Retrofit ACC VW T6
TMC
C?ID=345686
Hello
I am attempting a retrofit of ACC to a T6 transporter. I have changed the ABS pump to the correct type for ACC but I need to modify the coding for the function Front Assist with City Braking w/ACC FTS. Previous function was Front Assist with City Braking w/o ACC.
Original ABS Code is: 307E40986566847E0C7D027CA68921D379F700
Can someone help modify the code?
ABS Part Number: 7E0907975Q (new fitted part) Type MK100ESC.
Many thanks
Colin
Westbury, UK
Often (usually?) the coding of the ABS is also dependent on other modules fitted to the vehicle, so were going to need you to post a full VCDS Auto-Scan (between CODE tags - see my signature how to).
TMC
C?ID=345686
Please see the attached. This is with the new unit fitted.
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 13 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZJH072570   Mileage: 13710km-8518miles
Address 01: Engine (2D2D2-CXHA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KG    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 3771
   Revision: 23002001
   Coding: 00254014434501090000
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ECM20TDI03004L906056KG 004004
   ROD: EV_ECM20TDI03004L906056KG_004.rod
   VCID: 7CB40B82F708FCAA7E-8028
25130 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [163] - -
          [Checking coding/versions ofcontrol modules in drivetrain]
                    Mileage: 13718 km
                    Date: 2009.01.31
                    Time: 12:44:25
                    Engine speed: 0.00 /min
                    Coolant temperature: 22 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 11.625 V
                    Acceleration: 0.000 m/s²
                    Cruise Control System (CCS): status: ERROR
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake function status-ABS intervention: No
                    Drivetrain coordinator: brake function status-ESP intervention: No
                    Drivetrain coordinator: brake function status-EDL intervention: No
                    Drivetrain coordinator: brake function status-ASR intervention: No
                    Drivetrain coordinator: brake function status-MSR intervention: No
                    Drivetrain coordinator: brake function status-Driver braking: No
                    Drivetrain coordinator: brake function status-HDC active: No
                    Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
                    Drivetrain coordinator: brake function status-EPB active: No
                    Drivetrain coordinator: brake function status-ASP intervention: No
                    Drivetrain coordinator: brake function status-ADS intervention: No
                    Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: No
                    Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): No
                    Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): No
                    Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: No
                    Drivetrain coordinator: brake function status-ACC stopping distance control active: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
Readiness: N/A
   Part No SW: 0BT 300 046 J    HW: 0BH 927 711 G
   Component: DSG DQ500-7F  H11 5301
   Revision: 00H11V01
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: 3D32C686AC9235A209-8068
Address 03: ABS Brakes (J104)       Labels:. 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
   Revision: 00000000    Serial number: 61887000000354
   VCID: 40CCBF72DB60584A62-8014
11 Faults Found:
0143 - ABS/ESP Control Module
          U10C5 00 [137] - No or Incorrect Basic Setting
          [valve calibrating data missing]
                    Reset counter: 157
                    Mileage: 13718 km
                    Date: 2018.09.06
                    Time: 12:44:26
0195 - Control module not coded
          U1013 00 [137] - -
          [ECU marked as Not Configured because vehicle ID is invalid]
                    Reset counter: 157
                    Mileage: 13718 km
                    Date: 2018.09.06
                    Time: 12:44:26
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 157
                    Mileage: 13718 km
                    Date: 2018.09.06
                    Time: 12:44:26
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 157
                    Mileage: 13718 km
                    Date: 2018.09.06
                    Time: 12:44:26
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 157
                    Mileage: 13718 km
                    Date: 2018.09.06
                    Time: 12:44:26
0295 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 157
                    Mileage: 13718 km
                    Date: 2018.09.06
                    Time: 12:44:26
0338 - ABS/ESP Control Module
          [inlet valve calibration data missing]
                    Reset counter: 157
                    Mileage: 13718 km
                    Date: 2018.09.06
                    Time: 12:44:26
4255 - Internal Fault
          B200F F0 [137] - Unknown Error Elaboration
          [Hecu_mismatch_final]
                    Reset counter: 157
                    Mileage: 13718 km
                    Date: 2018.09.06
                    Time: 12:44:26
8297 - Databus
          U1121 00 [136] - Missing Message
          [ACAN: mIdent signal timeout]
                    Reset counter: 197
                    Mileage: 13718 km
                    Date: 2018.09.06
                    Time: 12:44:33
8319 - Databus
          U1122 00 [137] - Implausible Message
          [ACAN: mMotor_10 Start_Stop coding missmatch]
                    Reset counter: 157
                    Mileage: 13718 km
                    Date: 2018.09.06
                    Time: 12:44:26
8324 - Databus
          [ACAN: LW1_ID wrong value]
