2018 Tiguan SEL MK2 North-America Failed Tow Hitch Module Coding Attempt - Need Help.
tomekd77
Leonartown, MD, USA
C?ID=342201
Greetings,
I’m a new Ross-tech user, with limited VW software knowledge. Appreciate any help.
Moderator please move the post to correct section as needed.
Car:
2018 VW Tiguan SEL North America (long wheel base). Car comes with Adaptive Cruse Control (no front camera) and rear collision aid (I think its rear camera based since no acoustic sensors are present).
Objective:
Retrofit/Code 5NN-055-203 kit hitch module with 4 pin trailer connector.
Background:
I purchased kit 5NN-055-203 from, VW Naples, FL dealer, which comes with a 4 pin tow harness and module #5Q0907383N. In U.S. 4 pin provides basic lights to a trailer (turn signal, stop, back lights).
The Module 5Q0907383N has 4 ports(A,B,C,D). The largest module, port A, connects to provided trailer harness. Tiguan’s existing harness has 2 connectors, larger (20?) and smaller (10pin). The 5Q0907383N has two 10pin ports (C and D). I connected Tiguans 10pin to port closer to larger connector - C leaving second 10pin port D on the module empty. Installation instructions specify connection of two leaded wire behide the glove box as well which I did. Any verification of installation would be appreciated, the VW instructions are not detailed what to do with port D.
My first coding attempt failed and I disconnected the module to eliminate all the errors I was getting. The errors were related to front assist not available, rear collision warning not working, stop start not working….). I used battery charger to maintain voltage, cleared OBDII and did not notice Long Code Helper omittance of one of the codes made it more confusing.
Manual code entry was necessary, Long Helper is missing value for bit 5 of 01. Missing value “66” caused ACC not available/error, Start/Stop Disable, (front assist cleared after drive)
My coding attempt was based on flowing post: https://forums.ross-tech.com/showth...itch-wiring-to-2018-Tiguan-SE-(North-America)
The scans:
Prior to hardware installation:
Scan-3VV2B7AX3JM002106-20180721-1245-13706km-8516mi
Saturday,21,July,2018,12:45:31:30494
VCDS Version: 18.2.1.5 (x64)  HEX-NET CB: 0.4411.4
VIN: 3VV2B7AX3JM002106   License Plate:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 22 2B 3C 42 44 52 5F 6C 6D
          75 CA
VIN: 3VV2B7AX3JM002106   Mileage: 13706km-8516miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 5NA 907 115 A    HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H30 0004
   Revision: 1DH30000
   Coding: 012A00122466010FB4000000000000000000000000000000
   Shop #: WSC 00066 790 00291
   ASAM Dataset: EV_ECM20TFS0115NA907115A 001005
   ROD: EV_ECM20TFS0115NA907115A.rod
   VCID: 3C34CD1FB71CB9A438-8068
7657 - Secondary Air Injection System Switching Valve Bank 1
          P2440 00 [096] - Stuck Open
                    Mileage: 12632 km
                    Date: 2018.07.10
                    Time: 17:04:03
                    Engine speed: 1289.00 /min
                    Normed load value: 16.1 %
                    Vehicle speed: 7 km/h
                    Coolant temperature: 48 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 14.440 V
                    Unlearning counter according OBD: 21
                    Engine status: COENG_RUNNING
   Part No SW: 09G 927 158 Q    HW: 09G 927 158
   Component: AISIN AQ8     206 3379
   Coding: 0002000100000000000000000000000000000000
   Shop #: WSC 00066 790 00453
   ROD: EV_TCMAQ450031_VW27.rod
   VCID: 41CABCEBD0FED44C6B-8014
   Revision: 00000000    Serial number: 50987000000137
   Coding: 0BFA6BA454201B6EC5780300A2C949D0D62AD8A3C045927C18415058C28A4200002864121A1C230935351919323200
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
   VCID: 77BE1233CEBA5AFC15-8022
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0434760327
   Coding: 032C0C070F
14222592 - Databus
          [Message ELV_01 missing]
                    Reset counter: 205
                    Mileage: 1048574 km
                    Time: 00:00:00
                    Terminal_15_Kessy_specified_value: OFF
                    Terminal_15_Kessy_actual_value: OFF
                    Terminal_15_central electric_actual_value: Timeout
                    Terminal_15red_Kessy_specified_value: OFF
