hex Value: 0x0026
                    Hex Value: 0x0180
                    Hex Value: 0x0000
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   3233
   Coding: 00100
   Shop #: WSC 00672
   VCID: 6D87CAB64484965FAA2-5160
01172 - Temperature Sensor; Driver's Heated Seat (G59)
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  ECE 0907
   Coding: 20001
   Shop #: WSC 00672
   VCID: 3D273AF65464C6DF5A2-4B00
            30-00 - Open or Short to Plus
02738 - Bulb for Tail/Brake Light; Left
01800 - Light Switch (E1)
            27-00 - Implausible Signal
Address 15: Airbags        Labels: 8H0-959-655-94.lbl
   Part No SW: 8H0 959 655 E    HW: 8H0 959 655 E
   Component:    Airbag 9.42  H10 1840
   Revision: 92H10184    Serial number: 0037Y000WRHY
   Coding: 0071114
   VCID: 3C2137F24A6ECFD76DC-8068
   Subsystem 1 - Serial number: 6332BRB40248D37BT
   Subsystem 2 - Serial number: 6342BRB4024910E7J
   Subsystem 3 - Serial number: 63729RB40240619CH
   Subsystem 4 - Serial number: 63829RB4023E47CB.
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0701
   Coding: 02111
   Shop #: WSC 00672
   VCID: 41DF4606289CA23F3EA-4B00
   Part No SW: 8H0 920 951 D    HW: 8H0 920 951 D
   Component: KOMBI+WFS 4     H14 0200
   Revision: 0200        Serial number: 00000000000000
   Coding: 0006411
   Shop #: WSC 00378 210 91348
   VCID: 2E050DBA8C022D47D38-5184
01176 - Key
   Coding: 0006411
01176 - Key
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8H0 951 178
   Component: Innenraumueberw.   0411
   Coding: 00001
   VCID: 6FBBD0BE4E88644F98E-5118
01839 - Transceiver Module 1 for Interior Monitoring (G303)
   Part No: 8H0 959 433 M
   Component: Komfortgerát T3B    5342
   Coding: 06831
   Shop #: WSC 00672
   VCID: 3E253DFA5962DDC7438-4B00
   Subsystem 1 - Part No: 8H2959802D
   Component: Tõrsteuer.FS BRM 0205
   Subsystem 2 - Part No: 8H2959801D
   Component: Tõrsteuer.BF BRM 0205
   Subsystem 3 - Part No: 8H0959801A
   Component: Tõrsteuer.HL BRM 0002
   Subsystem 4 - Part No: 8H0959802A
   Component: Tõrsteuer.HR BRM 0002
9 Faults Found:
01616 - Signal Wire to Interior Monitor
            79-10 - Please Check Fault Codes - Intermittent
01370 - Alarm triggered by Interior Monitoring
            35-00 -  -
00962 - Alarm via. Tilt Sensor
            35-00 -  -
01369 - Alarm triggered by Hood Switch
            35-00 -  -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 -  -
00956 - Key 2
            35-10 -  -  - Intermittent
   Part No SW: 8E0 035 186 AK    HW: 8E0 035 186 AK
   Component: R Concert2+     H03 0221
   Revision: 00H03000    Serial number: AUZ1Z3G1804642
   Coding: 0210331
   VCID: 70B9D3C256867BB7814-5160
            000 -  -
                    Time Indication: 15
End----------(Elapsed Time: 05:13, VBatt start/end: 12.5V/12.8V)-----------
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 25: DTCs cleared
Address 45: DTCs cleared
Address 46: DTCs cleared
Address 56: DTCs cleared
vagcom pro
Verified VCDS-User
C?ID=342235
Without security access it wont let me code
golfi_vend
Tartu, Estonia
C?ID=195131
Correct part: 8E4 910 155 B.
Or flash to correct if hardware matches.
starkie
C?ID=279996
Rip it out and put a manual in like i did to my cvt 😁😁
zeeshan
C?ID=327143
Try to swap the gearbox module from old to the new gearbox then shouldn't need any coding as long module is good done ones but both gearbox was from similar cars.
Gone But Not Forgotten
Not a good idea or fun to try swapping shit until it's researched on parts microfilm or EPC and repair hardware specs is it?