                    Reset counter: 157
                    Mileage: 13718 km
                    Date: 2018.09.06
                    Time: 12:44:26
   Serial number: 03101713470066
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EB0018AE114EEBA50-802A
   Part No SW: 7E0 907 047 AK    HW: 7E0 907 047 AK
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   Shop #: WSC 02739 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 73A620BEDA56B3D22F-8026
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Component: BCM PQ25 Max4 H82 0752
   Revision: B9082001    Serial number: 4000 284170036
   Coding: B9AC393A0A61341193284F747FEB8E750F04710F60CC6D60330400230840
   Shop #: WSC 02739 534 199619
   VCID: 2B16F8DE4AE6AB12A7-807E
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 270917 04  47  0106
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU026091772690596
   Coding: 1400B0
   Subsystem 3 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU004101772770455
   Coding: 0400A0
   Subsystem 4 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 1K0 951 605 F
   Subsystem 6 - Part No: 7E1 951 172
   Subsystem 7 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 29160002249940056441
   Coding: B40000
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231724900983
   Coding: 30810C
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 71AA2AB6A04A81C2DD-8024
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Serial number: 2409170440ACBC
   Coding: 00005000FE0779
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: 3620D9AA89A4E6FAC8-8062
1071 - Databus
          [FAULT_CIS_AXV_INVALID]
                    Reset counter: 157
                    Mileage: 13718 km
                    Date: 2018.09.06
                    Time: 12:44:25
                    Control Module temperature: 27 °C
                    Voltage terminal 15: 11.5 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 157
                    Mileage: 13718 km
                    Date: 2018.09.06
                    Time: 12:44:25
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Reset counter: 157
                    Mileage: 13718 km
                    Date: 2018.09.06
                    Time: 12:44:25
   Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
   Component: VW10Airbag021 H08 0018
   Revision: --------    Serial number: 003V3006F51L
   Coding: 000000000000000000000000000000003231
   Shop #: WSC 02734 790 50316
   VCID: 3A38CD9ABDBC029A2C-806E
          B13BC F2 [137] - No function
                    Mileage: 13718 km
                    Date: 2018.09.06
                    Time: 12:44:40
   Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
   Component: KOMBI         H03 1107
   Coding: 450B010300
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Component: GW-K-CAN TP20 H82 0752
   Revision: B9082001
   Coding: 042307
   VCID: 689C47D29B90400A8A-803C
   Component: IMMO          H03 1107
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A983DDA8D9C721A9C-803E
   Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
   Component: MU-S-ND-ER    H41 0468
   Serial number: VWZAZ2T5409046
   Coding: 065700013C00000011111101008808001F0100D6002001004F
   Shop #: WSC 27359 003 104857
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 25020EE624029D6271-8070
   Subsystem 1 - Part No SW: 3G0 919 866 BC    HW: -----------
   Component: ECE1 2017/18  --- 0820
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 030B1A73
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Serial number: 7588570000170926060F
TMC
C?ID=345686
The effective change I am making is PR code 8T2 & 6K2 to PR code 8T3 & 6K3.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Did you get the ACC's component protection already matched? If so, how did you get around the SWaP activation of the ACC functionality?
downtime
Finland
C?ID=280813
Does T6 even have component protection? I'm under the impression that no. Lot of parts are common to PQ25 platform car like prev gen Polo and Ibiza. Those did not have CP scheme yet.
The new MQB A0 platform Polo, Ibiza etc. introduce that scheme.
This is my understanding so please don't shoot me if I'm mistaken :)
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Believe me, it does (with the Instrument Cluster as CP Master) - the Transporter/Multivan was always the Frankenstein when it came to the VW parts lego game. Though the bigger problem here is SWaP, hence my question...
downtime
Finland
C?ID=280813
Ok I didn't know that. Know I do. Thanks for enlightening me.
Yes, SWaP will be an issue then. CP itself won't be a problem if there's no FeC in play but with FeC, weeeelllll... It will be a long and difficult road.
golfi_vend
Tartu, Estonia
C?ID=195131
I think i have a idea how this can be bypassed, but it's not for public discussion.
I've been using similar technology for retrofitting Discover Media, to cars where it was never available, without adding a emulator or patching the eeprom.
But this would mean i need cluster, radio and radar. All components of CP system.
cilitkas
LT
are you sure all t6 had CP? i have bought BCM and navi from late 2015 T6, fitted to my 2012 t5 and all works fine, no CP errors...
kamold
Australia
C?ID=241363
PQ platform vehicles' CP scheme doesn't include BCM like it does in MQB platform vehicles..
dnoermann
C?ID=358118
So, for PQ25/PQ35 Car's with Component Protection Master inside the Cluster i figured out the Code.
You need a ACC Radar and Cluster which are already configured with the right Swap Codes and CP Data from a working or broken T6 for Example.
It is possible to read out the encrypted Component Protection Data from the Cluster, 20 Bytes @ Offset 0x1540 in Eeprom
Decrypt it, and than Encrypt it for the your Car.
With the Component Protection "Transfered", the Swap Codes from the original Car stays and everything works.