                    Terminal_15red_Kessy_actual_value: OFF
                    Terminal_S_Kessy_specified_value: OFF
                    Terminal_S_Kessy_actual_value: OFF
                    Terminal_S_central electric_actual_value: Timeout
                    ZAT_pressed: OFF
                    Park selector lever position: Engaged and locked
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 12.644 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Actuation to the inside: active
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID sensor 1 authentication: status: No response
                    ID sensor 2 authentication: status: No response
                    ID sensor 3 authentication: status: No response
                    ID sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 5NN 907 044 A    HW: 5NN 907 044 A
   Component: AC Automat    H35 4301
   Revision: 20K08000    Serial number: 00000D00004849
   Coding: 0002002420011800100501001211140E
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   ROD: EV_ACClimaPrehVW37X_002_VW37.rod
   VCID: 4AD89BC7EDC81714BA-801E
   Part No SW: 5Q0 937 087 AS    HW: 5Q0 937 087 AP
   Component: BCM PQ37BOSCH 034 0243
   Revision: --------    Serial number: C864120417023U
   ROD: EV_BCMCONTI.rod
   VCID: 0C545DDFA73C492448-8058
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 170308  034 0373
   Serial number: 17030521051340
   Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
   Component: G355_FeuchteS  H07 0002
   Serial number: 71808607
   Coding: 3200008150FF8728749C8145304097
   Shop #: WSC 00066 790 00274
   VCID: 3E30C717A100ABB416-806A
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Reset counter: 219
                    Mileage: 12775 km
                    Date: 2018.07.15
                    Time: 07:58:36
                    Voltage terminal 15: 13.1 V
                    Control Module temperature: 47 °C
                    Velocity_vehicle_reference: 3.92 m/s
196741 - Sensor for Automatic Distance Control
          [FCTSEN_BLOCKAGE]
                    Reset counter: 231
                    Mileage: 13670 km
                    Date: 2018.07.21
                    Time: 10:34:55
                    Voltage terminal 15: 12.8 V
                    Control Module temperature: 37 °C
                    Velocity_vehicle_reference: 24.82 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.16 m/s²
196742 - Sensor for Automatic Distance Control
          [FCTSEN_DEC_BLOCKAGE]
                    Reset counter: 231
                    Mileage: 13672 km
                    Date: 2018.07.21
                    Time: 10:36:34
                    Control Module temperature: 36 °C
                    Velocity_vehicle_reference: 20.37 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.53 m/s²
196743 - Sensor for Automatic Distance Control
          [FCTSEN_INC_BLOCKAGE]
                    Reset counter: 231
                    Mileage: 13668 km
                    Date: 2018.07.21
                    Time: 10:32:25
                    Velocity_vehicle_reference: 21.65 m/s
   Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
   Component: AirbagVW21    004 0336
   Serial number: 003NUM057U6/
   Coding: 8CCCFC00000000005000001AC20800000065
   VCID: 054268FB8456386C17-8050
   Occupant Detection:
   Serial number: IBH0000000000073RU0R
   Coding: 303351
   Subsystem 2 - Part No SW: -----------    HW: 480 001 503 17
   Serial number: 357000000000D3191223
   Subsystem 3 - Part No SW: -----------    HW: 480 001 503 17
   Serial number: 358000000003D3191227
   Subsystem 4 - Part No SW: -----------    HW: 480 402 503 17
   Serial number: 3510001A32527B23351L
   Subsystem 5 - Part No SW: -----------    HW: 480 401 901 17
   Serial number: 3520001B922A9B34353/
   Subsystem 6 - Part No SW: -----------    HW: 480 402 103 17
   Serial number: 3550001C724CDB2395AI
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 103 17
   Component: FrontSensor_P  000 6149
   Serial number: 3560001C724CDB2392BH
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 07041708491719
   Coding: 0410
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 075E62F3BE5A2A7C65-8052
   Part No SW: 5NA 920 850 A    HW: 5NA 920 850 A
   Component: KOMBI         361 8311
   Coding: 0BA4001AA788CF0502886B095400000020000000
