A6 4F ASB 171kW "deaeration" of the fuel system(label file)?
FandaTDI
Czech Republic
C?ID=204559
Hi,
where can I activate the fuel pump more "comfortably" then in act.test (just sequentional...)?
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4F0 910 402 D HW: 4F0 907 401 C
Component: 3.0L V6TDI G000AG 0020
Revision: --H04--- Serial number:
Coding: 0011372
Shop #: WSC 02334 785 00200
VCID: 1E703277C99849B435-804A
Even e.g. basic settings of air flaps, egr, etc. isn´t in this .clb ... Job is done but would be great if it would be there. ;-)
Thanks in advance
NEtech
Denmark
C?ID=56995
Basic Settings MWB 035.
It will be added.
FandaTDI
Czech Republic
C?ID=204559
Hi, will it be added, please? And the basic settings of swirl flaps will be also great (should be channels 33 and 44 or 44 and 55?). I was trying it also with other diag. (SuperVAG), where it is documented (engine warm, hold the pedals, rpm should go to approx.2800ot.), but also no success (no faults, conditions met I hope, but even with brake pedal pressed the throttle reacts "normally", not like in other basic setting when the ecu sets rpm as it wants even with full throttle...), any ideas? Thanks
NEtech
Denmark
C?ID=56995
You can use without being added (not saying it is not being added), also here.
What is not working, SuperVAG, VCDS, which Basic Setting MWB ?
Please explain what/how you are doing it.
FandaTDI
Czech Republic
C?ID=204559
It was just "quick action" after work for my colleague (also owner of official VCDS) and further investigation will be when he will fit the second swirl flap repair kit, but wasn´t working the basic setting of these flaps nor with VCDS neither with SuperVAG. I´ve not searched the exact MWB (as far as I remember, 44 should be one of them, this I´ve tried with VCDS), rather take the SuperVAG and thought it will be quicker, but no... I´m not sure, if the SuperVAG has the right description (to do it with engine hot at idle and that the ecu should raise the RPM to about 2800 with pedals pressed - the description says brake and clutch pedals, so in case of AT I assume just brake pedal, but tried both - just brake pedal and with throttle also, both didn´t worked...), so I´m expecting some further searching will be needed...