For this you need to be able to read out the 2 Mbyte Firmware of the Cluster @ offset 0x10034 is the 16 Byte CBC AES Key for CP Eeprom Data encryption
@ 0x1540 in Eeprom there are 20 Bytes, first 4 bytes are CRC32 of the next 16 Byte "Data" (but only after decryption)
The AES is only calculated over the first 16 byte.
So do a AESCBC Decryption of Byte 0-15, than you can do a crc32 over Decrypted Byte 4-15 and original Bytes 16-19 from eeprom, this should be identical to Decrypted Bytes 0-3.
Than you can encrpt the data for the new cluster.
Done :)
Took me 3 Month of Cluster Firmware Reverse-Engineering ....
I am aware that this way of copying the cp Data is already known by some people, but due to for me unknown circumstances this was not made public by them.
I like to share this information now publicly. Be happy with it.
Attached a real Use Case Picture for Better understanding.
dnoermann
C?ID=358118
Since i now own a DM i looked again a bit deeper.
Here is the Mapping of the Eeprom Addresses
First number is the Last Data Byte of UDS_WriteDataByIdentifier 0x00BE
0x14 ==> 0x1500 with backup in 0x1520 UDS AES-KEY (used for UDS_WriteDataByIdentifier)
0x57 ==> 0x1540 with backup in 0x1560 ACC
0x73 ==> 0x1660 with backup in 0x1680 DM
0xFF ==> 0x16A0 with backup in 0x16C0 Free, for Future USE
Lukas001
Czech Republic
C?ID=349149
Hi, I need help with errors in ABS, I installed ACC, other abs, steering wheel, the car had no cruise control. Thanks
Sobota,30,Leden,2021,18:22:10:42624
VCDS -- Windows VAG/VAS Emulator Běží na Windows 7 x64
VCDS verze: SVO 20.4.2.1  HEX-V2 CB: 0.4513.4
Verze dat: 20200331 DS317.0
www.vag-com.cz
Jméno servisu: LUKAS AUTO
Číslo dílny: 111 12312 233332
VIN: WV2ZZZ7HZJH164984   Výrobní štítek: 6J50505
Kilometry: 46110km   Číslo zakázky::
Model: 7H-VN75 (7E0)
Sken: 01 02 03 04 08 09 10 13 15 17 18 19 25 55 5F 61 69 0B
VIN: WV2ZZZ7HZJH164984   Kilometry: 46110km
01-Motor -- stav: Nefunkční 0010
02-Aut. převodovka -- stav: OK 0000
03-ABS brzdy -- stav: Nefunkční 0010
04-Snímač úhlu řízení -- stav: OK 0000
08-Klima/topení -- stav: OK 0000
09-Centrální elektrika -- stav: OK 0000
10-Asist park./řízení -- stav: OK 0000
13-Regulace odstupu -- stav: Nespolehlivá komunikace 1000
15-Airbagy -- stav: OK 0000
17-Přístrojová deska -- stav: Nefunkční 0010
18-Přídavné topení -- stav: Nefunkční 0010
19-CAN Gateway -- stav: Nefunkční 0010
25-Imobilizér -- stav: OK 0000
55-Reg.sklonu světel -- stav: Nefunkční 0010
5F-Elektro info -- stav: Nefunkční 0010
61-Regulace baterie -- stav: Nefunkční 0010
69-Funkce přívěsu -- stav: OK 0000
Adresa 01: Motor (2D2D2-CXFA)       Labely:. SVO\04L-907-309-V2.clb
   Řídící jednotka SW: 04L 906 056 KH    HW: 04L 907 445
   Díl: R4 2.0l TDI   H02 5952
   Revize: 23002001
   Kódování: 0025401C435401080000
   Dílna #: WSC 12312 111 233332
   ASAM Dataset: EV_ECM20TDI03004L906056KH 004012
   ROD: EV_ECM20TDI03004L906056JS_004.rod
   VCID: 7DA60F58ED7B06E3394-8028
2 závad nalezeno.