   VCID: 3D32C01BAC06B0AC0F-8068
   Part No SW: 3Q0 907 530 C    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5286
   Serial number: 08051700840113
   Coding: 030500347F085900FB0322581E0F00010001050000000000000000000000
   Shop #: WSC 00066 790 00064
   ROD: EV_GatewNF_VW27.rod
   VCID: 2F2EEA53766A523C8D-807A
   Subsystem 2 - Part No SW: 5NN 959 442 A    HW: 5NN 959 442 A
   Serial number: 0201700020200003BL2B
   Coding: 2C0000
   Serial number: 0475402904
   Serial number: HA1-00003.11.16
   Coding: 0101
   Serial number: 17000075290009
   Coding: 0800000000000000
   Shop #: WSC 00066 790 00440
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71AA2C2BA0DE04CCDB-8024
   Component: HRE_Master    H12 0080
   Serial number: 0431834720
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
   Component: HRE_Slave  H12 0080
   Serial number: 0434370916
   Coding: 010111
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Component: TSG FS        010 0032
   Serial number: 7028702000146
   Coding: 00301B200000028000000000
   VCID: 45C2A8FBC4D6F86C57-8010
   Serial number: 00000000000005973918
   Coding: 011000
   Part No SW: 5Q0 909 143 P    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2051
   Revision: 00000000    Serial number: 0001620982
   Coding: 01000010004001
   ROD: EV_SteerAssisVWBSMQBA_009.rod
   VCID: 40CCB9EFDBF4DD4464-8014
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Component: TSG BFS       010 0032
   Serial number: 8028712700422
   Coding: 003013200000028000000000
   VCID: 44C4B5FFCFECC16440-8010
   Serial number: 00000000000006065356
   Coding: 091000
   Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
   Component: MU-S-NS-US    840 0755
   Coding: 02730602BE00000051220001001808001F0500C401200105C6
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 3228E32765587FD4E2-8066
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H50 8120
   Serial number: VWZ6ZHT1300503
   Subsystem 2 - Part No SW: 3G0 919 866 BB    HW: -----------
   Component: NAR 2017  --- 0525
   Coding: 0123060120002017300040
   VCID: 393AD40BB82E8C8C23-806C
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
   Coding: 0A08
   ROD: EV_DeckLidCONTIAU736_VW27.rod
   Component: OCULowMQBUS   007 0570
   Coding: 02230602C2823A017F1E06020000
   ROD: EV_OCULowMQB.rod
   VCID: 43C6B6E3CAE2C65C79-8016
   Component: SAD_STG_1     013 0005
   Coding: 00804073260C
   ROD: EV_SunRoofCONTIAU736.rod
End----------(Elapsed Time: 01:45, VBatt start/end: 12.3V/12.3V)-----------
After Installation and my last attempt to get it to work, after that I disconnected and worked on reverting changes back:
Scan-3VV2B7AX3JM002106-20180902-1031-15347km-9536mi
Sunday,02,September,2018,10:31:05:30494
Workshop Code: 000 03743 000000
Scan: 01 02 03 05 08 09 13 15 16 17 19 22 2B 3C 42 44 52 5F 69 6C
          6D 75 CA
VIN: 3VV2B7AX3JM002106   Mileage: 15347km-9536miles
   Revision: 1DH30000
17156 - Databus
                    Mileage: 15347 km
                    Date: 2018.09.02
                    Time: 09:39:01
                    Coolant temperature: 29 °C
                    Intake air temperature: 28 °C
                    Voltage terminal 30: 12.820 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
                    Mileage: 12632 km
                    Date: 2018.07.10
                    Time: 17:04:03
                    Unlearning counter according OBD: 25
   Component: VWKESSYMQB    036 VWKESSYMQB    036 08110811
   Coding: 032C0C070F
   Coding: 0002002410011800100501401211140E
0836 - Databus
                    Reset counter: 26
                    Mileage: 15274 km
                    Date: 2018.08.29
                    Time: 15:43:42
                    Voltage terminal 15: 13.6 V
                    Control Module temperature: 60 °C
                    Velocity_vehicle_reference: 4.86 m/s
                    Longitudinal_acceleration_vehicle_reference: -1.63 m/s²
1229 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING_AAG]
                    Reset counter: 243
                    Mileage: 15347 km
                    Date: 2018.09.02
                    Time: 09:39:02
                    Voltage terminal 15: 12.7 V
                    Control Module temperature: 28 °C
                    Longitudinal_acceleration_vehicle_reference: -0.16 m/s²