25812 - Autom.regulace vzdálenosti
          U0235 00 [032] - bez komunikace
          [Lost Communication WithCruise Control Front Distance Range Sensor]
          Sporadická - Nepotvrzeno - Testováno od smazání paměti
             info o závadě:
                    Stav závad: 00000001
                    Priorita závad: 2
                    Frekvence závad: 2
                    Kilometry: 45910 km
                    Datum: 2027.01.08
                    Čas: 16:26:37
                    Otáčky motoru: 0.00 /min
                    Normovaná hodnota zátěže: 0.0 %
                    Rychlost vozidla: 0 km/h
                    Teplota chladicí kapaliny: 17 °C
                    Teplota nasávaného vzduchu: 19 °C
                    Okolní tlak vzduchu: 940 mbar
                    Napětí svorky 30: 11.257 V
                    Čítač zapomenutí po OBD: 31
                    Dráha plynového pedálu: hrubá hodnota: 0.00 %
                    Stav CAN - řídicí jednotka motoru: 0
                    Tempomat: stav: Inicializace
                    Zařazený stupeň: Proces řazení aktivní
25130 - kontrolovat kodovani ridicich jednotkek CAN-BUS pohonu
          P1647 00 [175] - -
          Kontrolka závad ZAP - Potvrzeno - Testováno od smazání paměti
             info o závadě:
                    Priorita závad: 2
                    Frekvence závad: 40
                    Kilometry: 45910 km
                    Datum: 2027.01.08
                    Čas: 01:30:54
                    Teplota nasávaného vzduchu: 10 °C
                    Napětí svorky 30: 11.164 V
                    Čítač zapomenutí po OBD: 40
                    Zrychlení: 0.000 m/s˛
                    Koordinátor hnacího ústrojí: chybové stavy ACC-ACC aktivní navzdory zpoždění EPB: ne
                    Koordinátor hnacího ústrojí: chybové stavy ACC-ACC aktivní: ačkoli TSK pasivní: ne
                    Koordinátor hnacího ústrojí: chybové stavy ACC-přání na rozjezd nebo zastavení u rychlosti zastavení není dáno: ne
                    Koordinátor hnacího ústrojí: chybové stavy ACC-požadavek rozjezdu a zastavení se odesílají současně: ne
                    Koordinátor hnacího ústrojí: chybové stavy ACC-ACC aktivní: ačkoli omezovač je aktivní: ne
                    Koordinátor hnacího ústrojí: chybové stavy ACC-ACC se po zablokování reaktivuje: ne
                    Koordinátor hnacího ústrojí: chybové stavy ACC-ACC odesílá nedefinované signály: ne
                    Koordinátor hnacího ústrojí: chybové stavy ACC-ACC aktivní: ačkoli hlavní spínač vypnutý: ne
                    Koordinátor hnacího ústrojí: chybové stavy ACC-ACC aktivní navzdory brzdění řidiče: ne
                    Koordinátor hnacího ústrojí: chybové stavy ACC-ACC je aktivní navzdory pasivnímu klíčování ESP/ASR: ne
                    Koordinátor hnacího ústrojí: funkční stav brzd-Zásah ABS: ne
                    Koordinátor hnacího ústrojí: funkční stav brzd-Zásah ESP: ne
                    Koordinátor hnacího ústrojí: funkční stav brzd-Zásah EDS: ne
                    Koordinátor hnacího ústrojí: funkční stav brzd-Zásah ASR: ne
                    Koordinátor hnacího ústrojí: funkční stav brzd-Zásah MSR: ne
                    Koordinátor hnacího ústrojí: funkční stav brzd-Řidič brzdí: ne
                    Koordinátor hnacího ústrojí: funkční stav brzd-HDC aktivní: ne
                    Koordinátor hnacího ústrojí: funkční stav brzd-ESP provádí brzdění TSK: ne
                    Koordinátor hnacího ústrojí: funkční stav brzd-EPB aktivní: ne
                    Koordinátor hnacího ústrojí: funkční stav brzd-zásah ASP: ne
                    Koordinátor hnacího ústrojí: funkční stav brzd-zásah ADS: ne
                    Koordinátor hnacího ústrojí: funkční stav brzd-varovné trhnutí AWV2: ne
                    Koordinátor hnacího ústrojí: funkční stav brzd-ESP zapnutý pasivně (ESP vyp): ne
                    Koordinátor hnacího ústrojí: funkční stav brzd-ASR zapnutý pasivně (ASR vyp): ne
                    Koordinátor hnacího ústrojí: funkční stav brzd-ESP detekuje stojící vozidlo: ne
                    Koordinátor hnacího ústrojí: funkční stav brzd-ACC: regulace brzdné dráhy aktivní: ne
                    Koordinátor hnacího ústrojí: chybové stavy brzd-regulátor zpomalení nedostupný: ne
                    Koordinátor hnacího ústrojí: chybové stavy brzd-závada regulátoru zpomalení: ne
                    Koordinátor hnacího ústrojí: chybové stavy brzd-chyba systému ESP: ne
                    Koordinátor hnacího ústrojí: chybové stavy brzd-ESP: chyba systému kvůli nepřesnosti momentů motoru: ne
                    Koordinátor hnacího ústrojí: chybové stavy brzd-ESP hlásí chybu konzistence odezvy TSK: ne
                    Koordinátor hnacího ústrojí: chybové stavy brzd-TSK/ESP: chyba součinnosti: ne
                    Koordinátor hnacího ústrojí: chybové stavy brzd-ESP: nucené přepnutí chybné: ne
                    Koordinátor hnacího ústrojí: chybové stavy brzd-brzdové světlo neplatné: ne
Readiness: N/A
Adresa 02: Aut. převodovka (J743)       Labely:. SVO\0BH-927-711.clb
   Řídící jednotka SW: 0BT 300 046 J    HW: 0BH 927 711 G
   Díl: DSG DQ500-7F  H11 5301
   Revize: 00H11V01
   Kódování: 0014
   Dílna #: WSC 00000 000 00000
   VCID: 3D26CF58ADFBC6E3794-8068
Nenalezena žádná chyba.
Adresa 03: ABS brzdy (J104)       Labely: SVO\7E0-907-37x-MK100ESC.clb
   Řídící jednotka SW: 7E0 907 379 Q    HW: 7E0 907 379 N
   Díl: ESC           H06 0133
   Revize: 00000000    Seriové číslo: 62188000000380
   Kódování: 307E4098256884820C7E027EA48621D378F600
   VCID: 40D8B6ACDA09AB0B122-8014
2 závad nalezeno.
8285 - Datová sběrnice; chybějící odezva
          U1121 00 [008] - -
          [ACAN: mAWV frame timeout]
          Sporadická - Potvrzeno - Testováno od smazání paměti
             info o závadě:
                    Priorita závad: 3
                    Frekvence závad: 2
                    Počítadlo resetů: 153
                    Kilometry: 45910 km
                    Datum: 2021.01.24
                    Čas: 16:26:38
8324 - Datová sběrnice; neplatná odezva
          U1122 00 [137] - -
             info o závadě:
                    Priorita závad: 2
                    Frekvence závad: 1
                    Počítadlo resetů: 113
                    Kilometry: 45910 km
                    Datum: 2021.01.24
                    Čas: 01:24:53
Adresa 04: Snímač úhlu řízení (G085)       Labely:* SVO\6R0-959-654.clb
   Řídící jednotka SW: 6R0 959 654     HW: 6R0 959 654
   Díl: LENKW.SENSOR  H07 0070
   Seriové číslo: 12031813470849
   Kódování: 01
   VCID: 7EA40854E07D1DFB20E-802A
Adresa 08: Klima/topení (J255)       Labely:| SVO\7E5-907-040.clb
   Řídící jednotka SW: 7E0 907 040 R    HW: 7E0 907 040 R
   Díl: ClimatronicT5 H04 0613
   Revize: 00001K04
   Kódování: 0004000103
   Dílna #: WSC 02762 790 50316
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 323CEC6464A5099B946-8066
   Slave 1:
   Subsystém 1 - Řídící jednotka SW: 7E5 907 049 C    HW: 7E5 907 049 C
   Díl: Heckbedienung  H11 0303
   Seriové číslo: BHB-0011104180015173
Adresa 09: Centrální elektrika (J519)       Labely:. SVO\7E0-937-BCM-V1.clb
   Řídící jednotka SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Díl: BCM PQ25 Max4 H82 0752
   Revize: B9082001    Seriové číslo: 4000 105180369
   Kódování: 62A83D3A4A23201301280F606CEB8FD5C084738960CD79603304003F0820
   VCID: 2B02F100430F5853D70-807E
   Subsystém 1 - Řídící jednotka: 5K7 955 559 C  Labely: SVO\5K7-955-559.CLB
   Díl: RLS 040418 04  47  0106
   Kódování: 0228DD
   Subsystém 2 - Řídící jednotka SW: 7E0 959 801 N    HW: 7E0 959 801 N  Labely: SVO\7E0-959-80X-V2.CLB
   Díl: J386__TSG_FT  004 0653
   Seriové číslo: KU0KU003041880931537
   Kódování: 0400A1
   Subsystém 3 - Řídící jednotka SW: 7E0 959 802 R    HW: 7E0 959 802 R  Labely: SVO\7E0-959-80X-V2.CLB
   Díl: J387__TSG_BT  005 0653
   Seriové číslo: KU0KU029031880880805
   Kódování: 1400A1
   Subsystém 4 - Řídící jednotka SW: 7E0 959 442 A    HW: 7E0 959 442 A  Labely: SVO\3C8-959-537.CLB
   Díl: E221__MFL-DC1  H02 0103
   Seriové číslo: 29160001985410026407
   Kódování: B5FFFF
Adresa 10: Asist park./řízení (J446)       Labely:| SVO\7E0-919-475.clb
   Řídící jednotka SW: 7E0 919 475 AA    HW: 7N0 919 475
   Díl: PARKHILFE 8K  H06 0212
   Revize: --------    Seriové číslo: 28231807501767
   Kódování: 118109
   VCID: 71BE2368A1237283ADC-8024
Adresa 13: Regulace odstupu (J428)       Labely:| SVO\7N0-907-572.clb
   Řídící jednotka SW: 7N0 907 572 C    HW: 7E0 907 572
   Díl: ACC Bosch PQx H03 0211
   Seriové číslo: 13101604390197
   Kódování: 00005800FE0779
   ROD: EV_ACCBEGVW361.rod
   VCID: 3634D07488CD15BBB8E-8062
5 závad nalezeno.