   Occupant Detection:
   Coding: 303351
   Coding: 0410
   Coding: 0BA5001AA788CF0502887B095400000020000000
   Coding: 2C0000
66304 - Databus
          U1124 00 [008] - Additional Installations Detected
          [Mehrverbau CAN]
                    Reset counter: 28
                    Mileage: 15347 km
                    Date: 2018.09.02
                    Time: 09:22:00
                    Supply voltage: Terminal 30: 12.2 V
                    Terminal 15: OFF
   Coding: 0101
   Coding: 01011103
   Coding: 010111
   Coding: 011000
   Coding: 091000
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0447480187
   Coding: 0100000202000000
   VCID: 42C8B3E7D5F8CF5472-8016
136203 - Supply Voltage
          P1757 00 [009] - Open Circuit
                    Reset counter: 243
   Coding: 0A08
End------(Elapsed Time: 15:33, VBatt start/end: 12.3V/12.3V, Deb=2)--------
Removed Hardware, check 01 bit 5 46 (couse of my frustrations):
Scan-3VV2B7AX3JM002106-20180903-1224-15416km-9579mi
Monday,03,September,2018,12:24:27:30494
          75 CA
VIN: 3VV2B7AX3JM002106   Mileage: 15416km-9579miles
   Revision: 1DH30000
   Coding: 012A00122446010FB4000000000000000000000000000000
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [175] - -
          [Checking coding/versions ofcontrol modules in drivetrain]
                    Mileage: 15356 km
                    Date: 2018.09.03
                    Time: 08:26:05
                    Engine speed: 709.50 /min
                    Normed load value: 2.7 %
                    Coolant temperature: 99 °C
                    Intake air temperature: 62 °C
                    Voltage terminal 30: 13.240 V
                    ACC variants-Bits 0-7: 2
                    CCS Switch-Bits 0-7: 2
                    Cruise control switch actuation-Bits 0-7: 32
                    Cruise control switch actuation-Bits 0-7: 1
                    ACC variants (coding)-Bits 0-7: 2
Readiness: 0000 1100
8309 - Engine Control Module Incorrectly Coded
          P1612 00 [009] - -
                    Fault Frequency: 8
                    Reset counter: 244
                    Mileage: 15356 km
                    Date: 2018.09.03
                    Time: 08:47:57
   Coding: 032C0C070F
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Fault Frequency: 8
                    Reset counter: 244
                    Mileage: 15356 km
                    Date: 2018.09.03
                    Time: 08:47:27
                    Voltage terminal 15: 12.3 V
                    Control Module temperature: 88 °C
2119 - Databus
          [FAULT_TSK_ACC_CODING_PLAUS_FAIL]
                    Fault Frequency: 8
                    Reset counter: 244
                    Mileage: 15356 km
                    Date: 2018.09.03
                    Time: 08:47:27
                    Longitudinal_acceleration_vehicle_reference: -0.19 m/s²
196698 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [008] -  -
          [ALN_EAL_MAX_PWR_LOW_NEAR]
                    Reset counter: 28
                    Mileage: 15356 km
                    Date: 2018.09.03
                    Time: 08:47:27
196835 - Internal Fault
          B200F F0 [008] - Unknown Error Elaboration
          [FCTSEN_BELOW_MIN_PERF_DIST_AZ]
                    Reset counter: 28
                    Mileage: 15356 km
                    Date: 2018.09.03
                    Time: 08:47:27
                    Control Module temperature: 89 °C
   Occupant Detection:
   Coding: 303351
   Coding: 0410
   Coding: 2C0000
   Coding: 0101
   Coding: 01011103
   Coding: 010111
   Coding: 011000
   Coding: 091000
   Coding: 0A08
End----------(Elapsed Time: 01:44, VBatt start/end: 12.4V/12.4V)-----------
After I figured out that Long Code Helper was missing a bit, and this is my configuration now. (I have not been able to verify ACC function - if it tracks traffic in front):
Scan-3VV2B7AX3JM002106-20180903-1247-15416km-9579mi
Monday,03,September,2018,12:47:47:30494
          75 CA
   Revision: 1DH30000
Readiness: 1110 1101
   Coding: 032C0C070F
   Occupant Detection:
   Coding: 303351
   Coding: 0410
   Coding: 2C0000
   Coding: 0101
   Coding: 01011103
   Coding: 010111
   Coding: 011000
   Coding: 091000
   Coding: 0A08
End----------(Elapsed Time: 01:43, VBatt start/end: 12.6V/12.5V)-----------
Thanks!