1058 - Datová sběrnice; přijatá chybová hodnota
          U1123 00 [009] - -
             info o závadě:
                    Priorita závad: 6
                    Frekvence závad: 1
                    Kilometry: 45910 km
                    Datum: 2021.01.24
                    Čas: 01:24:52
                    Teplota řídicí jednotky: 39 °C
                    Napětí svorky 15: 14.4 V
                    Rychlost vozidla: 0.00 m/s
                    Zrychlení: 0.00 m/s˛
1059 - Datová sběrnice; přijatá chybová hodnota
          U1123 00 [009] - -
             info o závadě:
                    Priorita závad: 6
                    Frekvence závad: 1
                    Kilometry: 45910 km
                    Datum: 2021.01.24
                    Čas: 01:24:52
1037 - Datová sběrnice; přijatá chybová hodnota
          U1123 00 [009] - -
          [FAULT_CIS_QDCACC_FAIL]
             info o závadě:
                    Priorita závad: 6
                    Frekvence závad: 2
                    Kilometry: 45910 km
                    Datum: 2021.01.24
                    Čas: 01:24:52
1038 - Datová sběrnice; přijatá chybová hodnota
          U1123 00 [008] - -
          [FAULT_CIS_QDCPSS_FAIL]
             info o závadě:
                    Priorita závad: 6
                    Frekvence závad: 1
                    Kilometry: 45910 km
                    Datum: 2021.01.24
                    Čas: 16:27:01
                    Teplota řídicí jednotky: 19 °C
                    Napětí svorky 15: 11.8 V
1807 - Žádná uvolňovací identifikace aktivní
          B2032 00 [009] - Neznámá chyba zpracování
          [FAULT_SWAP_NO_FSID_ACTIVE]
             info o závadě:
                    Priorita závad: 3
                    Frekvence závad: 40
                    Počítadlo resetů: 122
                    Kilometry: 45910 km
                    Datum: 2021.01.24
                    Čas: 01:24:52
Adresa 15: Airbagy (J234)       Labely:| SVO\5K0-959-655.clb
   Řídící jednotka SW: 7E0 959 655 K    HW: 7E0 959 655 K
   Díl: VW10Airbag01R 010 0018
   Revize: --------    Seriové číslo: 003EM000NFLC
   Kódování: 000000000000000000000000000000003152
   Dílna #: WSC 02164 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3E24C854A0FDDDFB60E-806A
   Snímač nárazu bočního airbagu: strana řidiče:
   Seriové číslo: 3495ZRB405B5EC068P2E
   Snímač nárazu bočního airbagu: strana spolujezdce:
   Seriové číslo: 3505ZRB40535DCRUHP9L
Adresa 17: Přístrojová deska (J285)       Labely:| SVO\5K0-920-xxx-17.clb-SRI1
   Řídící jednotka SW: 7E0 920 870 S    HW: 7E0 920 870 S
   Díl: KOMBI         H03 1107
   Seriové číslo: 00000000000000
   Kódování: 140D030300
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 392EDB48B9D3FAC355C-806C
1 nalezena chyba:
13654640 - Omezení funkce kvuli chybející odezve
          U1111 00 [008] - -
          [Steuergeraet fuer Abstandsdistanzregelung Low: keine Kommunikation]
             info o závadě:
                    Priorita závad: 6
                    Frekvence závad: 2
                    Kilometry: 45910 km
                    Datum: 2021.01.24
                    Čas: 16:26:40
Adresa 18: Přídavné topení (J364)       Labely:| SVO\7E0-963-27X-18.clb
   Řídící jednotka SW: 7E0 963 273 A    HW: 7E0 963 273 A
   Díl: STH-T5GP2     003 0009
   Kódování: 4101
   ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
   ROD: EV_AuxilParkiHeateWOST5G2.rod
   VCID: 2B02F100438F5853D70-807E
1 nalezena chyba:
0375 - Omezení funkce
          U1400 00 [008] - podpetím
          [DYSFUNCTION BY UNDERVOLTAGE]
             info o závadě:
                    Priorita závad: 7
                    Frekvence závad: 5
                    Počítadlo resetů: 160
                    Kilometry: 45955 km
                    Datum: 2021.01.26
                    Čas: 07:22:46
                    Nezávislé topení: provozní stav: vypnuto
                    71
                    Teplota chladicí kapaliny nezávislého topení: -2 °C
                    Teplota chladicí kapaliny: 0 °C
                    Stav běhu motoru: není zjištěn
                    Zásoba paliva: 70 l
                    Topný výkon: 0 W
Adresa 19: CAN Gateway (J533)       Labely:. SVO\7E0-909-901.clb
   Řídící jednotka SW: 7E0 909 901     HW: 7E0 937 090 C
   Díl: GW-K-CAN TP20 H82 0752
   Revize: B9082001
   Kódování: 042205
   VCID: 68884E0C9279B34BFA2-803C
1 nalezena chyba:
01319 - ridici jednotka pro rizeni vzdalenosti odstupu (J428)
            004 - zadny signal / komunikace - Sporadická
             info o závadě:
                    Stav závad: 00100100
                    Priorita závad: 2
                    Frekvence závad: 2
                    Kilometry: 45910 km
                    Indikace času: 0
                    Datum: 2021.01.24
                    Čas: 16:26:38
Adresa 25: Imobilizér (J334)       Labely:| SVO\5K0-920-xxx-25.clb
   Řídící jednotka SW: 5K0 953 234     HW: 5K0 953 234
   Díl: IMMO          H03 1107
   Seriové číslo:
   Kódování: 000000
   VCID: 6A8C34048CF5815BEC6-803E
Adresa 55: Reg.sklonu světel (J431)       Labely:. SVO\6R0-907-357.clb
   Řídící jednotka SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Díl: AFS-ECU       005 0050
   Revize: --------    Seriové číslo: --------------
   Kódování: 0FCA020001000000
   ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3A2CC444BCD5F1DB5C6-806E
2 závad nalezeno.
5256213 - Snímač světlé výšky vpředu vlevo
          C1034 15 [137] - preruseni nebo zkrat na plus
             info o závadě:
                    Priorita závad: 2
                    Frekvence závad: 40
                    Kilometry: 45910 km
                    Datum: 2021.01.24
                    Čas: 01:24:52
5256209 - Snímač světlé výšky vpředu vlevo
          C1034 11 [137] - Zkrat na kostru
             info o závadě:
                    Priorita závad: 2
                    Frekvence závad: 40
Adresa 5F: Elektro info (J794)       Labely:| SVO\5G0-035-MIB-STD2.clb
   Řídící jednotka SW: 5K7 035 200 L    HW: 5K7 035 200 L
   Díl: MU-S--ER      H41 0468
   Seriové číslo: VWZAZ2U0714991
   Kódování: 06570000BE00000011110001000808001F0100C40020010003
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2D06FF187D9B5663C94-8078
Adresa 61: Regulace baterie (J840)       Labely:. SVO\1K0-907-534.clb
   Řídící jednotka SW: 7E0 907 534     HW: 7E0 937 090 C
   Díl: Batt.regelung H82 0752
   Kódování: 330B1A73
   Dílna #: WSC 02762 790 00000
   Subsystém 1 - Řídící jednotka SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Díl: J367-BDMConti  H03 1050
   Seriové číslo: 75885700001804130568
1 nalezena chyba:
02256 - klidovy stav proudu
            001 - horni mezni hodnota prekrocena - Sporadická
             info o závadě:
                    Stav závad: 00100001
                    Priorita závad: 7
                    Frekvence závad: 1
                    Kilometry: 45910 km
                    Indikace času: 0
                    Datum: 2021.01.24
                    Čas: 08:08:10
Adresa 69: Funkce přívěsu (J345)       Labely:. SVO\1K0-907-383-V2.clb
   Řídící jednotka SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Díl: Anhaenger     H12 0130
   Revize: 3B001001    Seriové číslo: 00000477142493
   Kódování: 410D000103000000
   VCID: 323CEC646425099B946-8066
Konec-(Uplynulý čas: 01:42, VBat začátek/konec: 10.7V/10.2V. VIgn 10.2V)---
dnoermann
C?ID=358118
Please post an english autoscan.
For ACC or CCS via MFSW in T6 the linbus from MFSW needs to be connected to bcm Pin36
In BCM coding Byte 29 Bit 6 Set ==> MFSW is connected to BCM via LIN Bus Pin 36 on T73b (normal Use Case on EU6 Diesel Engine)
downtime
Finland
C?ID=280813
Also if I read the autoscan correctly, ACC radar is disconnecting due to invalid FeC (the swap error).
That is something you need to circumvent by other means than coding.
dnoermann
C?ID=358118
Robert-VW
Ireland & Poland
C?ID=423656
Trying to complete ACC retrofit on 2017 VW T6 204PS RHD DSG 4MOTION panel van.
Effectively it is going to be an upgrade from factory MFSW CCS to ACC.
Originally without FRONT ASSIST so no radar but compatible ABS was already onboard.
Correct MFSW buttons & radar have been installed.
CP and appropriate SWAP also done.
Battery was disconnected to reset BCM but it didn't change anything.
What am I missing?