Tom
myounus
Northwest UK
C?ID=321059
Hi Tom
You post is very confusing. What is the current status?
Are you retrofitting according to a VW provided guide? Module 5Q0907383N is for trailer recognition. A Passat module also has abcd so yours is not unique. If you follow a standard VW wiring guide then it will also specify coding via ODIS and will not specific the coding or adaptations that are required to make this work.
It appears your have a V2 cable which would specific on the error codes which databus is producing an error on the CAN network which makes it a heck of a lot easier in guiding adaptations. If you need help with the coding then I would recommend you make a scan before making any changes, connect it all back up and post a scan with your faults. Please explain what you've done so far so we can look and guide you on what the error codes means.
Hope this helps
tomekd77
Leonartown, MD, USA
C?ID=342201
myounus,
You are right original post is confusing. Sorry about that.
This is clear version:
Scan without module connected:
Tuesday,04,September,2018,15:57:14:30494
          75 CA
VIN: 3VV2B7AX3JM002106   Mileage: 15487km-9623miles
   Revision: 1DH30000
Readiness: 0000 0100
   Coding: 032C0C070F
   Occupant Detection:
   Coding: 303351
   Coding: 0410
   Coding: 2C0000
   Coding: 0101
   Coding: 01011103
   Coding: 010111
   Coding: 011000
   Coding: 091000
   Coding: 0A08
End----------(Elapsed Time: 01:47, VBatt start/end: 12.3V/12.3V)-----------
Scan with module connected as per original post, with errors, no cods were modified.
Tuesday,04,September,2018,16:02:30:30494
          6D 75 CA
69-Trailer -- Status: Not registered 0011
   Revision: 1DH30000
17156 - Databus
                    Mileage: 15487 km
                    Date: 2018.09.04
                    Time: 16:00:25
                    Coolant temperature: 80 °C
                    Intake air temperature: 73 °C
                    Voltage terminal 30: 12.280 V
   Coding: 032C0C070F
          U1014 00 [009] - -
          [FAULT_CODING_AAG]
                    Reset counter: 247
                    Mileage: 15487 km
                    Date: 2018.09.04
                    Time: 16:00:25
                    Voltage terminal 15: 12.2 V
                    Control Module temperature: 55 °C
                    Status_ACC_System: ACC_Off_MainSwitch_Off
   Occupant Detection:
   Coding: 303351
   Coding: 0410
   Coding: 2C0000
66304 - Databus
          U1124 00 [009] - Additional Installations Detected
          [Mehrverbau CAN]
                    Reset counter: 247
                    Mileage: 15487 km
                    Date: 2018.09.04
                    Time: 15:57:00
                    Supply voltage: Terminal 30: 12.4 V
                    Terminal 15: OFF
   Coding: 0101
   Coding: 01011103
   Coding: 010111
   Coding: 011000
   Coding: 091000
   Shop #: WSC 03743 123 12345
                    Reset counter: 243
                    Mileage: 15350 km
                    Date: 2018.09.02
                    Time: 16:56:17
342020 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0011 00 [008] - Performance
          [Convenience data bus - no signal/communication]
                    Reset counter: 32
   Coding: 0A08
End----------(Elapsed Time: 01:57, VBatt start/end: 12.3V/12.3V)-----------
Thanks
NEtech
C?ID=56995
Suggested coding as for original trailer.
Use battery charger.
Disable start/stop with button (if installed - placed at gearshift or middle of instrument)
Change WSC etc. to none zero in VCDS, see here.
[19-CAN Gateway] > [Installation list] > [69] > [Save coding], explanation here.
Explanation
[Controller number] > New coding
[01] > 012A00122476010FB4000000000000000000000000000000
[13] > 3200008950FF8728749C8145304097 (Secure access first)
[3C] > 01012103
[69] > 0200000202000000
[6C] > 0123060121002017300040
[6D] > 0A88
tomekd77
Leonartown, MD, USA
C?ID=342201
Thanks, looks 69 needs some work.
Explanation
[3C] > 01012103
[6D] > 0A88
Thanks NEtech
Changes per your suggestion, much better, looks like 69 needs some tweaking. I tried 0100000202000000 and 0200000202000000 with the same error code showing.
Wednesday,05,September,2018,18:53:49:30494
          6D 75 CA
VIN: 3VV2B7AX3JM002106   Mileage: 15506km-9634miles
   Revision: 1DH30000
   Coding: 012A00122476010FB4000000000000000000000000000000
   Coding: 032C0C070F
   Coding: 3200008950FF8728749C8145304097
   Occupant Detection:
   Coding: 303351
   Coding: 0410
   Coding: 2C0000
   Coding: 0101
   Coding: 01012103
   Coding: 010121
   Coding: 011000
   Coding: 091000
   Coding: 0200000202000000
   Shop #: WSC 03099 444 12345
                    Reset counter: 248
                    Mileage: 15506 km
                    Date: 2018.09.05
                    Time: 18:51:20
   Coding: 0123060121002017300040
   Coding: 0A88
End----------(Elapsed Time: 01:46, VBatt start/end: 12.6V/12.6V)-----------
Tom
tomekd77
Leonartown, MD, USA
C?ID=342201
The error P1757 Open Circuit and supply voltage 136203 implies no power to the module, but that is not the case since the module accepts coding, right?
Or is this error referring to a voltage that's should present so it can be switched by the trailer module 5Q0907383N to trailer when connected?
Do I have an issue how other modules are affected by addition of 5Q0907383N or the issue is within 5Q0907383N?
The tow kit module came with a activation codes, would that be helpful?
My initial attempt did not get me far so I rather avoid random code flipping.
Any suggestions would be appreciated, thanks in advance.
Tom
MyTiguanFun
C?ID=343508
Explanation
[3C] > 01012103
[6D] > 0A88
Everything above except 69 with 0200000200000000 does the trick. I have no errors. Was stumped for quite sometime on this. Thanks Netech.
tomekd77
Leonartown, MD, USA
C?ID=342201
Here are my scans without errors.
I left 69 set at 0200000200000000 but 0200000000000000 returns without errors as well.
Both these bits are referring to bus power and pin 9 and pin 10 respectively in long code helper, does anyone know what that refers to?
Friday,07,September,2018,10:33:08:30494
          6D 75 CA
VIN: 3VV2B7AX3JM002106   Mileage: 15525km-9646miles
   Revision: 1DH30000
Readiness: 0000 0001
   Coding: 032C0C070F
   Occupant Detection:
   Coding: 303351
   Coding: 0410
   Coding: 2C0000
   Coding: 0101
   Coding: 01012103
   Coding: 010121
   Coding: 011000
   Coding: 091000
   Coding: 0200000200000000
   Coding: 0A88
End----------(Elapsed Time: 01:46, VBatt start/end: 12.5V/12.5V)-----------
69 set at 0200000000000000
Friday,07,September,2018,10:10:07:30494
          6D 75 CA
   Revision: 1DH30000
   Coding: 032C0C070F
   Occupant Detection:
   Coding: 303351
   Coding: 0410
   Coding: 2C0000
   Coding: 0101
   Coding: 01012103
   Coding: 010121
   Coding: 011000
   Coding: 091000
   Coding: 0200000000000000
   Coding: 0A88
End----------(Elapsed Time: 01:46, VBatt start/end: 12.6V/12.5V)-----------
Thanks!
Tom
VolksTrooper
Canada
C?ID=94579
Not to bring up an old thread but I just installed the OEM wiring. I managed to activate everything with a few tweaks the actual wiring seems to be working. My 360 Area view seems to have stopped working, and I have a few other errors Still that I can't seem to figure out. Errors are under the following modules. 10 Park steer assist, 13 Auto dist Reg, 44 Steering Assist, 4b mutifuction, 5f information electr, 69 trailer, 6c backup cam, a5 frt sens drive assist. I followed the coding above to a t but i'm wondering if I have more options on my vehicle which is causing the erros.