Monday,24,January,2022,19:12:05:50413
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4607.4
VIN: WV1ZZZ7HZHH066285   License Plate:
Mileage: 129400km-80405mi   Repair Order:
Scan: 01 02 03 04 08 09 10 13 15 17 19 22 25 55 5F 61 0B
VIN: WV1ZZZ7HZHH066285   Mileage: 129400km-80405miles
Address 01: Engine (2D2D2-CXEB)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KN    HW: 04L 907 445 A
   Component: R4 2.0l BTD   H03 3776
   Revision: 23101001
   Coding: 00254014436701080000
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ECM20BTD03004L906056KN 004004
   ROD: EV_ECM20BTD03004L906056KN_004.rod
   VCID: 035276EBCB9956C3BA3-8056
   VINID: 9E606AAAA1D8A9860018608814B5BE5C8D
25815 - Implausible Data Received from Diagnostic Gateway Module
          U0447 00 [039] - -
                    Mileage: 129409 km
                    Date: 2060.01.02
                    Time: 19:05:30
                    Engine RPM: 0.00 /min
                    Coolant temperature: 33 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 11.421 V
                    Accelerator pedal travel: raw value: 0.00 %
                    CAN status - engine control module: 0
                    Cruise Control System (CCS): status: Initialization
                    selected gear: Shifting process active
Readiness: N/A
   Part No SW: 0BT 300 012 C    HW: 0BH 927 711 G
   Component: DSG DQ500-7A  H11 5302
   Revision: 00H11V01    CVN: E785A3F3
   VCID: 2F3AEA5B379102A30EB-807A
Address 03: ABS Brakes (J104)       Labels:. User\TEST-03.lbl
   Revision: 00000000    Serial number: 42676000003799
   Coding: 557E809865688484AA77017EA687219679F700
   VCID: 3FDABA1BE7F1F2239EB-806A
   Serial number: 08101613471214
   Coding: 01
   VCID: 7EA4071FA07B3B2BD5D-802A
   Revision: 00001002
   Coding: 0000000003
   VCID: 73B2262B9B396643AA3-8026
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 279160374
   Coding: B8A0303A4A63343193284F507EEB8F75C284728F60CD7960320400220840
   Shop #: WSC 12345 123 61029
   VCID: 2A0CFB4F0CF3678BD95-807E
   Component: RLS 220916 04  42  0106
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 Q    HW: 7E0 959 801 Q  Labels: 7E0-959-80X-V2.CLB
   Serial number: KU0KU022091662666502
   Coding: 1400B1
   Subsystem 3 - Part No SW: 7E0 959 802 Q    HW: 7E0 959 802 Q  Labels: 7E0-959-80X-V2.CLB
   Serial number: KU0KU023091662676746
   Coding: 0400A1
   Subsystem 5 - Part No: 1K0 951 605 C
   Serial number: 39170003008480017525
   Coding: B4FFFF
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331727500488
   Coding: 0031051211
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: 372AD23BCFC1CA6356B-8062
12718592 - Databus
          [Steuergerät für Lenksäulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
                    Reset counter: 15
                    Mileage: 129409 km
                    Date: 2022.01.24
                    Time: 18:12:07
   Serial number: 01121476510053
   Coding: 003C5200FE0F79
   Shop #: WSC 00046 123 12345
   VCID: 3634DF3FC8CB336B4DD-8062
1043 - Automatic Distance Control
          B10E7 F0 [009] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 15
                    Mileage: 129409 km
                    Date: 2022.01.24
                    Time: 19:06:08
                    Control Module temperature: 31 °C
                    Voltage terminal 15: 11.4 V
0786 - Databus
          [FAULT_CHK_mGRA_Neu]
                    Reset counter: 15
                    Mileage: 129409 km
                    Date: 2022.01.24
                    Time: 19:06:08
   Revision: --------    Serial number: 003V3002E29L
   VCID: 3A2CCB0FFCD3D70BA95-806E
   Part No SW: 7E0 920 870 S    HW: 7E0 920 870 S
   Coding: 140F010300
   VCID: 392ED403F9D5DC13A0F-806C
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 042307
   VCID: 68884147D27F959B0F1-803C
   Part No SW: 0AY 907 554 L    HW: 0CQ 525 130 A
   Component: Haldex4Motion H53 7620
   Serial number: HA1-00022.08.16
   Coding: 0501
   VCID: 54F085B77E77017B539-8000
   Component: IMMO          H03 1104
   VCID: 6A8C3B4FCCF3A78B195-803E
Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Coding: 0FCE020001000000
   Shop #: WSC 02757 790 50316
   Part No SW: 5C0 035 680 D    HW: 5C0 035 680 D
   Component: MU-S-N-ER     H31 0359
   Serial number: VWZAZ2S5291902
   Coding: 065700013C00000011110001000808001F0100C6002001004F
   VCID: 221C136F7443BFCB915-8076
   Subsystem 1 - Part No SW: 5NA 919 866 AR    HW: -----------
   Component: ECE AS 20/21  --- 1430
   Component: Batt.regelung H81 0744
   Coding: 030B1A73
   Serial number: 75410903001609222182
End----------(Elapsed Time: 01:54, VBatt start/end: 14.5V/14.5V)-----------
downtime
Finland
C?ID=280813
Isn't this error about cruise buttons?
0786 - Databus
Coding perhaps incorrect? In gateway? Steering wheel module?
VWT6
Finland
C?ID=295527
What am I missing?
:confused:
Mine (ACC, LHD, DSG, 4Motion) https://forums.ross-tech.com/index.php?threads/14188/
Coding: 00005800FE0779
RHD vans which I believe have ACC https://forums.ross-tech.com/showthread.php?22773-VW-T6-Electric-Tailgate-retrofit and https://www.t6forum.com/threads/high-beam-assistant-retrofit-coding-help.14603/post-203449
